  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 119.7k Aufrufe
  • A
    A
    Andrei34
    #121
    Теперь почему-то вылетает Node-Red
    `node-red-0	2015-08-24 04:14:18	info	node-red exited with 1
    node-red-0	2015-08-24 04:14:18	debug	at Error (native)
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - Error: ENOENT, open '/opt/iobroker/opt/iobroker/log/iobroker.log.2015-08-24'
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [red] Uncaught Exception:
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] /opt/iobroker/iobroker-data/node-red/
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] in the directory:
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] npm install
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] To install any of these missing modules, run:
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] - serial-port (provided by npm module node-red-node-serialport)
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] Waiting for missing types to be registered:
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] Starting flows
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] Server now running at http://127.0.0.1:1880/
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    node-red-0	2015-08-24 04:14:18	debug	24 Aug 04:14:18 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js`[/red]
    • A
      A
      Andrei34
      #122
      Спасибо с ioBroker.js-controller 0.7.11 всё опять заработало.
      • E
        E
        electric69
        #123
        BlueFox, подскажи пожалуйста, почему сервер не может получить сведения об обновлениях?
        Скрин лога прилагаю.
        Хотя интернет есть, все сайты пингуются, в том числе гитхаб…
        • BluefoxB
          #124
          @electric69:
          Хотя интернет есть, все сайты пингуются, в том числе гитхаб… `
          Что пишет, если ты в консоли вызываешь
          iobroker update
          • M
            M
            MSapogov
            #125
            Спасибо за обновление драйвера Mega-D!
            А сейчас процесс установки на Debian Ubuntu (amd64) чемто отличается от приведенный на первой странице?
            Дохожу до
            /opt/iobroker# npm install iobroker
            А в ответ сразу:
            npm WARN cannot run in wd iobroker@0.5.6 node lib/setup.js (wd=/opt/iobroker/node_modules/iobroker)
            iobroker@0.5.6 node_modules/iobroker
            └── yargs@1.2.6 (minimist@0.1.0)
            И дальше тишина …
            Одинаково и в Debian 0.8.2 и Ubuntu 14.04
            Можно как-то обновить инструкцию...
            • BluefoxB
              #126
              Попробуй: sudo npm install iobroker
              • M
                M
                MSapogov
                #127
                @Bluefox:
                Попробуй: sudo npm install iobroker `
                Я все запускал от root-а.
                Все оказалось очень просто…
                Установка node из репозитория.
                chmod 777 /opt/iobroker
                и ссылка на "node" с помощью команды "sudo ln -s /usr/bin/nodejs /usr/bin/node"
                После этого
                Прошла как по маслу...
                Спасибо.
                • BluefoxB
                  #128
                  Надо внести в инструкцию:
                  ` > Firts check if node.js is installed. You can do it with command node -v.
                  If you got an answer, you can continue with the installation.
                  If not. Try to install node.js with apt-get install nodejs.
                  Sometimes node.js has not installed the soft link. If you see outputs with /usr/bin/nodejs -v, following can help:
                  ln -s /usr/bin/nodejs /usr/bin/node `
                  • F
                    F
                    ford7
                    #129
                    @ford7:
                    Подскажите, как починить?
                    вкладка "драйвера" пустая.
                    upd:
                    вкладка "сервера" тоже пустая.
                    А в настройках все штатно: `
                    Вот при каждой попытке обновления js-controller происходит такая штука. Приходится заново руками js-controller устанавливать. Может у меня чего-то не так установилось изначально или строки какой-нить не хватает?
                    • E
                      E
                      electric69
                      #130
                      @ford7:
                      @ford7:
                      upd:
                      А в настройках все штатно: Вот при ****каждой**** попытке обновления js-controller происходит такая штука. Приходится заново руками js-controller устанавливать. Может у меня чего-то не так установилось изначально или строки какой-нить не хватает?
