  4. philips hue tento slim ceiling light zigbee adapter?? "erl"
    6.7k
zigbee adapter
26 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • D denjo
    @arteck sagte in philips hue tento slim ceiling light zigbee adapter??:
    https://github.com/ioBroker/ioBroker.zigbee/tarball/ZHC_latest
    wenn ich die v3.0.2 installiere kommt diese meldungen:
    zigbee.0
    2025-07-08 12:35:43.543	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"f87fbb8463c9eb11b1448b4f1d69213e","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87fbb8463c9eb11b1448b4f1d69213e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    zigbee.0
    2025-07-08 12:35:43.509	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":326,"ack":false,"time":1751970943451},"_id":87903700} disconnected
    zigbee.0
    2025-07-08 12:35:43.455	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":326,"ack":false,"time":1751970943451},"_id":87903700}
    zigbee.0
    2025-07-08 12:35:43.454	debug	readNvBackup returns {"channel":11,"precfgkey":"01030507090b0d0f00020406080a0c0d","extPanID":"dddddddddddddddd","panID":6754}
    zigbee.0
    2025-07-08 12:35:43.453	debug	readNvBackup called
    zigbee.0
    2025-07-08 12:34:29.316	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"f87fbb8463c9eb11b1448b4f1d69213e","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87fbb8463c9eb11b1448b4f1d69213e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    zigbee.0
    2025-07-08 12:34:29.249	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":313,"ack":false,"time":1751970869173},"_id":87903687} disconnected
    zigbee.0
    2025-07-08 12:34:29.200	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":313,"ack":false,"time":1751970869173},"_id":87903687}
    zigbee.0
    2025-07-08 12:34:29.200	debug	readNvBackup returns {"channel":11,"precfgkey":"01030507090b0d0f00020406080a0c0d","extPanID":"dddddddddddddddd","panID":6754}
    zigbee.0
    2025-07-08 12:34:29.199	debug	readNvBackup called
    zigbee.0
    2025-07-08 12:33:27.911	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2025_07_08-12_33_27.tar.gz success
    zigbee.0
    2025-07-08 12:33:27.901	warn	Zigbee autostart option not set - omitting start of zigbee substystem!
    zigbee.0
    2025-07-08 12:33:27.901	info	--- creating device debug ---
    zigbee.0
    2025-07-08 12:33:27.900	info	delete old Backup files. keep only last 10
    zigbee.0
    2025-07-08 12:33:27.878	info	init localConfig
    zigbee.0
    2025-07-08 12:33:27.877	info	Adapter ready - starting subsystems. Adapter is running in debug mode.
    zigbee.0
    2025-07-08 12:33:27.865	info	starting. Version 3.0.2 (non-npm: ioBroker/ioBroker.zigbee#ZHC_latest) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.3, js-controller: 7.0.6
    zigbee.0
    2025-07-08 12:33:27.708	debug	Plugin sentry Initialize Plugin (enabled=true)
    zigbee.0
    2025-07-08 12:33:27.662	debug	States connected to redis: 127.0.0.1:9000
    zigbee.0
    2025-07-08 12:33:27.553	debug	States create User PubSub Client
    zigbee.0
    2025-07-08 12:33:27.553	debug	States create System PubSub Client
    zigbee.0
    2025-07-08 12:33:27.517	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    zigbee.0
    2025-07-08 12:33:27.461	debug	Objects connected to redis: 127.0.0.1:9001
    zigbee.0
    2025-07-08 12:33:27.458	debug	Objects client initialize lua scripts
    zigbee.0
    2025-07-08 12:33:27.315	debug	Objects create User PubSub Client
    zigbee.0
    2025-07-08 12:33:27.314	debug	Objects create System PubSub Client
    zigbee.0
    2025-07-08 12:33:27.314	debug	Objects client ready ... initialize now
    zigbee.0
    2025-07-08 12:33:27.266	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iOBroker
    2025-07-08 12:33:26.674	info	instance system.adapter.zigbee.0 in version "3.0.2" (non-npm: ioBroker/ioBroker.zigbee#ZHC_latest) started with pid 38528
    leider kann ich damit nichts anfangen und in der Doku finde ich auch nix drüber oder ich bin blind. sorry
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @denjo warum lässt du den Adapter in debug laufen? Dafür gibt es prinzipiell überhaupt keinen Grund. Der zickt Adapter sollte ausschließlich dann in debug laufen, wenn ein Entwickler explizit danach gefragt hat. Die Menge Anmeldung, die in dieser Situation erzeugt wird, ist so groß, dass sie eher verwirrt als hilft.
    Keine der Meldungen sind in irgendeiner Form relevant für dein Gerät. Das Version von GitHub und aus dem latest zusätzliche Meldungen bringen ist normal. Es sind Entwicklerversionen.
    So wie ich das sehe, reicht es nicht die 3.0.2 zu installieren, sondern du musst von GitHub den ZHC _ Latest branch installieren, in diesem sollte die Lampe unterstützt sein.
    A.
    • D denjo
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.iOBroker
      AlexHaxe
      @denjo said in philips hue tento slim ceiling light zigbee adapter??:
      > zigbee.0
      Ich schätze mal Du hast vergessen den Haken zu setzen: https://forum.iobroker.net/topic/80644/tester-zigbee-adapter-3-x-gesucht
      zigbee.0
      Ich meine gelesen zu haben, dass es nicht ratsam ist, wenn die extPanID auf dddddddddddddddd steht. Konnte aber auf die Schnelle keine belastbare Quelle finden.
      D arteckA 2 Antworten Letzte Antwort
      • A AlexHaxe
        > zigbee.0
        zigbee.0
        denjo
        @alexhaxe geil dankeee, es lag an dem haken. vielen dank
        • A AlexHaxe
          > zigbee.0
          zigbee.0
          arteckA Offline
          arteckA Offline
          arteck
          @alexhaxe sagte in philips hue tento slim ceiling light zigbee adapter?? "erl":
          so ist es auch.. aber wenn das Netz schon so aufgebaut worden ist .. dann muss es so bleiben.. ausser man hat bock alles neu aufzubauen
          • D denjo
            arteckA Offline
            arteckA Offline
            arteck
            @denjo also läuft es jetzt.. funktioniert dein Gerät auch ?? wenn nicht neu pairen bitte
            • arteckA arteck
              denjo
              @arteck läuft alles perfekt, danke für die hilfe
