  4. RPI2 Monitor wirft Fehlermeldung raus.
5 Beiträge 2 Kommentatoren 646 Aufrufe 2 Beobachtet
    Beowolf
    ich wollte den RPI2 Adapter installieren.
    Die Adapterinstallation endet mit diesem LOG Hinweis.
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@10.8.2
    2 info using node@v20.18.1
    3 silly config load:file:/usr/lib/node_modules/npm/npmrc
    4 silly config load:file:/opt/iobroker/.npmrc
    5 silly config load:file:/home/iobroker/.npmrc
    6 silly config load:file:/usr/etc/npmrc
    7 verbose title npm install iobroker-community-adapters/ioBroker.rpi2
    8 verbose argv "install" "iobroker-community-adapters/ioBroker.rpi2" "--foreground-scripts"
    9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-11-21T09_11_38_148Z-
    10 verbose logfile /home/iobroker/.npm/_logs/2024-11-21T09_11_38_148Z-debug-0.log
    11 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
    12 silly logfile start cleaning logs, removing 1 files
    13 silly logfile done cleaning log files
    14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    15 silly idealTree buildDeps
    16 silly fetch manifest iobroker.rpi2@iobroker-community-adapters/ioBroker.rpi2
    17 silly placeDep ROOT iobroker.rpi2@2.2.2 OK for: iobroker.inst@3.0.0 want: iobroker-community-adapters/ioBroker.rpi2
    18 silly fetch manifest opengpio@^1.0.16
    19 silly packumentCache full:https://registry.npmjs.org/opengpio cache-miss
    20 silly fetch manifest ci@^2.3.0
    21 silly packumentCache full:https://registry.npmjs.org/ci cache-miss
    22 silly fetch manifest node-dht-sensor@^0.4.3
    23 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor cache-miss
    24 http fetch GET 200 https://registry.npmjs.org/opengpio 20ms (cache hit)
    25 silly packumentCache full:https://registry.npmjs.org/opengpio set size:29380 disposed:false
    26 http fetch GET 200 https://registry.npmjs.org/ci 22ms (cache hit)
    27 silly packumentCache full:https://registry.npmjs.org/ci set size:22895 disposed:false
    28 http fetch GET 200 https://registry.npmjs.org/node-dht-sensor 22ms (cache hit)
    29 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor set size:72767 disposed:false
    30 silly placeDep ROOT ci@2.3.0 OK for: iobroker.rpi2@2.2.2 want: ^2.3.0
    31 silly placeDep ROOT node-dht-sensor@0.4.3 OK for: iobroker.rpi2@2.2.2 want: ^0.4.3
    32 silly placeDep ROOT opengpio@1.0.16 OK for: iobroker.rpi2@2.2.2 want: ^1.0.16
    33 silly fetch manifest node-addon-api@^1.6.3
    34 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
    35 silly fetch manifest debug@^4.3.4
    36 silly packumentCache full:https://registry.npmjs.org/debug cache-miss
    37 http fetch GET 200 https://registry.npmjs.org/node-addon-api 15ms (cache hit)
    38 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:290718 disposed:false
    39 http fetch GET 200 https://registry.npmjs.org/debug 21ms (cache hit)
    40 silly packumentCache full:https://registry.npmjs.org/debug set size:188929 disposed:false
    41 silly placeDep node_modules/node-dht-sensor node-addon-api@1.7.2 OK for: node-dht-sensor@0.4.3 want: ^1.6.3
    42 silly placeDep node_modules/opengpio debug@4.3.7 OK for: opengpio@1.0.16 want: ^4.3.4
    43 silly fetch manifest ms@^2.1.3
    44 silly packumentCache full:https://registry.npmjs.org/ms cache-miss
    45 http fetch GET 200 https://registry.npmjs.org/ms 17ms (cache hit)
    46 silly packumentCache full:https://registry.npmjs.org/ms set size:84885 disposed:false
    47 silly placeDep node_modules/opengpio ms@2.1.3 OK for: debug@4.3.7 want: ^2.1.3
    48 silly reify moves {}
    49 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-win32-x64-msvc
    50 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-win32-x64-msvc' ]
    51 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-win32-ia32-msvc
    52 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-win32-ia32-msvc' ]
    53 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-win32-arm64-msvc
    54 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-win32-arm64-msvc' ]
    55 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-linux-x64-musl
    56 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-linux-x64-musl' ]
    57 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-linux-x64-gnu
    58 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-linux-x64-gnu' ]
    59 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-linux-arm-gnueabihf
    60 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-linux-arm-gnueabihf' ]
    61 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-darwin-x64
    62 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-darwin-x64' ]
    63 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-darwin-universal
    64 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-darwin-universal' ]
    65 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-darwin-arm64
    66 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-darwin-arm64' ]
    67 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-android-arm64
    68 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-android-arm64' ]
    69 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-android-arm-eabi
    70 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-android-arm-eabi' ]
    71 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
    72 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
    73 http fetch GET 200 https://codeload.github.com/iobroker-community-adapters/ioBroker.rpi2/tar.gz/1e17dad080e6908c84cc0a8e3386881d3847943e 295ms (cache revalidated)
    74 verbose stack Error: git dep preparation failed
    74 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
    74 verbose stack     at module.exports (/usr/lib/node_modules/npm/node_modules/pacote/lib/util/npm.js:13:10)
    74 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/git.js:183:14
    74 verbose stack     at async withTempDir (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/with-temp-dir.js:21:14)
    75 error code 1
    76 error git dep preparation failed
    77 error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
    78 error > node-dht-sensor@0.4.3 install
    78 error > node-gyp configure
    78 error
    78 error
    78 error
    78 error > opengpio@1.0.16 install
    78 error > node-gyp rebuild
    78 error
    78 error
    78 error make: Entering directory '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio/build'
    78 error   CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
    78 error make: Leaving directory '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio/build'
    79 error npm warn using --force Recommended protections disabled.
