  4. Nightscout Instanz startet nicht mehr
    6.4k
26 Beiträge 5 Kommentatoren 1.4k Aufrufe 4 Beobachtet
  • mcm1957M mcm1957
    @thomasw-1
    Versuch mal den fork zu installieren:
    https://github.com/mcm1957/ioBroker.nightscout
    Wenn der funktioniert, gib bitte Bescheid ich erstell denn nen PR und triggere Bluefox für ne sauber Release.
    Und alles Gute für deinen Sohn.
    @mcm1957
    Da fehlt wohl noch was. Installlog:
    echad@chet:/opt/iobroker $ iob url https://github.com/mcm1957/ioBroker.nightscout --debug
    install mcm1957/ioBroker.nightscout#d532a8138253b27473223f8f1bdcdb990e7185ad
    NPM version: 11.6.2
    Installing mcm1957/ioBroker.nightscout#d532a8138253b27473223f8f1bdcdb990e7185ad... (System call)
    npm warn skipping integrity check for git dependency ssh://git@github.com/mcm1957/ioBroker.nightscout.git
    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
    npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated whatwg-encoding@1.0.5: Use @exodus/bytes instead for a more spec-conformant and faster implementation
    npm warn deprecated whatwg-encoding@2.0.0: Use @exodus/bytes instead for a more spec-conformant and faster implementation
    npm warn deprecated left-pad@1.3.0: use String.prototype.padStart()
    npm warn deprecated domexception@1.0.1: Use your platform's native DOMException instead
    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
    npm warn deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
    npm warn deprecated gauge@3.0.2: This package is no longer supported.
    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
    > sharp@0.32.6 install
    > (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)
    sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.14.5-linux-arm64v8.tar.br
    sharp: Integrity check passed for linux-arm64v8
    > @scarf/scarf@1.4.0 postinstall
    > node ./report.js
    > ejs@2.7.4 postinstall
    > node ./postinstall.js
    Thank you for installing EJS: built with the Jake JavaScript build tool (https://jakejs.com/)
    > nightscout@14.2.11 postinstall
    > npm run-script generate-keys
    > nightscout@14.2.11 generate-keys
    > node bin/generateRandomString.js >tmp/randomString
    node:internal/modules/cjs/loader:1423
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/nightscout/bin/generateRandomString.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1420:15)
        at defaultResolveImpl (node:internal/modules/cjs/loader:1058:19)
        at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1063:22)
        at Module._load (node:internal/modules/cjs/loader:1226:37)
        at TracingChannel.traceSync (node:diagnostics_channel:328:14)
        at wrapModuleLoad (node:internal/modules/cjs/loader:245:24)
        at Module.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:154:5)
        at node:internal/main/run_main_module:33:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v25.2.0
    added 148 packages in 53s
    255 packages are looking for funding
      run `npm fund` for details
    upload [16] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [15] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [14] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [13] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [12] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [11] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [10] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [9] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [8] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [7] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [6] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [5] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/index_m.html index_m.html text/html
    upload [4] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/jsonConfig.json jsonConfig.json application/json
    upload [3] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/nightscout.png nightscout.png image/png
    upload [2] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/style.css style.css text/css
    upload [1] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/tsconfig.json tsconfig.json application/json
    upload [0] nightscout.admin /opt/iobroker/node_modules/iobroker.nightscout/admin/words.js words.js application/javascript
    Updating objects from io-package.json for adapter "nightscout" with version "1.1.0"
    • mcm1957M Online
      mcm1957M Online
      mcm1957
      VORSICHT: ZUmindest auf meinem Windows System läuft der Fork auch nicht. Er findet anscheinen nicht mal main ???
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M Online
        mcm1957M Online
        mcm1957
        Ich muss aus zeitlichen Gründen eher passen.
        Die originale Fehlermeldung kommt wie auch schon OliverIO festgestellet hat daher, dass moment-timezone nicht in den dependencies des Adapters eingetragen ist.
