  4. System & Admin Upgrade "exited with code 25" Start-Schleife?
    6.4k
75 Beiträge 3 Kommentatoren 7.8k Aufrufe 3 Beobachtet
  • A adarof
    @thomas-braun sagte in System & Admin Upgrade "exited with code 25" Start-Schleife?:
    npm ls npm ls graceful-fs
    Oh - das scheint ein guter Ansatz.
    hier
    iobroker.inst@2.0.2 /opt/iobroker
    ├── @iobroker-javascript.0/klf-200-api@npm:klf-200-api@6.0.1
    ├── @iobroker-javascript.0/node-fetch@npm:node-fetch@2.7.0
    ├── buffer-shims@1.0.0 extraneous
    ├── colors@1.4.0
    ├── decimal.js@10.6.0 extraneous
    ├── fs-extra@7.0.1
    ├── futoin-hkdf@1.4.3 extraneous
    ├── homebridge-plugin-wrapper@3.2.0 extraneous
    ├── iobroker.admin@7.7.2
    ├── iobroker.alexa2@3.27.3
    ├── iobroker.amazon-dash@1.2.0
    ├── iobroker.backitup@3.3.5
    ├── iobroker.daswetter@3.2.3
    ├── iobroker.device-watcher@2.13.1
    ├── iobroker.discovery@5.0.0
    ├── iobroker.dwd@2.8.5
    ├── iobroker.easee@1.0.10
    ├── iobroker.email@2.0.4
    ├── iobroker.evcc@0.2.4 invalid: "github:Newan/ioBroker.evcc" from the root project
    ├── iobroker.flot@1.12.0
    ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
    ├── iobroker.ham@5.3.1
    ├── iobroker.history@3.0.1
    ├── iobroker.hm-rega@5.1.0
    ├── iobroker.hm-rpc@2.0.2
    ├── iobroker.homeconnect@1.4.3
    ├── iobroker.ical@1.17.0
    ├── iobroker.icons-addictive-flavour-png@0.1.0
    ├── iobroker.icons-material-png@0.1.0
    ├── iobroker.icons-mfd-png@1.2.1
    ├── iobroker.icons-mfd-svg@1.2.0
    ├── iobroker.javascript@8.9.2
    ├── iobroker.js-controller@7.0.7
    ├── iobroker.lg-thinq@1.1.2
    ├── iobroker.material@1.3.1
    ├── iobroker.matter@0.5.5
    ├── iobroker.mielecloudservice@6.5.10
    ├── iobroker.mobile@1.0.1
    ├── iobroker.modbus@6.3.2
    ├── iobroker.nina@0.0.25
    ├── iobroker.nut@1.6.0
    ├── iobroker.opendtu@3.1.0
    ├── iobroker.parser@2.2.4
    ├── iobroker.ping@1.6.2
    ├── iobroker.pvforecast@5.0.0
    ├── iobroker.rickshaw@1.0.0
    ├── iobroker.simple-api@2.8.0
    ├── iobroker.socketio@6.7.1
    ├── iobroker.sonoff@3.2.1
    ├── iobroker.sql@3.0.1
    ├── iobroker.statistics@2.4.0
    ├── iobroker.syrconnect@0.1.1 invalid: "github:eifel-tech/ioBroker.syrconnect#f6d0efe93eed9eb985fab54eeda2afd0b66f9f28" from the root project
    ├── iobroker.telegram-menu@2.4.4
    ├── iobroker.telegram@4.1.0
    ├── iobroker.text2command@3.0.3
    ├── iobroker.tr-064@4.3.0
    ├── iobroker.tuya@3.16.0
    ├── iobroker.unifi@0.7.0
    ├── iobroker.vis-bars@0.1.4
    ├── iobroker.vis-canvas-gauges@1.0.1
    ├── iobroker.vis-colorpicker@2.0.3
    ├── iobroker.vis-fancyswitch@1.1.0
    ├── iobroker.vis-history@1.0.0
    ├── iobroker.vis-hqwidgets@1.5.1
    ├── iobroker.vis-jqui-mfd@1.1.1
    ├── iobroker.vis-metro@1.2.0
    ├── iobroker.vis-rgraph@0.0.2
    ├── iobroker.vis-timeandweather@1.2.2
    ├── iobroker.vis@1.5.6
    ├── iobroker.vw-connect@0.6.0
    ├── iobroker.waterkotte-easycon@0.0.3 invalid: "github:theknut/ioBroker.waterkotte-easycon#d8c7921fcfde98465e481a4780ad4c0e73375c31" from the root project
    ├── iobroker.web@7.0.8
    ├── iobroker.wiegand-tcpip@0.4.7
    ├── iobroker.ws@2.6.2
    ├── iobroker@2.0.3
    ├── mock-require@3.0.3 extraneous
