  4. Mihome-vacuum Adapter error Socket Close nach Node.js update
    1.0k
    6.1k
8 Beiträge 4 Kommentatoren 837 Aufrufe 3 Beobachtet
  • Elektroniker86E Offline
    Elektroniker86
    nachdem ich meine ioBroker Instanz auf die aktuellste Node.js: v20.18.1 aktualisiert hatte, läuft der Mihome-vacuum Adapter leider nicht mehr. Im Log kommt oben genannter Fehler.
    mihome-vacuum.0
    2024-12-01 13:48:05.866	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:47:53.864	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:47:41.864	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:47:29.861	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:47:17.859	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:47:05.857	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:46:53.855	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:46:41.854	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:46:29.852	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:46:17.851	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:46:05.848	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:45:53.848	debug	Helo message Timeout
    mihome-vacuum.0
    2024-12-01 13:45:51.847	debug	server started on 0.0.0.0:53421
    mihome-vacuum.0
    2024-12-01 13:45:51.847	info	IOT enabled, create state
    mihome-vacuum.0
    2024-12-01 13:45:51.845	debug	MIIO: Config: ip:192.168.1.91 token: 67336a5578XXXXXXXXX
    mihome-vacuum.0
    2024-12-01 13:45:51.845	debug	Create State for deviceInfounsupported
    mihome-vacuum.0
    2024-12-01 13:45:51.845	debug	Create State for deviceInfowifi_signal
    mihome-vacuum.0
    2024-12-01 13:45:51.845	debug	Create State for deviceInfofw_ver
    mihome-vacuum.0
    2024-12-01 13:45:51.845	debug	Create State for deviceInfomodel
    mihome-vacuum.0
    2024-12-01 13:45:51.845	debug	Create State for deviceInfomac
    mihome-vacuum.0
    mihome-vacuum.0
    2024-12-01 13:45:51.839	debug	load Map creator... true
    mihome-vacuum.0
    2024-12-01 13:45:51.822	info	starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
    mihome-vacuum.0
    2024-12-01 13:45:51.697	debug	Plugin sentry Initialize Plugin (enabled=true)
    mihome-vacuum.0
    2024-12-01 13:45:47.680	info	terminating
    mihome-vacuum.0
    2024-12-01 13:45:47.181	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0
    2024-12-01 13:45:47.180	info	terminating
    mihome-vacuum.0
    2024-12-01 13:45:47.180	error	Socket Close
    mihome-vacuum.0
    2024-12-01 13:45:47.179	info	Got terminate signal TERMINATE_YOURSELF
    mihome-vacuum.0
    2024-12-01 13:44:45.411	info	IOT enabled, create state
    mihome-vacuum.0
    2024-12-01 13:44:45.383	info	starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
    mihome-vacuum.0
    2024-12-01 13:44:41.073	info	terminating
    mihome-vacuum.0
    2024-12-01 13:44:40.573	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0
    2024-12-01 13:44:40.573	info	terminating
    mihome-vacuum.0
    2024-12-01 13:44:40.573	error	Socket Close
    mihome-vacuum.0
    2024-12-01 13:44:40.572	info	Got terminate signal TERMINATE_YOURSELF
    Hat jemand eine Idee wie man das fixt oder hab ich was übersehen?
    Danke schonmal für eure Hilfe!
    • Elektroniker86E Elektroniker86
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      @elektroniker86
      Das sollte aber nichts mit nodejs 20.18.1 zu tun haben, denn:
      2024-12-01 13:56:09.624  - info: mihome-vacuum.0 (85667) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
      2024-12-01 13:56:09.679  - info: mihome-vacuum.0 (85667) IOT enabled, create state
      2024-12-01 13:56:09.739  - info: mihome-vacuum.0 (85667) select standard vacuum protocol....
      2024-12-01 13:56:09.944  - info: mihome-vacuum.0 (85667) create state for carpet_mode
      2024-12-01 13:56:10.327  - info: mihome-vacuum.0 (85667) settest next timer: not available
      Hol mal einen gescheiten Auszug aus dem log ran.
      Per
      iob logs --watch
      z. B.