                      Попробуй поиграться с правами на папку iobroker. Мне помогло вроде…
                      • aurodionovA
                        aurodionovA
                        aurodionov
                        #131
                        Сегодня "пал смертью храбрых" хард на неттопе где крутился iobroker, вагон бедов
                        Отсель вопрос как быстро натянуть назад iobroker, ставил в первые версии, всё руками и исходников, что изменилось
                        Сори ,что спрашиваю не перелопатив ветки и вики.
                        Пишу с пульта….
                        • BluefoxB
                          #132
                          ioBroker ставится 4мя командами:
                          sudo mkdir /opt/iobroker
                          cd /opt/iobroker
                          sudo chmod 777 .
                          • aurodionovA
                            aurodionovA
                            aurodionov
                            #133
                            Поменял хард, накатил debian 8.2.0, node, ставлю iobroker и получаю вагон варнингов и ошибок
                            Может чего не установилось или забыл поставить, прошлый раз ноду собирал из сырцов, сейчас водрузил с репо
                            root@SmartHome:/opt/iobroker# npm install iobroker
                            iobroker@0.5.6 install /opt/node_modules/iobroker
                            node lib/setup.js
                            ! npm install iobroker.js-controller --production --prefix /opt
                            npm WARN engine hawk@3.1.0: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
                            npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                            npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                            npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                            In file included from ../src/validation.cc:15:0:
                            ../node_modules/nan/nan.h:328:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’
                            static const unsigned kReplaceInvalidUtf8 = v8::String::REPLACE_INVALID_UTF8;
                            make: *** [Release/obj.target/validation/src/validation.o] Ошибка 1
                            gyp ERR! build error
                            gyp ERR! stack Error: make failed with exit code: 2
                            gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
                            gyp ERR! stack at ChildProcess.emit (events.js:98:17)
                            gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:809:12)
                            gyp ERR! System Linux 3.16.0-4-686-pae
                            gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
                            gyp ERR! cwd /opt/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
                            gyp ERR! node -v v0.10.29
                            gyp ERR! node-gyp -v v0.12.2
                            gyp ERR! not ok
                            npm WARN This failure might be due to the use of legacy binary "node"
                            npm WARN For further explanations, please read
                            /usr/share/doc/nodejs/README.Debian
                            In file included from ../src/bufferutil.cc:16:0:
                            make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Ошибка 1
                            gyp ERR! cwd /opt/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                            gyp ERR! not ok
                            npm WARN optional dep failed, continuing utf-8-validate@1.2.1
                            gyp ERR! cwd /opt/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                            gyp ERR! not ok
                            npm WARN optional dep failed, continuing bufferutil@1.2.1
                            gyp ERR! cwd /opt/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                            gyp ERR! not ok
                            npm install iobroker.admin --production --prefix /opt
                            gyp ERR! cwd /opt/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
                            gyp ERR! not ok
                            gyp ERR! cwd /opt/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                            gyp ERR! not ok
                            gyp ERR! cwd /opt/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                            gyp ERR! not ok
                            gyp ERR! cwd /opt/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                            gyp ERR! not ok
                            Non-critical error: EISDIR, illegal operation on a directory '/opt/node_modules/iobroker/lib/../../../iobroker'
                            iobroker@0.5.6 ../node_modules/iobroker
                            Пишу с пульта….
                            • aurodionovA
                              aurodionovA
                              aurodionov
                              #134
                              При помощи буна,гугла и какой-то матери я его поставил.
                              8294_zwite_log.txt
                              Пишу с пульта….
                              • BluefoxB
                                #135
                                А что было то?
