  4. iobroker.js-con 100% cpu
    6.4k
86 Beiträge 9 Kommentatoren 13.7k Aufrufe 8 Beobachtet
  • spicerS spicer
    			v.2024-10-19
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-2712
        Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		64 bit
    Timezone: 		Europe/Zurich (CET, +0100)
    User-ID: 		1000
    Display-Server: 	true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	1
    Nodejs-Installation:
    /usr/bin/nodejs 	v20.18.0
    /usr/bin/node 		v20.18.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.3
    Recommended versions are nodejs 20.18.0 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            8.4G        2.4G        3.3G         80M        2.9G        6.0G
    Swap:           209M          0B        209M
    Total:          8.7G        2.4G        3.5G
    Active iob-Instances: 	11
    Upgrade policy: none
    ioBroker Core: 		js-controller 		6.0.11
    			admin 			7.1.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		11171
    States: 		10600
    Size of iob-Database:
    28M	/opt/iobroker/iobroker-data/objects.jsonl
    18M	/opt/iobroker/iobroker-data/states.jsonl
    Operating System is the current Debian stable version codenamed 'bookworm'!
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
           Icon name: computer
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     19:06:22 up 8 days,  5:22,  4 users,  load average: 0.47, 0.82, 0.73
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2024-11-18 19:06:22 CET
               Universal time: Mon 2024-11-18 18:06:22 UTC
                     RTC time: Mon 2024-11-18 18:06:22
                    Time zone: Europe/Zurich (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    daniel
    HOME=/home/daniel
    GROUPS=daniel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.4G        2.2G        3.5G         80M        3.0G        6.3G
    Swap:           209M          0B        209M
    Total:          8.7G        2.2G        3.7G
             8052 M total memory
             2053 M used memory
             2302 M active memory
             1965 M inactive memory
             3358 M free memory
              347 M buffer memory
             2466 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 19:06:22 up 8 days,  5:22,  4 users,  load average: 0.47, 0.82, 0.73
    Tasks: 226 total,   1 running, 225 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.3 total,   3358.0 free,   2053.7 used,   2814.6 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5998.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     806M  6.2M  800M   1% /run
    /dev/sda2      ext4       58G  8.5G   47G  16% /
    tmpfs          tmpfs     4.0G  448K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/sda1      vfat      511M   76M  436M  15% /boot/firmware
    tmpfs          tmpfs     806M  160K  806M   1% /run/user/1000
    [Sun Nov 10 13:43:45 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:6C:BC:CC vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=6221f4d0-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Nov 10 13:43:47 2024] EXT4-fs (sda2): mounted filesystem 461fb03e-8771-4663-bbaf-82d08f9f667d ro with ordered data mode. Quota mode: none.
    [Sun Nov 10 13:43:48 2024] EXT4-fs (sda2): re-mounted 461fb03e-8771-4663-bbaf-82d08f9f667d r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE    FSTYPE      OPTIONS
    /                    /dev/sda2 ext4        rw,noatime
    |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G	/var/
    562M	/var/log
    559M	/var/log/journal/314adfe5e576468c98c86afebd8547cb
    203M	/var/lib
    Archived and active journals take up 558.6M in the file system.
