  4. Probleme mit Homematic (hm-rpc)
75 Beiträge 9 Kommentatoren 10.5k Aufrufe 6 Beobachtet
  • A axel
    @homoran Gerne. Ist LEQ0534934. Es sieht so aus, dass einige Werte da wären, andere nicht. Energy_Counter ist da, FREQUENCY nicht, ich glaube, die Kanäle 3 bis 6 sind ungenutzt. Im Kanal 1 stehen die wichtigen Werte.
    2025-03-18 12:23:39.928  - debug: hm-rpc.1 (341300) xml multicall <event>: sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f,LEQ0534934:2,BOOT,true
    2025-03-18 12:23:39.928  - debug: hm-rpc.1 (341300) xmlrpc <- event ["sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f","LEQ0534934:2","BOOT",true]
    2025-03-18 12:23:39.928  - debug: hm-rpc.1 (341300) xmlrpc <- event: hm-rpc.1.LEQ0534934.2.BOOT:true discarded, no matching device
    2025-03-18 12:23:39.935  - debug: hm-rpc.1 (341300) xml multicall <event>: sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f,LEQ0534934:2,ENERGY_COUNTER,19065.6
    2025-03-18 12:23:39.935  - debug: hm-rpc.1 (341300) xmlrpc <- event ["sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f","LEQ0534934:2","ENERGY_COUNTER",19065.6]
    2025-03-18 12:23:39.935  - debug: hm-rpc.1 (341300) xmlrpc <- event: hm-rpc.1.LEQ0534934.2.ENERGY_COUNTER:19065.6 discarded, no matching device
    2025-03-18 12:23:39.936  - debug: hm-rpc.1 (341300) xml multicall <event>: sh:hm-rpc.1:1011d```d27be38c43f73063a1e18aa071f,LEQ0534934:2,POWER,0.16
    2025-03-18 12:23:39.936  - debug: hm-rpc.1 (341300) xmlrpc <- event ["sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f","LEQ0534934:2","POWER",0.16]
    2025-03-18 12:23:39.936  - debug: hm-rpc.1 (341300) xmlrpc <- event: hm-rpc.1.LEQ0534934.2.POWER:0.16 discarded, no matching device
    2025-03-18 12:23:39.936  - debug: hm-rpc.1 (341300) xml multicall <event>: sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f,LEQ0534934:2,CURRENT,2
    2025-03-18 12:23:39.936  - debug: hm-rpc.1 (341300) xmlrpc <- event ["sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f","LEQ0534934:2","CURRENT",2]
    2025-03-18 12:23:39.939  - debug: hm-rpc.1 (341300) xmlrpc <- event: hm-rpc.1.LEQ0534934.2.CURRENT:2 discarded, no matching device
    2025-03-18 12:23:39.940  - debug: hm-rpc.1 (341300) xml multicall <event>: sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f,LEQ0534934:2,VOLTAGE,233.8
    2025-03-18 12:23:39.940  - debug: hm-rpc.1 (341300) xmlrpc <- event ["sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f","LEQ0534934:2","VOLTAGE",233.8]
    2025-03-18 12:23:39.940  - debug: hm-rpc.1 (341300) xmlrpc <- event: hm-rpc.1.LEQ0534934.2.VOLTAGE:233.8 discarded, no matching device
    2025-03-18 12:23:39.940  - debug: hm-rpc.1 (341300) xml multicall <event>: sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f,LEQ0534934:2,FREQUENCY,49.97
    2025-03-18 12:23:39.940  - debug: hm-rpc.1 (341300) xmlrpc <- event ["sh:hm-rpc.1:1011dd27be38c43f73063a1e18aa071f","LEQ0534934:2","FREQUENCY",49.97]
    2025-03-18 12:23:39.940  - debug: hm-rpc.1 (341300) xmlrpc <- event: hm-rpc.1.LEQ0534934.2.FREQUENCY:49.97 discarded, no matching device
    axel
    #61
    @axel aber nur Kanal 0 hat Werte bei den Objects...
    QNAP 677 VM 16 GB, 4 Kerne, 3,4 GHz
    29.375 Objekte
    24.247 Zustände
    • A axel
      #62
      @axel sagte in Probleme mit Homematic (hm-rpc):
      klar doch
      werden ja
      in der Konfig
      @homoran sagte in Probleme mit Homematic (hm-rpc):
      system.adapter.hm-rpc.1 : hm-rpc : sh - enabled
      hier fehlt der Port!!!
      A 1 Antwort Letzte Antwort
        klar doch
        werden ja
        in der Konfig
        axel
        #63
        @homoran ... aber welcher Port fehlt?
