  4. Backup wiederherstellen auf js-controller 4.0
    3.1k
    3.0k
32 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • X xT1GeRx
    @homoran ich habe mal die warnings rausgesucht. Die Liste ist aktuell über 1000 Zeilen Lang.
    2025-06-09 17:56:41.710  - error: admin.0 (2990) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2025-06-09 17:56:42.746  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user resarts it.
    2025-06-09 17:57:31.161  - warn: host.iobroker startInstance cannot find adapter "javascript@6.0.3". Try to install it... 1 attempt
    2025-06-09 18:00:28.860  - error: admin.0 (3429) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2025-06-09 18:00:29.853  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
    2025-06-09 18:11:13.453  - error: admin.0 (4020) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2025-06-09 18:11:13.455  - info: admin.0 (4020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-06-09 18:11:13.768  - info: admin.0 (4020) Request actual repository...
    2025-06-09 18:11:14.024  - warn: admin.0 (4020) Cannot check node.js/npm version
    2025-06-09 18:11:14.048  - info: admin.0 (4020) terminating http server on port 8081
    2025-06-09 18:11:14.533  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
    2025-06-09 18:27:24.227  - error: admin.0 (4479) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2025-06-09 18:27:24.230  - info: admin.0 (4479) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-06-09 18:27:24.501  - info: admin.0 (4479) Request actual repository...
    2025-06-09 18:27:24.778  - warn: admin.0 (4479) Cannot check node.js/npm version
    2025-06-09 18:27:25.039  - info: admin.0 (4479) terminating http server on port 8081
    2025-06-09 18:27:25.449  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
    2025-06-09 18:27:25.514  - info: host.iobroker Do not restart adapter system.adapter.admin.0 because desired by instance
    2025-06-09 18:27:26.456  - info: backitup.0 (4506) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.2, js-controller: 4.0.23
    2025-06-09 18:27:26.557  - info: backitup.0 (4506) [iobroker] backup was activated at 02:30 every 1 day(s)
    Wie es aussieht gibt es ein Problem mit dem Admin Web Zugang oder?
    HomoranH Offline
    HomoranH Offline
    @xt1gerx sagte in Backup wiederherstellen auf js-controller 4.0:
    uninteressant!
    es geht um die gerade aktuellen Meldungen!
    die geposteten sind ja "uralt"
    • X xT1GeRx
      @xt1gerx
      Ist das Backup jetzt drin?
      Dann musst du jetzt den Rest in die Gegenwart holen.
      Inkl. des js-controllers@7 dann.
      X 1 Antwort Letzte Antwort
      • X Offline
        X Offline
        xT1GeRx
        @Thomas-Braun
        aktuell die letzten. Kann auch die komplette Liste einfügen?
        2025-06-09 18:27:24.286  - info: host.iobroker instance system.adapter.backitup.0 started with pid 4506
        2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
          @xt1gerx
          X Offline
          X Offline
          xT1GeRx
          @thomas-braun ich würde sagen das das backup geladen ist. Verstehe ich das richtig, dass ich zuerst alles updaten soll bevor der Webzugang wieder geht? Wenn ja, hättest du mir eine sichere anleitung, bevor ich wieder was versaue?
          • X xT1GeRx
            @xt1gerx
            Dann lass uns doch mal sehen, wo du da nun stehst.
            iob diag
            anschauen.
              @xt1gerx
              iob diag
              anschauen.
              X Offline
              X Offline
              xT1GeRx
              @thomas-braun alles war rauskam
              ```bash
              Script v.2025-03-08
              *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer
                        Kernel: Linux 6.12.25+rpt-rpi-v8
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               19:01:35 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Mon 2025-06-09 19:01:35 CEST
                         Universal time: Mon 2025-06-09 17:01:35 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              admin
              HOME=/home/admin
              GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              *** DISPLAY-SERVER SETUP ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        385M        1.8G        6.2M        1.9G        3.6G
              Swap:           536M          0B        536M
              Total:          4.5G        385M        2.3G
              Active iob-Instances:   2
                       3791 M total memory
                        367 M used memory
                        406 M active memory
                       1464 M inactive memory
                       1712 M free memory
                         99 M buffer memory
                       1693 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              top - 19:01:36 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
              Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3791.4 total,   1712.3 free,    367.5 used,   1793.1 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3423.9 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     380M  5.9M  374M   2% /run
              /dev/mmcblk0p2 ext4      117G  4.1G  107G   4% /
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Mon Jun  9 16:30:57 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm28        35.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  c        onsole=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Mon Jun  9 16:30:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
              [Mon Jun  9 16:31:00 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              889M    /var/
              213M    /var/cache
              208M    /var/cache/apt
              164M    /var/lib
              135M    /var/lib/apt/lists
              Archived and active journals take up 4.7M in the file system.
