  4. Zigbee2MQTT Build Fehler
18 Beiträge 4 Kommentatoren 2.2k Aufrufe 4 Beobachtet
    Diamand2k22
    @Thomas-Braun
    viell. kannst du mir auf die schnelle weiterhelfen.
    wollte gerade mein System updaten wie gewohnt und den zigbee2mqtt adapter.
    Nun erhalte ich beim Ausführen des Befehls npm ci folgenden Fehler:
    pi4b@pi4b:/opt/zigbee2mqtt$ npm ci
    npm error code EUSAGE
    npm error
    npm error The `npm ci` command can only install with an existing package-lock.json or
    npm error npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
    npm error later to generate a package-lock.json file, then try again.
    npm error
    npm error Clean install a project
    npm error
    npm error Usage:
    npm error npm ci
    npm error
    npm error Options:
    npm error [--install-strategy <hoisted|nested|shallow|linked>] [--legacy-bundling]
    npm error [--global-style] [--omit <dev|optional|peer> [--omit <dev|optional|peer> ...]]
    npm error [--include <prod|dev|optional|peer> [--include <prod|dev|optional|peer> ...]]
    npm error [--strict-peer-deps] [--foreground-scripts] [--ignore-scripts] [--no-audit]
    npm error [--no-bin-links] [--no-fund] [--dry-run]
    npm error [-w|--workspace <workspace-name> [-w|--workspace <workspace-name> ...]]
    npm error [-ws|--workspaces] [--include-workspace-root] [--install-links]
    npm error
    npm error aliases: clean-install, ic, install-clean, isntall-clean
    npm error
    npm error Run "npm help ci" for more info
    npm error A complete log of this run can be found in: /home/pi4b/.npm/_logs/2024-12-05T19_59_47_899Z-debug-0.log
    was ist den nun schon wieder verbogen im System?
    BananaJoeB Thomas BraunT 2 Antworten Letzte Antwort
    • D Diamand2k22
      @Thomas-Braun
      npm error
      npm error
      npm error
      npm error Usage:
      npm error npm ci
      npm error
      npm error Options:
      npm error
      npm error
      BananaJoeB Online
      BananaJoeB Online
      BananaJoe
      @diamand2k22 öhm, warum gibst du npm Befehle ein?
      • D Diamand2k22
        @Thomas-Braun
        npm error
        npm error
        npm error
        npm error Usage:
        npm error npm ci
        npm error
        npm error Options:
        npm error
        npm error
        @diamand2k22 sagte in Zigbee2MQTT Build Fehler:
        Davon hab ich keine Ahnung, weil nicht im Einsatz.
        Da scheinen mir aber veraltete Versionen im Spiel zu sein.
        Sicher, dass man das so überhaupt installiert und aktuell hält?
        • mickymM Offline
          mickymM Offline
          mickym
          Für zigbee2mqtt gibts ein eigenes Script im zigbee Verzeichnis. Mit dem user ausführen, mit dem man installiert hat. Und Adapter updated man ganz normal im Admin.
          Warum liest man die Doku nicht?
          https://www.zigbee2mqtt.io/guide/installation/01_linux.html#for-later-update-zigbee2mqtt-to-the-latest-version
            Diamand2k22
            ja die install anleitung ist von zigbee2mqtt.io.
            ich installier immer den dev branch.
            soll ich es mal mit npm install probieren in dem zigbee Ordner? dann sollten zumindest mal die npm depencies aktualisiert werden oder?
            @mickym
            das Skript funktioniert bei mir nicht, da er nie die Unterschiede auflösen kann.
            • D Diamand2k22
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              @diamand2k22 Versteh ich zwar nicht - dann ist die Installation komisch. Dann würde ich lieber neu installieren und ggf. das data Verzeichnis retten. Wenn das update Skript nicht klappt - führst Du es ggf. unter dem falschen User aus. Der User der richtig ist, siehst Du an den Rechten der Dateien.
              • mickymM mickym
                Diamand2k22
                @mickym
                das data Verzeichnis habe ich wegkopiert, inwiefern meinst du neu installieren?
                • D Diamand2k22
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @diamand2k22 Nun ich würde mich halt das Verzeichnis nochmal komplett löschen und neu installieren, nach Anleitung:
                  https://www.zigbee2mqtt.io/guide/installation/01_linux.html#installing
                  Nodejs brauchst ja nicht, das hast ja schon. Zum Schluss halt das data Verzeichnis wieder zurückkopieren (und auf die Rechte achten).