        29.375 Objekte
        24.247 Zustände
        • A axel
          #64
          sieh im diag unter hm-rpc.1 nach!
          dafür ist der da.
          die von dir in dem admin gemachten Einstellungen scheinen nicht übernommen worden zu sein, warum auch immer
            axel
            #65
            • system.adapter.hm-rpc.0 : hm-rpc : sh - enabled, port: 18701
            Du meinst das:
            • system.adapter.hm-rpc.1 : hm-rpc : sh - enabled
            • system.adapter.hm-rpc.2 : hm-rpc : sh - enabled
            HM-RPC.0 ist an den Rega andekoppelt. Dieser Port wird da dargestellt. 1 ist für Standard HM und der 2 für HM-IP
            So wurde es automatisch detektiert.
            29.375 Objekte
            24.247 Zustände
            • A axel
              Du meinst das:
              axel
              #66
              @axel Nicht rega, CCU!
              29.375 Objekte
              24.247 Zustände
              • A axel
                axel
                #67
                @axel natürlich CUX, tut mir leid
                29.375 Objekte
                24.247 Zustände
                • A axel
                  #68
                  @axel was jetzt?
                  was willst du mit den Screenshots zeigen, wenn
                    @axel was jetzt?
                    axel
                    #69
                    @homoran Ich kenne immer noch keine Lösung für das Problem. Alles scheint i.O., ein Port fehlt. Was mache ich denn jetzt damit?
                    29.375 Objekte
                    24.247 Zustände
                    • A axel
                      #70
                      ich auch nicht wirklich.
                      Fakt ist, dass an deiner Installation etwas krumm ist.
                      Jetzt könnteman mit der
                      HOLZHAMMERMETHODE
                      alles platt machen, neu installieren und Backup wiederherstellen.
                      ETWAS MILDER
                      nur den hm-rpc Adapter mit allen Instanzen löschen und neu installieren
                      ODER
                      versuchen drn hm-rpc Adapter nochmal drüberinstallieren
                      Oder gaaaanz vorsichtig einmal mit iob upload hm-rpc versuchen zu fixen.
                      Der Erfolg für die ganzen Reparaturmögichkeiten hängt davon ab, was zu der Inkonsistenz deiner Installation geführt hat.
                      Ich kann dir nicht sagen ob und was noch alles unter der Haube nicht richtig läuft.
                      A 2 Antworten Letzte Antwort
                        HOLZHAMMERMETHODE
                        ETWAS MILDER
                        ODER
                        axel
                        #71
                        @homoran ok. Ich habe da immer noch das Problem mit meinen Auswertungen. Wenn ich die Instanzen lösche und neu installiere passen meine ID's sicher nicht mehr, siehe gestern. Ich werde wohl erst einmal den Adapter beim Start auf neu einlesen stellen und schauen, was passiert. Geht die Datenbank kaputt, kann ich sie aus dem Backup rekonstruieren. Das ist die vorsichtigste Vorhehensweise. Danach würde ich den iob upload hm-rpc probieren. Dann die Neuinstallation des einen Adapters, usw. Muß ich aber drüber nachdenken. Wenn ich den Energy_Counter abgreifen kann, wäre mein Ziel erreicht. Dann kann alles so bleiben.
                        Kann es auch ein Problem in der Steckdose sein? Sind das eigentlich Wired- oder Funk-Geräte?
                        29.375 Objekte
                        24.247 Zustände
                        • A axel
                          #72
                          warum nicht?
                          siehe gestern!
                          Du bist doch seit 2015 dabei!
                          du hast doch eine VM!
                          Wo ist da das Problem?
                          Bau doch einfach eine zweite VM parallel auf, da iob mit ausschließlich hmrpc drauf.
                          Dann siehst du was passiert
                          welche Steckdose?
                          hast du da ein Buskabel dran?
                            axel
                            #73
                            LEQ0534934
                            Das untersuchte Gerät ist eine Steckdose, eine HM-ES-PMSw1-Pl. Kein Buskabel, nur ein und aus schalten und Leistung messen. Diesen Leistungsmesspunkt wollte ich in einer VIS_View einbauen, Datempunkte waren leer. So fing das Übel an...
                            Das mit der Test-VM ist eine gute Idee :-)
                            29.375 Objekte
                            24.247 Zustände
                              HOLZHAMMERMETHODE
                              ETWAS MILDER
                              ODER
                              axel
                              #74
                              @homoran Also, ich konnte das Problem lösen. Habe ein Test-System aufgebaut und die HM-Adapter getestet. Die Einstellungen werden automatisch von Discovery erkannt und verwendet. Callback-Adressen nicht erforderlich. Die Ports sind alle gesetzt.
                              Habe dann im normalen System die Devices des entsprechenden RPV neu eingelesen. ID's sind gleich geblieben, Datenpunkte sind nun alle vorhanden, die Signalbilder sind normal.
                              Augenscheinlich ist das Problem mit dem Adapter gelöst. Der verliert anscheinend mit der Zeit ein paar Informationen ...
                              Danke nochjmal an alle die mich tatkräftig unterstützt haben.
                              29.375 Objekte
                              24.247 Zustände
                              • A axel
                                Meister MopperM Offline
                                Meister Mopper
                                #75
                                Das kann ja nicht die Ursache sein, oder ziehst du Demenz ins Kalkül? 😀
                                Proxmox und HA ...
