  4. Mal wieder BLE Probleme
58 Beiträge 5 Kommentatoren 7.3k Aufrufe 4 Beobachtet
  • T Tenor 0
    ich stosse immer wieder auf die Meldung:
    bluetoothd[3674]: Failed to set privacy: Rejected (0x0b)
    2024-10-12T20:41:52.551245+02:00 server systemd[1]: bluetooth.service: Deactivated successfully.
    2024-10-12T20:41:52.551384+02:00 server systemd[1]: Stopped bluetooth.service - Bluetooth service.
    2024-10-12T20:41:54.589079+02:00 server systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
    2024-10-12T20:41:54.814941+02:00 server systemd[1]: Configuration file /run/systemd/system/systemd-networkd-wait-online.service.d/10-netplan.conf is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
    2024-10-12T20:41:55.201508+02:00 server (uetoothd)[3674]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
    2024-10-12T20:41:55.201632+02:00 server systemd[1]: Starting bluetooth.service - Bluetooth service...
    2024-10-12T20:41:55.250612+02:00 server bluetoothd[3674]: Bluetooth daemon 5.72
    2024-10-12T20:41:55.251545+02:00 server systemd[1]: Started bluetooth.service - Bluetooth service.
    2024-10-12T20:41:55.251591+02:00 server bluetoothd[3674]: Starting SDP server
    2024-10-12T20:41:55.251620+02:00 server bluetoothd[3674]: Excluding (cli) sap
    2024-10-12T20:41:55.251891+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support csip plugin
    2024-10-12T20:41:55.251945+02:00 server bluetoothd[3674]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
    2024-10-12T20:41:55.251988+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support micp plugin
    2024-10-12T20:41:55.252020+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support vcp plugin
    2024-10-12T20:41:55.252045+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support mcp plugin
    2024-10-12T20:41:55.252070+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support bass plugin
    2024-10-12T20:41:55.252095+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support bap plugin
    2024-10-12T20:41:55.252554+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
    2024-10-12T20:41:55.252690+02:00 server dbus-daemon[971]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.45' (uid=0 pid=3674 comm="/usr/libexec/bluetooth/bluetoothd --noplugin=sap" label="unconfined")
    2024-10-12T20:41:55.252765+02:00 server bluetoothd[3674]: Bluetooth management interface 1.22 initialized
    2024-10-12T20:41:55.252793+02:00 server bluetoothd[3674]: Battery Provider Manager created
    2024-10-12T20:41:55.252889+02:00 server bluetoothd[3674]: Failed to set privacy: Rejected (0x0b)
    2024-10-12T20:41:55.253179+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
    2024-10-12T20:41:55.271225+02:00 server systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
    2024-10-12T20:41:55.347612+02:00 server dbus-daemon[971]: [system] Successfully activated service 'org.freedesktop.hostname1'
    2024-10-12T20:41:55.347704+02:00 server systemd[1]: Started systemd-hostnamed.service - Hostname Service.
    2024-10-12T20:41:55.356604+02:00 server bluealsa: bluez.c:783: Registering battery provider: /org/bluez/hci0/battery
    2024-10-12T20:41:55.357266+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/source/1
    2024-10-12T20:41:55.357317+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/source/1
    2024-10-12T20:41:55.357504+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/source/1
    2024-10-12T20:41:55.357618+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/source/2
    2024-10-12T20:41:55.357670+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/source/2
    2024-10-12T20:41:55.357785+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/source/2
    2024-10-12T20:41:55.357890+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/1
    2024-10-12T20:41:55.357930+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/sink/1
    2024-10-12T20:41:55.358065+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/sink/1
    2024-10-12T20:41:55.358135+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/2
    2024-10-12T20:41:55.358155+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/sink/2
    2024-10-12T20:41:55.358215+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/sink/2
    2024-10-12T20:41:55.358275+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
    2024-10-12T20:42:25.372785+02:00 server systemd[1]: systemd-hostnamed.service: Deactivated successfully.
    meistens verschwindet sie nach dem Neustart des Adapters, weiß aber nicht wie relevant sie ist.
    @tenor-0
    rfkill
    sagt?
      @tenor-0
      rfkill
      sagt?
