  4. Z2M-Adapter: Geräte als offline markiert obwohl online
12 Beiträge 6 Kommentatoren 1.4k Aufrufe 4 Beobachtet
  • KodijackK Offline
    KodijackK Offline
    Kodijack
    schrieb am zuletzt editiert von Kodijack
    Due to request from @arteck : Here's the post.
    Problem:
    After a fresh start of the z2m-instance, all devices are available and working. After a while most devices now show as
    offline, despite being online. Everything works fine though. it's just availability=false
    Steps tried so far:
    • double-checking config-settings according to documentation.
    advanced:
      ota_timeout: 1200
      output: json
      cache_state: false
    availability:
      enabled: true
      active:
        timeout: 120
      passive:
        timeout: 1500
    (removing the timeouts doesn't change the behaviour)
    • Trying all possible settings in MQTT/Z2M+Z2M-Adapter in desperately trying to fix it.
    -Zigbee2mqtt-Adapter 3.0.2
    -Zigbee2mqtt v2.0
    -MQTT (external server)
    • js-cont 7.0.6
    • admin-adapter: most current
    • nodejs 20.10.0
    • npm 10.8.2
                            v.2024-10-19
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.0-204-generic
          Architecture: x86-64
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     12
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:           9.7G        2.5G        3.9G        1.0M        3.3G        6.9G
    Swap:          2.0G          0B        2.0G
    Total:          11G        2.5G        5.9G
    Active iob-Instances:   25
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.6
                            admin                   7.4.14
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.0.10 (SSL), run as: admin
      system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8099, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.0.10 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8084, bind: 192.168.0.10, run as: httpuser
    + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8098, bind: 0.0.0.0 (SSL), run as: httpuser
    Objects:                15731
    States:                 12426
    Size of iob-Database:
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/objects.json.migrated
    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    48M     /opt/iobroker/iobroker-data/states.jsonl
    2.8M    /opt/iobroker/iobroker-data/states.json.migrated
    2.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
    Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
    DANKE
    Bitte ausfüllen:
    • Adaptername: ...
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: ...
    • js-controller Version: ...
    • Admin Version: ...
    • Hardwaresystem: NUC, Pi4 ...
    • Arbeitsspeicher: ...xGB
    • Festplattenart: SD-Karte, SSD, HDD, ...
    • Betriebssystem: ...
    • Nodejs-Version: ...
    • NPM-Version: ...
    • Installationsart: Skript oder Manuell ?
    • Image, Docker genutzt: Ja - Nein
    • Ort, Name der Imagedatei: ...
    Linux User bitte hier den Output von iob diag einfügen.Due to request from @arteck : Here's the post.
    Problem:
    Steps tried so far:
    advanced:
      ota_timeout: 1200
      output: json
      cache_state: false
    availability:
      enabled: true
      active:
        timeout: 120
      passive:
        timeout: 1500
    -Zigbee2mqtt v2.0
    • js-cont 7.0.6
    • nodejs 20.10.0
    • npm 10.8.2
                            v.2024-10-19
               Chassis: vm
        Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    User-ID:                1000
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    MEMORY:
    Swap:          2.0G          0B        2.0G
                            admin                   7.4.14
    Objects type: jsonl
    States  type: jsonl
    Objects:                15731
    States:                 12426
    • KodijackK Kodijack
      Problem:
      Steps tried so far:
      advanced:
        ota_timeout: 1200
        output: json
        cache_state: false
      availability:
        enabled: true
        active:
          timeout: 120
        passive:
          timeout: 1500
      -Zigbee2mqtt v2.0
      • js-cont 7.0.6
      • nodejs 20.10.0
      • npm 10.8.2
                              v.2024-10-19
                 Chassis: vm
          Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:          2.0G          0B        2.0G
                              admin                   7.4.14
      Objects type: jsonl
      States  type: jsonl
      Objects:                15731
      States:                 12426
      DANKE
      Bitte ausfüllen:
      • Adaptername: ...
      • NPM-Version: ...
      Problem:
      Steps tried so far:
      advanced:
        ota_timeout: 1200
        output: json
        cache_state: false
      availability:
        enabled: true
        active:
          timeout: 120
        passive:
          timeout: 1500
      -Zigbee2mqtt v2.0
      • js-cont 7.0.6
      • nodejs 20.10.0
      • npm 10.8.2
                              v.2024-10-19
                 Chassis: vm
          Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:          2.0G          0B        2.0G
                              admin                   7.4.14
      Objects type: jsonl
      States  type: jsonl
      Objects:                15731
      States:                 12426
      arteckA Offline
      arteckA Offline
      arteck
      @kodijack sagte in Z2M-Adapter: Devices marked offline despite being online:
      active:
      timeout: 120
      passive:
      timeout: 1500
      hast du die mal ausgeschaltet ?? hat auch nix gebracht ?
      und wie war das
      so oder ??
      KodijackK 1 Antwort Letzte Antwort
      • arteckA arteck
        active:
        timeout: 120
        passive:
        timeout: 1500
        und wie war das
        so oder ??
        KodijackK Offline
        KodijackK Offline
        Kodijack
        @arteck said in Z2M-Adapter: Devices marked offline despite being online:
        active:
        timeout: 120
        passive:
        timeout: 1500
        Nein, nix geändert nach Löschung beider Optionen
        und wie war das
        so oder ??
        External, ja.
          active:
          timeout: 120
          passive:
          timeout: 1500
          und wie war das
          so oder ??
          External, ja.
          arteckA Offline
          arteckA Offline
          arteck
          @kodijack poste mal bitte nach adapterstart das log.
          irgendwas ist bei dir anders.