                                • aurodionovA
                                  aurodionovA
                                  aurodionov
                                  #136
                                  Вобщем встал криво, по моему что-то не то с кодировкой
                                  npm ERR! not a package /tmp/npm-1594-psWTuwUR/1446747427997-0.4993789638392627/tmp.tgz
                                  iobroker@0.5.6 install /opt/iobroker/node_modules/iobroker
                                  node lib/setup.js
                                  ! npm install iobroker.js-controller --production --prefix /opt/iobroker
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
                                  gyp ERR! not ok
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                                  gyp ERR! not ok
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                                  gyp ERR! not ok
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                                  gyp ERR! not ok
                                  npm install iobroker.admin --production --prefix /opt/iobroker
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
                                  gyp ERR! not ok
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                                  gyp ERR! not ok
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                                  gyp ERR! not ok
                                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                                  gyp ERR! not ok
                                  Write "./iobroker start" to start the ioBroker
                                  Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                                  iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                                  root@SmartHome:/opt/iobroker# node -v
                                  v0.10.29
                                  Копаю дальше, натянул виз, не открывается
                                  Пишу с пульта….
                                  • H
                                    H
                                    Haus
                                    #137
                                    Привет всем
                                    Вчера мучался пол дня с установкой Iobroker на Debian, сначала думал может какие проблемы с 8.2 (кстати nodejs есть в репозитариях) накатил 7.9 та же фигня ошибок и варнингов при установке кучи. Перечитал все способы установки и вуаля.
                                    Debian 8.2 чистый под "root"
                                    apt-get update
                                    apt-get upgrade
                                    apt-get install curl
                                    apt-get install build-essential
                                    curl -sL https://deb.nodesource.com/setup | bash -
                                    mkdir /opt/iobroker
                                    cd /opt/iobroker
                                    Проблемы с nodejs и npm в репозитах они старые и с кодировкой чего то не то если кому пригодится отпешитесь о результатах
                                    Вопрос к Bluefox не приходят обновления драйверов всё остальное как часы?
                                    ! root@Server1:~# cd /opt/iobroker
                                    ! root@Server1:/opt/iobroker# iobroker update
                                    ! update done
                                    ! Adapter "zwave" : 0.2.3
                                    ! Adapter "yr" : 0.1.9 , installed 0.1.9
                                    ! Adapter "wolf" : 0.0.9
                                    ! Adapter "web" : 1.2.1 , installed 1.2.1
                                    ! Adapter "vis-timeandweather": 0.0.2 , installed 0.0.2
                                    ! Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
                                    ! Adapter "vis-plumb" : 0.1.6
                                    ! Adapter "vis-metro" : 0.1.9
                                    ! Adapter "vis-lcars" : 0.1.6
                                    ! Adapter "vis-keyboard" : 0.0.2
                                    ! Adapter "vis-jqui-mfd" : 0.1.0
                                    ! Adapter "vis-hqwidgets" : 0.2.2 , installed 0.2.2
                                    ! Adapter "vis-google-fonts": 0.1.0
                                    ! Adapter "vis-fancyswitch": 0.1.0
                                    ! Adapter "vis-colorpicker": 0.1.1
                                    ! Adapter "vis-bars" : 0.1.1
                                    ! Adapter "vis" : 0.7.7 , installed 0.7.7
                                    ! Adapter "terminal" : 0.1.2
                                    ! Adapter "sonos" : 0.1.7
                                    ! Adapter "rickshaw" : 0.2.2 , installed 0.2.2
                                    ! Adapter "pushover" : 0.1.1
                                    ! Adapter "pushbullet" : 0.0.11
                                    ! Adapter "owfs" : 0.0.2 , installed 0.0.2
                                    ! Adapter "onkyo" : 0.1.9
                                    ! Adapter "socketio" : 1.0.0
                                    ! Adapter "simple-api" : 1.0.0
                                    ! Adapter "scenes" : 0.2.2
                                    ! Adapter "sayit" : 0.3.15 , installed 0.3.15
                                    ! Adapter "s7" : 0.2.4
