  4. [gelöst] adapter.discovery Exception-Code: EADDRINUSE
6 Beiträge 2 Kommentatoren 289 Aufrufe 2 Beobachtet
    bornholm
    schrieb am zuletzt editiert von bornholm
    In einer neuen ioBroker-Installation auf einem debian bookworm habe ich einen Fehler beim Ausführen von adapter.discovery:
    Exception-Code: EADDRINUSE: addMembership EADDRINUSE
    Welche IP oder welchen Port möchte discovery da verwenden und kann nicht?
    Die Oberfläche unter http://kaczmarek.local:8081 ist erreichbar.
    iob diag:
    bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: kaczmarek
           Icon name: computer-desktop
             Chassis: desktop 🖥
              Kernel: Linux 6.1.0-26-amd64
        Architecture: x86-64
     Hardware Vendor: PC Engines
      Hardware Model: APU2
    Firmware Version: 4.0.7
    OS is similar to:
    model name      : AMD GX-412TC SOC
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:32:30 up  1:17,  3 users,  load average: 0.46, 0.19, 0.20
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2024-11-05 20:32:30 CET
               Universal time: Tue 2024-11-05 19:32:30 UTC
                     RTC time: Tue 2024-11-05 19:32:30
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    faxel
    OPENHAB_HOME=/usr/share/openhab
    HOME=/home/faxel
    GROUPS=faxel cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.1G        902M        2.0G        3.5M        1.5G        3.2G
    Swap:           1.0G          0B        1.0G
    Total:          5.1G        902M        3.0G
    Active iob-Instances:   5
             3898 M total memory
              860 M used memory
              439 M active memory
             1358 M inactive memory
             1879 M free memory
               68 M buffer memory
             1342 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 20:32:31 up  1:17,  3 users,  load average: 0.46, 0.19, 0.20
    Tasks: 135 total,   1 running, 134 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3898.6 total,   1878.2 free,    862.1 used,   1410.6 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.   3036.4 avail Mem
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * openhab.service loaded failed failed openHAB - empowering the smart home
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    3 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     390M  944K  389M   1% /run
    /dev/sda1      ext4       58G  7.5G   48G  14% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     390M     0  390M   0% /run/user/0
    [Tue Nov  5 19:15:11 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Nov  5 19:15:12 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    919M    /var/
    394M    /var/lib
    245M    /var/log
    226M    /var/log/journal/c78b9d697fbc44ff97e67909f99e0528
    Archived and active journals take up 15.3M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    71M     /opt/iobroker/iobroker-data/
    60M     /opt/iobroker/iobroker-data/files
    31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    10M     /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
    5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    kaczmarek           kaczmarek (version: 6.0.11, hostname: kaczmarek     , alive, uptime: 3997)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : kaczmarek                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : kaczmarek                                -  enabled
    + system.adapter.discovery.0              : discovery             : kaczmarek                                -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : kaczmarek                                -  enabled, port: 1883
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
    Objects and States
    Objects:        170
    States:         126
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian bookworm-backports InRelease
    Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          16881      512/node
    tcp        0      0 192.168.0.131:49152     0.0.0.0:*               LISTEN      106        18614      607/gerbera
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        690        522/mosquitto
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      995        529        397/systemd-resolve
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23211      3420/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23206      3420/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18122      521/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          339        1/init
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18679      755/lighttpd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26609      3662/io.admin.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      105        691        522/mosquitto
    tcp6       0      0 :::5355                 :::*                    LISTEN      995        537        397/systemd-resolve
    tcp6       0      0 fe80::f7d5:d386:e:49152 :::*                    LISTEN      106        18615      607/gerbera
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18133      521/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          14596      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          18678      755/lighttpd
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           106        18619      607/gerbera
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15446      1/init
    udp        0      0 127.0.0.1:58576         0.0.0.0:*                           106        18616      607/gerbera
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           102        16545      460/avahi-daemon: r
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           995        528        397/systemd-resolve
    udp        0      0 0.0.0.0:44283           0.0.0.0:*                           102        16547      460/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                106        18621      607/gerbera
    udp6       0      0 :::1900                 :::*                                106        18620      607/gerbera
