  4. Hannah — Open Source Smart-Home-Sprachassistentin
    apollon77A
311 Beiträge 24 Kommentatoren 31.8k Aufrufe 36 Beobachtet
  • Walter.O.W Walter.O.
    @Leonie sagte:
    Sorry Leonie,ich hoffe ich Nerve nicht.
    So hab ich es gemacht.
    $ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah/master/core/deploy/install.sh | sudo bash
    [sudo: authenticate] Password:
    [INFO] Fetching latest core release from https://hannah-update.sgessinger.de (channel: core-stable) ...
    [INFO] Latest version: v0.75.0
    iob@iob:~$ systemctl status hannah
    Unit hannah.service could not be found.
    iob@iob:~$ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah/master/proxy/deploy/install.sh | sudo bash
    [INFO] Fetching latest proxy release from https://hannah-update.sgessinger.de (channel: proxy-stable-amd64) ...
    [INFO] Latest version: v0.75.0 (amd64)
    iob@iob:~$ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah/master/telegram/deploy/install.sh | sudo bash
    [INFO] Fetching latest telegram release from https://hannah-update.sgessinger.de (channel: telegram-stable) ...
    iob@iob:~$ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah/master/voiceid/deploy/install.sh | sudo bash
    [INFO] Fetching latest voiceid release from https://hannah-update.sgessinger.de (channel: voiceid-stable) ...
    iob@iob:~$ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah/master/autodeploy/deploy/install.sh | sudo bash
    [INFO] Fetching latest autodeploy release from https://hannah-update.sgessinger.de (channel: autodeploy-stable) ...
    [INFO] Latest version: v0.64.1
    iob@iob:~$ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah-webui/refs/heads/main/deploy/install.sh | sudo bash
    [INFO] Fetching latest webui release from https://hannah-update.sgessinger.de (channel: webui-stable) ...
    [INFO] Latest version: v2.3.2
    L
    L
    Leonie
    #61
    @Walter.O. sagte:
    tust du nicht :D
    Ich schaue es mir später an. ok?
    • M
      M
      manne01
      schrieb am zuletzt editiert von manne01
      #62
      Erstmal Danke für Eure Rückmeldungen - ihr seid echt spitze!
      Nun auch von mir ein Update:
      Ich habe dank der Infos von @Walter.O. und nach den nötigen Anpassungen an mein Setup nun auch fast alles mal (bis auf den Proxy) bei mir auf der Synology Container Manager ans laufen bekommen - denke ich.
      Was geklappt hat:
      • die einzelnen Container für WebUi+Core+Telegram+voiceID laufen und die Logs sehen gut aus (bis auf 404 wegen fehlender static files)
      • der iobroker.hannah-Adapter und dieVerknüpfung und Kommunikation mit Hannah tut
      • die Verknüpfung mit meinem lokalen lemonade-ai server fürs LM uns damit das eingeben eines TextCommand an den Datenpunkt und die Rückgabe der LLM-Antwort - yayy!
      Was mir noch nicht gelingt ist:
      • Meinen Telegram-Account zu verbinden. nachdem ich den Token in Telegram config und den WebUI Container hinterlegt habe wird im WebUI Telegram als konfiguriert angezeigt - es kommt aber im WebUI nach Click auf das Telegram-Icon eine neue Seite mit der Rückmeldung "Bot domain invalid". Zur "lokalen" Domain bei Telegram bzw. zur Domainverknüpfung mit /setdomain finde ich kaum Infos. Eine extern erreichbare Domain habe ich nicht vor. Der Telegram Chatbot antwortet also hartnäckig dass er mich nicht kennt und ich verknüpfen soll.
      • in der WebUI das CSS/Bilder aus dem Ordner static zu laden (sieht natürlich grausig aus, aber funktionieren tuts ja :-) )
      • rauszufinden wie ich die core-Datenbank so mounte, dass sie mir auf das core-Verzeichnis des Hosts gelegt wird
      Aber wenn Du @Leonie jetzt eventuell bald "offizielle" Dockerfiles bereitstellt, dann teste ich auch gerne diese natürlich umgehend!
      Viele Grüße und nochmal vielen vielen Dank!