                  Oder halt das Update Skript nochmal mit dem richtigen User ausführen:
                  Bei mir ist es der user mwadmin - wie gesagt schauen, welcher User die Rechte hat.
                  • mickymM mickym
                    Diamand2k22
                    @mickym
                    hab gerade die update.sh mit dem entsprechenden User probiert, dann kommt das hier
                    pi4b@pi4b:/opt/zigbee2mqtt$ /opt/zigbee2mqtt/update.sh
                    Checking Zigbee2MQTT status...
                    Updating...
                    Bereits aktuell.
                    Installing dependencies...
                    /opt/zigbee2mqtt/update.sh: Zeile 21: pnpm: Kommando nicht gefunden.
                    wahrscheinlich hat es das npm zerschossen...
                    mickymM Thomas BraunT 2 Antworten Letzte Antwort
                    • D Diamand2k22
                      @mickym
                      Updating...
                      Bereits aktuell.
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @diamand2k22 Na dann schau mal, ob die Rechte bzw. alle Dateien dem User gehören unter dem der Service läuft. Ansonten lösch das Verzeichnis und installiere neu - das data Verzeichnis hast Du ja wegkopiert und da ist Deine Konfig drin.
                      Um sicher zu gehen, dass Du den richtigen User hast, schau Dir mit
                      systemctl status zigbee2mqtt
                      den Service an.
                      Du solltest so eine Ausgabe bekommen:
                      mwadmin@mwzigbee2mqtt:/lib/systemd/system$ systemctl status zigbee2mqtt
                      ● zigbee2mqtt.service - zigbee2mqtt
                           Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
                           Active: active (running) since Wed 2024-12-04 14:07:38 CET; 1 day 7h ago
                         Main PID: 121 (npm start)
                            Tasks: 23 (limit: 9189)
                           Memory: 190.1M
                              CPU: 36min 17.701s
                           CGroup: /system.slice/zigbee2mqtt.service
                                   ├─121 "npm start"
                                   ├─286 sh -c "node index.js"
                                   └─287 node index.js
                      Dort siehst Du auch den Pfad zur Konfig:
                      Dort siehst Du unter welchem User der Service läuft und NUR mit diesem darfst Du arbeiten:
                      cat zigbee2mqtt.service
                      [Unit]
                      Description=zigbee2mqtt
                      After=network.target
                      [Service]
                      Environment=NODE_ENV=production
                      Type=exec
                      ExecStart=/usr/bin/npm start
                      WorkingDirectory=/opt/zigbee2mqtt
                      StandardOutput=inherit
                      # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
                      StandardError=inherit
                      Restart=always
                      RestartSec=10s
                      User=mwadmin
                      [Install]
                      WantedBy=multi-user.target
                      Also:
                      • D Diamand2k22
                        @mickym
                        Updating...
                        Bereits aktuell.
                        pnpm ist nicht npm. Setzt aber mindestens nodejs>=18.12 voraus.
                        • mickymM mickym
                          den Service an.
                               Memory: 190.1M
                                  CPU: 36min 17.701s
                                       ├─121 "npm start"
                                       └─287 node index.js
                          [Unit]
                          [Service]
                          Type=exec
                          Restart=always
                          RestartSec=10s
                          User=mwadmin
                          [Install]
                          Also:
                          Diamand2k22
                          @mickym
                          pi4b@pi4b:~$ systemctl status zigbee2mqtt.service
                               Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
                               Active: activating (auto-restart) (Result: exit-code) since Thu 2024-12-05 21:45:00 CET; 3s ago
                              Process: 1058968 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
                             Main PID: 1058968 (code=exited, status=1/FAILURE)
                          das ist Ausgabe
                          • D Diamand2k22
                            @mickym
                            das ist Ausgabe
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @diamand2k22 Dann läuft Dein Service gar nicht. Entweder kommt unten noch ein Fehler oder Du schaust mit journalctl was der Fehler ist. - Wie gesagt ich würde neu installieren nach Anleitung.
                            Aussehen muss der Service wie bei mir. Aber im jetzigen Zustand läuft dein zigbee2mqtt gar nicht.
                            • mickymM mickym
                              Diamand2k22
                              @mickym
                              ok...jetzt bin ich schon mal weiter!