    /opt/iobroker/backups:
    75M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G	/opt/iobroker/iobroker-data/
    888M	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    29M	/opt/iobroker/iobroker-data/objects.jsonl
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03219092-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 710547)
    Core adapters versions
    js-controller: 	6.0.11
    admin: 		7.1.5
    javascript: 	8.8.3
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      system.adapter.email.0                  : email                 : iobroker                                 - disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.heizoel24-mex.0          : heizoel24-mex         : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "heizoel24-mex": 1.3.5    , installed 1.3.5
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.1  [Updatable]
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "solarmanpv"   : 0.6.1    , installed 0.6.1
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects: 	11171
    States: 	10600
    Hit:1 http://phoscon.de/apt/deconz generic InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13804      3032/io.mqtt.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6719       995/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16091      2734/deCONZ
    tcp        0      0 0.0.0.0:81              0.0.0.0:*               LISTEN      0          11387      1595/nginx: master
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16116      2734/deCONZ
    tcp        0      0 0.0.0.0:444             0.0.0.0:*               LISTEN      0          11388      1595/nginx: master
    tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          4778       748/rsyslogd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7699       956/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7704       956/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3227919    221748/cupsd
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          11385      1595/nginx: master
    tcp6       0      0 :::5900                 :::*                    LISTEN      992        9280       980/wayvnc
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6721       995/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          11386      1595/nginx: master
    tcp6       0      0 :::514                  :::*                    LISTEN      0          4779       748/rsyslogd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3227918    221748/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16166      2813/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16927      2951/io.web.0
    udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          4773       748/rsyslogd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6537       735/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18441      3014/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13581      2734/deCONZ
    udp        0      0 0.0.0.0:35370           0.0.0.0:*                           104        6539       735/avahi-daemon: r
    udp6       0      0 :::514                  :::*                                0          4774       748/rsyslogd
    udp6       0      0 fe80::514c:7b18:567:546 :::*                                0          9635       945/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        6538       735/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       18443      3014/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       18442      3014/io.deconz.0
    udp6       0      0 :::40741                :::*                                104        6540       735/avahi-daemon: r
    2024-11-18 19:03:00.037  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 50.7 °C
    2024-11-18 19:03:00.038  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 3299
     MB von 922MB (358%)
    2024-11-18 19:03:11.359  - info: admin.0 (2813) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts
    2024-11-18 19:03:11.360  - info: admin.0 (2813) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts-show
    2024-11-18 19:03:25.107  - info: admin.0 (2813) ==> Connected system.user.admin from ::ffff:192.168.1.10
    2024-11-18 19:03:25.969  - info: admin.0 (2813) ==> Connected system.user.admin from ::ffff:192.168.1.10
    2024-11-18 19:03:36.785  - info: mqtt.1 (3032) Client [mosqpub|24949-Dachrollo] connected with secret 1731953016784_8858
    2024-11-18 19:03:36.787  - info: mqtt.1 (3032) Client [mosqpub|24949-Dachrollo] connection closed: disconnected
    2024-11-18 19:04:00.032  - info: javascript.0 (2885) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
    2024-11-18 19:04:00.034  - info: javascript.0 (2885) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
    2024-11-18 19:05:36.014  - info: host.iobroker instance system.adapter.solarmanpv.0 in version "0.6.1" started with pid 243076
    2024-11-18 19:05:36.823  - info: solarmanpv.0 (243076) starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.18.0, js-controller: 6.0.11
    2024-11-18 19:05:41.095  - info: solarmanpv.0 (243076) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-11-18 19:05:41.609  - info: host.iobroker instance system.adapter.solarmanpv.0 having pid 243076 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-18 19:06:00.048  - info: javascript.0 (2885) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
    2024-11-18 19:06:00.072  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 199
     MB von 2048MB (10%)
    2024-11-18 19:06:00.072  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 48.8 °C
    2024-11-18 19:06:00.073  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 48.5 °C
    2024-11-18 19:06:00.073  - info: javascript.0 (2885) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
    2024-11-18 19:06:00.080  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 3380
     MB von 922MB (367%)
    2024-11-18 19:06:36.993  - info: mqtt.1 (3032) Client [mosqpub|25169-Dachrollo] connected with secret 1731953196993_7235
    2024-11-18 19:06:36.998  - info: mqtt.1 (3032) Client [mosqpub|25169-Dachrollo] connection closed: disconnected
    iob diag has finished.
    #81
    @spicer
    Bring halt mqtt auf Stand.
    spicerS 1 Antwort Letzte Antwort
      @spicer
      spicerS Offline
      spicerS Offline
      spicer
      #82
      Hab den downgraded, wegen einem Fehler. Das CPU-Problem ist auch mit der neuesten Version vorhanden.
      Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
      (Murphys Gesetz)
      Thomas BraunT ESP8266E 2 Antworten Letzte Antwort
      • spicerS spicer
        #83
        @spicer
        Mit deinem GUI-System hast du ja immer wieder Probleme...
        Bin dann auch raus.
        • spicerS spicer
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          schrieb am zuletzt editiert von ESP8266
          #84
          @spicer , und die Mqtt Instanz gehört auf 0.
          Warum ist die nicht auf 0 Installiert worden? Diesen Fehler schleppst du scheinbar schon ewig mit.
          @Thomas-Braun, bei der Gelegenheit, schaust du mal bei mir drüber...