      L 1 Antwort Letzte Antwort
      • L
        L
        Leonie
        #63
        Ihr Verrückten :D
        Ich habe nun die letzten Stunden damit verbracht Container Images zu bauen. Habe die Services dafür verändert, meine Pipelines überarbeitet, aber hier ist nun das Composefile mit allem drin:
        services:
         hannah-core:
           image: quay.io/m1kad0/hannah-core:latest
           container_name: hannah-core
           restart: unless-stopped
           pull_policy: always
           depends_on:
             mysql-db:
               condition: service_healthy
               required: false
             mosquitto:
               required: false
           ports:
             - "50051:50051"
           networks:
             - hannah_network
           volumes:
             - core_activity_audio:/app/activity_audio
             - core_audio_dumps:/app/audio_dumps
             - core_data:/app/data
             - ./core-config.yaml:/etc/hannah/config.yaml:ro
         hannah-webui:
           image: quay.io/m1kad0/hannah-webui:latest
           container_name: hannah-webui
           pull_policy: always
           depends_on:
             - hannah-core
           networks:
             - hannah_network
           ports:
             - "5000:5000"
           environment:
             HANNAH_WEBUI_SECRET_KEY: "SGVsbG8gV29ybGQhIFRoaXMgaXMgYSByYW5kb20gMTI4LWNoYXJhY3RlciBCYXNlNjQgc3RyaW5nIGNyZWF0ZWQgZm9yIHRlc3RpbmcgcHVycG9zZXMubmNlMXkyMw=="
             HANNAH_WEBUI_GRPC_HOST: "hannah-core"
             HANNAH_WEBUI_GRPC_PORT: "50051"
         hannah-telegram:
           image: quay.io/m1kad0/hannah-telegram:latest
           container_name: hannah-telegram
           pull_policy: always
           profiles: ["full", "integrations", "telegram"]
           depends_on:
             - hannah-core
           networks:
             - hannah_network
           volumes:
             - ./telegram-config.yaml:/etc/hannah-telegram/config.yaml:ro
         hannah-proxy:
           image: quay.io/m1kad0/hannah-proxy:latest
           container_name: hannah-proxy
           pull_policy: always
           profiles: ["full", "with-proxy"]
           depends_on:
             - hannah-core
           networks:
             - hannah_network
           volumes:
             - ./proxy-config.yaml:/etc/hannah-proxy/config.yaml:ro
         hannah-voiceid:
           image: quay.io/m1kad0/hannah-voiceid:latest-cpu
           container_name: hannah-voiceid
           pull_policy: always
           profiles: ["full", "with-voiceid"]
           depends_on:
             - hannah-core
           networks:
             - hannah_network
           volumes:
             - ./voiceid-config.yaml:/etc/hannah-voiceid/config.yaml:ro
             - hannah_mem:/mnt/hannah_mem
         hannah-timer:
           image: quay.io/m1kad0/hannah-timer:latest
           container_name: hannah-timer
           pull_policy: always
           profiles: ["full", "with-timer"]
           depends_on:
             - hannah-core
           networks:
             - hannah_network
           environment:
             HANNAH_TIMER_HANNAH_ADDRESS: "hannah-core:50051"
             HANNAH_TIMER_LOG_LEVEL: "info"
           volumes:
             - timer_data:/app/data
         mysql-db:
           image: mysql:8.0
           container_name: hannah-db
           profiles: ["full", "with-db"]
           environment:
             MYSQL_ROOT_PASSWORD: secretpassword
             MYSQL_DATABASE: hannah_db
             MYSQL_USER: hannah_user
             MYSQL_PASSWORD: hannah_pass
           networks:
             - hannah_network
           volumes:
             - mysql_data:/var/lib/mysql
           healthcheck:
             test: ["CMD", "mysqladmin", "ping", "-h", "localhost", "-u", "root", "-psecretpassword"]
             interval: 5s
             timeout: 5s
             retries: 5
         mosquitto:
           image: eclipse-mosquitto:2
           container_name: hannah-mosquitto
           profiles: ["full","with-mqtt"]
           networks:
             - hannah_network
           ports:
             - "1883:1883"
             - "9001:9001"
           volumes:
             - mosquitto_data:/mosquitto/data
             - mosquitto_log:/mosquitto/log
             - ./mosquitto.conf:/mosquitto/config/mosquitto.conf:ro
           healthcheck:
             test: ["CMD-SHELL", "nc -z localhost 1883 || exit 1"]
             interval: 5s
             timeout: 3s
             retries: 5
        volumes:
         core_data:
         core_audio_dumps:
         timer_data:
         mysql_data:
         mosquitto_data:
         mosquitto_log:
         hannah_mem:
        networks:
         hannah_network:
           driver: bridge
        Gestartet werden kann der ganze Stack bspw. so: docker compose --profile full up -d
        Am Besten tauscht ihr dann auch entsprechende Secrets aus, alles in dem File ist von meiner Seite aus Demo, aber voll getestet.
        Für VoiceID habe ich eine cpu-only Version bereitgestellt. Eine Version mit GPU-Unterstützung kann ich aktuell nicht bauen, zumindest nicht automatisiert.
        Mitgestartet wird auch ein MySQL-Server, der für den Activity Log genutzt wird. Warum ein MySQL-Server? Weil Hannah bei mir komplett auf einem Raspberry Pi läuft und ich mit der Datenbank für den Activty Log, die naturgemäß eine Menge Schreiboperationen aufweisen kann, die SD-Karte nicht belasten will.
        Außerdem wird ein Mosquitto, als MQTT-Broker gestartet. Ich denke der ein oder andere von euch wird bereits einen Broker einsetzen, für alle anderen, ist hier die Vorlage.
        Ich habe euch auch gleich einen Service dazu gepackt, den ich noch nicht vorgestelt habe: hannah-timer. Das ist ein Timerbackend für Core. Der hält alle Timer die Core stellen mag persistent. Egal ob man Wecker stellt, ob man sich an irgendwas erinnern lassen möchte oder einfach nur einer Eieruhr stellt, dieser Service sorgt für die Integrität.
        Warum ein eigener Service? In der Entwicklung hat sich gezeigt das Core bei mir öfter neustarten muss, auch bspw. aufgrund von Updates. Timer ist so stabil, das er bereits seit Monaten bei mir ohne Downtime laufen kann. Außerdem kann so die ganze Timer-Logik aus dem Core draußen bleiben. Timer informiert Core aktiv, wenn ein Timer abgelaufen ist und stellt ihm wieder die Informationen bereit, die Core braucht um Aktionen zu ergreifen.
        Eventuell bekommen in Zukunft noch weitere Services Unterstützung fürs Environment. Ich verstehe schon, das es sich doof anfühlt bspw. für den Proxy eine Configdatei mit 6 Zeilen zu schreiben, während timer bspw. Environment-Variablen hat. Faktisch unterstützen die meisten Services es nicht, da sind dann Configs notwendig.
