  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Ubiquiti Unifi Protect Kameras in Yahka einbinden
    2.8k
    4.8k
    4.1k
22 Beiträge 5 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • H halsi82
    @wendy2702
    Hier nochmal die Stream Konfig von Yahka
      "-nostats",
      "-nostdin",
      "-y",
      "-re",
      "-i",
      "${source}",
      "-an",
      "-sn",
      "-dn",
      "-codec:v",
      "${codec}",
      "-pix_fmt",
      "yuv420p",
      "-r",
      "${fps}",
      "-f",
      "rawvideo",
      "-tune",
      "zerolatency",
      "-vf",
      "scale=${width}:${height}",
      "-b:v",
      "${bitrate}k",
      "-bufsize",
      "${bitrate}k",
      "-payload_type",
      "${payloadtype}",
      "-ssrc",
      "${targetVideoSsrc}",
      "-f",
      "rtp",
      "-srtp_out_suite",
      "AES_CM_128_HMAC_SHA1_80",
      "-srtp_out_params",
      "${videokey}",
      "srtp://${targetAddress}:${targetVideoPort}?rtcpport=${targetVideoPort}&localrtcpport=${targetVideoPort}&pkt_size=${mtu}"
    halsi82
    ffmpeg version 7.0.2-homebridge-alpine-x86_64-static Copyright (c) 2000-2024 the FFmpeg developers
      built with gcc 13.2.1 (Alpine 13.2.1_git20240309) 20240309
      configuration: --enable-hardcoded-tables --enable-nonfree --enable-gpl --enable-hardcoded-tables --enable-hardcoded-tables --enable-openssl --enable-libdav1d --enable-libsvtav1 --enable-libx264 --enable-libx265 --enable-libvpx --enable-libxvid --enable-libvidstab --enable-libaom --enable-libzimg --enable-lv2 --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libmp3lame --enable-libopus --enable-libspeex --enable-libvorbis --enable-libtheora --enable-libfdk-aac --enable-libwebp --enable-libsrt --disable-ffnvcodec --enable-amf --disable-debug --disable-shared --enable-pthreads --enable-static --enable-version3 --extra-cflags='-I/build/workspace/include -I/build/workspace/include/lilv-0' --extra-ldexeflags=-static --extra-ldflags=-L/build/workspace/lib --extra-libs='-ldl -lpthread -lm -lz' --pkgconfigdir=/build/workspace/lib/pkgconfig --pkg-config-flags=--static --prefix=/build/workspace --extra-version=homebridge-alpine-x86_64-static
      libavutil      59.  8.100 / 59.  8.100
      libavcodec     61.  3.100 / 61.  3.100
      libavformat    61.  1.100 / 61.  1.100
      libavdevice    61.  1.100 / 61.  1.100
      libavfilter    10.  1.100 / 10.  1.100
      libswscale      8.  1.100 /  8.  1.100
      libswresample   5.  1.100 /  5.  1.100
      libpostproc    58.  1.100 / 58.  1.100```
    H 1 Antwort Letzte Antwort
    • H halsi82
      halsi82
      schrieb am zuletzt editiert von halsi82
      Ich konnte den Fehler bzgl Videostream finden.
      Bzgl. Videostream.
      Mein Siri Homepod steht im Internal LAN, mein iobroker im Smarthome LAN.
      FFMPEG von Yahka nimmt den Stream der Kameras und schickt diesen an den Homepod.
      Und genau das wurde von meiner Firewall blockiert. Habe jetzt dem Iobroker erlaubt sich zum Homepod über TCP zu verbinden und voila - Stream ging sofort.
      Herzlichen Dank an Alle die versucht haben mir zu helfen. Schlussendlich ein Firewall Problem.