      Tenor 0
      @thomas-braun said in Mal wieder BLE Probleme:
      rfkill
      alles tuti
      matthias@server:~$ rfkill
      ID TYPE      DEVICE      SOFT      HARD
       0 bluetooth hci0   unblocked unblocked
       1 wlan      phy0   unblocked unblocked
      matthias@server:~$ rfkill list
      0: hci0: Bluetooth
              Soft blocked: no
              Hard blocked: no
      1: phy0: Wireless LAN
              Soft blocked: no
              Hard blocked: no
      • T Tenor 0
        rfkill
        alles tuti
        0: hci0: Bluetooth
                Soft blocked: no
                Hard blocked: no
                Soft blocked: no
                Hard blocked: no
        @tenor-0
        Den Haken bei 'Neue Gerät akzeptieren' im Adapter hattest du schon mal gesetzt?
          @tenor-0
          Tenor 0
          ja diverse male
          • T Tenor 0
            ja diverse male
            @tenor-0
            Dann weiß ich nix mehr dazu.
              @tenor-0
              Tenor 0
              Schade, aber Danke für deine Hilfe!
              • haselchenH Offline
                haselchenH Offline
                haselchen
                @tenor-0
                Was sagt
                hciconfig --all
                • haselchenH haselchen
                  @tenor-0
                  Was sagt
                  hciconfig --all
                  Tenor 0
                  matthias@server:~$ sudo hciconfig --all
                  [sudo] password for matthias:
                  hci0:   Type: Primary  Bus: USB
                          BD Address: 8C:88:4B:05:62:63  ACL MTU: 1021:6  SCO MTU: 255:12
                          UP RUNNING
                          RX bytes:4613 acl:0 sco:0 events:349 errors:0
                          TX bytes:38399 acl:0 sco:0 commands:353 errors:0
                          Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
                          Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
                          Link policy: RSWITCH HOLD SNIFF PARK
                          Link mode: PERIPHERAL ACCEPT
                          Class: 0x000000
                          Service Classes: Unspecified
                          Device Class: Miscellaneous,
                          HCI Version: 5.1 (0xa)  Revision: 0xdfc6
                          LMP Version: 5.1 (0xa)  Subversion: 0xd922
                          Manufacturer: Realtek Semiconductor Corporation (93)
                  matthias@server:~$
                  matthias@server:~$
                  matthias@server:~$ sudo hciconfig hci0 down
                          DOWN
                          RX bytes:4896 acl:0 sco:0 events:353 errors:0
                          TX bytes:38411 acl:0 sco:0 commands:357 errors:0
                  matthias@server:~$ sudo hciconfig hci0 up
                  Can't init device hci0: Connection timed out (110)
                  matthias@server:~$
                          DOWN
                          TX bytes:38414 acl:0 sco:0 commands:358 errors:0
                  Nach einem Reboot und anschließendem Neustart des BT Dienstes (das musste wohl wegen dem intern deaktivierten BT Adapter immer gemacht werden) ist auf Linux ebene scheinbar alles ok.
                  Sobald ich den hci0 down nehme kommt er nicht mehr hoch. Das deutet wohl darauf hin, das es doch noch treiber Probleme o.ä, gibt.
                  • C Offline
                    chris299
                    Ich habe auch ein Problem mit BLE, seit ein paar Monaten empfange ich keine Daten mehr (wie ich grade erstaunt festgestellt habe).
                    mein IOBROKER System (auf Ubuntu 22.04 bare metal) läuft auch schon eine Weile unverändert (nicht zuletzt weil ich etwas Angst vor dem nächsten update habe...), so dass daher m.W. keine Veränderung kam, die das hätte auslösen können....
                    Der BLE adapter startet anscheinend einwandfrei und zeigt auch grün, aber in den Daten bekomme ich nur
                    "unknown" in "driverState".... :-(
                    Der hier https://forum.iobroker.net/topic/30179/ble-adapter-grün-driverstate-unknown?_=1730753369874 dazu genannte Befehl hat nicht geholfen. Das betrifft anscheinend auch eher die "unauthorized" Meldung gem. https://github.com/AlCalzone/ioBroker.ble
                    Auf OS-Ebene scheint der bluetooth-stack einwandfrei zu funktionieren, z.B. arbeitet hcitool einfwandfrei und zeigt alles wie erwartet....
                    das Adapter-debug log sieht ein bisschen so aus, als würde der Adapter hängen bleiben, aber er wird ja "grün"...
                    Habt Ihr noch eine Idee, wo ich hingreifen könnte, um das wieder anzuwerfen?