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
           19:41:03 up 4 days,  5:45,  2 users,  load average: 1.19, 0.80, 0.71
          CPU threads: 4
          Current issues:
                         Local time: Mon 2024-11-18 19:41:03 CET
                     Universal time: Mon 2024-11-18 18:41:03 UTC
                           RTC time: Mon 2024-11-18 18:41:03
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.4G        4.3G        623M        5.6M        3.6G        4.1G
          Swap:           209M        1.1M        208M
          Total:          8.7G        4.3G        832M
          Active iob-Instances:   43
                   8052 M total memory
                   4145 M used memory
                   3862 M active memory
                   2990 M inactive memory
                    595 M free memory
                    226 M buffer memory
                   3187 M swap cache
                    199 M total swap
                      1 M used swap
                    198 M free swap
          top - 19:41:03 up 4 days,  5:45,  2 users,  load average: 1.19, 0.80, 0.71
          Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
          MiB Mem :   8052.3 total,    595.1 free,   4145.5 used,   3414.0 buff/cache
          MiB Swap:    200.0 total,    199.0 free,      1.0 used.   3906.8 avail Mem
          *** FILESYSTEM ***
          tmpfs          tmpfs     806M  5.5M  800M   1% /run
          /dev/sda2      ext4      110G  7.7G   97G   8% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          [Thu Nov 14 13:55:31 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:6D:AE:D8 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=5e8525e6-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Nov 14 13:55:34 2024] EXT4-fs (sda2): mounted filesystem 3b445224-0aeb-4897-9108-009ed4211fb4 ro with ordered data mode. Quota mode: none.
          [Thu Nov 14 13:55:35 2024] EXT4-fs (sda2): re-mounted 3b445224-0aeb-4897-9108-009ed4211fb4 r/w. Quota mode: none.
          /var:
          724M    /var/
          248M    /var/cache
          241M    /var/cache/apt
          172M    /var/lib
          142M    /var/lib/apt/lists
          Archived and active journals take up 98.6M in the file system.
          33M     /opt/iobroker/backups/
          1.6G    /opt/iobroker/iobroker-data/
          1.3G    /opt/iobroker/iobroker-data/files
          37M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
          /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 91747)
          js-controller:  7.0.3
          admin:          7.4.0
          javascript:     8.8.3
          nodejs modules from github:     4
          +-- iobroker.apsystems-ecu@0.2.10 (git+ssh://git@github.com/npeter/ioBroker.apsystems-ecu.git#548da10e3e534154e71dcdfa060190a62172ed66)
          +-- iobroker.fakeroku@0.3.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fakeroku.git#b05da5cd96e8e29ddca79839a474a196016a9893)
          +-- iobroker.frontier_silicon@0.3.0 (git+ssh://git@github.com/pdbjjens/ioBroker.frontier_silicon.git#bad61870c48d9f699a2c8112df9dfaf00c7d28fe)
          | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
          + system.adapter.apsystems-ecu.0          : apsystems-ecu         : iobroker                                 -  enabled, compact disabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled, compact disabled
          + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled, compact disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
          + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled, compact disabled
          + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled, compact disabled
            system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled, compact disabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
          + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled, compact disabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact enabled (group 1)
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
          + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled, compact disabled
          + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
          + system.adapter.frontier_silicon.0       : frontier_silicon      : iobroker                                 -  enabled, compact disabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact enabled (group 1)
          + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled, compact disabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled, compact disabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
            system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
          + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, compact enabled (group 1), port: 9090
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled, compact disabled
          + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled, compact disabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1888, bind: 0.0.0.0
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled, compact disabled
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled, compact disabled
            system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, compact disabled, port: 80, 7575, 8000, 8080, 8081, 8899, 554, 9101
            system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled, compact disabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled, compact disabled
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled, compact disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
            system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 192.168.62.15
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled, compact disabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled, compact disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.withings.0               : withings              : iobroker                                 -  enabled, compact disabled
            system.adapter.wled.0                   : wled                  : iobroker                                 - disabled, compact disabled
          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled, compact disabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          + instance is alive
          Active repo(s): beta
          Used repository: beta
          Adapter    "admin"        : 7.4.0    , installed 7.4.0
          Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
          Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
          Adapter    "backitup"     : 3.0.27   , installed 3.0.27
          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
          Adapter    "bshb"         : 0.3.0    , installed 0.3.0
          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
          Adapter    "denon"        : 1.15.12  , installed 1.15.12
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
          Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
          Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
          Adapter    "iot"          : 3.4.3    , installed 3.4.3
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Controller "js-controller": 7.0.3    , installed 7.0.3
          Adapter    "kodi"         : 3.1.0    , installed 3.1.0
          Adapter    "logparser"    : 2.2.2    , installed 2.2.2
          Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "parcel"       : 0.2.8    , installed 0.2.8
          Adapter    "rpi2"         : 2.2.2    , installed 2.2.2
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 8.4.0    , installed 8.4.0
          Adapter    "shuttercontrol": 1.8.4   , installed 1.8.4
          Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.4.0    , installed 3.4.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
          Adapter    "vis-icontwo"  : 1.8.1    , installed 1.8.1
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
          Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
          Adapter    "web"          : 6.3.1    , installed 6.3.1
          Adapter    "withings"     : 0.0.15   , installed 0.0.15
          Adapter    "wled"         : 0.7.3    , installed 0.7.3
          Adapter    "yahka"        : 1.0.9    , installed 1.0.9
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects:        25332
          States:         21239
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2594196    234334/iobroker.js-
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2594201    234334/iobroker.js-
          tcp        0      0 0.0.0.0:36337           0.0.0.0:*               LISTEN      1001       2600918    236997/io.yahka.0
          tcp        0      0 192.168.62.15:1883      0.0.0.0:*               LISTEN      1001       3424204    311977/io.sonoff.0
          tcp        0      0 192.168.62.15:1885      0.0.0.0:*               LISTEN      1001       2597509    235561/io.mqtt.0
          tcp        0      0 192.168.62.15:1884      0.0.0.0:*               LISTEN      1001       2597508    235561/io.mqtt.0
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          773673     77605/ebusd
          tcp        0      0 192.168.62.15:9093      0.0.0.0:*               LISTEN      1001       2595774    235337/io.fakeroku.