    ├── node-persist@0.0.11 extraneous
    ├── q@1.1.2 extraneous
    ├── remove-trailing-separator@1.1.0 extraneous
    ├── semver@5.7.2
    ├── string-argv@0.3.2 extraneous
    └── yargs@7.1.2
    npm error code ELSPROBLEMS
    npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
    npm error extraneous: decimal.js@10.6.0 /opt/iobroker/node_modules/decimal.js
    npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
    npm error extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
    npm error invalid: iobroker.evcc@0.2.4 /opt/iobroker/node_modules/iobroker.evcc
    npm error invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
    npm error invalid: iobroker.syrconnect@0.1.1 /opt/iobroker/node_modules/iobroker.syrconnect
    npm error invalid: iobroker.waterkotte-easycon@0.0.3 /opt/iobroker/node_modules/iobroker.waterkotte-easycon
    npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
    npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
    npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
    npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
    npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-09T19_07_41_606Z-debug-0.log
    /opt/iobroker$ npm ls graceful-fs
    ├─┬ fs-extra@7.0.1
    │ ├── graceful-fs@4.2.11
    │ └─┬ jsonfile@4.0.0
    │   └── graceful-fs@4.2.11 deduped
    ├─┬ homebridge-plugin-wrapper@3.2.0 extraneous
    │ ├─┬ fs-extra@10.1.0 extraneous
    │ │ └── graceful-fs@4.2.11 deduped
    │ └─┬ jsonfile@6.2.0 extraneous
    ├─┬ iobroker.admin@7.7.2
    │ └─┬ archiver@7.0.1
    │   └─┬ archiver-utils@5.0.2
    ├─┬ iobroker.backitup@3.3.5
    │ └─┬ fs-extra@11.3.2
    │   ├── graceful-fs@4.2.11 deduped
    ├─┬ iobroker.ham@5.3.1
    │ └─┬ homebridge-plugin-wrapper@3.2.0
    │   └─┬ fs-extra@10.1.0
    ├─┬ iobroker.js-controller@7.0.7
    │ ├─┬ @iobroker/db-objects-file@7.0.7
    │ │ ├─┬ @iobroker/db-base@7.0.7
    │ │ │ └─┬ fs-extra@11.3.2
    │ │ │   ├── graceful-fs@4.2.11 deduped
    │ │ │   └─┬ jsonfile@6.2.0
    │ │ │     └── graceful-fs@4.2.11 deduped
    │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
    │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
    │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
    │ │ │ │ └── graceful-fs@4.2.11 deduped
    │ │ │ └─┬ fs-extra@10.1.0
    │ ├─┬ @iobroker/js-controller-adapter@7.0.7
    │ │ ├─┬ @alcalzone/pak@0.8.1
    │ ├─┬ @iobroker/js-controller-cli@7.0.7
    │ ├─┬ @iobroker/js-controller-common-db@7.0.7
    │ ├─┬ @iobroker/js-controller-common@7.0.7
    ├─┬ iobroker.matter@0.5.5
    │ └─┬ @matter/nodejs-ble@0.15.6
    │   └─┬ @stoprocent/bleno@0.11.4
    │     └─┬ @stoprocent/bluetooth-hci-socket@2.2.3
    │       └─┬ patch-package@8.0.1
    │         └─┬ klaw-sync@6.0.0
    ├─┬ iobroker.simple-api@2.8.0
    │ └─┬ @iobroker/testing@4.1.3
    ├─┬ iobroker.sql@3.0.1
    │ └─┬ sqlite3@5.1.7
    │   └─┬ node-gyp@8.4.1
    ├─┬ iobroker.telegram-menu@2.4.4
    │ └─┬ nyc@17.1.0
    │   └─┬ caching-transform@4.0.0
    │     └─┬ package-hash@4.0.0
    ├─┬ iobroker.tuya@3.16.0
    └─┬ yargs@7.1.2
      └─┬ read-pkg-up@1.0.1
        └─┬ read-pkg@1.1.0
          ├─┬ load-json-file@1.1.0
          └─┬ path-type@1.1.0
    Da sind ja eingie Fehler. Was kann ich dagegen tun?