        Und natürlich werden die Images jetzt nicht bei mir gehostet, das heißt, die sollten zu jeder Zeit abrufbar sein :D
        Liebe Grüße
        Leonie
        • M manne01
          Was geklappt hat:
          L
          L
          Leonie
          schrieb am zuletzt editiert von Leonie
          #64
          @manne01 sagte:
          Meinen Telegram Account zu verbinden - es kommt "Bot domain invalid" und meine "lokale" Domain bei Telegram mit /setdomain zu verknüpfen macht doch irgendwie keinen Sinn? Zur Domainregistrierung finde ich kaum Infos.
          Ich ziehe das nochmal nach.
          Leider habe ich selbst keinen Einfluss auf das was Telegram verlangt. Hannah nutzt ein "Login with Telegram" in der WebUI für die Verknüpfung. Dafür benötigt der BotFather eine Domain, die Domain unter der die WebUI erreichbar ist.
          Leider funktionieren da keine IP-Adressen und keine lokalen Domains. Telegram erfordert eine öffentliche überprüfbare Domain. Nicht falsch verstehen, die WebUI muss nur eine öffentliche Domain nutzen, nicht aus der Öffentlichkeit erreichbar sein.
          Ja, ist nicht ideal, aber den Ablauf gibt leider Telegram vor.
          Ich selbst habe glücklicherweise eine eigene Domain. Unter der kann ich meine WebUI aufrufen und Telegram ist glücklich. Damit ich die aber aufrufen kann, muss ich zu Hause sein. Aus dem Internet geht es nicht.
          An der Stelle mag ich schonmal sagen, das eine DynDNS-Adresse bspw. von MyFritz! schon ausreichend ist, damit der BotFather zu Frieden ist.
          Liebe Grüße
          Leonie
          • M
            M
            manne01
            #65
            Wow🤩 Freue mich riesig drauf das Compose einzurichten und melde mich wieder.
            DANKE @Leonie !
            Ich hoffe dass das den Anwenderkreis am Ende auch nochmal so deutlich erweitert wie ich mir das vorstelle👍
            Okay, und eine Domain habe ich grundsätzlich schon auch, ich probiere es damit nochmal.
            • L Leonie
              @manne01 sagte:
              Liebe Grüße
              Leonie
              OliverIOO
              OliverIOO
              OliverIO
              #66
              @Leonie sagte:
              wer einen port nach außen öffnet, sollte unbedingt einen
              reverse proxy einsetzen um die Angriffsfläche zu verkleinern.
              Weiterhin das noch mit fail2ban absichern, was aber ein wenig Beobachtung und Konfiguration erfordert
              beides ist als dockercontainer verfügbar.
              einen container mit dem reverse proxy ist sehr einfach
              durch ein paar zusätzliche Anweisungen im docker compose welcher dann im internet auf anfragen horchen soll.
              https://hub.docker.com/r/jwilder/nginx-proxy
              https://hub.docker.com/r/linuxserver/fail2ban
              kleine werbung in eigener Sache: Wer fail2ban mit einer webgui überwachen möchte kann sich diesen Container anschauen, leider ist die kommandozeile von fail2ban etwas grausam:
              https://hub.docker.com/r/oweitman/fail2bancontrol
              und zur Überwachung im iobroker:
              https://github.com/oweitman/ioBroker.fail2bancontrol
              Meine Adapter und Widgets
              Links im Profil
              • OliverIOO OliverIO
                @Leonie sagte:
                L
                L
                Leonie
                #67
                @OliverIO sagte:
                Das muss es auch nicht. Davon habe ich nichts gesagt. Die Adresse muss existieren und hausintern erreichbar sein. Mehr nicht.
                Ich habe nochmal alles überprüft und habe hier eine bessere Anqleitung/Erklärung:
                Telegram-Konto mit Hannah verknüpfen — Setup & Voraussetzungen
                Über die WebUI (/me) kann jeder Nutzer sein eigenes Telegram-Konto mit seinem Hannah-Account verknüpfen (z.B. für Benachrichtigungen). Damit der Button dafür überhaupt erscheint, muss der Betreiber der Hannah-Instanz vorher einmalig etwas einrichten.
                Was man braucht
                1. Einen Telegram-Bot (Token + Username)
                2. Eine Domain, unter der die WebUI erreichbar ist
                3. HTTPS auf der WebUI (Zertifikat darf selfsigned sein)
                4. Bot-Daten in der WebUI-Konfiguration eingetragen
                Schritt für Schritt
                1. Bot bei BotFather anlegen
                In Telegram mit @BotFather chatten, /newbot ausführen. Man bekommt danach:
                • einen Bot-Token (z.B. 123456789:AAExxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
                • einen Bot-Usernamen (z.B. MeinHannahBot)
                2. Domain beim Bot freischalten
                Ebenfalls bei BotFather: /setdomain ausführen und die Domain eintragen, unter der die WebUI erreichbar ist (z.B. hannah.mein-zuhause.duckdns.org).
                Wichtig: Ohne diesen Schritt lehnt Telegram den Login-Versuch direkt ab, noch bevor er bei der WebUI ankommt.