                    2024-11-04 21:58:25.157 - info: ble.0 (802921) Got terminate signal TERMINATE_YOURSELF
                    2024-11-04 21:58:25.159 - info: ble.0 (802921) terminating
                    2024-11-04 21:58:25.161 - info: ble.0 (802921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-11-04 21:58:25.195 - info: host.HP-EliteDesk-800-G3-DM-35W stopInstance system.adapter.ble.0 send kill signal
                    2024-11-04 21:58:25.664 - info: ble.0 (802921) terminating
                    2024-11-04 21:58:25.786 - info: host.HP-EliteDesk-800-G3-DM-35W instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2024-11-04 21:58:28.313 - info: host.HP-EliteDesk-800-G3-DM-35W instance system.adapter.ble.0 started with pid 870418
                    2024-11-04 21:58:28.706 - debug: ble.0 (870418) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2024-11-04 21:58:28.731 - debug: ble.0 (870418) Objects client ready ... initialize now
                    2024-11-04 21:58:28.732 - debug: ble.0 (870418) Objects create System PubSub Client
                    2024-11-04 21:58:28.732 - debug: ble.0 (870418) Objects create User PubSub Client
                    2024-11-04 21:58:28.773 - debug: ble.0 (870418) Objects client initialize lua scripts
                    2024-11-04 21:58:28.775 - debug: ble.0 (870418) Objects connected to redis: 127.0.0.1:9001
                    2024-11-04 21:58:28.803 - debug: ble.0 (870418) Redis States: Use Redis connection: 127.0.0.1:9000
                    2024-11-04 21:58:28.856 - debug: ble.0 (870418) States create System PubSub Client
                    2024-11-04 21:58:28.857 - debug: ble.0 (870418) States create User PubSub Client
                    2024-11-04 21:58:28.920 - debug: ble.0 (870418) States connected to redis: 127.0.0.1:9000
                    2024-11-04 21:58:28.986 - info: ble.0 (870418) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.20.4, js-controller: 5.0.19
                    2024-11-04 21:58:29.048 - info: ble.0 (870418) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                    2024-11-04 21:58:29.048 - info: ble.0 (870418) enabled plugins: Xiaomi, BTHome, _default
                    2024-11-04 21:58:29.048 - info: ble.0 (870418) monitoring all services
                    2024-11-04 21:58:29.097 - info: ble.0 (870418) starting scanner process...
                    2024-11-04 21:59:17.771 - info: admin.0 (1849) ==> Connected system.user.admin from ::ffff:192.168.246.129
                    2024-11-04 21:59:36.498 - info: ble.0 (870418) Now accepting new devices
                    • C chris299
                      @chris299 sagte in Mal wieder BLE Probleme:
                      Dann bring jetzt das Ding auf Stand...
                      Inkl. nodejs und z. B. dem js-controller.
                      C 1 Antwort Letzte Antwort
                        chris299
                        @thomas-braun wenn ich nun den Controller hochziehe und danach die momentan laufenden Versionen diverser Adapter nicht mehr laufen, habe ich ein ernsthaftes Problem, weil die aktuellen Versionen einiger Adapter mit breaking changes daherkommen, und, wie man hier und da lesen kann, kleiner und grössere Problem mitbringen. Allen voran der Zigbee-Adapter, mit dem ich auch lange Schwierigkeiten hatte, bevor er in der nun von mir verwendeten Version für meine Usecases lief.
                        Insofern ist das für mich erst der letzte Schritt der Experimente.... Vorher würde ich gern erstmal analysieren, wo denn da das Problem eigentlich liegt, bevor ich es mit Expermimenten versuche zu lösen.
                        • C chris299
                          @chris299
                          Nicht rum schnacken, bring das Ding auf Stand.
                          Das ist die notwendige Basis für alles weitere.
                            @chris299
                            chris299
                            @thomas-braun also node ist doch mit v18.20.4 auf einem aktuellen Stand. und was den Controller betrifft kann das nicht der Grund für mein Problem sein. Mit meiner derzeitigen Controller-Version und der Adapterversion von BLE lief es ja schon mal.
                            Und tut mir leid, aber PRODUKTIONS-Systeme updated man nicht mal eben auf Verdacht, besonders dann nicht, wenn man eine Indikation hat, dass andere bisher funktionierende Teile dann nicht mehr funktionieren.....
                            • C chris299
                              @chris299
                              Nein, nodejs@20 ist aktuell...