              /opt/iobroker/backups:
              11M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              198M    /opt/iobroker/iobroker-data/
              169M    /opt/iobroker/iobroker-data/files
              48M     /opt/iobroker/iobroker-data/files/javascript.admin
              47M     /opt/iobroker/iobroker-data/files/admin.admin
              46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
              26M     /opt/iobroker/iobroker-data/objects.jsonl
              12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
              8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
              6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
              4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3476-if00
              *** ZigBee Settings ***
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.19.2
              /usr/bin/node           v20.19.2
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.31.0
              nodejs:
                Installed: 20.19.2-1nodesource1
                Candidate: 20.19.2-1nodesource1
                Version table:
               *** 20.19.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.19.1-1nodesource1 1001
                   20.19.0-1nodesource1 1001
                   20.18.3-1nodesource1 1001
                   20.18.2-1nodesource1 1001
                   20.18.1-1nodesource1 1001
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker            iobroker (version: 4.0.23, hostname: iobroker      , alive, uptime: 2058)
              Core adapters versions
              admin:          6.3.5
              javascript:     6.0.3
              nodejs modules from github:     0
              Adapter State
                system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                system.adapter.hmip.0                   : hmip                  : iobroker                                 - disabled
                system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 443
                system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
                system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "admin"        : 7.6.17   , installed 6.3.5  [Updatable]
              Adapter    "backitup"     : 3.2.2    , installed 2.5.12 [Updatable]
              Adapter    "birthdays"    : 4.0.0    , installed 2.2.0  [Updatable]
              Adapter    "daswetter"    : 3.2.3    , installed 3.1.7  [Updatable]
              Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
              Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
              Adapter    "fullybrowser" : 3.1.1    , installed 2.1.2  [Updatable]
              Adapter    "hmip"         : 1.27.0   , installed 1.20.0 [Updatable]
              Adapter    "hue"          : 3.16.1   , installed 3.7.1  [Updatable]
              Adapter    "javascript"   : 8.9.2    , installed 6.0.3  [Updatable]
              Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
              Adapter    "pollenflug"   : 2.0.0    , installed 1.0.6  [Updatable]
              Adapter    "pushover"     : 4.1.0    , installed 3.0.3  [Updatable]
              Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
              Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
              Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
              Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
              Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
              Adapter    "vis-icontwo"  : 1.11.0   , installed 0.90.0 [Updatable]
              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.1  [Updatable]
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
              Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
              Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
              Adapter    "zigbee"       : 2.0.5    , installed 1.8.10 [Updatable]
              Objects and States
              Objects:        8811
              States:         7998
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists... Done
              Pending Updates: 48
              2025-06-09 18:27:17.755  - info: host.iobroker hostname: iobroker, node: v20.19.2
              2025-06-09 18:27:17.757  - info: host.iobroker ip addresses: 192.168.178.37 2003:d0:6700:2e00:d638:5401:7be0:ba73 fe80::76d4:1422:ca5b:b545
              2025-06-09 18:27:19.448  - info: host.iobroker connected to Objects and States
              2025-06-09 18:27:19.500  - info: host.iobroker added notifications configuration of host
              2025-06-09 18:27:20.179  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
              2025-06-09 18:27:20.181  - info: host.iobroker 22 instances found
              2025-06-09 18:27:20.218  - info: host.iobroker starting 2 instances
              2025-06-09 18:27:20.313  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
              2025-06-09 18:27:20.328  - info: host.iobroker instance system.adapter.admin.0 started with pid 4479
              2025-06-09 18:27:20.340  - info: host.iobroker Some obsolete host states deleted.
              2025-06-09 18:27:22.763  - info: admin.0 (4479) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.2, js-controller: 4.0.23
              2025-06-09 18:27:22.809  - info: admin.0 (4479) requesting all states
              2025-06-09 18:27:22.810  - info: admin.0 (4479) requesting all objects
              2025-06-09 18:27:24.173  - info: admin.0 (4479) received all objects
              2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user res        tarts it.
              iob diag has finished.
              • X xT1GeRx
                ```bash
                Script v.2025-03-08
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                admin
                HOME=/home/admin
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           536M          0B        536M
                         3791 M total memory
                          367 M used memory
                          406 M active memory
                         1712 M free memory
                           99 M buffer memory
                         1693 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                *** FILESYSTEM ***
                /var:
                889M    /var/
                213M    /var/cache
                208M    /var/cache/apt
                164M    /var/lib
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          6.3.5
                javascript:     6.0.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        8811
                States:         7998
                Pending Updates: 48
                @xt1gerx
                Also alles updatebar.
                Mit dem System selber anfangen:
                iob stop
                sudo apt update && sudo apt full-upgrade
                sudo reboot
                Dann den ioBroker in Angriff nehmen:
                iob update
                iob upgrade all
                Das wird vermutlich nicht ohne Fehlermeldungen durchlaufen. Aber egal.