                3. Bot-Daten in der WebUI eintragen
                In config.yaml:
                ```yaml
                telegram_bot_token: "123456789:AAExxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                telegram_bot_username: "MeinHannahBot"
                Oder bei Docker-Deployment als Umgebungsvariablen:
                HANNAH_WEBUI_TELEGRAM_BOT_TOKEN=123456789:AAExxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                HANNAH_WEBUI_TELEGRAM_BOT_USERNAME=MeinHannahBot
                Fehlt eines von beiden, zeigt /me nur den Hinweis "Telegram-Verknüpfung ist auf diesem Server nicht konfiguriert." — kein Fehler, einfach kein Button.
                Häufige Fragen zur Domain
                Reicht eine DynDNS-Domain (DuckDNS, No-IP, …)?
                Ja. Telegram vergleicht die Domain nur als Text (das, was bei /setdomain hinterlegt wurde, gegen das, was die WebUI beim Login-Versuch mitschickt) — es wird nicht per DNS aufgelöst oder angepingt. Dass sich die IP dahinter ständig ändert, spielt also keine Rolle.
                Muss das TLS-Zertifikat "echt" sein (Let's Encrypt o.ä.)?
                Nein, ein selfsigned Zertifikat reicht. Grund: Telegrams Server verbinden sich nie direkt mit der WebUI. Der komplette Rücksprung läuft über den Browser des jeweiligen Nutzers:
                1. Browser → oauth.telegram.org (Nutzer bestätigt dort den Login)
                2. Telegram leitet den Browser zurück zur WebUI, mit den signierten Login-Daten im Gepäck
                3. Ein kleines Skript auf der WebUI-Seite nimmt diese Daten entgegen und schickt sie an die WebUI
                Der Browser ist es also, der die TLS-Verbindung zur WebUI aufbaut — nicht Telegram. Ein selfsigned Zertifikat funktioniert, solange der jeweilige Nutzer es akzeptiert (Klick durch die Warnung, oder eigene CA im Trust-Store).
                Muss die WebUI öffentlich aus dem Internet erreichbar sein? Braucht es Portfreigabe?
                Nein. Aus demselben Grund wie oben: Da nur der Browser des Nutzers die WebUI kontaktiert (nie Telegram selbst), reicht es, wenn der Browser die WebUI erreichen kann — z.B. im Heimnetz oder per VPN. Keine Portfreigabe, keine öffentliche Erreichbarkeit nötig.
                Aber Achtung:
                Die Domain, über die man auf die WebUI zugreift, muss exakt die sein, die bei /setdomain hinterlegt wurde. Wer mal über die DynDNS-Domain und mal über eine lokale IP/einen anderen Hostnamen auf die WebUI geht, bekommt den Login-Button nur bei der registrierten Domain zu sehen bzw. der Login schlägt sonst fehl. Ich muss allerdings auch sagen, dass das nur für die Verknüpfung selbst relevant ist. Ist der Account einmal verbunden, braucht man das Widget nie wieder, bzw. erst wieder, wenn man die Verbindung trennen möchte.
                Der Ablauf beim eigentlichen Verknüpfen (zur Info)
                1. Nutzer klickt auf /me den Telegram-Button → Redirect zu Telegram
                2. Nutzer bestätigt dort den Login
                3. Telegram schickt die signierten Daten zurück — technisch als URL-Fragment (#...), das kommt beim Server gar nicht an
                4. Ein JS-Snippet auf der Seite liest das Fragment im Browser aus und leitet es als normalen Request an die WebUI weiter
                5. Die WebUI prüft die Signatur (mit dem Bot-Token) und dass die Anfrage nicht älter als 5 Minuten ist
                6. Passt alles → Konto ist verknüpft
                Typische Stolperfallen
                Problem Ursache
                Login-Button erscheint gar nicht telegram_bot_token oder telegram_bot_username fehlt in der Config
                Telegram bricht schon vor der WebUI ab Domain bei /setdomain falsch/vergessen, oder stimmt nicht mit der tatsächlich aufgerufenen Domain überein
                "ungültige oder abgelaufene Signatur" Bot-Token in der Config falsch/vertippt, oder Nutzer hat länger als 5 Minuten gebraucht, um den Login bei Telegram zu bestätigen
                • L Leonie
                  @OliverIO sagte:
                  Was man braucht
                  Schritt für Schritt
                  In config.yaml:
                  ```yaml
                  Aber Achtung:
                  Problem Ursache
                  OliverIOO
                  OliverIOO
                  OliverIO
                  #68
                  @Leonie
                  Sorry, kannte bisher nur die webhook Methode um auch Nachrichten empfangen zu können.
                  Hab gesehen das es auch die long polling Methode gibt.
                  Dafür brauch man dann keinen Port nach außen.
                  Links im Profil
                  • Walter.O.W
                    Walter.O.W
                    Walter.O.
                    schrieb am zuletzt editiert von Walter.O.
                    #69
                    @leonie
                    Denkst du noch an mich?
                    Habe es gerade mal auf meinem Linux PC versucht,
                    das irritiert mich jetzt aber. Der core ist da ja noch garnicht draufgewesen.
                    [sudo: authenticate] Passwort:
                    [INFO] Latest version: v0.75.7
                    walter@walter-pc:~$ systemctl status hannah
                    • M
                      M
                      manne01
                      #70
                      Guten Morgen,
                      @walter.o. Dir vielen dank für die Infos und erste Fassung der Dockerfiles - das hatte mir ermöglicht direkt schonmal einen Durchstich zu machen von Spracheingabe Telegram bis funktionierender ioBroker-Statusänderung und Sprachrückgabe :)
                      @Leonie vielen Dank für die CI Pipeline und das Compose.
