  3. Off Topic
  4. Grafana
  5. Fehler bei Wiederherstellung von Grafana
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
36 Beiträge 4 Kommentatoren 4.5k Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    wibear
    Hallo Forum,
    ich kann Grafana nicht wiederherstellen. Es ist ein Raspi4 mit Bookworm. Das Backup stammt vom Bullseye. Es gibt ein Fehler in der IOB-Log:
    Error: Command failed: sudo mount -t cifs -o username=iobrokerBackup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    und in dem Wiederherstellungsdialog:
    11:00:40.504INFOguistarting Restore...
    11:00:40.803DEBUGgrafanaStart Grafana Restore ...
    11:00:40.811DEBUGgrafanafilename for restore: /opt/iobroker/backups/grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
    11:00:40.846DEBUGgrafanaGrafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    11:00:40.853DEBUGgrafanastart decompress
    11:00:51.594DEBUGgrafanaGrafana request started
    11:00:51.942DEBUGgrafanaGrafana is available ... Status: 200
    11:00:52.040DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/infinity.json
    11:00:52.086DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/influxdb.json
    11:00:52.106DEBUGgrafanacannot restore datasource "infinity": "data source with the same name already exists"
    11:00:52.111DEBUGgrafanacannot restore datasource "influxdb": "data source with the same name already exists"
    11:00:55.006DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-ladeleistung.json
    11:00:55.065DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-soc.json
    11:00:55.074DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/energie.json
    11:00:55.089DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/funk.json
    11:00:55.112DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/gauges.json
    11:00:55.121DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/heizung.json
    11:00:55.127DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/temperaturen-ww-hz.json
    11:00:55.132DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/umwalzpumpe.json
    11:00:55.139DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-waschmaschiene.json
    11:00:55.157DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/signalstarke.json
    11:00:55.161DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-solar.json
    11:00:55.167DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/verbrauch-ww-taglich.json
    11:00:55.172DEBUGgrafanacannot restore dashboard "energie": {"message":"Unauthorized","traceID":""}
    11:00:55.175DEBUGgrafanacannot restore dashboard "batterie-soc": {"message":"Unauthorized","traceID":""}
    11:00:55.178DEBUGgrafanacannot restore dashboard "batterie-ladeleistung": {"message":"Unauthorized","traceID":""}
    11:00:55.229DEBUGgrafanacannot restore dashboard "funk": {"message":"Unauthorized","traceID":""}
    11:00:55.237DEBUGgrafanacannot restore dashboard "verbrauch-hz-taglich": {"message":"Unauthorized","traceID":""}
    11:00:55.248DEBUGgrafanacannot restore dashboard "heizung": {"message":"Unauthorized","traceID":""}
    11:00:55.275DEBUGgrafanacannot restore dashboard "gauges": {"message":"Unauthorized","traceID":""}
    11:00:55.278DEBUGgrafanacannot restore dashboard "temperaturen-ww-hz": {"message":"Unauthorized","traceID":""}
    11:00:55.285DEBUGgrafanacannot restore dashboard "verbrauch-ww-taglich": {"message":"Unauthorized","traceID":""}
    11:00:55.290DEBUGgrafanacannot restore dashboard "temperatur-shelly": {"message":"Unauthorized","traceID":""}
    11:00:55.294DEBUGgrafanacannot restore dashboard "umwalzpumpe": {"message":"Unauthorized","traceID":""}
    11:00:55.298DEBUGgrafanacannot restore dashboard "leistung-solar": {"message":"Unauthorized","traceID":""}
    11:01:00.969DEBUGgrafanacannot restore dashboard "signalstarke": {"message":"Unauthorized","traceID":""}
    11:01:01.013DEBUGgrafanacannot restore dashboard "leistung-waschmaschiene": {"message":"Unauthorized","traceID":""}
    11:01:01.022DEBUGgrafanaGrafana request ended
    11:01:01.030DEBUGgrafanaTry deleting the Grafana tmp directory
    11:01:01.037DEBUGgrafanaGrafana tmp directory was successfully deleted
    11:01:02.977DEBUGgrafanaGrafana Restore completed successfully
    Nur die Data sources werden übernommen.
    Woran könnte es liegen?
    Danke und Grüße
    Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
    • W wibear
      Hallo Forum,
      Danke und Grüße
      @wibear sagte in Fehler bei Wiederherstellung von Grafana:
      Da greift schon was auf den Mountpunkt /opt/iobroker/backups zu.
      Ist das Verzeichnis leer, wenn die Freigabe nicht gerade gemountet ist?
      mount | sort
      anschauen.
      [Edit:] Mountpunkt korrigiert.
      W 3 Antworten Letzte Antwort
        mount | sort
        anschauen.
        W Offline
        W Offline
        wibear
        @thomas-braun sagte in Fehler bei Wiederherstellung von Grafana:
        Das Verzeichnis ist nicht leer.
          mount | sort
          anschauen.