                              Tut mir leid, gerade PRODUKTIONS-Systeme hält man auf einem stabilen Stand.
                                @chris299
                                chris299
                                @thomas-braun sagte in Mal wieder BLE Probleme:
                                @chris299
                                genau, und das ist eben oft nicht der neueste Stand.
                                Und ich würde gern wissen, was das eigentliche Problem ist. Alte Versionen sind nicht pauschal immer das Problem, besonders nicht, wenn sie stabil liefen....
                                Ich vermute hier eher ein Problem durch ein OS update im Bluetooth stack mit dem der BLE-Adapter nicht zurecht kommt. "undefined" ist IMHO schon ein starkes Indiz hierfür. mich würde dazu die Meinung von @AlCalzone sehr interssieren.... auch dazu, welche weiteren Analyse-möglichkeiten es gibt.
                                • C chris299
                                  @chris299
                                  @chris299
                                  iob diag
                                  in der Langfassung sagt?
                                  • C chris299
                                    @chris299
                                    Genau, es ist der STABILSTE Stand, in dem die meisten Fehler ausgebügelt sind. Ich rede nicht von Beta-Versionen.
                                    Und ich vermute eher ein Problem durch veraltete Versionen.
                                      chris299
                                      unser Marketing erzählt auch diese Geschichte, sie stimmt halt öfter mal nicht ;-) speziell wenn neue Versionen durch breaking changes in dependencies motiviert sind, und ich glaube es gibt hier genügend solcher Beispiele, wo es dann wirklich unreifes Zeug ins stable geschafft hat, auch bei zentralen Adaptern.
                                      Auch wenn wir hier wohl unterschiedlicher Meinung sind, möchte ich Dir für Dein umfangreiches Engagement im Forum danken.
                                      aber welche? NODE18 ist doch AFAIk immernoch offiziell unterstüzt. BLE-Adapter ist in der aktuellsten Verision, womit nur noch der Controller in Frage kommt. Welchen Einfluss nimmt der denn auf BLE und dessen Kommunikation mit dem OS-Treiber, so dass der Adapter vor drei Monaten einfach aufhört zu funktionieren?
                                      Script v.2024-10-19
                                      *** BASE SYSTEM ***
                                       Static hostname: HP-EliteDesk-800-G3-DM-35W
                                             Icon name: computer-desktop
                                               Chassis: desktop
                                      Operating System: Ubuntu 22.04.5 LTS
                                                Kernel: Linux 6.8.0-45-generic
                                          Architecture: x86-64
                                      OS is similar to: debian
                                      model name      : Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       08:40:52 up 24 days,  8:28,  3 users,  load average: 0.87, 0.58, 0.46
                                      CPU threads: 8
                                      *** LIFE CYCLE STATUS ***
                                      Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
                                      *** TIME AND TIMEZONES ***
                                                     Local time: Tue 2024-11-05 08:40:52 CET
                                                 Universal time: Tue 2024-11-05 07:40:52 UTC
                                                       RTC time: Tue 2024-11-05 07:40:52
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      christoph
                                      HOME=/home/christoph
                                      GROUPS=christoph adm cdrom sudo dip www-data plugdev lpadmin lxd sambashare plex iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video bluetooth
                                      *** DISPLAY-SERVER SETUP ***
                                      Display-Server: true
                                      Desktop:
                                      Terminal:       tty
                                      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                      *** MEMORY ***
                                      Mem:             15G        9.6G        569M        356M        5.7G        5.5G
                                      Swap:           2.0G        2.0G        0.0K
                                      Total:           17G         11G        569M
                                      Active iob-Instances:   31
                                              15867 M total memory
                                               9646 M used memory
                                               4593 M active memory
                                               8986 M inactive memory
                                                569 M free memory
                                                296 M buffer memory
                                               5355 M swap cache
                                               2047 M total swap
                                               2047 M used swap
                                                  0 M free swap
                                      top - 08:40:53 up 24 days,  8:28,  3 users,  load average: 0.87, 0.58, 0.46
                                      Tasks: 381 total,   1 running, 380 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  8.3 us,  2.6 sy,  0.0 ni, 89.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :  15867.9 total,    575.9 free,   9639.5 used,   5652.5 buff/cache
                                      MiB Swap:   2048.0 total,      0.5 free,   2047.5 used.   5547.1 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      tmpfs          tmpfs     1.6G  4.4M  1.6G   1% /run
                                      /dev/nvme0n1p4 ext4      1.8T  476G  1.2T  29% /
                                      tmpfs          tmpfs     7.8G  2.1M  7.8G   1% /dev/shm
                                      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
                                      efivarfs       efivarfs  150K   83K   63K  57% /sys/firmware/efi/efivars
                                      /dev/sda       ext4      7.3T  5.9T  1.1T  86% /media/christoph/Mediathek_big
                                      /dev/nvme0n1p2 vfat      629M   99M  530M  16% /boot/efi
                                      tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run/user/1000
                                      /dev/sdb2      ext4      3.6T  478G  3.0T  14% /run/timeshift/backup
                                      [Sat Oct 12 01:12:00 2024] EXT4-fs (nvme0n1p4): mounted filesystem 6a6fb72d-be1e-4341-bad6-f898f61454a6 ro with ordered data mode. Quota mode: none.
