  3. Einsteigerfragen
  4. Installation
  5. vw-connect Adapter nicht mehr verfügbar
Geplant Angeheftet Gesperrt Verschoben Installation
29 Beiträge 4 Kommentatoren 3.8k Aufrufe 4 Beobachtet
    @wibear
    Die Langfassung? Da dürfte es ein paar Fehler hageln.
    W Offline
    W Offline
    wibear
    ```bash
    Script v.2024-10-26 Raspbian
    *** BASE SYSTEM ***
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7l+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     19:54:22 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2024-10-26 19:54:22 CEST
               Universal time: Sat 2024-10-26 17:54:22 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    wibear
    HOME=/home/wibear
    GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.9G        1.3G        1.9G        1.0M        702M        2.5G
    Swap:            99M          0B         99M
    Total:          4.0G        1.3G        2.0G
    Active iob-Instances:   23
             3887 M total memory
             1291 M used memory
              238 M active memory
             1638 M inactive memory
             1894 M free memory
               79 M buffer memory
              622 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 19:54:23 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
    Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.9 us,  0.0 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3887.9 total,   1893.7 free,   1291.5 used,    702.7 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2542.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       29G   12G   17G  41% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     778M  1.1M  777M   1% /run
    /dev/mmcblk0p1 vfat      255M   60M  196M  24% /boot
    tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
    [Sat Oct 26 16:05:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Oct 26 16:05:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Oct 26 16:05:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Oct 26 16:05:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    4.6G    /var/
    2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
    2.9G    /var/log
    856M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    82M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    886M    /opt/iobroker/iobroker-data/
    744M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    10M     /opt/iobroker/iobroker-data/states.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u5 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 4054)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
    + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: patch
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
    Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        6233
    States:         5240
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 https://repos.influxdata.com/debian bullseye InRelease
    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
    Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12074      793/influxd
    tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       115695     11790/io.hm-rpc.1
    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       116210     11809/io.hm-rpc.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14292      833/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       113621     11529/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113626     11529/iobroker.js-c
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14324      864/dnsmasq
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117355     11859/io.shelly.0
    tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       116245     11826/io.mqtt.0
    tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       115664     11771/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12057      833/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        16019      1633/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16546      793/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       117499     11995/io.simple-api
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       115812     11548/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119220     12011/io.web.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14323      864/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14320      864/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      616/dhclient
    udp        0      0 0.0.0.0:60117           0.0.0.0:*                           108        1632       380/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1630       380/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1631       380/avahi-daemon: r
    udp6       0      0 :::47912                :::*                                108        1633       380/avahi-daemon: r
    2024-10-26 19:35:59.872  - info: netatmo-crawler.0 (14397) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-26 19:36:00.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14397 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-26 19:38:20.696  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.7
    2024-10-26 19:40:20.611  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.8
    2024-10-26 19:40:55.044  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14653
    2024-10-26 19:40:57.906  - info: netatmo-crawler.0 (14653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
    2024-10-26 19:40:57.974  - info: netatmo-crawler.0 (14653) Getting data for stationid:70:ee:50:33:0f:3e
    2024-10-26 19:41:17.205  - info: netatmo-crawler.0 (14653) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-26 19:41:17.737  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14653 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-26 19:41:19.284  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
    2024-10-26 19:45:50.558  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.2
    2024-10-26 19:45:55.020  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14873
    2024-10-26 19:45:57.866  - info: netatmo-crawler.0 (14873) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
    2024-10-26 19:45:57.927  - info: netatmo-crawler.0 (14873) Getting data for stationid:70:ee:50:33:0f:3e
    2024-10-26 19:45:58.878  - info: netatmo-crawler.0 (14873) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-26 19:45:59.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14873 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-26 19:50:55.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 16135
    2024-10-26 19:50:58.133  - info: netatmo-crawler.0 (16135) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
    2024-10-26 19:50:58.197  - info: netatmo-crawler.0 (16135) Getting data for stationid:70:ee:50:33:0f:3e
    2024-10-26 19:50:59.665  - info: netatmo-crawler.0 (16135) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-26 19:51:00.207  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 16135 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-26 19:51:51.107  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.5
    2024-10-26 19:52:35.857  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.7
    2024-10-26 19:52:50.596  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.6
    2024-10-26 19:54:34.254  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
    • W wibear
      @thomas-braun sagte in vw-connect Adapter nicht mehr verfügbar:
      Die Langfassung
      Wie bekomme ich diese?
      @wibear
      Die läuft vor der Zusammenfassung über deinen Bildschirm.