          W Offline
          W Offline
          wibear
          raspi@raspi:~ $ mount | sort
          binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
          bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
          cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
          configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
          debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
          devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
          /dev/sda1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
          /dev/sda2 on / type ext4 (rw,noatime)
          fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
          lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
          mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
          proc on /proc type proc (rw,relatime)
          pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
          ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
          securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
          sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
          sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
          systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4955)
          tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
          tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
          tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=388192k,mode=755)
          tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=388188k,nr_inodes=97047,mode=700,uid=1000,gid=1000)
          tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
          udev on /dev type devtmpfs (rw,nosuid,relatime,size=1672772k,nr_inodes=418193,mode=755)
            mount | sort
            anschauen.
            W Offline
            W Offline
            wibear
            schrieb am zuletzt editiert von wibear
            Da greift schon was auf den Mountpunkt /opt/iobroker/ zu.
            • W wibear
              Sollte es aber sein, wenn es als Einhängepunkt fungieren soll.
              W 1 Antwort Letzte Antwort
                W Offline
                W Offline
                wibear
                Über welches Verzeichnis sprechen wir /opt/iobroker ?
                Was soll ich ändern?
                • W wibear
                  Wir sprechen vom Mountpunkt /opt/iobroker/backups. Hatte das oben falsch.
                    W Offline
                    W Offline
                    wibear
                    Dieses Verzeichnis ist ja leer. Was kann es noch sein?
                    • W wibear
                      @wibear
                      Was passiert denn, wenn du das Ding manuell mountest?
                        @wibear
                        W Offline
                        W Offline
                        wibear
                        Bin mit Linux nicht so vertraut.
                        Wie mounte ich das bitte?
                        • W wibear
                          @wibear
                          Schauen, ob der Mountpunkt leer ist:
                          ls -l /opt/iobroker/backups
                          dann mounten:
                          Dein password muss noch gesetzt werden.
                          W 2 Antworten Letzte Antwort
                            @wibear
                            dann mounten:
                            W Offline
                            W Offline
                            wibear
                            dann mounten:
                            Ich habe gemountet und danach wie empfohlen
                            sudo systemctl daemon-reload
                            ausgeführt.
                            raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackup,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups
                            mount: (hint) your fstab has been modified, but systemd still uses
                                   the old version; use 'systemctl daemon-reload' to reload.
                            raspi@raspi:~ $ ^C
                            raspi@raspi:~ $ sudo systemctl daemon-reload
                            • W wibear
                              dann mounten:
                              ausgeführt.
                              raspi@raspi:~ $ ^C
                              W Offline
                              W Offline
                              wibear
                              @wibear
                              ich habe umount ausgeführt, danach wieder mount:
                              raspi@raspi:~ $ sudo umount /opt/iobroker/backups
                              raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackp,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobrker/backups
                              raspi@raspi:~ $
                              Es wurde ohne irgendeine Meldung ausgeführt.
                                @wibear
                                dann mounten:
                                W Offline
                                W Offline
                                wibear
                                Das war vor mount
                                raspi@raspi:~ $ ls -l /opt/iobroker/backups
                                total 0
                                und das ist nach mount:
                                raspi@raspi:~ $ ls -l /opt/iobroker/backups                                        total 73984
                                -rwxrwxrwx 1 iobroker iobroker     9507 Dec  1 02:41 grafana_2024_12_01-02_41_35_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker     9505 Dec  8 02:41 grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  1 02:30 homematic_2024_12_01-02_30_22_3.79.6_backupiobroker.tar.sbk
                                -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  8 02:30 homematic_2024_12_08-02_30_22_3.79.6_backupiobroker.tar.sbk
                                -rwxrwxrwx 1 iobroker iobroker      225 Dec 10 15:20 homematic_2024_12_10-15_20_10_3.79.6_backupiobroker.tar.sbk
                                -rwxrwxrwx 1 iobroker iobroker 28285363 Dec  1 02:41 influxDB_2024_12_01-02_40_29_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker 30373723 Dec  8 02:41 influxDB_2024_12_08-02_40_29_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker  2114413 Dec  1 02:40 iobroker_2024_12_01-02_40_20_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker  2132546 Dec  8 02:40 iobroker_2024_12_08-02_40_20_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker    31808 Dec  1 02:41 javascripts_2024_12_01-02_41_52_backupiobroker.tar.gz
                                -rwxrwxrwx 1 iobroker iobroker    32943 Dec  8 02:42 javascripts_2024_12_08-02_41_59_backupiobroker.tar.gz
                                • W wibear
                                  Das war vor mount
                                  total 0
                                  @wibear
                                  So soll das aussehen.
                                    @wibear
                                    W Offline
                                    W Offline
                                    wibear
                                    Wie soll ich bitte weiter vorgehen?
                                    Oder kann ich es irgenwie manuell machen?
                                      @wibear
                                      W Offline
                                      W Offline
                                      wibear
                                      mount/unmount funktioniert manuell.
                                      Warum geht das nicht über Backitup (error 16)?
                                      Wie kann man es über die Konsole einspielen?
                                      Kann ich den Fehler in einer Log suchen?
                                      • W wibear
                                        Erscheint die Meldung denn immer noch?
                                        Du darfst nicht mit irgendwelchen Prozessen (z. B. deinem graphischen Dateimanager) auf den Mountpunkt zugreifen.
                                          W Offline
                                          W Offline
                                          wibear
                                          Der Fehler ist immer noch da, auch wenn ich nur die Konsole benutze.
