  3. Einsteigerfragen
  4. Installation
  5. influxdb Error: connect ECONNREFUSED 192.168.1.9:8086
Geplant Angeheftet Gesperrt Verschoben Installation
2 Beiträge 2 Kommentatoren 378 Aufrufe 2 Beobachtet
    maximinus
    Den thread mit gleichem Namen vom 11 Feb 2024 habe ich nachvollzogen:
    sudo apt update
    sagt:
    pi@pivpn:~ $ sudo apt update
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
    Hit:3 https://repos.influxdata.com/debian bullseye InRelease
    Get:4 https://packages.grafana.com/oss/deb stable InRelease [7,661 B]
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
    Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [329 kB]
    Get:8 https://packages.grafana.com/oss/deb stable/main armhf Packages [298 kB]
    Fetched 13.9 MB in 7s (2,080 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@pivpn:~ $
    apt policy influxdb*
    sagt:
    pi@pivpn:~ $ apt policy influxdb
    influxdb:
      Installed: 1.8.10-1
      Candidate: 1.8.10-1
      Version table:
     *** 1.8.10-1 500
            500 https://repos.influxdata.com/debian bullseye/stable armhf Packages
            100 /var/lib/dpkg/status
         1.6.7~rc0-1 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    pi@pivpn:~ $
    systemctl status influx*
    sagt:
    pi@pivpn:~ $ systemctl status influx
    Unit influx.service could not be found.
    pi@pivpn:~ $
    sudo du -sh /var/lib/influxdb/
    sagt:
    pi@pivpn:~ $ sudo du -sh /var/lib/influxdb/
    84M     /var/lib/influxdb/
    pi@pivpn:~ $
    Wenn ich influx aufrufe kommt:
    pi@pivpn:~ $ influx
    Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
    Please check your connection settings and ensure 'influxd' is running.
    pi@pivpn:~ $
    Wie mache ich das: Please check your connection settings and ensure 'influxd' is running.
    LG Gerhard
    RasPi 4 4GB bookworm
    nodejs v20.19.4
    npm 10.8.2
    Objects type: jsonl
    States type: redis
    js-controller: 7.0.6
    admin: 7.6.17
    javascript: 8.9.2
    • crunchipC Offline
      crunchipC Offline
      @maximinus sagte in influxdb Error: connect ECONNREFUSED 192.168.1.9:8086:
      raspbian bullseye
      nicht näher auf deine Frage eingegangen, da dein OS zu alt ist und du eh neu installieren musst