      • W wibear
        Hallo zusammen, der vw-connect Adapter sowie seine Instanz waren bis zuletzt noch installiert und haben funktioniert.. Nach einem Backup-Recovery verschwand der Adapter aus der Liste und ich kann ihn nicht finden, auch bei GitHub nicht.
        Ist was dazu bekannt?
        Danke und Grüße
        mcm1957M Offline
        mcm1957M Offline
        mcm1957
        @wibear said in vw-connect Adapter nicht mehr verfügbar:
        Danke und Grüße
        Der Adapter vw-connect ist nur mehr im LATEST / BETA repository verfügbar:
        Der Maintainer hat keine aktuelle Version für das Stable Repository bereitgestellt und auch auf mehrfache Nachfrage nicht bestätigt, dass die (eher veraltete) Version im Stable Repository noch funktionstüchtig ist. Siehe https://github.com/TA2k/ioBroker.vw-connect/issues/316
        Es gibt daher von diesem Adapter derzeit nur eine BETA Version im LATEST Repository. Wenn du diese BETA Version installieren willst, kannst du das durch Auswahl des Beta Repositories oder über "von NPM installieren" im Expertenmodus machen. Bite beachte, dass BETA Versionen generell zum Testen gedacht sind und für produktive Systeme nicht empfohlen werden. Es steht dir frei, den Maintainer zu ersuchen eine geeignete Version für STABLE bereitzustellen.
        Bezüglich INSTALLATION von Github noch die nachfolgende Information:
        Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
        Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
        Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
        Und falls es irgendwie unklar ist:
        ioBroker unterstützt folgende Arten von Installation:
        • aus dem STABLE Repository
          Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
        • aus dem LATEST Repository
          Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
        • direkt von GITHUB
          Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
        • direkt von npm
          Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
        Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        W 2 Antworten Letzte Antwort
        • mcm1957M mcm1957
          Danke und Grüße
          • direkt von GITHUB
          • direkt von npm
          W Offline
          W Offline
          wibear
          @mcm1957
          Guten Morgen und danke für den Hinweis. Ich habe mich einfach gewundert, warum dieser Adapter plötzlich verschwunden ist. Schade, dass er nicht weiter entwickelt wird.
          • W wibear
            @mcm1957
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            @mcm1957
            Das möchte ich nicht so im Raum stehen lassen. Meiner Info nach wird der Adapter durchaus weiter entwickelt - nur eher im "Quick and Dirty" Stil. Das soll jetzt nicht abwertend klingen sondern nur beschreiben, dass das Drumherum (Changelog, Readme, Stable Requests, ...) eingespart werden und der Grundgedanke "Hauptsache es läuft mal" überwiegt.
            Jeder Dev hat nur maximal 24h am Tage Zeit. Und je nach User ist auch eine Software die wenig gestestet ist und mal eben so angepasst wird ausreichend. Das muss jeder User selbst entscheiden. Derzeit ist nicht geplant den Adapter aus LATEST zu entfernen.
            • mcm1957M mcm1957
              Danke und Grüße
              • direkt von GITHUB
              • direkt von npm
              W Offline
              W Offline
              wibear
              @mcm1957 sagte in vw-connect Adapter nicht mehr verfügbar:
              Wie kann ich es bitte finden? vw-connect ist weder von npm noch von github auffindbar.
              • W wibear
                @wibear
                iobroker url iobroker.vw-connect@latest --debug
                Damit mal probiert?
                W 1 Antwort Letzte Antwort
                  @wibear
                  Damit mal probiert?
                  W Offline
                  W Offline
                  wibear
                  Damit mal probiert?
                  Danke, es funktioniert jetzt.
                  • J Offline
                    jupedi
                    Hallo
                    habe jetzt einige Zeit gebraucht, um auf die Daten meines Tavascan zuzugreifen.
                    (vw-connect: 0.7.13)
                    Lange erfolglos. Hatte auch erst die hier bereits genannte Token warning usw.
                    Ich war mir auch nicht sicher, ob Cupra derzeit überhaupt funktioniert, da es im Kopf nicht mehr genannt wird.
                    Der Fehler war letztlich, ich hatte als Type immer Seat Cupra #2 Alternativ eingestellt.
                    (War für mich naheliegend, da ich sonst nichts passend fand und auch keine Elli Wallbox besitze)
                    Da mir nichts mehr besseres einfiel, habe ich den Type einfach mal auf My SEAT umgestellt und oh Wunder, es functioniert.
                    Vielleicht hilft es ja jemand.