                      Ich find das klasse, besonders auch zB dass die diversen configs des Stacks jetzt nebeneinander liegen.
                      Es funktioniert damit schon einiges aber noch läuft die core nicht.
                      Folgende kleine Änderungen habe ich gemacht, damit es für mein Setup läuft:
                      a) Auskommentieren der Zeilen mit "profiles" - die blockieren wohl irgendwas im Synology Container Manager (Fehlermeldung beim compose-build dann "service mysql not found" o.ä.), scheinen auch optional zu sein
                      b) mosquitto broker auskommentiert, habe ich in iobroker schon
                      c) den volumes-Block unten gelöscht und stattdessen bei den Container-Definitionen die Unterordner (core_data/timer_data...) jeweils auf von mir erstellte Unterordner von /volume1/docker/hannah (in dem Verzeichnis in dem die compose liegt)
                      Was läuft:
                      • mysql
                      • webUI - jetzt mit static assets 👍
                      • voiceid
                      • telegram
                      • proxy
                      Was läuft nicht (im sinne von container bleibt oben/terminiert nicht):
                      • hannah timer bringt fehler und terminiert regelmäßig (wartet der auf core?)
                      {"time":"2026-08-30T08:45:33.408807593Z","level":"INFO","msg":"starting hannah-timer","version":"dev","hannah_addr":"hannah-core:5051","db":"/app/data/timers.db"}
                      {"time":"2026-08-30T08:45:33.409175976Z","level":"ERROR","msg":"opening store","err":"running migrations: unable to open database file (14)"}
                      • die core, Log:
                      07:54:54 [INFO] hannah.main: Hannah Core dev
                      Traceback (most recent call last):
                        File "/app/main.py", line 2257, i <module>
                          main()
                        File "/app/main.py", line 101, in main
                          init_db()
                        File "/app/hannah/utils/db.py", line 216, in init_db
                          db = get_db()
                        File "/app/hannah/utils/db.py", line 201, in get_db
                          db = Database.sqlite(DB_PATH)
                        File "/usr/local/lib/python3.14/site-packages/pyorm/database.py", line 22, in sqlite
                          return cls(dialect.connect(database=database, **kwargs), dialect)
                        File "/usr/local/lib/python3.14/site-packages/pyorm/dialects/sqlite.py", line 21, in connect
                          connection = sqlite3.connect(check_same_thread=False, **kwargs)
                      sqlite3.OperationalError: unable to open database file
                      Bin nicht sicher wie das gedacht ist - neben der mysql (wenn ich es richtig verstehe ist die nur für Activities) muss ja die WebUI/Core ihre Settings etc. irgendwo speichern. Wenn ich es richtig verstehe ist das eine kleine sqlite.db (hannah.db?)
                      Gefunden hab ich in der core-config.yaml "nur" eine Angabe für hannah_users.db ?
                      user_registry:
                        db_path: "hannah_users.db"   # SQLite-Datei (relativ zum Arbeitsverzeichnis)
                        sync_interval: 60            # Sekunden zwischen ioBroker-Abfragen
                      Ist da trotz des Namens alles drin? Oder gibts mehrere db.files? Im Code habe ich auch eine hanna.db gefunden und weitere (zb rooms/memory.db)
                      Auch müsste diese Datenbank ja noch aus dem Container raus und vom volume her auf den Host ausgelagert werden, so dass man auf dem Host alles wichtige außerhalb von Containern hat, backup machen kann etc.
                      Aufgefallen ist mir noch dass innerhalb des Ordners mysql_data ein Ordner hannah_db angelegt wurde, ist aber leer.
                      ./core_data ist auch leer (gemountet in den Container nach /app/data)
                      Ich hoffe das sind nur noch Kleinigkeiten. Viele Grüße!
                      • L
                        L
                        Luxi
                        #71
                        Hallo @leonie
                        Vielen Dank erstmal einmal für deine tolle Arbeit.
                        Zum Thema Satelliten:
                        • wie weit bist du denn mit der Evaluierung von PCPway Zwecks dem Shared Projekt?
                        • könntest du die nötigen Dateien für eine Produktion zur Verfügung stellen?
                          LG Luxi
                          @leonie
                          L
                          L
                          Leonie
                          #72
                          @Walter.O. sagte:
                          Ja, aber ich habe auch ein Privatleben :)
                          @manne01 sagte:
                          Beide Fehler kommen zu 100% von deiner Änderung mit den Volumes. Ja, der Volumeblock ist optional, schließlich beschreibt der names Docker Volumes die von compose verwaltet werden. Weil du aber lieber Bind mounts nutzten willst, musst du die Dateirechte entsprechend anpassen.
                          @manne01 sagte:
                          Der Configwert existiert bereits seit langer Zeit nicht mehr und ist in der aktuellen config.example.yaml entfernt. In meiner Container-Version wird die Datenbank nach /app/data gespeichert, weil da das Volume eingehangen wird, ist die Datenbank dann peristent. Die dedizierte hannah_users.db wird nicht verwendet.
                          Die memory.db ist der Langzeitspeicher für das LLM. Sozusagen die low-budget-Variante einer VectorDB. Konfigurieren kannst du die bspw. so:
                          llm:
                            db: "/app/data/memory.db"
                          @manne01 sagte:
                          Das ist auch ein Fehler von dir ;) bzw. eine Eigenheit von Docker. Um dir mehr dazu zu sagen, müsstest du mir dein Compose File geben.
