  4. Update von Node 18 auf Node 20 bricht ab
nodejsiobroker update
63 Beiträge 7 Kommentatoren 8.8k Aufrufe 5 Beobachtet
    @searcher57
    iob nodejs-update 20
    searcher57
    @thomas-braun said in Update von Node 18 auf Node 20 bricht ab:
    @searcher57
    @searcher57
    Danach bekomme ich folgendes;
    ioBroker nodejs fixer 2024-10-10
    You requested to install latest version from nodejs v20 tree.
    Your current setup is:
    /usr/bin/nodejs         v20.18.2
    /usr/bin/node           v20.18.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 20.18.2-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
     *** 20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v20.18.2. Do you want to install latest version from nodejs v.20 tree?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
    Waiting for ioBroker to shut down - Give me a minute...
    Removing dfsg-nodejs
    *** These repos are active on your system:
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Get:6 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
    Get:7 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [10.4 kB]
    Get:8 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [10.4 kB]
    Fetched 33.0 kB in 1s (26.6 kB/s)
    Installing nodejs now!
    Installing the nodejs!
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    • S searcher57
      @searcher57
      @searcher57
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Package: nodejs
      Pin-Priority: 1001
      @searcher57
      Dann ist jetzt nodejs@20 richtig installiert.
        @searcher57
        searcher57
        @searcher57
        So, meine Einstellungen sind endlich aktuallisiert. Trotzdem bekomme ich den Telegram- Adapter nicht auf den neuesten Stand.
        Thomas BraunT S 2 Antworten Letzte Antwort
        • S searcher57
          @searcher57
          @searcher57 sagte in Update von Node 18 auf Node 20 bricht ab:
          Das heißt konktet mit welchen Meldungen?
          iob update
          iob upgrade all
          • S searcher57
            @searcher57
            searcher57
            @searcher57 said in Update von Node 18 auf Node 20 bricht ab:
            @searcher57
            Entschuldigung!! Update: Alles Gut es hat funktioniert! Danke!👍 👏
              iob update
              iob upgrade all
              searcher57
              iob update
              iob upgrade all
              Ich war mal wieder zu ungeduldig und habe nach den Eingaben nicht abgewartet, ob eine Lösung statt gefunden hat! Asche über mein Haupt!!🤕
                iob update
                iob upgrade all
                searcher57
                schrieb am zuletzt editiert von searcher57
                iob update
                iob upgrade all
                @searcher57
                Anstatt iob nodejs-update 20 habe ich iob nodejs-update v 20.18.2 eingegeben!
                • S searcher57
                  iob update
                  iob upgrade all
                  @searcher57
                  @searcher57
                  Und warum?
                  v 20.18.2 ist keine gültige Option bei dem Skript. Und das hat dir auch keiner so falsch vorgegeben. Und in der Hilfe steht das auch nicht drin. Also WARUM?
                    @searcher57
                    Und warum?
                    searcher57
                    @searcher57
                    Und warum?
                    Weil ich das in meinem Raspi 5 so angegeben bekomme!
                    S Thomas BraunT 2 Antworten Letzte Antwort
                    • S searcher57
                      @searcher57
                      Und warum?
                      searcher57
                      @searcher57
                      Und warum?
                      Kann ich also die Version vom Raspi 5 nicht auf den Raspi 4 übernehmen?
                      • S searcher57
                        @searcher57
                        Und warum?
                        @searcher57
                        Das ist die volle Versionierung. Bei nodejs-update gibt man aber nur die Major-Version an.
                        In der Hilfe ist das Kommando so enthalten:
                        iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
                        Hab mir eine Plausibiltätsprüfung für das Argument aber schon auf meine 'ToDo'-Liste gesetzt.
                        • S searcher57
                          @searcher57
                          Und warum?
                          searcher57
                          @searcher57
                          Und warum?
                          Seltsam ist, dass es jetzt so aussieht:
                          • S searcher57
                            @searcher57
                            Und warum?
                            Warum ist das seltsam?
                            Eine volle Versionsnummer unterteilt sich in drei Segmente.
                            Major.Minor.Patch
                            Beim nodejs-update gibst du nur den Major-Zweig an, die genaue aktuelle Version findet das Skript dann automatisch.
                              @searcher57
                              searcher57
                              @searcher57
                              Das sagt mir wenig! Hauptsache Ihr habt mir geholfen!!👍 😊
                              • S searcher57
                                @searcher57
                                Das sagt mir wenig!
                                Deswegen meine Erläuterung einen Post zuvor.
                                  Das sagt mir wenig!
                                  searcher57
                                  Das sagt mir wenig!
                                  OK, nochmal Danke!
                                    einen Screen-shot:
                                    da steht's doch ganz deutlich und rot markiert
                                    usr/bin/nodejs v18.20.6
                                    ist zu alt
                                    du brauchst v20
                                    searcher57
                                    @homoran said in Update von Node 18 auf Node 20 bricht ab:
                                    einen Screen-shot:
                                    ist zu alt
                                    soll!
                                    du brauchst v20
                                    Also dann sag mir doch bitte in Zukunft, was ich machen
                                    • S searcher57
                                      Das sagt mir wenig!
                                      OK, nochmal Danke!
                                      searcher57
                                      Das sagt mir wenig!
                                      OK, nochmal Danke!
                                      einen Screen-shot:
                                      ist zu alt
                                      soll!
                                      du brauchst v20
                                      Sei's drum es ist ja wieder alles in Ordnung, aber ich wünsche mir einen Umgang mit Normalos!!😙
                                      • S searcher57
                                        einen Screen-shot:
                                        ist zu alt
                                        soll!
                                        du brauchst v20
                                        @searcher57
                                        Es steht doch eigentlich alles klar und deutlich in dem Screenshot drin...
                                        Rot markiert: nodejs20 ist erforderlich, du hast 18 laufen
                                        Im Changelog auch nochmal:
                                        Nodejs >20 ist erforderlich.
                                        Sollte auch für 'Normalos' (Was auch immer das genau sein soll) verständlich sein.
                                        • S searcher57
                                          Das sagt mir wenig!
                                          OK, nochmal Danke!
                                          einen Screen-shot:
                                          ist zu alt
                                          soll!
                                          du brauchst v20
                                          was mutet dir denn unnormal an 🤔