    udp6       0      0 :::36957                :::*                                102        16548      460/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          15447      1/init
    udp6       0      0 fe80::f7d5:d386:e1c:546 :::*                                0          18201      475/NetworkManager
    udp6       0      0 :::5353                 :::*                                102        16546      460/avahi-daemon: r
    udp6       0      0 :::5355                 :::*                                995        536        397/systemd-resolve
    udp6       0      0 :::30000                :::*                                107        16640      505/minetestserver
    2024-11-05 19:59:57.112  - info: discovery.0 (4153) Done discovering upnp devices. 49 packages received
    2024-11-05 19:59:57.852  - info: discovery.0 (4153) Done discovering ping devices. 9 packages received
    2024-11-05 19:59:57.879  - info: discovery.0 (4153) Found 15 addresses
    2024-11-05 20:00:56.010  - error: discovery.0 (4153) uncaught exception: addMembership EADDRINUSE
    2024-11-05 20:00:56.016  - error: discovery.0 (4153) Error: addMembership EADDRINUSE
        at Socket.addMembership (node:dgram:865:11)
        at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/sma-em.js:94:20)
        at Socket.onListening (node:dgram:261:7)
        at Socket.emit (node:events:519:28)
        at startListening (node:dgram:184:10)
        at node:dgram:375:7
        at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
    2024-11-05 20:00:56.018  - error: discovery.0 (4153) Exception-Code: EADDRINUSE: addMembership EADDRINUSE
    2024-11-05 20:00:56.531  - info: discovery.0 (4153) terminating
    2024-11-05 20:00:56.536  - warn: discovery.0 (4153) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-11-05 20:00:57.031  - info: discovery.0 (4153) terminating
    2024-11-05 20:00:57.157  - error: host.kaczmarek instance system.adapter.discovery.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-11-05 20:00:57.162  - info: host.kaczmarek Restart adapter system.adapter.discovery.0 because enabled
    2024-11-05 20:01:03.485  - info: admin.0 (3662) <== Disconnect system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191 admin
    2024-11-05 20:01:03.534  - info: admin.0 (3662) ==> Connected system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191
    2024-11-05 20:01:03.603  - info: admin.0 (3662) <== Disconnect system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191 admin
    2024-11-05 20:01:04.089  - info: admin.0 (3662) ==> Connected system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191
    2024-11-05 20:01:28.010  - info: host.kaczmarek instance system.adapter.discovery.0 in version "5.0.0" started with pid 4458
    2024-11-05 20:01:32.239  - info: discovery.0 (4458) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2024-11-05 20:01:32.531  - info: discovery.0 (4458) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.0, js-controller: 6.0.11
    EADDRINUSE
    • B bornholm
      iob diag:
      bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
               Chassis: desktop 🖥
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      faxel
      HOME=/home/faxel
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
               3898 M total memory
                860 M used memory
                439 M active memory
               1879 M free memory
                 68 M buffer memory
               1342 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      919M    /var/
      394M    /var/lib
      245M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.1.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        170
      States:         126
      Pending Updates: 0
          at node:dgram:375:7
      EADDRINUSE
      @bornholm sagte in adapter.discovery Exception-Code: EADDRINUSE:
      Schau dir diese Fehler genauer an.
      B 1 Antwort Letzte Antwort
        bornholm
        @thomas-braun sagte in adapter.discovery Exception-Code: EADDRINUSE:
        Danke für den Hinweis.
        dmesg sagt da das Folgende:
        [Di,  5. Nov 2024, 19:15:05] __common_interrupt: 1.55 No irq handler for vector
        [Di,  5. Nov 2024, 19:15:05] __common_interrupt: 2.55 No irq handler for vector
        [Di,  5. Nov 2024, 19:15:05] __common_interrupt: 3.55 No irq handler for vector
        Diese Fehler kann man wohl ignorieren. Sie treten seit Jahren mit bestimmten AMD CPUs auf und haben laut diverser Netzfundstellen keine Auswirkungen.
          bornholm
          Etwas mehr Logbuch:
          2024-11-06 00:04:16.295  - error: discovery.0 (10404) Error: addMembership EADDRINUSE
              at node:dgram:375:7
          2024-11-06 00:04:16.297  - error: discovery.0 (10404) Exception-Code: EADDRINUSE: addMembership EADDRINUSE
          Kann man den Loglevel eigentlich erhöhen um mehr zu sehen?
          • B bornholm
            Etwas mehr Logbuch:
                at node:dgram:375:7
            Ja, auf debug und als höchste Stufe noch auf silly.
            Da scheint es aber bei sma-em zu haken.
              bornholm
              Wo denn ? ;)
              In sma-em.js:94 scheitert dann wohl ein client.addMembership
                  // Bind socket to the multicast address on all ipv4 devices except localhost
                  client.bind(MULTICAST_PORT, () => {
                      const addresses = tools.getIP4addresses();
                      for (const dev of addresses) {
                          debug && options.log.debug(`Listen via UDP on Device ${dev.name} with IP ${dev.ip} on Port ${MULTICAST_PORT} for Multicast IP ${MULTICAST_IP}`);
                          client.addMembership(MULTICAST_IP, dev.ip);
              Und bei "multicast" dachte ich: komisch, falsches Netzwerk? Und schaute in die Networkmanager Konfiguration, da schau her:
              [ipv4]
              address1=192.168.0.131/32,192.168.0.10
              address2=192.168.0.131/24
              Keine Ahnung wie der Unsinn da rein kommt, die APU Box hatte ich für verschiedenen Basteleien verwendet. War wahrscheinlich mal wieder zu spät =)
              Nachdem das /24 richtig drin steht ist der discovery Fehler verschwunden.