                          @Luxi sagte:
                          PCBway scheint ein guter Partner dafür zu sein
                          @Luxi sagte:
                          Hier habe ich einen Interessenskonflikt. Ja, die ESPs funktionieren, aber nicht fehlerfrei. Es gibt Bugs bei denen ich aktuell nicht weiß ob sie in er Firmware oder der Hardware liegen. Ich kann das Projekt dort anlegen, dann könnt ihr es bestellen, aber zu 100% glücklich bin ich noch nicht und das widerstrebt meinem Perfektionismus.
                          Liebe Grüße
                          • L
                            L
                            Leonie
                            #73
                            @walter.o.
                            Ich habe mir mal eben ein Ubuntu 26.04 installiert. Bei mir ist das Install-Script gesprächiger?
                            administrator@hannah-test:~$ curl -fsSL https://raw.githubusercontent.com/NurPech/hannah/master/core/deploy/install.sh | sudo bash
                            [OK]    Downloaded v0.75.7.
                            [OK]    Extracted to /opt/hannah/core.
                            [INFO]  Creating Python venv ...
                            The virtual environment was not created successfully because ensurepip is not
                            available.  On Debian/Ubuntu systems, you need to install the python3-venv
                            package using the following command.
                                apt install python3.14-venv
                            You may need to use sudo with that command.  After installing the python3-venv
                            package, recreate your virtual environment.
                            Failing command: /opt/hannah/core/venv/bin/python3
                            Nach der installation von python3.14-venv, habe ich das nochmal gestartet:
                            [INFO]  Installing Python dependencies ...
                            bash: line 85: /opt/hannah/core/venv/bin/pip: No such file or directory
                             ls /opt/hannah/core/venv/bin/
                            python  python3  python3.14  𝜋thon
                            Und siehe da, Pip wurde im venv nicht installiert. Eine kurze Recherche von mir ergab, das Ubuntu das aus Ressourcengründen nicht installiert.
                            Ein Befehl bringt Abhilfe:
                            administrator@hannah-test:~$ sudo /opt/hannah/core/venv/bin/python3 -m ensurepip --default-pip
                            Looking in links: /tmp/tmpjq2mpmmu
                            Processing /tmp/tmpjq2mpmmu/pip-25.1.1-py3-none-any.whl
                            Installing collected packages: pip
                            Successfully installed pip-25.1.1
                            administrator@hannah-test:~$ ls /opt/hannah/core/venv/bin/
                            pip  pip3  pip3.14  python  python3  python3.14  𝜋thon
                            Dann läuft die Installation auch korrekt durch:
                            [OK]    Python dependencies installed.
                            [INFO]  Creating system user 'hannah' ...
                            [INFO]  Created /etc/hannah — place your config.yaml there.
                            [OK]    Service unit installed.
                            [OK]    Installed v0.75.7. Place config.yaml in /etc/hannah and run:
                            [OK]      systemctl enable --now hannah
                            administrator@hannah-test:~$ sudo systemctl enable --now hannah
                            Created symlink '/etc/systemd/system/multi-user.target.wants/hannah.service' → '/etc/systemd/system/hannah.service'.
                            Ubuntu scheint da ein paar Besonderheiten zu haben. Ich denke das ensurepip kann ich in den Install-Scripten einbauen. Die Paketinstallationen überlasse ich aber lieber euch.
                            Warum die Scripte bei dir komplett stumm bleiben, kann ich nicht sagen. Das muss irgendwas mit deinem System zu tun haben. Getestet habe ich auf stock Ubuntu 26.04, frisch installiert.
                            Liebe Grüße
                            • L Leonie
                              @Walter.O. sagte:
                              @manne01 sagte:
                              @manne01 sagte:
                              llm:
                              @manne01 sagte:
                              @Luxi sagte:
                              @Luxi sagte:
                              Liebe Grüße
                              M
                              M
                              manne01
                              #74
                              @Leonie Danke Dir für die erneute und schnelle Rückmeldung!
                              Hab mir das mit den Datenbanken nochmal angeschaut und ja, mich hat folgendes verwirrt:
                              im COMPOSE ist überall "hannah":
                              mysql-db:
                                 image: mysql:8.0
                                 environment:
                              vs. in deinem Beitrag oben ist es "Activity-DB":
                              Ich dachte kurzzeitig die hannah.db soll auch in mysql oder würde dort automatisch erkannt etc. Nachdem ich nun aber annehme dass hannah.db eine sqlite ist und bleibt (und ja, die rechte fehlten😇, daher hat der core die nicht anlegen können) habe ich im compose alles mit "hannah-db" auf activity umgemünzt, damit da draufsteht was drin ist (also entsprechend der core-config in "activity_db" benannt und user usw. ebenso.)
                              Ich hoffe ich habe jetzt bzgl. der Datenbanken alles richtig verstanden!
                              Die Kerstin-Dateien musste ich noch daneben legen, das meldet ja auch das log. Wäre es eine Idee die standardmässig/als Default mitzuliefern? Ändern kann ja dann jeder selber.
                              Jetzt läuft jedenfalls alles mit dem neuen Compose und alle Container und Logs schauen happy aus! 😊 Jetzt muss ich wohl erstmal in ioBroker meine ganzen Objekte/Geräte kategorisieren... Ich vermute da ist erstmal das virtual device script (von dem ich bisher nur mal gelesen habe) hier die Empfehlung der Wahl?
                              Viele Grüße!