            Hab das mal hier hingeschoben. Ist ja wohl kein Bug von ioBroker.
            @Kodijack kannst du bitte den Threadtitel noch auf deutsch ändern!
            • arteckA arteck
              KodijackK Offline
              KodijackK Offline
              Kodijack
              zigbee2mqtt.0
              	2025-01-21 18:28:54.000	info	==================================================================================
              zigbee2mqtt.0
              	2025-01-21 18:28:54.000	info	|| Network panid 6555 channel: 11 ext_pan_id: 0x5a9b81c29a3de1d1
              zigbee2mqtt.0
              	2025-01-21 18:28:54.000	info	|| Coordinator type: zStack3x0 Version: 20240710 Serial: tcp://192.168.0.250:6638
              zigbee2mqtt.0
              	2025-01-21 18:28:54.000	info	|| Zigbee2MQTT Version: 2.0.0
              zigbee2mqtt.0
              	2025-01-21 18:28:53.999	info	============================ Zigbee2MQTT Information =============================
              zigbee2mqtt.0
              	2025-01-21 18:28:53.988	info	Connect to Zigbee2MQTT over external mqtt connection.
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	==================================================================================
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Coordinator Check Cron : 0 3 * * *
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Coordinator Check Loglevel: info
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Use Automatic Coordinator Check: no
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Use Simple Press/Release State: yes
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Use Simple Move/Stop State: yes
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Use Simple Hold/Release State: yes
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Use Device Icons: yes
              zigbee2mqtt.0
              	2025-01-21 18:28:53.857	info	|| Use Event In Desc: yes
              zigbee2mqtt.0
              	2025-01-21 18:28:53.856	info	|| Use BrightnessStep OnOff: no
              zigbee2mqtt.0
              	2025-01-21 18:28:53.856	info	|| Use BrightnessMove OnOff: no
              zigbee2mqtt.0
              	2025-01-21 18:28:53.856	info	|| Use ColorTemperature ColorSync: no
              zigbee2mqtt.0
              	2025-01-21 18:28:53.856	info	|| Use Kelvin: no
              zigbee2mqtt.0
              	2025-01-21 18:28:53.856	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: deactivated
              zigbee2mqtt.0
              	2025-01-21 18:28:53.856	info	|| Zigbee2MQTT Debug Log: deactivated
              zigbee2mqtt.0
              	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Externanl MQTT Credentials: use
              zigbee2mqtt.0
              	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Externanl MQTT Port: 1883
              zigbee2mqtt.0
              	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Externanl MQTT Server: mosquitto.<redacted domain>
              zigbee2mqtt.0
              	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Connection Type: exmqtt
              zigbee2mqtt.0
              	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Frontend Port: 8080
              zigbee2mqtt.0
              	2025-01-21 18:28:53.854	info	|| Zigbee2MQTT Frontend Server:
              zigbee2mqtt.0
              	2025-01-21 18:28:53.854	info	|| Zigbee2MQTT Frontend Scheme: http
              zigbee2mqtt.0
              	2025-01-21 18:28:53.854	info	================================= Adapter Config =================================
              zigbee2mqtt.0
              	2025-01-21 18:28:53.844	info	starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v20.18.0, js-controller: 7.0.6
              Irgendwas hilfreiches dabei oder meintest du eher das z2m-log? Soll ich nochmal mit dem forwarded-log zusammen posten?
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                zigbee2mqtt.0
                arteckA Offline
                arteckA Offline
                arteck
                @kodijack direkt nach dem start sind die alle online.. ??
                zeigmal ein screenshot von paar objekten
                • arteckA arteck
                  KodijackK Offline
                  KodijackK Offline
                  Kodijack
                  @arteck said in Z2M-Adapter: Geräte als offline markiert obwohl online:
                  Ja, direkt nach Adapter-Neustart sind alle online (die auch tatsächlich online sind natürlich). Das Gleiche auch wenn ich Z2M selber neustarte, nicht aber den Adapter.
                  Es dauerte ein paar Stunden bis (fast) alle wieder offline waren.
                  Die anderen sind auch alle available:false. Änder ich einen state wie "on" im gleichen Gerät, funktioniert es, availability bleibt jedoch offline.
                  Hier sind ein paar noch online, aber bald auch offline :-)
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    @kodijack sagte in Z2M-Adapter: Geräte als offline markiert obwohl online:
                    cache_state: false
                    setzt den mal auf
                    cache_state: false
                    • arteckA arteck
                      cache_state: false
                      setzt den mal auf
                      cache_state: false
                      KodijackK Offline
                      KodijackK Offline
                      Kodijack
                      cache_state: false
                      setzt den mal auf
                      cache_state: false
                      Öh. Ist doch schon :-)
                        cache_state: false
                        setzt den mal auf
                        cache_state: false
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @kodijack jo hast recht....
                          cache_state: false
                        device_options: {}
                        availability:
                          enabled: true
                          active:
                            timeout: 10
                          passive:
                            timeout: 1500
                        das ist meine Einstellung.. kann ja dann nur ean dem timeout liegen
                        • arteckA arteck
                            cache_state: false
                          device_options: {}
                          availability:
                            enabled: true
                            active:
                              timeout: 10
                            passive:
                              timeout: 1500
                          KodijackK Offline
                          KodijackK Offline
                          Kodijack
                          Den hatte ich ja schon rausgenommen. War deine erste Idee in Tgram.
                          Deine Version ist ja, glaub ich, der default, 10 und 1500. Werd ich aber auch nochmal explizit so übernehmen, who knows...
