  4. iobroker startet nicht
    6.3k
32 Beiträge 4 Kommentatoren 733 Aufrufe 2 Beobachtet
    @IbizaGT
    sudo apt update && sudo apt install distro-info
    I Offline
    I Offline
    IbizaGT
    @Thomas-Braun
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists... Done
    All packages are up to date.
    pi@raspberrypi:~ $ sudo apt install distro-info
    distro-info is already the newest version (1.0+deb11u1).
    The following packages were automatically installed and are no longer required:
      gyp libauthen-sasl-perl libc-ares2 libclone-perl libdata-dump-perl
      libdrm-amdgpu1 libdrm-nouveau2 libdrm-radeon1 libencode-locale-perl
      libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl
      libfile-mimeinfo-perl libfont-afm-perl libfontenc1 libgl1 libgl1-mesa-dri
      libglapi-mesa libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl
      libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl
      libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
      libhttp-message-perl libhttp-negotiate-perl libio-html-perl
      libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl
      libjs-highlight.js libjs-inherits libjs-is-typedarray libjs-psl
      libjs-typedarray-to-buffer libllvm11 liblwp-mediatypes-perl
      liblwp-protocol-https-perl libmailtools-perl libnet-dbus-perl
      libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libsensors-config
      libsensors5 libssl-dev libtie-ixhash-perl libtimedate-perl libtry-tiny-perl
      liburi-perl libuv1-dev libvulkan1 libwayland-client0 libwww-perl
      libwww-robotrules-perl libx11-protocol-perl libx11-xcb1 libxaw7
      libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
      libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcomposite1 libxcursor1
      libxdamage1 libxfixes3 libxi6 libxinerama1 libxkbfile1 libxml-parser-perl
      libxml-twig-perl libxml-xpathengine-perl libxmu6 libxrandr2 libxshmfence1
      libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 mesa-vulkan-drivers
      perl-openssl-defaults x11-utils x11-xserver-utils xdg-utils
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    pi@raspberrypi:~ $
    • I IbizaGT
      @Thomas-Braun
      pi@raspberrypi:~ $
      @IbizaGT
      sudo apt autoremove
      iob nodejs-update 22
      Rückfragen mit y bestätigen.
      Und bitte für Texte aus der Konsole die CodeTags </> verwenden.
      • I Offline
        I Offline
        IbizaGT
        ioBroker nodejs fixer 2026-03-05
        You requested to install latest version from nodejs v22 tree.
        Your current setup is:
        /home/iobroker/.nodejs-update.sh: line 214: node: command not found
        /home/iobroker/.nodejs-update.sh: line 215: npm: command not found
        /home/iobroker/.nodejs-update.sh: line 216: npx: command not found
        /home/iobroker/.nodejs-update.sh: line 227: node: command not found
        /home/iobroker/.nodejs-update.sh: line 228: npm: command not found
        /home/iobroker/.nodejs-update.sh: line 229: npx: command not found
        *** nodejs is NOT correctly installed ***
        We found these nodejs versions available for installation:
        nodejs:
          Installed: (none)
          Candidate: 12.22.12~dfsg-1~deb11u8
          Version table:
             12.22.12~dfsg-1~deb11u8 500
        Your nodejs-Installation seems to be faulty. Shall we try to fix it?
        Press <y> to continue or any other key to quit
        Fixing your nodejs setup
        *** Deleting  ***
        *** Deleting  ***
        *** Deleting  ***
        Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
        /home/iobroker/.nodejs-update.sh: line 317: node: command not found
        You are missing the nodesource repo file or
        you want to change your current nodejs version:  ?
        Trying to fix your installation now. Please be patient.
        You are running nodejs . Do you want to install latest version from nodejs v.22 tree?
        rm: cannot remove '': No such file or directory
        Stopping ioBroker now
        ioBroker has been stopped
        Removing any previously installed nodejs version
        *** The following repos are active on your system:
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.sources and pinning source
        /home/iobroker/.nodejs-update.sh: line 87: log: command not found
        pi@raspberrypi:~ $
        • I IbizaGT
          nodejs:
            Installed: (none)
            Version table:
          *** Deleting  ***
          *** Deleting  ***
          *** Deleting  ***
          pi@raspberrypi:~ $
          @IbizaGT
          Alles komplett veraltet und falsch installiert...
          sudo apt update && apt policy nodejs
          sagt?
          I 1 Antwort Letzte Antwort
            @IbizaGT
            sagt?
            I Offline
            I Offline
            IbizaGT
            @Thomas-Braun
            pi@raspberrypi:~ $ apt policy nodejs
            nodejs:
             Installed: (none)
             Version table:
            pi@raspberrypi:~ $
            • I IbizaGT
              @Thomas-Braun
              nodejs:
               Installed: (none)
               Version table:
              pi@raspberrypi:~ $
              @IbizaGT wo kommt die uralte dfsg version her?
