  4. Problem mit email-Adaper V2.02
    1.0k
    6.1k
email error
15 Beiträge 4 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • joergeliJ Online
    joergeliJ Online
    joergeli
    • Adaptername: email
    • Link zu Adapterrepository: https://github.com/iobroker-community-adapters/ioBroker.email/issues/331
    • Adapterversion: V2.02 ( von beta-repository )
    • js-controller Version: 7.06
    • Admin Version: 7.6.2
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: ...8GB
    • Festplattenart: SD-Karte
    • Betriebssystem: Linux
    • Nodejs-Version: 20.19.0
    • NPM-Version: 10.8.2
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    unglücklicherweise kann ich keine emails mit dem email-Adapter V2.0.2 aus iobroker mehr versenden.
    Weder die "Test-Mail", noch "normale" Mails werden gesendet, Ich bekomme immer diese Fehler:
    email.0 2025-03-15 13:41:40.022	error	Cannot send email: Error: * OK [CAPABILITY IMAP4 IMAP4rev1 QUOTA LITERAL+ NAMESPACE UIDPLUS IDLE SORT] IMAP Proxy ready (secureimap.t-online.de)
    email.0 2025-03-15 13:41:40.020	error	Error * OK [CAPABILITY IMAP4 IMAP4rev1 QUOTA LITERAL+ NAMESPACE UIDPLUS IDLE SORT] IMAP Proxy ready (secureimap.t-online.de)
    email.0 2025-03-15 13:41:39.846	info	Send email: {"subject":"ioBroker-Nachricht","to":"bxxxxxxxx@t-online.de","from":"iobroker@joergeli.de","text":"This is a test email from ioBroker!"}
    email.0 2025-03-15 13:41:39.845	warn	From email address is not equal to the configured email address for authentication. Some services do not allow this!
    admin.0 2025-03-15 13:41:38.044	warn	email has an invalid jsonConfig: [{"instancePath":"/items/tab-main/items/_microsoft","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"bundlerType"},"message":"must NOT have additional properties"},{"instancePath":"/items/tab-main/items/_microsoft","schemaPath":"#/patternProperties/%5E.%2B/allOf/16/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/tab-main","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    (Wobei die Warnmeldungen wohl nicht relevant sind?)
    Meine bisherigen Lösungsversuche:
    Ich habe den email-Adapter V2.0.2 kpl. gelöscht und anschl. reinstalliert --> Fehler bleibt bestehen
    Dann habe ich ein Downgrade auf email-Adapter V1.4.0 gemacht und jetzt ebenfalls Fehlermeldung bekommen:
    email.0 2025-03-15 14:06:54.536	error	Error * OK [CAPABILITY IMAP4 IMAP4rev1 QUOTA LITERAL+ NAMESPACE UIDPLUS IDLE SORT] IMAP Proxy ready (secureimap.t-online.de)
    email.0 2025-03-15 14:06:54.273	info	Send email: {"subject":"ioBroker-Nachricht","to":"bxxxxx@t-online.de","from":"iobroker@joergeli.de","text":"This is a test email from ioBroker!","service":""}
    (Hinweis: email-Empfänger hier unkenntlich gemacht)
    Ein issue habe ich bereits erstellt
    Hat evtl. von euch jemand noch eine Idee?
    OliverIOO mcm1957M 2 Antworten Letzte Antwort
    • joergeliJ joergeli
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @joergeli
      Liegt es evtl. an dieser Meldung?
      Ist deine absendersdresse ungleich der email mit der du dich anmeldest?
      Um den versandt von Spam mails mit falscher absenderadresse zu vermeiden wird das meist reguliert.
      Meine Adapter und Widgets
      Links im Profil
      joergeliJ 1 Antwort Letzte Antwort
      • OliverIOO OliverIO
        @joergeli
        joergeliJ Online
        joergeliJ Online
        joergeli
        @oliverio
        Keine Ahnung, unter den email-Verbindungseinstellungen habe meine normale email-Adresse bxxxxxx@t-online.de eingetragen. Bei den Standardeinstellungen ebenfalls.
        Ich weiß aber nicht, was
        bedeuten soll, bzw. wo ich die "configured email adress" eintragen soll
          @oliverio
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @joergeli
          Als from hast du iobroker@joergeli.de eingetragen, sofern du das nicht auch editiert hast.
          Wenn das nicht deiner anmelde email oder eine der erlaubten email Adressen entspricht (manchmal kann man ja auch mehrere email Accounts anmelden, da kenne ich deinen Provider nicht)
          Ist das das Problem.
          Setze die from Adresse auf deine anmelde email Adresse, dann müsste es gehen.
