  3. Einsteigerfragen
  4. Installation
  5. Pi3 Neuinstallation Deprecation section in apt-key(8)
Geplant Angeheftet Gesperrt Verschoben Installation
3 Beiträge 2 Kommentatoren 593 Aufrufe 2 Beobachtet
    Smallfeuer
    aus gegebenen Anlass versuche ich grad einen 2. alten Pi3Model B V1.2 in Betrieb zu nehmen. Leider bisher ohne Erfolg.
    Folgendes passiert bei der Installation, egal ob 32 oder 64 Bit Version. Die Meldungen zu den Deprecation section kommt dann nach jeder Installation bis er irgendwann abbricht.
        Welcome to the ioBroker installer!
        Installer version: 2024-10-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Get:1 http://archive.raspberrypi.com/debian bookworm InRelease [39.3 kB]
    Get:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease [15.0 kB]
    Get:3 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages [14.        5 MB]
    Get:4 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [520 kB        ]
    Get:5 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [549 kB        ]
    Fetched 15.6 MB in 22s (724 kB/s)
    Reading package lists... Done
    W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg k        eyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Node.js not found. Installing...
    W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    rm: cannot remove '/etc/apt/keyrings/nodesource.gpg': No such file or directory
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    • S Smallfeuer
      Package: nodejs
      Pin-Priority: 1001
      crunchipC Abwesend
      crunchipC Abwesend
      @smallfeuer sagte in Pi3 Neuinstallation Deprecation section in apt-key(8):
      z.b https://github.com/RPi-Distro/repo/issues/348#issuecomment-1856137060
        Smallfeuer
        @crunchip Dankeschön. Problem behoben.
        Package: nodejs
        Pin-Priority: 1001
         Processing triggers for man-db (2.11.2-2) ...ource1_armhf.deb ...led.)
        Installed nodejs
        Node.js Installed successfully!
        Guten Rutsch. ;)