                              pi4b@pi4b:~$ node --version
                              v20.18.1
                              pi4b@pi4b:~$ npm --version
                              10.8.2
                              pi4b@pi4b:~$ sudo mkdir /opt/zigbee2mqtt
                              pi4b@pi4b:~$ sudo chown -R pi4b:pi4b /opt/zigbee2mqtt
                              pi4b@pi4b:~$ sudo chmod -R 755 /opt/zigbee2mqtt
                              pi4b@pi4b:~$ git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt
                              Klone nach '/opt/zigbee2mqtt'...
                              remote: Enumerating objects: 143, done.
                              remote: Counting objects: 100% (143/143), done.
                              remote: Compressing objects: 100% (138/138), done.
                              remote: Total 143 (delta 7), reused 62 (delta 1), pack-reused 0 (from 0)
                              Empfange Objekte: 100% (143/143), 572.27 KiB | 1.50 MiB/s, fertig.
                              Löse Unterschiede auf: 100% (7/7), fertig.
                              pi4b@pi4b:~$ cd /opt/zigbee2mqtt
                              npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                              npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                              added 646 packages, and audited 647 packages in 22s
                              90 packages are looking for funding
                                run `npm fund` for details
                              found 0 vulnerabilities
                              pi4b@pi4b:/opt/zigbee2mqtt$ npm run build
                              > zigbee2mqtt@1.42.0 build
                              > tsc && node index.js writehash
                              jetzt start ich mal den service....
                              • D Diamand2k22
                                @mickym
                                v20.18.1
                                10.8.2
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @diamand2k22 Erst mal starten und wie Du den Service einrichtest, siehst Du ja hier: https://www.zigbee2mqtt.io/guide/installation/01_linux.html#optional-running-as-a-daemon-with-systemctl
                                Wenn Du es richtig gemacht hast, dann sollten Deine Dateien alle dem User pi gehören.
                                • mickymM mickym
                                  Diamand2k22
                                  @mickym
                                  sieht wieder gut aus
                                  pi4b@pi4b:/opt/zigbee2mqtt$ sudo chown -R pi4b:pi4b /opt/zigbee2mqtt
                                  pi4b@pi4b:/opt/zigbee2mqtt$ sudo chmod -R 755 /opt/zigbee2mqtt
                                  pi4b@pi4b:/opt/zigbee2mqtt$ sudo systemctl start zigbee2mqtt
                                  pi4b@pi4b:/opt/zigbee2mqtt$ systemctl status zigbee2mqtt.service
                                       Active: active (running) since Thu 2024-12-05 21:53:34 CET; 6s ago
                                     Main PID: 1059382 (npm start)
                                        Tasks: 23 (limit: 8754)
                                          CPU: 8.916s
                                               ├─1059382 "npm start"
                                               ├─1059393 sh -c "node index.js"
                                               └─1059394 node index.js
                                  Dez 05 21:53:34 pi4b systemd[1]: Started zigbee2mqtt.service - zigbee2mqtt.
                                  Dez 05 21:53:35 pi4b npm[1059382]: > zigbee2mqtt@1.42.0 start
                                  Dez 05 21:53:35 pi4b npm[1059382]: > node index.js
                                  Dez 05 21:53:35 pi4b npm[1059394]: Starting Zigbee2MQTT without watchdog.
                                  • D Diamand2k22
                                    @mickym
                                            CPU: 8.916s
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @diamand2k22 Ja das sieht gut aus und nun hast Du ja automatisch die aktuellste Version. Und in Zukunft nur das Skript ./update.sh im zigbee2mqtt unter dem User PI ausführen.
                                    Wenn Du das data Verzeichnis zurückkopierst, schauen dass die Rechte alle dem User pi gehören.
                                    • mickymM mickym
                                      Diamand2k22
                                      @mickym
                                      passt, danke dir für deine Hilfe!
                                      bist jetzt hab ich immer den DEV Branch genutzt, weil teilweise Geräte noch nicht im Stable Repository drin waren.
                                      Das habe ich dann immer wie folgt installiert (bisher ohne Probleme). Grund für die Installationsweise ist, das er bei mir nie die Unterschiede auflösen kann, auch mit dem entsprechenden User.
                                      DEV Branch:
                                      sudo systemctl stop zigbee2mqtt
                                      sudo rm -r /opt/zigbee2mqtt
                                      cd /opt/zigbee2mqtt
                                      git fetch origin dev
                                      git config --get remote.origin.fetch
                                      git config remote.origin.fetch "+refs/heads/*:refs/remotes/origin/*"
                                      git fetch --all
                                      git checkout dev
                                      npm ci
                                      npm run build