        Die Fehlermeldungen betreffend random String sind eher unklar, es gibt im Repo kein bin Verzeichnis. Da wird anscheinend irgendwas im os Bereich erwartet.
        Allerdings starte der Adapter nach fix der moment-timezone dependency auch nicht. Zumindest nicht unter windows, da die dependencies mit require('./lib/client') angegeben sind. Die aktuellen Node versionen erwarten da aber die extension. Anpassen auf require('./lib/client.js') behebt zwar das problem, aber der Adapter crashed dann beim require der optional dependency nightscout....
        • OliverIOO OliverIO
          @ThomasW-1 sagte in Nightscout Instanz startet nicht mehr:
          nightscout
          das scheint ein problem des adapters zu sein.
          der adapter benötigt die bibliothek moment-timezone
          die ist aber in der package.json des adapters nicht notiert, daher wird die nicht installiert. auch ist sie in der moment bibliothek nicht als dependency notiert.
          warum der adapter zuvor funktioniert hat konnte ich nicht nachvollziehen. wahrscheinlich war diese eine bibliothek durch einen anderen adapter, der nun nicht mehr da ist, bereitgestellt worden.
          du könntest jetzt (aber ohne garantie das danach der adapter oder der iobroker noch funktioniert, daher definitiv erst ein backup machen) in das verzeichnis /opt/iobroker gehen und den folgenden befehl eingeben. das verzeichnis von dem man den befehl aus eingibt ist wichtig, also nicht woanders eingeben
          npm i moment-timezone
          das installiert diese bibliothek nach und ist vermutlich dann auch für den adapter verfügbar.
          auf jeden fall solltest du auf github bei dem adapter ein issue erstellen.
          ThomasW 1T Offline
          ThomasW 1T Offline
          ThomasW 1
          schrieb am zuletzt editiert von ThomasW 1
          @OliverIO
          danke, dies hat geklappt. Die Instanz läuft jetzt wieder. :-)
          • ThomasW 1T ThomasW 1
            @OliverIO
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @ThomasW-1
            probiere trotzdem den fork aus, damit man das in ein release einfließen lassen kann.
            so ist es nur flickwerk und beim nächsten iobroker update kommt das problem wieder.
            aufgrund der mongodb abhängigkeit kannst du es am besten testen
            Meine Adapter und Widgets
            Links im Profil
              @ThomasW-1
              mcm1957M Online
              mcm1957M Online
              mcm1957
              @OliverIO sagte in Nightscout Instanz startet nicht mehr:
              Ich hab den zurück gezogen da er bei mir nicht lauffähig war und ich nichts durch eine Installation verschlimmbessern wollte.
              Hab allerdings ein Issue beim Adapter eingestellt, damit das nicht untergeht.
              Bezüglich fork
              • ergänzen moment-timezone ist kein Problem und ging
              • allerdings funktionieren mit der aktuellen node Umgebung zumindest unter windows die requires nicht mehr. Im code steht require('./lib/client'). Daas file heißt client.js. Ich kann mich erinnern dass irgendwann die Ergänzung von .js per Default weggefallen ist. Ändert man diese requires aug require('./lib/client.js') dann kmmt man da drüber.
              • allerdings crashed der code wenig später an einer Stelle wo er require('nightscout') absetzt. Das Paket ist als optionale dependency eingetragen. Anscheinend rechnet der Code aber nicht damit dass sie optional ist ....
              • Und zuletzt gibts bei der Installation eine Fehlermeldung weil eine Datei bin/irgendwas zum errechnen einer Zufallszahl (dem Namen nach) nicht existiert. Nur bin Verzeichnis gibts im Repo gar nicht.
              Damit hab ich mal abgebrochen - hab leider keine Zeit den ganzen Adapter zu durchforsten und zu bereinigen.
              Da die letzen Anpassungen Bluefox gemacht hat könnt ihr ihn ja direkt kontaktieren und fragen ob er Zeit hat. Sinnvollerweise via Telegramm, da Github Mails ihn m.W. nach nicht erreichen.