                              • M manne01
                                mysql-db:
                                   image: mysql:8.0
                                   environment:
                                Viele Grüße!
                                L
                                L
                                Leonie
                                #75
                                Ja, grade die Datenbanken sind etwas unglücklich benannt von mir. Der MySQL-server ist wirklich nur für den Activity Log. Alle anderen Daten liegen in einer sqlite. Zwar kann das Storage-Backend auch MySQL (sonst würde es den Activitiy Log gar nicht geben), das kam aber erst mit dem Log, da waren die anderen Teile schon zu weit. Und eine Migration zu schreiben, hatte ich bisher noch keinen Need. Und umbedingt einen externen MySQL-Server vorzuschreiben, während der Activity Log ja optional ist, kommt mir auch nicht passend vor.
                                @manne01 sagte:
                                Ob ich die Daten mitliefern darf, weiß ich gar nicht, das müsste ich mit HuggingFace klären. Vermutlich dürfte aber nichts dagegen sprechen einen Downloader einzubauen für die Datei, der die automatisch ins Data-Dir bringt. Muss ich aber auch klären und Lizenzen sind ja immer so ein Thema.
                                @manne01 sagte:
                                Nein, nicht zwingend. Ich nutze ioBroker schon sehr lange und seit vielen Versionen. So gab es bspw. keine komfortable Möglichkeit für Aliase und ich hatte ioBroker bspw. für Hue-Leuchten genutzt. Wenn ich dann eine Leuchte getauscht habe, war die natürlich in der ObjektDB ein neues Objekt und ich musste alle Scripte, Trigger und Aktionen bearbeiten. Da habe ich dann das virtualDevice-Script hier im Forum gefunden, was im Prinzip Objekte "kopiert", also eigene Objekte, für physisiche Objekte erstellt. So habe ich das Objekt "Wohnzimmerlampe" das auf die Zigbee-Adresse 0x00001245 (willkürlich eingetippt) mappt. Wird "Wohnzimmerlampe" eingeschaltet, wird die Zigbee-Adresse geschaltet.
                                Was das Script mir auch bietet und warum ich es nicht missen will: Ich habe einen Zoo an smarter Hardware. Mensche Sensoren von Bosch, andere von Homatic, manche laufen über Tasmota und wieder andere kommen vom KNX. Was sich so über die Jahre historisch angesammelt hat. Alle verwenden aber unterschiedliche Daten. Fenstersensoren von Bosch melden bspw. "OPEN" und "CLOSED", Homematic liefert "true" und "false". Das Script kann mir das konvertieren, so das meine "virtuellen" Fenstersensoren immer true oder false haben, egal welche Hardware dahinter ist.
                                Das wiederrum gibt mir die Möglichkeit da sich in sämtlichen Scripten nicht darauf achten muss, welche Sensoren oder Aktoren ich benutze, weil ich ja alles auf ein spezifisches Format bringe.
                                Und weil ich eben dieses Script nutze und Hannah am Anfang ihrer Entstehung die States über MQTT empfing, habe ich auch bei ihr mit dem Script im Kopf gearbeitet. So kommt bspw. im initalpost die Vorraussetzung das man das Script nutzt.
                                Tatscählich hat sich Hannah in den Monaten aber stetig weiterentwickelt. So ist auch die MQTT-Anbindung zum ioBroker entfernt und durch den wesentlich mächtigeren Adapter ersetzt worden. Natürlich läuft in meinem Produktionssytem noch immer das virtual Device Script und das werde ich auch nicht abschalten. Getestet habe ich Hannah aber auch gegen einen nativen ioBroker, heißt mit nativen Geräten, ohne Konvertierungsscript.
                                Wichtig für Hannah ist, das die Geräte Räumen und die States Funktionen zugewiesen sind. Das ist mit einer gewissen Arbeit verbunden.
                                Im Adapter kann man dann die Kombination an Räumen und Funktionen wählen, die an Hannah gesendet werden. Der Adapter versucht dann quasi auf best-effort-Basis, die States in ioBroker zu interpretieren. Wird bspw. die Funktion "Fenstersensor" ausgelesen im Raum "Badezimmer", geht der Adapter davon aus, wenn es einen boolean-State gibt, das der offen/geschlossen repräsentiert. Das übersetzt der dann in das "Hannah-Protokoll" und sendet das an den Core. Der Core ist in der Beziehung also eigentlich recht "dumm", er verwendet genau die Daten die der Adapter sendet.
                                Das Verhalten vom Adapter kann man auf mehrere Arten beeinflussen. So kann man States bspw. eigene Eigenschaften hinzufügen, die dem Adapter mitteilen, wie er den State zu nutzen hat.
                                An der Stelle möchte ich anmerken, das ich nicht weiß mit welchen Geräten/welchen States der Adapter funktioniert, er tut es mit den Geräten die ich habe auf jeden Fall.
                                So, ist nun wieder recht viel geworden, aber ich hoffe das beantwortet deine Fragen.