          tcp        0      0 192.168.62.15:9094      0.0.0.0:*               LISTEN      1001       2595775    235337/io.fakeroku.
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21494      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6228       749/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:53401           0.0.0.0:*               LISTEN      103        21945      4925/rpc.statd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2614441    240452/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3440322    313339/io.admin.0
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       2605546    238279/io.harmony.0
          tcp6       0      0 :::50000                :::*                    LISTEN      1001       2606193    238228/io.g-homa.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          22668      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6230       749/sshd: /usr/sbin
          tcp6       0      0 :::21                   :::*                    LISTEN      0          2717       739/vsftpd
          tcp6       0      0 :::53547                :::*                    LISTEN      103        21951      4925/rpc.statd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20240      1/init
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       2605547    238279/io.harmony.0
          udp        0      0 127.0.0.1:861           0.0.0.0:*                           0          21937      4925/rpc.statd
          udp        0      0 0.0.0.0:33786           0.0.0.0:*                           103        21942      4925/rpc.statd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2600923    236997/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2600922    236997/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6025       620/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       2600426    236401/io.shelly.0
          udp        0      0 0.0.0.0:34467           0.0.0.0:*                           104        6027       620/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2595776    235337/io.fakeroku.
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2598430    236556/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2598431    236556/io.tuya.0
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2596981    234877/io.broadlink
          udp        0      0 0.0.0.0:39616           0.0.0.0:*                           1001       2596984    234877/io.broadlink
          udp        0      0 0.0.0.0:52088           0.0.0.0:*                           1001       2595553    234877/io.broadlink
          udp6       0      0 :::56490                :::*                                103        21948      4925/rpc.statd
          udp6       0      0 :::111                  :::*                                0          20242      1/init
          udp6       0      0 :::5353                 :::*                                104        6026       620/avahi-daemon: r
          udp6       0      0 :::38369                :::*                                104        6028       620/avahi-daemon: r
          Thomas BraunT spicerS 2 Antworten Letzte Antwort
          • ESP8266E ESP8266
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                     8052 M total memory
                     4145 M used memory
                      595 M free memory
                      226 M buffer memory
                     3187 M swap cache
                      199 M total swap
                        1 M used swap
                      198 M free swap
            *** FILESYSTEM ***
            /var:
            724M    /var/
            248M    /var/cache
            241M    /var/cache/apt
            172M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.4.0
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        25332
            States:         21239
            Pending Updates: 0
            #85
            @esp8266 sagte in iobroker.js-con 100% cpu:
            Nix wirklich wildes zu sehen.
            • ESP8266E ESP8266
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
                       8052 M total memory
                       4145 M used memory
                        595 M free memory
                        226 M buffer memory
                       3187 M swap cache
                        199 M total swap
                          1 M used swap
                        198 M free swap
              *** FILESYSTEM ***
              /var:
              724M    /var/
              248M    /var/cache
              241M    /var/cache/apt
              172M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.4.0
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        25332
              States:         21239
              Pending Updates: 0
              spicerS Offline
              spicerS Offline
              spicer
              #86
              @esp8266
              Wurde wohl mit dem Restore so übernommen. Das Ganze war ja vorher auf einem RPI3.
              (Murphys Gesetz)