    79 error npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
    79 error npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array instead
    79 error npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
    79 error npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.
    79 error gyp info it worked if it ends with ok
    79 error gyp info using node-gyp@10.1.0
    79 error gyp info using node@20.18.1 | linux | arm64
    79 error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    79 error gyp info spawn /usr/bin/python3
    79 error gyp info spawn args [
    79 error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    79 error gyp info spawn args 'binding.gyp',
    79 error gyp info spawn args '-f',
    79 error gyp info spawn args 'make',
    79 error gyp info spawn args '-I',
    79 error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/node-dht-sensor/build/config.gypi',
    79 error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    79 error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.1/include/node/common.gypi',
    79 error gyp info spawn args '-Dlibrary=shared_library',
    79 error gyp info spawn args '-Dvisibility=default',
    79 error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.1',
    79 error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    79 error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.1/<(target_arch)/node.lib',
    79 error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/node-dht-sensor',
    79 error gyp info spawn args '-Dnode_engine=v8',
    79 error gyp info spawn args '--depth=.',
    79 error gyp info spawn args '--no-parallel',
    79 error gyp info spawn args '--generator-output',
    79 error gyp info spawn args 'build',
    79 error gyp info spawn args '-Goutput_dir=.'
    79 error gyp info spawn args ]
    79 error gyp info ok
    79 error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio/build/config.gypi',
    79 error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio',
    79 error gyp info spawn make
    79 error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    79 error ../cpp/opengpio.cpp:3:10: fatal error: gpiod.hpp: No such file or directory
    79 error     3 | #include <gpiod.hpp>
    79 error       |          ^~~~~~~~~~~
    79 error compilation terminated.
    79 error make: *** [opengpio.target.mk:106: Release/obj.target/opengpio/cpp/opengpio.o] Error 1
    79 error gyp ERR! build error
    79 error gyp ERR! stack Error: `make` failed with exit code: 2
    79 error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
    79 error gyp ERR! System Linux 6.6.51+rpt-rpi-2712
    79 error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    79 error gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio
    79 error gyp ERR! node -v v20.18.1
    79 error gyp ERR! node-gyp -v v10.1.0
    79 error gyp ERR! not ok
    79 error npm error code 1
    79 error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio
    79 error npm error command failed
    79 error npm error command sh -c node-gyp rebuild
    79 error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-21T09_11_41_279Z-debug-0.log
    80 silly unfinished npm timer reify 1732180298438
    81 silly unfinished npm timer reify:unpack 1732180300842
    82 silly unfinished npm timer reifyNode:node_modules/iobroker.rpi2 1732180300842
    83 verbose cwd /opt/iobroker
    84 verbose os Linux 6.6.51+rpt-rpi-2712
    85 verbose node v20.18.1
    86 verbose npm  v10.8.2
    87 verbose exit 1
    88 verbose code 1
    89 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-21T09_11_38_148Z-debug-0.log
    Was läuft da wo falsch?
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
      Beowolf
      schrieb am zuletzt editiert von Beowolf
      Hat sich erledigt.
      Habe alles was ich finden konnte upgedatet. Nun läuft die Installation durch.
      • B Beowolf
        75 error code 1
        78 error
        78 error
        78 error
        78 error
        78 error
        87 verbose exit 1
        88 verbose code 1
        @beowolf sagte in RPI2 Monitor wirft Fehlermeldung raus.:
        Da kann opengpio nicht gebaut werden. Ist das Paket
        libgpiod-dev
        installiert?
        sudo apt update
        apt policy libgpiod-dev
        • B Beowolf
          Hat sich erledigt.
          Das ist ohnehin eine Grundvoraussetzung für ein rundes System.
          Updates immer zeitnah einspielen.
            Beowolf
            Trotzdem Danke für die Info.