                                    ! Adapter "ping" : 0.1.4
                                    ! Adapter "node-red" : 0.3.5
                                    ! Adapter "mqtt" : 0.2.15
                                    ! Adapter "modbus" : 0.3.9
                                    ! Adapter "mobile" : 0.0.5
                                    ! Adapter "megad" : 1.0.6 , installed 1.0.6
                                    ! Adapter "knx" : 0.2.10
                                    ! Controller "js-controller" : 0.7.15 , installed 0.7.15
                                    ! Adapter "javascript" : 1.0.7 , installed 1.0.7
                                    ! Adapter "icons-ultimate-png": 0.1.0
                                    ! Adapter "icons-open-icon-library-png": 0.1.1
                                    ! Adapter "icons-mfd-svg" : 0.1.2
                                    ! Adapter "icons-mfd-png" : 0.1.2
                                    ! Adapter "icons-material-svg": 0.1.0
                                    ! Adapter "icons-material-png": 0.1.0
                                    ! Adapter "icons-addictive-flavour-png": 0.1.0
                                    ! Adapter "ical" : 1.1.1 , installed 1.1.1
                                    ! Adapter "hmm" : 1.0.0
                                    ! Adapter "hue" : 0.5.1
                                    ! Adapter "hm-rpc" : 0.5.2
                                    ! Adapter "hm-rega" : 0.2.2
                                    ! Adapter "history" : 0.1.3 , installed 0.1.3
                                    ! Adapter "harmony" : 0.5.4
                                    ! Adapter "example" : 0.1.1 , installed 0.1.1
                                    ! Adapter "fritzbox" : 0.2.1
                                    ! Adapter "flot" : 0.1.1 , installed 0.1.1
                                    ! Adapter "email" : 0.1.2
                                    ! Adapter "dwd" : 1.0.1
                                    ! Adapter "cul" : 0.0.4
                                    ! Adapter "b-control-em" : 0.1.1
                                    ! Adapter "artnet" : 0.0.3
                                    ! Adapter "admin" : 0.6.6 , installed 0.6.6
                                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                    admin: 3.6.0
                                    javascript: 4.1.10
                                    web: 2.4.1 vis: 1.1.10
                                    cloud: 2.6.2
                                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                                    Adapter: MegaD-2561, Mega-ES…
                                    • H
                                      H
                                      Haus
                                      #138
                                      @Haus:
                                      Привет всем
                                      apt-get update
                                      apt-get upgrade
                                      mkdir /opt/iobroker
                                      cd /opt/iobroker
                                      ! update done
                                      ! Adapter "admin" : 0.6.6 , installed 0.6.6 `
                                      Сам себе и отвечу
                                      Нет обновлений.
                                      На гите рабочие версии, которые ни в коем случае нельзя устанавливать, если не знаешь javascript.
                                      Процесс разработки следующий. Я сначала заливаю версию на гит (она может быть и не рабочей). Потом прошу пользователей, кто не боится трудностей и способен определить проблемы установить эти версии специальной командой.
                                      Если у них бежит, то я заливаю версию на npm и вот оттуда она доступна всем.
                                      Почему у тебя показываются версии с гита надо ещё выяснить.
                                      Рабочую версию, кстати, можно посмотреть здесь http://iobroker.net:8081 и http://iobroker.net:8082/vis/edit.html
                                      admin: 3.6.0
                                      javascript: 4.1.10
                                      cloud: 2.6.2
                                      • E
                                        E
                                        electric69
                                        #139
                                        Пытаюсь установить iobroker на bananapi образ http://www.armbian.com/banana-pi/.
                                        NodeJS и NPM https://github.com/nodejs/node-v0.x-archive/wiki/Installing-Node.js-via-package-manager#debian-and-ubuntu-based-linux-distributions без проблем:
                                        root@bananapi:/# nodejs -v
                                        v5.1.1
                                        root@bananapi:/# npm -v
                                        3.3.12
                                        root@bananapi:/#
                                        Затем:
                                        $ cd /opt
                                        $ mkdir iobroker
                                        $ cd iobroker
                                        $ sudo npm install iobroker
                                        Ошибка:
                                        • BluefoxB
                                          #140