      Elektroniker86E 1 Antwort Letzte Antwort
        @elektroniker86
        Per
        iob logs --watch
        z. B.
        Elektroniker86
        schrieb am zuletzt editiert von Elektroniker86
        @thomas-braun sagte in Mihome-vacuum Adapter error Socket Close nach Node.js update:
        iob logs --watch
        Ist wirklich komisch, nach dem update liefen beide Adapter nicht mehr hab schon die Adapter mehrmals neu gestartet. Sogar den iob fix habe ich nach dem update durchlaufen lassen -> keine Fehler.
        2024-12-01 14:01:10.305  - info: host.ioBroker stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
        2024-12-01 14:01:10.306  - info: mihome-vacuum.0 (5618) Got terminate signal TERMINATE_YOURSELF
        2024-12-01 14:01:10.307  - error: mihome-vacuum.0 (5618) Socket Close
        2024-12-01 14:01:10.307  - info: mihome-vacuum.0 (5618) terminating
        2024-12-01 14:01:10.308  - debug: mihome-vacuum.0 (5618) Plugin sentry destroyed
        2024-12-01 14:01:10.308  - info: mihome-vacuum.0 (5618) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-12-01 14:01:10.370  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 68.5ms (Tried 0/1 times)
        2024-12-01 14:01:10.383  - info: host.ioBroker stopInstance system.adapter.mihome-vacuum.0 send kill signal
        2024-12-01 14:01:10.808  - info: mihome-vacuum.0 (5618) terminating
        2024-12-01 14:01:10.898  - info: host.ioBroker instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-12-01 14:01:11.250  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:12.306  - info: smartmeter.0 (2661) Received 13 values, 5 updated
        2024-12-01 14:01:13.380  - info: smartmeter.0 (2661) Received 13 values, 5 updated
        2024-12-01 14:01:14.183  - info: host.ioBroker instance system.adapter.mihome-vacuum.0 in version "4.2.0" started with pid 6369
        2024-12-01 14:01:14.456  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:14.609  - debug: mihome-vacuum.0 (6369) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2024-12-01 14:01:14.627  - debug: mihome-vacuum.0 (6369) Objects client ready ... initialize now
        2024-12-01 14:01:14.628  - debug: mihome-vacuum.0 (6369) Objects create System PubSub Client
        2024-12-01 14:01:14.628  - debug: mihome-vacuum.0 (6369) Objects create User PubSub Client
        2024-12-01 14:01:14.664  - debug: mihome-vacuum.0 (6369) Objects client initialize lua scripts
        2024-12-01 14:01:14.667  - debug: mihome-vacuum.0 (6369) Objects connected to redis: 0.0.0.0:9001
        2024-12-01 14:01:14.685  - debug: mihome-vacuum.0 (6369) Redis States: Use Redis connection: 0.0.0.0:9000
        2024-12-01 14:01:14.694  - debug: mihome-vacuum.0 (6369) States create System PubSub Client
        2024-12-01 14:01:14.695  - debug: mihome-vacuum.0 (6369) States create User PubSub Client
        2024-12-01 14:01:14.749  - debug: mihome-vacuum.0 (6369) States connected to redis: 0.0.0.0:9000
        2024-12-01 14:01:14.764  - debug: mihome-vacuum.0 (6369) Plugin sentry Initialize Plugin (enabled=true)
        2024-12-01 14:01:14.888  - info: mihome-vacuum.0 (6369) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
        2024-12-01 14:01:14.904  - debug: mihome-vacuum.0 (6369) load Map creator... true
        2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfo
        2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfomac
        2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfomodel
        2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfofw_ver
        2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfowifi_signal
        2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfounsupported
        2024-12-01 14:01:14.914  - debug: mihome-vacuum.0 (6369) MIIO: Config: ip:192.168.1.91 token: 67336a5578XXXXXXXXX
        2024-12-01 14:01:14.915  - info: mihome-vacuum.0 (6369) IOT enabled, create state
        2024-12-01 14:01:14.916  - debug: mihome-vacuum.0 (6369) server started on 0.0.0.0:53421
        2024-12-01 14:01:15.387  - debug: ping.0 (2512) Pinging alive 192.168.1.95
        2024-12-01 14:01:15.387  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.95