                                Liebe Grüße
                                • M
                                  M
                                  manne01
                                  #76
                                  PS: eins ist mir grad noch aufgefallen - ffmpeg scheint im core-container noch zu fehlen. Aus dem core-log:
                                  18:50:10 [INFO] hannah.grpc_server: [grpc] SubmitVoice von telegram:8752210440 (user=2, 85487 bytes)
                                  18:50:10 [ERROR] grpc._server: Exception calling application: [Errno 2] No such file or directory: 'ffmpeg'
                                    File "/usr/local/lib/python3.14/site-packages/grpc/_server.py", line 608, in _call_behavior
                                      response_or_iterator = behavior(argument, context)
                                    File "/app/hannah/grpc_server.py", line 549, in SubmitVoice
                                      transcript, answer, intent_name, audio_ogg = self._handle_voice(
                                          request.audio, user_id,
                                          channel_type=request.source_service or "grpc_voice", channel_id=request.source_user_id,
                                    File "/app/main.py", line 1462, in _handle_voice
                                      proc = subprocess.run(
                                          ["ffmpeg", "-y", "-i", ogg_path,
                                           "-f", "s16le", "-ac", "1", "-ar", "16000", "-"],
                                          capture_output=True,
                                    File "/usr/local/lib/python3.14/subprocess.py", line 555, in run
                                      with Popen(*popenargs, **kwargs) as process:
                                    File "/usr/local/lib/python3.14/subprocess.py", line 1039, in __init__
                                      self._execute_child(args, executable, preexec_fn, close_fds,
                                                          pass_fds, cwd, env,
                                      ...<5 lines>...
                                                          gid, gids, uid, umask,
                                                          start_new_session, process_group)
                                    File "/usr/local/lib/python3.14/subprocess.py", line 1990, in _execute_child
                                      raise child_exception_type(errno_num, err_msg, err_filename)
                                  FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
                                  • L
                                    L
                                    Leonie
                                    #77
                                    Ist gefixt in Tag-Version 0.75.8 oder re-pull von latest
                                    • M
                                      M
                                      manne01
                                      #78
                                      Danke dir! Auch für die Erklärung bzgl. Iobroker Geräte-Konfiguration!
                                      Der ffmpeg-Fehler kommt jetzt nicht mehr und meine Spracheingaben werden korrekt angenommen. Allerdings ist mir noch eine Fehlermeldung aufgefallen die wohl doch nicht weg war bei meinem letzten Beitrag. Das erklärt auch warum nur der Text und keine Sprachnachrichten mehr an mich zurück kommen wenn ich welche absende:
                                      23:46:17 [ERROR] hannah.tts: TTS-Backend 'piper' Initialisierung fehlgeschlagen: [Errno 2] No such file or directory: '/app/data/de_DE-kerstin-low.onnx.json'
                                      In meinem compose sieht es für core so aus:
                                      volumes:
                                      - ./core_activity_audio:/app/activity_audio
                                      - ./core_audio_dumps:/app/audio_dumps
                                      - ./core_data:/app/data
                                      Im Unterverzeichnis core_data liegen die beiden "Kerstin-Dateien". Die Rechte passen.
                                      In core config sieht es so aus:
                                        model: "/app/data/de_DE-kerstin-low.onnx"   # leer = TTS deaktiviert
                                      Ich hab jetzt gefühlt alle Kombinationen durchkonfiguriert. Egal was ich konfiguriere, er lädt sie nicht. Komme leider nicht mehr weiter.
                                      Viele Grüße!
                                      • L
                                        L
                                        Leonie
                                        #79
                                        ein kleines Update für eure ständigen Fragen nach den ESPs: Ich habe mich nun endlich dazu durchgerungen, die Hardware freizugeben! 😉
                                        Ich weiß, wir haben hier schon gefühlt ewig über die Software, die Audio-Pipelines und das ganze Konzept gequatscht. Es hat auch ein bisschen Überwindung gekostet, das eigene „Baby“ nach den ganzen Entwicklungsstunden in die Wildnis zu entlassen – aber das Hannah Satellite (Revision 5) Board ist jetzt definitiv ready für die Welt!
                                        Kurzer Refresher, was auf der Platine steckt:
                                        ESP32-S3 Core: Satte Rechenleistung für unsere lokale Audio-Verarbeitung (gRPC / MQTT / RTSP).
                                        Low-Noise Audio Layout: Gezielte Signalführung fürs Mikrofon-Array, damit das Netzteil nicht in die Aufnahme reingrätscht.
                                        RGB-Status-LEDs: Visuelles Feedback für Hören, Denken oder Mute.
                                        SMT- & DIY-freundlich: Komplexe ICs und die RGB-LEDs lasst ihr am besten direkt über den PCBWay-SMT-Service bestücken. Bei den Passiven (Widerstände, Dioden, Kondensatoren) gibt's entspannte 0603-Footprints für alle, die noch selbst den Lötkolben schwingen wollen.
                                        Hier könnt ihr euch das Teil direkt ordern:
                                        👉 https://www.pcbway.com/project/shareproject/Hannah_Satellite_Revsion_5_676db7ad.html
                                        👉 Wichtiger Praxistipp: Ich empfehle euch dringend die Bestellung von PCB + Assembly. Ohne Reflowofen macht es absolut keinen Spaß, die ICs von Hand zu löten!
                                        Gerber-Dateien, BOM und CPL für den Bestückungsservice liegen im Projekt bereit (Lizenz: CC BY-NC-ND 4.0 für eure private Nutzung).
                                        @manne01
                                        Existieren denn beide Dateien (de_DE-kerstin-low.onnx und de_DE-kerstin-low.onnx.json) in deinem Volume oder nur die eine? Man benötigt beide Dateien für die Funktion.
                                        Liebe Grüße
                                        • M
                                          M
                                          manne01
                                          #80
                                          @leonie
                                          Konnte es lösen, da stimmte doch noch was mit den Berechtigungen nicht ✔ - es war einfach zu spät gestern
                                          84.0k
                                          1.4m
