  4. iobroker startet nicht
    6.3k
32 Beiträge 4 Kommentatoren 733 Aufrufe 2 Beobachtet
  • I IbizaGT
    @Thomas-Braun
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Reading package lists... Done
    All packages are up to date.
    pi@raspberrypi:~ $ apt policy nodejs
    nodejs:
     Installed: (none)
     Candidate: 12.22.12~dfsg-1~deb11u8
     Version table:
        12.22.12~dfsg-1~deb11u8 500
    pi@raspberrypi:~ $
    @IbizaGT
    sudo apt-get install -y curl
    curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
    sudo apt-get install -y nodejs
    node -v
    I 1 Antwort Letzte Antwort
      @IbizaGT wo kommt die uralte dfsg version her?
      I Offline
      I Offline
      IbizaGT
      @Homoran
      der pi läuft schon lange und ich habe da nichts groß gemacht. Jetzt wollte ich mal was neues dazu machen und da fällt alles auseinander...
      • I IbizaGT
        @Homoran
        @IbizaGT
        Das ist die Folge von "ich habe da nichts groß gemacht. "
        Das funktionier nämlich bekanntermaßen NICHT.
          @IbizaGT
          node -v
          I Offline
          I Offline
          IbizaGT
          @Thomas-Braun
          pi@raspberrypi:~ $ sudo apt-get install -y curl
          curl is already the newest version (7.74.0-1.3+deb11u16).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
          2026-06-20 10:33:18 - Installing pre-requisites
          ca-certificates is already the newest version (20230311+deb12u1~deb11u1).
          gnupg is already the newest version (2.2.27-2+deb11u3).
          The following NEW packages will be installed:
            apt-transport-https
          0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
          Need to get 160 kB of archives.
          After this operation, 166 kB of additional disk space will be used.
          Get:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB]
          Fetched 160 kB in 1s (288 kB/s)
          Selecting previously unselected package apt-transport-https.
          (Reading database ... 49127 files and directories currently installed.)
          Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
          Unpacking apt-transport-https (2.2.4) ...
          Setting up apt-transport-https (2.2.4) ...
          2026-06-20 10:33:27 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
          pi@raspberrypi:~ $
          • I Offline
            I Offline
            IbizaGT
            trotz error weitermachen?
            • I IbizaGT
              @Thomas-Braun
                apt-transport-https
              pi@raspberrypi:~ $
              @IbizaGT sagte:
              pi@raspberrypi:~ $
              Das ist das Prpblem deiner alten Installation
              Nur noch 64bit versionen bei nodejs 22
              Möglich dass noch was älteres geht, wenn nodesource die noch im Repo hat
              • I IbizaGT
                @IbizaGT
                Da gibt es nix weiter zu machen. Das Ding ist dir weggegammelt.
                Aber da du ja 'nix groß gemacht hast' kannste es ja auch komplett von Grund auf Neuinstallieren:
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                • I IbizaGT
                  Script v.2026-06-01
                  *** BASE SYSTEM ***
                  Operating System: Raspbian GNU/Linux 11 (bullseye)
                     Static hostname: raspberrypi
                           Icon name: computer
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  OS is similar to: debian
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 32bit
                  System was installed 1693 days ago (on 2021-10-30).
                  Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
                  Systemuptime and Load:
                   10:09:08 up 1 min,  1 user,  load average: 0.37, 0.30, 0.12
                  CPU threads     : 4
                  *** LIFE CYCLE STATUS ***
                  ERROR: Package 'distro-info' is not installed. Please do:
                  sudo apt update && sudo apt install distro-info
                  Alternatively execute the 'iob fix'
                  pi@raspberrypi:~ $
                  @IbizaGT sagte:
                  Kann aber 64 bit, aber nur per Neuinstallation
                  • I Offline
                    I Offline
                    IbizaGT
                    Gibt es irgeneine Chance das noch mal ans laufen zu bringen damit ich im iobroker ein Backup machen kann?
                    • I IbizaGT
                      @IbizaGT
                      Versuch mal
                      curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                      node -v
                        @IbizaGT
                        Versuch mal
                        node -v
                        I Offline
                        I Offline
                        IbizaGT
                        @Thomas-Braun
                        pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                        2026-06-20 10:39:51 - Installing pre-requisites
                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        apt-transport-https is already the newest version (2.2.4).
                        2026-06-20 10:39:57 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
                        pi@raspberrypi:~ $
                        • I IbizaGT
                          @Thomas-Braun
                          pi@raspberrypi:~ $
                          @IbizaGT sagte:
                          Der Zug ist also abgefahren. Und aus dem Debian-Repo gibt es nur nodejs12. Das ist zu alt, das wird vermutlich nicht mal als Notkrücke laufen.
                          Also Neuinstallation. 64Bit-Lite-Version, Kiste dann künftig regelmäßiger pflegen.
                          • I Offline
                            I Offline
                            IbizaGT
                            Dann muss ich mich wohl mit dem Gedanken anfreunden....
                            Trotzdem Danke für die Unterstützung
                            @haselchen