                Dann
                iob stop
                iob upgrade self
                iob start
                iob update
                iob upgrade all
                versuchen. Wenn das nicht in einem Rutsch den js-controller@7 auf die Kiste spült, dann versuchen wir es mit Schriten über js-controller@5 und @6.
                  @xt1gerx
                  iob stop
                  sudo reboot
                  iob update
                  iob upgrade all
                  Dann
                  iob stop
                  iob upgrade self
                  iob start
                  iob update
                  iob upgrade all
                  X Offline
                  X Offline
                  xT1GeRx
                  @thomas-braun Hat alles geklappt. Js auf 7 und node v20. Alle Updates ohne Fehlermeldung. Komme überall drauf und alles ist vorhanden wie davor.
                  VIELEN VIELEN DANK für deine Hilfe und Zeit @thomas-braun 🎉
                  • X xT1GeRx
                    @xt1gerx
                    Gut gut.
                    Dann zeig mal zum Abschluß nochmal ein
                    iob diag
                    Für die Zukunft: Lass das System nicht mehr versumpfen.
                    Man muss nicht eine Version x.0 am ersten Tag installieren, aber eine x.1 sollte man dann schon beizeiten mitnehmen.
                      @xt1gerx
                      Gut gut.
                      iob diag
                      X Offline
                      X Offline
                      xT1GeRx
                      ```bash
                      Script v.2025-03-08
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       20:21:41 up  1:02,  1 user,  load average: 0.22, 0.21, 0.20
                      CPU threads: 4
                      Current issues:
                                     Local time: Mon 2025-06-09 20:21:42 CEST
                                 Universal time: Mon 2025-06-09 18:21:42 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      admin
                      HOME=/home/admin
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.0G        1.4G        1.0G        6.2M        1.7G        2.6G
                      Swap:           536M          0B        536M
                      Total:          4.5G        1.4G        1.5G
                      Active iob-Instances:   15
                               3797 M total memory
                               1357 M used memory
                               1340 M active memory
                               1294 M inactive memory
                                958 M free memory
                                 72 M buffer memory
                               1501 M swap cache
                                511 M total swap
                                  0 M used swap
                                511 M free swap
                      top - 20:21:42 up  1:02,  1 user,  load average: 0.22, 0.21, 0.20
                      Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3797.4 total,    956.8 free,   1359.0 used,   1574.6 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2438.4 avail Mem
                      *** FILESYSTEM ***
                      /dev/mmcblk0p2 ext4      117G  4.2G  107G   4% /
                      [Mon Jun  9 19:19:06 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_h                                     eadphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size                                     =0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Mon Jun  9 19:19:07 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                      [Mon Jun  9 19:19:08 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                      /var:
                      890M    /var/
                      214M    /var/cache
                      208M    /var/cache/apt
                      164M    /var/lib
                      235M    /opt/iobroker/iobroker-data/
                      194M    /opt/iobroker/iobroker-data/files
                      32M     /opt/iobroker/iobroker-data/objects.jsonl
                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                      9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                      8.9M    /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 3429)
                      js-controller:  7.0.6
                      admin:          7.6.17
                      javascript:     8.9.2
                      Adapter State
                        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled
                      + instance is alive
                      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 400
                      Upgrade policy: none
                      Adapter    "admin"        : 7.6.17   , installed 7.6.17
                      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
                      Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
                      Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                      Adapter    "hue"          : 3.16.1   , installed 3.16.1
                      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                      Controller "js-controller": 7.0.6    , installed 7.0.6
                      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                      Objects and States
                      Objects:        8929
                      States:         8070
                      Pending Updates: 1
                      Danke nochmals. Ich werde es jetzt nicht mehr schleifen lassen mit den Updates.
                      • X xT1GeRx
                        ```bash
                        Script v.2025-03-08
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        admin
                        HOME=/home/admin
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           536M          0B        536M
                                 3797 M total memory
                                 1357 M used memory
                                  958 M free memory
                                   72 M buffer memory
                                 1501 M swap cache
                                  511 M total swap
                                    0 M used swap
                                  511 M free swap
                        *** FILESYSTEM ***
                        /var:
                        890M    /var/
                        214M    /var/cache
                        208M    /var/cache/apt
                        164M    /var/lib
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        8929
                        States:         8070
                        Pending Updates: 1
                        Pending Updates: 1
                        Da hängt noch was im Update.
                        sudo apt update
                          Pending Updates: 1
                          sudo apt update
                          X Offline
                          X Offline
                          xT1GeRx
                          @thomas-braun ist mir nicht aufgefallen. Danke. Erledigt.
                          admin@iobroker:~ $ sudo apt update
                          Building dependency tree... Done
                          All packages are up to date.