    Gruss -
    #61
    @adarof
    Die ganzen als 'invalid' gekennzeichneten Adapter mal ordentlich über ein Repo installieren und halt NICHT aus dem GitHub fischen. Macht man grundsätzlich nicht.
    A 1 Antwort Letzte Antwort
      @adarof sagte in System & Admin Upgrade "exited with code 25" Start-Schleife?:
      da laufen noch 1001 andere Sachen drauf, die ich alle nurnoch marginal weiss, wie sie zu konfigurieren sind.
      Das ist schlecht. Was machste denn, wenn das Ding aus anderen Gründen die Grätsche macht.
      Upgraden musste die Kiste eh mal irgendwann.
      adarof
      #62
      @thomas-braun Naja - Upgraden & hoffen ... Backups von allem sind schon vorhanden, aber ich muss halt jeweils mich neu einlesen, wenn es eine Neuinstallation ist.
        @adarof
        adarof
        #63
        Okay - räume ich auf.
        Viele nutze ich garnicht (mehr) ... keine Instanzen vorhanden
        Danke für heute erstmal.
        Gruss - Henning
        • A adarof
          Gruss - Henning
          #64
          @adarof
          Ziel sollte es sein, das in der Übersicht nichts anderes als die Adapter auftauchen. So wie hier:
          echad@chet:/opt/iobroker $ npm ls
          iobroker.inst@3.0.0 /opt/iobroker
          ├── iobroker.admin@7.7.19
          ├── iobroker.alexa2@3.27.4
          ├── iobroker.alias-manager@2.0.0
          ├── iobroker.ankersolix2@2.4.1
          ├── iobroker.awtrix-light@3.0.0
          ├── iobroker.backitup@3.3.10
          ├── iobroker.ble@0.14.1
          ├── iobroker.cloud@5.1.2
          ├── iobroker.devices@1.2.9
          ├── iobroker.echarts@2.0.10 (git+ssh://git@github.com/Grothesk242/ioBroker.echarts.git#7e00a1c9e78e378443ceac4396eeba04f7b7e73f)
          ├── iobroker.firetv@2.1.0
          ├── iobroker.followthesun@0.5.2
          ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
          ├── iobroker.govee-local@0.4.2
          ├── iobroker.ical@1.18.1
          ├── iobroker.iceroad@1.2.1
          ├── iobroker.iot@5.0.7
          ├── iobroker.javascript@9.0.11
          ├── iobroker.mihome-cloud@0.1.1 (git+ssh://git@github.com/TA2k/ioBroker.mihome-cloud.git#7b814e73970205d15ad9ba2af459c6a30d20af73)
          ├── iobroker.mihome-vacuum@5.3.0
          ├── iobroker.mihome@1.4.0
          ├── iobroker.mqtt@6.1.4
          ├── iobroker.nina@0.0.26
          ├── iobroker.notification-manager@1.3.0
          ├── iobroker.nuki-extended@2.7.0
          ├── iobroker.nut@1.7.0
          ├── iobroker.openweathermap@1.4.0
          ├── iobroker.parcel@0.2.10 (git+ssh://git@github.com/Grothesk242/ioBroker.parcel.git#e1c8a5a73c93b208eb8cd54015d059a865b87ec9)
          ├── iobroker.playstation@0.0.3
          ├── iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#4520729d0399a57717ea36573d39a726b120a048)
          ├── iobroker.sainlogic@0.12.1
          ├── iobroker.samsung_tizen@1.1.0
          ├── iobroker.samsung@0.6.1
          ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
          ├── iobroker.tado@0.8.2
          ├── iobroker.tankerkoenig@3.4.0
          ├── iobroker.tradfri@3.1.3
          ├── iobroker.trashschedule@4.0.1
          ├── iobroker.tuya@3.17.0
          ├── iobroker.weather-warnings@0.9.0
          ├── iobroker.web@7.0.9
          ├── iobroker.whatsapp-cmb@0.3.0
          └── iobroker.zigbee@3.2.5
          Edit: Ja, hier sind auch GitHub-Installationen dabei. Die sind aber bewusst da in genau diesem Zustand drin.
