  3. Off Topic
  4. Grafana
  5. Fehler bei Wiederherstellung von Grafana
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
36 Beiträge 4 Kommentatoren 4.5k Aufrufe 3 Beobachtet
  • W wibear
    Hallo Forum,
    ich kann Grafana nicht wiederherstellen. Es ist ein Raspi4 mit Bookworm. Das Backup stammt vom Bullseye. Es gibt ein Fehler in der IOB-Log:
    Error: Command failed: sudo mount -t cifs -o username=iobrokerBackup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    und in dem Wiederherstellungsdialog:
    11:00:40.504INFOguistarting Restore...
    11:00:40.803DEBUGgrafanaStart Grafana Restore ...
    11:00:40.811DEBUGgrafanafilename for restore: /opt/iobroker/backups/grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
    11:00:40.846DEBUGgrafanaGrafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    11:00:40.853DEBUGgrafanastart decompress
    11:00:51.594DEBUGgrafanaGrafana request started
    11:00:51.942DEBUGgrafanaGrafana is available ... Status: 200
    11:00:52.040DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/infinity.json
    11:00:52.086DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/influxdb.json
    11:00:52.106DEBUGgrafanacannot restore datasource "infinity": "data source with the same name already exists"
    11:00:52.111DEBUGgrafanacannot restore datasource "influxdb": "data source with the same name already exists"
    11:00:55.006DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-ladeleistung.json
    11:00:55.065DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-soc.json
    11:00:55.074DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/energie.json
    11:00:55.089DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/funk.json
    11:00:55.112DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/gauges.json
    11:00:55.121DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/heizung.json
    11:00:55.127DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/temperaturen-ww-hz.json
    11:00:55.132DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/umwalzpumpe.json
    11:00:55.139DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-waschmaschiene.json
    11:00:55.157DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/signalstarke.json
    11:00:55.161DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-solar.json
    11:00:55.167DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/verbrauch-ww-taglich.json
    11:00:55.172DEBUGgrafanacannot restore dashboard "energie": {"message":"Unauthorized","traceID":""}
    11:00:55.175DEBUGgrafanacannot restore dashboard "batterie-soc": {"message":"Unauthorized","traceID":""}
    11:00:55.178DEBUGgrafanacannot restore dashboard "batterie-ladeleistung": {"message":"Unauthorized","traceID":""}
    11:00:55.229DEBUGgrafanacannot restore dashboard "funk": {"message":"Unauthorized","traceID":""}
    11:00:55.237DEBUGgrafanacannot restore dashboard "verbrauch-hz-taglich": {"message":"Unauthorized","traceID":""}
    11:00:55.248DEBUGgrafanacannot restore dashboard "heizung": {"message":"Unauthorized","traceID":""}
    11:00:55.275DEBUGgrafanacannot restore dashboard "gauges": {"message":"Unauthorized","traceID":""}
    11:00:55.278DEBUGgrafanacannot restore dashboard "temperaturen-ww-hz": {"message":"Unauthorized","traceID":""}
    11:00:55.285DEBUGgrafanacannot restore dashboard "verbrauch-ww-taglich": {"message":"Unauthorized","traceID":""}
    11:00:55.290DEBUGgrafanacannot restore dashboard "temperatur-shelly": {"message":"Unauthorized","traceID":""}
    11:00:55.294DEBUGgrafanacannot restore dashboard "umwalzpumpe": {"message":"Unauthorized","traceID":""}
    11:00:55.298DEBUGgrafanacannot restore dashboard "leistung-solar": {"message":"Unauthorized","traceID":""}
    11:01:00.969DEBUGgrafanacannot restore dashboard "signalstarke": {"message":"Unauthorized","traceID":""}
    11:01:01.013DEBUGgrafanacannot restore dashboard "leistung-waschmaschiene": {"message":"Unauthorized","traceID":""}
    11:01:01.022DEBUGgrafanaGrafana request ended
    11:01:01.030DEBUGgrafanaTry deleting the Grafana tmp directory
    11:01:01.037DEBUGgrafanaGrafana tmp directory was successfully deleted
    11:01:02.977DEBUGgrafanaGrafana Restore completed successfully
    Nur die Data sources werden übernommen.
    Woran könnte es liegen?
    Danke und Grüße
    @wibear sagte in Fehler bei Wiederherstellung von Grafana:
    Da greift schon was auf den Mountpunkt /opt/iobroker/backups zu.
    Ist das Verzeichnis leer, wenn die Freigabe nicht gerade gemountet ist?
    mount | sort
    anschauen.
    [Edit:] Mountpunkt korrigiert.
    W 3 Antworten Letzte Antwort
      mount | sort
      anschauen.
      W Offline
      W Offline
      wibear
      @thomas-braun sagte in Fehler bei Wiederherstellung von Grafana:
      Das Verzeichnis ist nicht leer.
        mount | sort
        anschauen.
        W Offline
        W Offline
        wibear
        raspi@raspi:~ $ mount | sort
        binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        /dev/sda1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
        /dev/sda2 on / type ext4 (rw,noatime)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        proc on /proc type proc (rw,relatime)
        pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
        ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4955)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=388192k,mode=755)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=388188k,nr_inodes=97047,mode=700,uid=1000,gid=1000)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        udev on /dev type devtmpfs (rw,nosuid,relatime,size=1672772k,nr_inodes=418193,mode=755)
          mount | sort
          anschauen.
