iU891A-XL Instanz Wireless mbus mit Fehler
pi@raspi2:~ $ ls -la /dev/serial/by-id/ insgesamt 0 drwxr-xr-x 2 root root 80 19. Mär 03:31 . drwxr-xr-x 4 root root 80 14. Mär 14:57 .. lrwxrwxrwx 1 root root 13 19. Mär 03:31 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00 -> ../../ttyACM0 lrwxrwxrwx 1 root root 13 18. Mär 09:04 usb-IMST_iU891A_IMS4139-if00 -> ../../ttyACM1@DGR da fehlt das /dev/serial/by-id/ davor
host.raspi2 2026-03-19 10:39:21.776 error instance system.adapter.wireless-mbus.0 terminated with code 6 (UNCAUGHT_EXCEPTION) wireless-mbus.0 2026-03-19 10:39:21.238 error Exception-Code: ERR_BUFFER_OUT_OF_BOUNDS: Attempt to access memory outside buffer bounds wireless-mbus.0 2026-03-19 10:39:21.237 error RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds at boundsError (node:internal/buffer:86:11) at Buffer.readUInt16LE (node:internal/buffer:245:5) at HciMessageV2.parse (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/HciMessageV2.js:131:28) at ImstV2Receiver.isTelegramMessage (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/ImstV2Receiver.js:92:13) at ImstV2Receiver.onData (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/SerialDevice.js:119:23) at SerialPort.emit (node:events:519:28) at addChunk (node:internal/streams/readable:561:12) at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) at Readable.push (node:internal/streams/readable:392:5) at /opt/iobroker/node_modules/iobroker.wireless-mbus/node_modules/@serialport/stream/dist/index.js:208:18 wireless-mbus.0 2026-03-19 10:39:21.237 error unhandled promise rejection: Attempt to access memory outside buffer bounds wireless-mbus.0 2026-03-19 10:39:21.236 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). wireless-mbus.0 2026-03-19 10:39:16.461 error Serialport error: Port is not open -
host.raspi2 2026-03-19 10:39:21.776 error instance system.adapter.wireless-mbus.0 terminated with code 6 (UNCAUGHT_EXCEPTION) wireless-mbus.0 2026-03-19 10:39:21.238 error Exception-Code: ERR_BUFFER_OUT_OF_BOUNDS: Attempt to access memory outside buffer bounds wireless-mbus.0 2026-03-19 10:39:21.237 error RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds at boundsError (node:internal/buffer:86:11) at Buffer.readUInt16LE (node:internal/buffer:245:5) at HciMessageV2.parse (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/HciMessageV2.js:131:28) at ImstV2Receiver.isTelegramMessage (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/ImstV2Receiver.js:92:13) at ImstV2Receiver.onData (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/SerialDevice.js:119:23) at SerialPort.emit (node:events:519:28) at addChunk (node:internal/streams/readable:561:12) at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) at Readable.push (node:internal/streams/readable:392:5) at /opt/iobroker/node_modules/iobroker.wireless-mbus/node_modules/@serialport/stream/dist/index.js:208:18 wireless-mbus.0 2026-03-19 10:39:21.237 error unhandled promise rejection: Attempt to access memory outside buffer bounds wireless-mbus.0 2026-03-19 10:39:21.236 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). wireless-mbus.0 2026-03-19 10:39:16.461 error Serialport error: Port is not open@DGR sagte in iU891A-XL Instanz Wireless mbus mit Fehler:
warum auch immer
Mit diesen Einstellungen ist bei der Instanz VORERST alles grün, aber das hatte ich gestern auch schon und irgendwann in der Nacht ging es dann nicht mehr. Daten kommen an.
Ich teste erstmal weiter und versuche zu ermitteln, wann die Verbindung abbricht (immer zur gleichen Zeit vielleicht ?)
Das ist wahrscheinlich Zufall
in diesem Moment hat dein RasPi deinem Device ttyACM1 zugewiesen.
Dann müssten beide Einstellungen gehen!
Sobald dein RasPi deinem device eine andere Portbezeichnung zuweist, wird der Adapter es nicht mehr unter ttyACM1 finden.
wohl nicht
10:39:21.238
ist nicht