            @adarof
            adarof
            #65
            Kann ich diese "subadapter" oder Erweiterungen wie "klf-200-api" vom javascript manuell auf der commandozeile auch irgendwie löschen, also analog zu "iob del <adapter>" ?
            Aktuell wird immer
            npm uninstall @iobroker-javascript.0/klf-200-api
            aufgerufen und das läuft halt super-lange und kommt anscheinend auch nicht zum ende, denn es wird halt immer wieder aufgerufen.
            • A adarof
              Aktuell wird immer
              #66
              @adarof
              Das kommt solange, bis das erfolgreich kompiliert werden konnte.
              Oder der Adapter, der dieses Modul benötigt sauber deinstalliert wurde.
                @adarof
                adarof
                #67
                @thomas-braun Ich hab das beim js-controller aus den Einstellungen gelöscht - vermutlich soll es deswegen nun auch uninstall-ed werden. Kann ich das auf NPM Ebene manuell machen? Von mir aus auch erstmal installieren um es dann geordnet zu uninstallieren.
                • A adarof
                  #68
                  @adarof
                  Was zum Henker tust du da?
                  Was löschst du da wo raus?
                  Beim js-controller? Ich hoffe du meinst damit ein 'zusätzliches npm-Modul' im javascript-Adapter.
                    @adarof
                    adarof
                    #69
                    @thomas-braun Ja - genau in der Konfig-Oberfläche, wo man die zusätzlichen Module in die Zeile schreiben kann. sorry. Ich hab gerade keine Oberfläche um die richtigen Wörter zu nehmen
                    • A adarof
                      #70
                      @adarof
                      cd /opt/iobroker && npm ls @iobroker-javascript.0/klf-200-api
                      sagt?
                        @adarof
                        sagt?
                        adarof
                        #71
                        └── @iobroker-javascript.0/klf-200-api@npm:klf-200-api@6.0.1
                        • A adarof
                          #72
                          @adarof
                          Immer vollständig posten.
                          Inkl. vollständigem Prompt und der neuen Eingabezeile. Damit man sieht ob das vollständig ist.
                            @adarof
                            adarof
                            #73
                            hmersch@RoofServer:/opt/iobroker$ cd /opt/iobroker && npm ls @iobroker-javascript.0/klf-200-api
                            • A adarof
                              #74
                              npm uninstall @iobroker-javascript.0/klf-200-api@npm:klf-200-api
                              Wobei sich das mit Sicherheit wieder reinsetzt, solange das im javascript-Adapter noch eingetragen ist.
                                adarof
                                #75
                                Nun ist iob gerade wieder erfolgreich gestartet.
                                Da war mal klf-200-api eingetragen.
                                Ich deinstalliere das manuell wie von Dir geschrieben als nächsten Versuch
                                (aber erstmal übernachte ich mit dem aktuellen Lauf ;-) )
                                DANKE