          W Offline
          W Offline
          wibear
          schrieb am zuletzt editiert von wibear
          Da greift schon was auf den Mountpunkt /opt/iobroker/ zu.
          • W wibear
            Sollte es aber sein, wenn es als Einhängepunkt fungieren soll.
            W 1 Antwort Letzte Antwort
              W Offline
              W Offline
              wibear
              Über welches Verzeichnis sprechen wir /opt/iobroker ?
              Was soll ich ändern?
              • W wibear
                Wir sprechen vom Mountpunkt /opt/iobroker/backups. Hatte das oben falsch.
                  W Offline
                  W Offline
                  wibear
                  Dieses Verzeichnis ist ja leer. Was kann es noch sein?
                  • W wibear
                    @wibear
                    Was passiert denn, wenn du das Ding manuell mountest?
                      @wibear
                      W Offline
                      W Offline
                      wibear
                      Bin mit Linux nicht so vertraut.
                      Wie mounte ich das bitte?
                      • W wibear
                        @wibear
                        Schauen, ob der Mountpunkt leer ist:
                        ls -l /opt/iobroker/backups
                        dann mounten:
                        Dein password muss noch gesetzt werden.
                        W 2 Antworten Letzte Antwort
                          @wibear
                          dann mounten:
                          W Offline
                          W Offline
                          wibear
                          dann mounten:
                          Ich habe gemountet und danach wie empfohlen
                          sudo systemctl daemon-reload
                          ausgeführt.
                          raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackup,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups
                          mount: (hint) your fstab has been modified, but systemd still uses
                                 the old version; use 'systemctl daemon-reload' to reload.
                          raspi@raspi:~ $ ^C
                          raspi@raspi:~ $ sudo systemctl daemon-reload
                          • W wibear
                            dann mounten:
                            ausgeführt.
                            raspi@raspi:~ $ ^C
                            W Offline
                            W Offline
                            wibear
                            @wibear
                            ich habe umount ausgeführt, danach wieder mount:
                            raspi@raspi:~ $ sudo umount /opt/iobroker/backups
                            raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackp,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobrker/backups
                            raspi@raspi:~ $
                            Es wurde ohne irgendeine Meldung ausgeführt.
                              @wibear
                              dann mounten:
                              W Offline
                              W Offline
                              wibear
                              Das war vor mount
                              raspi@raspi:~ $ ls -l /opt/iobroker/backups
                              total 0
                              und das ist nach mount:
                              raspi@raspi:~ $ ls -l /opt/iobroker/backups                                        total 73984
                              -rwxrwxrwx 1 iobroker iobroker     9507 Dec  1 02:41 grafana_2024_12_01-02_41_35_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker     9505 Dec  8 02:41 grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  1 02:30 homematic_2024_12_01-02_30_22_3.79.6_backupiobroker.tar.sbk
                              -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  8 02:30 homematic_2024_12_08-02_30_22_3.79.6_backupiobroker.tar.sbk
                              -rwxrwxrwx 1 iobroker iobroker      225 Dec 10 15:20 homematic_2024_12_10-15_20_10_3.79.6_backupiobroker.tar.sbk
                              -rwxrwxrwx 1 iobroker iobroker 28285363 Dec  1 02:41 influxDB_2024_12_01-02_40_29_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker 30373723 Dec  8 02:41 influxDB_2024_12_08-02_40_29_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker  2114413 Dec  1 02:40 iobroker_2024_12_01-02_40_20_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker  2132546 Dec  8 02:40 iobroker_2024_12_08-02_40_20_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker    31808 Dec  1 02:41 javascripts_2024_12_01-02_41_52_backupiobroker.tar.gz
                              -rwxrwxrwx 1 iobroker iobroker    32943 Dec  8 02:42 javascripts_2024_12_08-02_41_59_backupiobroker.tar.gz
                              • W wibear
                                Das war vor mount
                                total 0
                                @wibear
                                So soll das aussehen.
                                  @wibear
                                  W Offline
                                  W Offline
                                  wibear
                                  Wie soll ich bitte weiter vorgehen?
                                  Oder kann ich es irgenwie manuell machen?
                                    @wibear
                                    W Offline
                                    W Offline
                                    wibear
                                    mount/unmount funktioniert manuell.
                                    Warum geht das nicht über Backitup (error 16)?
                                    Wie kann man es über die Konsole einspielen?
                                    Kann ich den Fehler in einer Log suchen?
                                    • W wibear
                                      Erscheint die Meldung denn immer noch?
                                      Du darfst nicht mit irgendwelchen Prozessen (z. B. deinem graphischen Dateimanager) auf den Mountpunkt zugreifen.
                                        W Offline
                                        W Offline
                                        wibear
                                        Der Fehler ist immer noch da, auch wenn ich nur die Konsole benutze.
                                          W Offline
                                          W Offline
                                          wibear
                                          Es gibt in der IOB Log diese Meldung:
                                          DATA: {"type":"nas / copy","fileName":"/opt/iobroker/backups/grafana_2024_12_08-02_41_41_backupiobroker.tar.gz","currentTheme":"none","currentProtocol":"http:","stopIOB":false}
                                          Ist stopIOB (false) OK?