                                      [Sat Oct 12 01:12:00 2024] EXT4-fs (nvme0n1p4): re-mounted 6a6fb72d-be1e-4341-bad6-f898f61454a6 r/w. Quota mode: none.
                                      [Sat Oct 12 01:12:01 2024] EXT4-fs (sda): mounted filesystem 2d65e01a-b73a-4971-9db1-d7945f671ad9 r/w with ordered data mode. Quota mode: none.
                                      [Sat Oct 12 01:12:12 2024] EXT4-fs (sdb2): mounted filesystem 4c212929-f67d-4173-98fe-9dd6dbe9d64b r/w with ordered data mode. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET                                   SOURCE                              FSTYPE      OPTIONS
                                      /                                        /dev/nvme0n1p4                      ext4        rw,relatime,errors=remount-ro
                                      |-/run/user/1000/doc                     portal                              fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                      |-/run/timeshift/backup                  /dev/sdb2                           ext4        rw,relatime,errors=remount-ro
                                      |-/snap/audacity/1051                    /dev/loop0                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/bare/5                           /dev/loop1                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/canonical-livepatch/282          /dev/loop2                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/canonical-livepatch/286          /dev/loop3                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/chromium/2985                    /dev/loop6                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/firefox/5187                     /dev/loop7                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core/16928                       /dev/loop8                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core/17200                       /dev/loop9                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core18/2829                      /dev/loop10                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core18/2846                      /dev/loop11                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core22/1663                      /dev/loop12                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core20/2379                      /dev/loop13                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/cups/1067                        /dev/loop14                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/core22/1621                      /dev/loop15                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/code/173                         /dev/loop16                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/cups/1058                        /dev/loop17                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/curl/1679                        /dev/loop18                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/curl/1754                        /dev/loop19                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gnome-3-28-1804/194              /dev/loop22                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gnome-3-28-1804/198              /dev/loop23                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gnome-3-38-2004/140              /dev/loop24                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gnome-3-38-2004/143              /dev/loop25                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gnome-42-2204/172                /dev/loop26                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gnome-42-2204/176                /dev/loop27                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/gtk-common-themes/1535           /dev/loop28                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/htop/4317                        /dev/loop29                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/htop/4407                        /dev/loop30                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/mediainfo/32                     /dev/loop31                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/mediainfo/34                     /dev/loop32                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/mediainfo-gui/32                 /dev/loop33                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/mediainfo-gui/34                 /dev/loop34                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/remote-touchpad/407              /dev/loop35                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/remote-touchpad/427              /dev/loop36                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/simplescreenrecorder/1           /dev/loop37                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/snap-store/1113                  /dev/loop38                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/snap-store/1216                  /dev/loop39                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/snapd/21465                      /dev/loop40                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/snapd/21759                      /dev/loop41                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/snapd-desktop-integration/247    /dev/loop42                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/var/snap/firefox/common/host-hunspell /dev/nvme0n1p4[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
                                      |-/snap/snapd-desktop-integration/253    /dev/loop43                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/media/christoph/Mediathek_big         /dev/sda                            ext4        rw,relatime,stripe=8191
                                      |-/boot/efi                              /dev/nvme0n1p2                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                                      |-/snap/firefox/5134                     /dev/loop44                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/media/christoph/Media_HDD_4Gb         /dev/sdb2                           ext4        rw,nosuid,nodev,relatime,errors=remount-ro
                                      |-/snap/chromium/2980                    /dev/loop20                         squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      |-/snap/code/174                         /dev/loop5                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      `-/snap/core20/2434                      /dev/loop4                          squashfs    ro,nodev,relatime,errors=continue,threads=single
                                      /var:
                                      131G    /var/
                                      96G     /var/www/nextcloud
                                      96G     /var/www
                                      93G     /var/www/nextcloud/data
                                      62G     /var/www/nextcloud/data/appdata_oc5rohg5lh5m
                                      Archived and active journals take up 3.7G in the file system.