          Links im Profil
            @joergeli
            joergeliJ Online
            joergeliJ Online
            joergeli
            @oliverio
            Ich habe jetzt bei von/from ebenfalls bxxxxxx@t-online.de eingetragen, Fehlermeldung bleibt aber und email wird nicht gesendet.
            email.0 2025-03-16 17:10:06.372	error	Cannot send email: Error: * OK [CAPABILITY IMAP4 IMAP4rev1 QUOTA LITERAL+ NAMESPACE UIDPLUS IDLE SORT] IMAP Proxy ready (secureimap.t-online.de)
            email.0 2025-03-16 17:10:06.371	error	Error * OK [CAPABILITY IMAP4 IMAP4rev1 QUOTA LITERAL+ NAMESPACE UIDPLUS IDLE SORT] IMAP Proxy ready (secureimap.t-online.de)
            email.0 2025-03-16 17:10:06.220	info	Send email: {"subject":"ioBroker-Nachricht","to":"bxxxxxx@t-online.de","from":"bxxxxx@t-online.de","text":"This is a test email from ioBroker!"}
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @joergeli
              Ich habe mir das mal im Code angeschaut.
              Das muss sich mal der author des Adapters anschauen.
              Die Fehlermeldung wird in diesem Bereich erzeugt und zwar dann wenn in error was drin steht. Dann wird die Meldung des Dienstes, also t-online ausgegeben.
              In dieser Meldung kann ich aber nicht wirklich eine Fehlermeldung erkennen. Beidesmal lautet es ja
              • OK ....
              mit irgendwelchen zusatzinformationen.
              Warum aus irgendwelchen Gründen da in der error variable was drin steht, ist nicht so einfach, da die verwendete Bibliothek Modemacher relativ komplex ist.
              Prüfe auf jedenfall mal noch deine zugangsinformationen und die Minimum Angaben für eine email gemäß Dokumentation.
              Evtl hat hier auch jemand ein funktionierendes Skript für t-online.
              Aktuell stellen ja viele Provider auf OAuth um und wie ich gelesen habe, haben einige Email Adapter damit Schwierigkeiten die Authentifizierung auf einfache Möglichkeit zu lösen.
              Als weitere Alternative, lege bei einem anderen email Provider ein neues Account an für das dir dann ein funktionierendes Skript vorliegt
              Links im Profil
                @joergeli
                • OK ....
                joergeliJ Online
                joergeliJ Online
                joergeli
                @oliverio sagte in Problem mit email-Adaper V2.02:
                OK ....
                Stimmt, es kommt nur der "Error" ohne eigentliche Fehler-Informationen, das hinter dem "* OK ........." sind ja m.E. nur Rückmeldungen von t-online.
                Ich hatte es auch mit einer gmail-Adresse versucht, aber ebenfalls gleicher Fehler.
                Dagegen spräche aber, daß die Fehlermeldung auch beim versuchten Absetzen einer "Test-email" aus dem Adapter kommt?
                Was mich irritiert ist, daß auch ein Downgrade des Adapter V 2.0.2 auf V 1.4.0 plötzlich die gleiche Fehlermeldung bringt - nur ein Zufall ?
                Naja, mal sehen, ob mit dem Issue das Problem gelöst wird.
                Trotzdem vielen Dank für Deine Bemühungen.👍
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @joergeli said in Problem mit email-Adaper V2.02:
                  Dass der Adapter zur Zeit im BETA Test ist dir aber schon klar?
                  Die V2.0.0 ist ein MAJOR Release mit größeren Änderungen. Wird sicher noch mehr Bugs drinnen geben.
                  Danke dass du ein Issue erstellt hast. Wird sich Bluefox sicher ansehen sobald er dazu kommt.
                  @Homoran
                  Wär das Topic nicht besser im TESTER Bereich aufgehoben? 2.0.x ist ja derzeit nur BETA.
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  HomoranH joergeliJ 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    @Homoran
                    @mcm1957 sagte in Problem mit email-Adaper V2.02:
                    gibt es dazu einen Tester Thread?
                    dann würde ich das mergen
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      Nö - Bluefox erstellt keine Tester Topics.
                      Aber ich kann ja mal einen anlegen.
                      • mcm1957M mcm1957
                        @Homoran
                        joergeliJ Online
                        joergeliJ Online
                        joergeli
                        schrieb am zuletzt editiert von joergeli
                        Jepp, BETA ist mir klar, allerdings gibt es in git ein weiteres Issue Warnmeldung nach Update auf eMail-Adapter V2.0.0, wo es zwar primär um Warnmeldungen ging, @Diginix aaber geschrieben hat, daß der email-Versand bei ihm funktioniert.
                        • mcm1957M mcm1957
                          oder ich schieb diesen hier nach Tester (und gebe dir die Rechte am Eröffnungspost, wenn @joergeli einverstanden ist)
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @homoran said in Problem mit email-Adaper V2.02:
                            https://forum.iobroker.net/topic/80327/test-adapter-email-2-0-x
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Ja - da steht aber auch drinnen, dass die eine in Ordnung ist wenn die Addressen sich unterscheiden und die zweite nur ein Problem mit dem Prüfschema darstellt (was aber in der nächsten admin Version auch behoben sein sollte.)
                              • mcm1957M mcm1957
                                @mcm1957 MIST!
                                das geht nicht!
                                dein thread ist neuer als dieser hier
                                ich hab den hier zugemacht!
                                sorry @joergeli!
                                bitte im Tester athread weiter machen