        2024-12-01 14:01:15.527  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:16.118  - debug: ping.0 (2512) Ping result for 192.168.1.95: true in 729ms (Tried 0/1 times)
        2024-12-01 14:01:16.121  - debug: ping.0 (2512) Pinging alive 192.168.1.161
        2024-12-01 14:01:16.121  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.161
        2024-12-01 14:01:16.128  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 4.75ms (Tried 0/1 times)
        2024-12-01 14:01:16.584  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:16.916  - debug: mihome-vacuum.0 (6369) Helo message Timeout
        2024-12-01 14:01:17.658  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:18.746  - info: smartmeter.0 (2661) Received 13 values, 5 updated
        2024-12-01 14:01:19.803  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:20.877  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:21.173  - debug: ping.0 (2512) Pinging alive 192.168.1.95
        2024-12-01 14:01:21.173  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.95
        2024-12-01 14:01:21.355  - debug: ping.0 (2512) Ping result for 192.168.1.95: true in 180ms (Tried 0/1 times)
        2024-12-01 14:01:21.358  - debug: ping.0 (2512) Pinging alive 192.168.1.161
        2024-12-01 14:01:21.358  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.161
        2024-12-01 14:01:21.425  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 65.0ms (Tried 0/1 times)
        2024-12-01 14:01:21.965  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:23.039  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:24.112  - info: smartmeter.0 (2661) Received 13 values, 5 updated
        2024-12-01 14:01:25.203  - info: smartmeter.0 (2661) Received 13 values, 5 updated
        2024-12-01 14:01:26.291  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:26.428  - debug: ping.0 (2512) Pinging alive 192.168.1.95
        2024-12-01 14:01:26.428  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.95
        2024-12-01 14:01:27.199  - debug: ping.0 (2512) Ping result for 192.168.1.95: true in 769ms (Tried 0/1 times)
        2024-12-01 14:01:27.203  - debug: ping.0 (2512) Pinging alive 192.168.1.161
        2024-12-01 14:01:27.203  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.161
        2024-12-01 14:01:27.260  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 54.4ms (Tried 0/1 times)
        2024-12-01 14:01:27.380  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:28.453  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:28.916  - debug: mihome-vacuum.0 (6369) Helo message Timeout
        2024-12-01 14:01:29.559  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:30.007  - debug: unifi.0 (6261) Update started
        2024-12-01 14:01:30.310  - debug: unifi.0 (6261) Login successful
        2024-12-01 14:01:30.341  - debug: unifi.0 (6261) fetchSites: default
        2024-12-01 14:01:30.341  - debug: unifi.0 (6261) Update site: default
        2024-12-01 14:01:30.370  - debug: unifi.0 (6261) fetchSiteSysinfo default: 1
        2024-12-01 14:01:30.445  - debug: unifi.0 (6261) fetchClients default: 77
        2024-12-01 14:01:30.653  - info: smartmeter.0 (2661) Received 13 values, 6 updated
        2024-12-01 14:01:30.944  - debug: unifi.0 (6261) fetchDevices default: 10
        2024-12-01 14:01:31.185  - debug: unifi.0 (6261) fetchWlans default: 3
        2024-12-01 14:01:31.208  - debug: unifi.0 (6261) fetchNetworks default: 9
          iob logs --watch
          @elektroniker86 und englisch ist das auch nicht ;-)
            Elektroniker86
            Ok... falscher Alarm nachdem ich beide Roboter komplett aus und wieder eingeschaltet habe und danach die Instanzen neu gestartet hatte, ist wieder alles grün und connectet.
            Trotzdem Danke!
              Trotzdem Danke!
              @elektroniker86
              Das wollte ich gerade sagen. Denn hier
              antwortet der Sauger nicht.
                Elektroniker86
                Sorry, hab ich mich wohl verklickt.
                Wie kann ich das Thema auf gelöst setzen?
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @elektroniker86
                  Titel im ersten Beitrag editieren
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