              • I IbizaGT
                @Thomas-Braun
                nodejs:
                 Installed: (none)
                 Version table:
                pi@raspberrypi:~ $
                @IbizaGT
                sudo apt-get install -y curl
                curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
                sudo apt-get install -y nodejs
                node -v
                  I Offline
                  I Offline
                  IbizaGT
                  @Homoran
                  der pi läuft schon lange und ich habe da nichts groß gemacht. Jetzt wollte ich mal was neues dazu machen und da fällt alles auseinander...
                  • I IbizaGT
                    @Homoran
                    @IbizaGT
                    Das ist die Folge von "ich habe da nichts groß gemacht. "
                    Das funktionier nämlich bekanntermaßen NICHT.
                      @IbizaGT
                      node -v
                      I Offline
                      I Offline
                      IbizaGT
                      @Thomas-Braun
                      pi@raspberrypi:~ $ sudo apt-get install -y curl
                      curl is already the newest version (7.74.0-1.3+deb11u16).
                      pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
                      2026-06-20 10:33:18 - Installing pre-requisites
                      ca-certificates is already the newest version (20230311+deb12u1~deb11u1).
                      gnupg is already the newest version (2.2.27-2+deb11u3).
                      The following NEW packages will be installed:
                        apt-transport-https
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 160 kB of archives.
                      After this operation, 166 kB of additional disk space will be used.
                      Get:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB]
                      Fetched 160 kB in 1s (288 kB/s)
                      Selecting previously unselected package apt-transport-https.
                      (Reading database ... 49127 files and directories currently installed.)
                      Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
                      Unpacking apt-transport-https (2.2.4) ...
                      Setting up apt-transport-https (2.2.4) ...
                      2026-06-20 10:33:27 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
                      pi@raspberrypi:~ $
                      • I Offline
                        I Offline
                        IbizaGT
                        trotz error weitermachen?
                        • I IbizaGT
                          @Thomas-Braun
                            apt-transport-https
                          pi@raspberrypi:~ $
                          @IbizaGT sagte:
                          pi@raspberrypi:~ $
                          Das ist das Prpblem deiner alten Installation
                          Nur noch 64bit versionen bei nodejs 22
                          Möglich dass noch was älteres geht, wenn nodesource die noch im Repo hat
                          • I IbizaGT
                            @IbizaGT
                            Da gibt es nix weiter zu machen. Das Ding ist dir weggegammelt.
                            Aber da du ja 'nix groß gemacht hast' kannste es ja auch komplett von Grund auf Neuinstallieren:
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                            • I IbizaGT
                              Script v.2026-06-01
                              *** BASE SYSTEM ***
                              Operating System: Raspbian GNU/Linux 11 (bullseye)
                                 Static hostname: raspberrypi
                                       Icon name: computer
                                          Kernel: Linux 6.1.21-v8+
                                    Architecture: arm64
                              OS is similar to: debian
                              Model           : Raspberry Pi 4 Model B Rev 1.1
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 32bit
                              System was installed 1693 days ago (on 2021-10-30).
                              Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
                              Systemuptime and Load:
                               10:09:08 up 1 min,  1 user,  load average: 0.37, 0.30, 0.12
                              CPU threads     : 4
                              *** LIFE CYCLE STATUS ***
                              ERROR: Package 'distro-info' is not installed. Please do:
                              Alternatively execute the 'iob fix'
                              pi@raspberrypi:~ $
                              @IbizaGT sagte:
                              Kann aber 64 bit, aber nur per Neuinstallation
                              • I Offline
                                I Offline
                                IbizaGT
                                Gibt es irgeneine Chance das noch mal ans laufen zu bringen damit ich im iobroker ein Backup machen kann?
                                • I IbizaGT
                                  @IbizaGT
                                  Versuch mal
                                  curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                                  node -v
                                    @IbizaGT
                                    Versuch mal
                                    node -v
                                    I Offline
                                    I Offline
                                    IbizaGT
                                    @Thomas-Braun
                                    pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                                    2026-06-20 10:39:51 - Installing pre-requisites
                                    apt-transport-https is already the newest version (2.2.4).
                                    2026-06-20 10:39:57 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
                                    pi@raspberrypi:~ $
                                    • I IbizaGT
                                      @Thomas-Braun
                                      pi@raspberrypi:~ $
                                      @IbizaGT sagte:
                                      Der Zug ist also abgefahren. Und aus dem Debian-Repo gibt es nur nodejs12. Das ist zu alt, das wird vermutlich nicht mal als Notkrücke laufen.
                                      Also Neuinstallation. 64Bit-Lite-Version, Kiste dann künftig regelmäßiger pflegen.
                                      • I Offline
                                        I Offline
                                        IbizaGT
                                        Dann muss ich mich wohl mit dem Gedanken anfreunden....
                                        Trotzdem Danke für die Unterstützung
                                        @haselchen