                                      /opt/iobroker/backups:
                                      7.5G    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      15G     /opt/iobroker/iobroker-data/
                                      14G     /opt/iobroker/iobroker-data/history
                                      1.1G    /opt/iobroker/iobroker-data/files
                                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                      37M     /opt/iobroker/iobroker-data/objects.jsonl
                                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a45c4ee898c9eb11b94d914f1d69213e-if00-port0
                                      /dev/serial/by-id/usb-0658_0200-if00
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyUSB0
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v18.20.4
                                      /usr/bin/node           v18.20.4
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.0
                                      nodejs:
                                        Installed: 18.20.4-1nodesource1
                                        Candidate: 18.20.4-1nodesource1
                                        Version table:
                                       *** 18.20.4-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                              100 /var/lib/dpkg/status
                                           18.20.3-1nodesource1 1001
                                           18.20.2-1nodesource1 1001
                                           18.20.1-1nodesource1 1001
                                           18.20.0-1nodesource1 1001
                                           18.19.1-1nodesource1 1001
                                           18.19.0-1nodesource1 1001
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                           12.22.9~dfsg-1ubuntu3.6 500
                                              500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                              500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                                           12.22.9~dfsg-1ubuntu3 500
                                              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      HP-EliteDesk-800-G3-DM-35W HP-EliteDesk-800-G3-DM-35W (version: 5.0.19, hostname: HP-EliteDesk-800-G3-DM-35W, alive, uptime: 2104146)
                                      Core adapters versions
                                      admin:          6.13.16
                                      javascript:     8.8.3
                                      nodejs modules from github:     1
                                      +-- iobroker.iobapp@0.2.1 (git+ssh://git@github.com/DNAngelX/ioBroker.iOSAppAdapter.git#e3bc6d2682eacb766d253c85be3f84486cb10848)
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : HP-EliteDesk-800-G3-DM-35W               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.alias-manager.0          : alias-manager         : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.backitup.0               : backitup              : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.ble.0                    : ble                   : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.cloud.0                  : cloud                 : HP-EliteDesk-800-G3-DM-35W               - disabled
                                        system.adapter.devices.0                : devices               : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.discovery.0              : discovery             : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.echarts.0                : echarts               : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.email.0                  : email                 : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.email.1                  : email                 : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.fb-checkpresence.0       : fb-checkpresence      : HP-EliteDesk-800-G3-DM-35W               - disabled
                                        system.adapter.feiertage.0              : feiertage             : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.flot.0                   : flot                  : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.followthesun.0           : followthesun          : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.history.0                : history               : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.info.0                   : info                  : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.iobapp.0                 : iobapp                : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.iot.0                    : iot                   : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.iqontrol.0               : iqontrol              : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.javascript.0             : javascript            : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.lovelace.0               : lovelace              : HP-EliteDesk-800-G3-DM-35W               - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                                        system.adapter.material.0               : material              : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.mielecloudservice.0      : mielecloudservice     : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.mobile.0                 : mobile                : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.mqtt.0                   : mqtt                  : HP-EliteDesk-800-G3-DM-35W               -  enabled, port: 1883, bind: 192.168.246.131
                                        system.adapter.net-tools.0              : net-tools             : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.netatmo.0                : netatmo               : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.nuki-extended.0          : nuki-extended         : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.opendtu.0                : opendtu               : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.ping.0                   : ping                  : HP-EliteDesk-800-G3-DM-35W               - disabled
                                        system.adapter.plex.0                   : plex                  : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.pushsafer.0              : pushsafer             : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.rest-api.0               : rest-api              : HP-EliteDesk-800-G3-DM-35W               - disabled, port: 8093, bind: 0.0.0.0, run as: admin
                                      + system.adapter.scenes.0                 : scenes                : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.schoolfree.0             : schoolfree            : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.shelly.0                 : shelly                : HP-EliteDesk-800-G3-DM-35W               -  enabled, port: 1882, bind: 192.168.246.131
                                        system.adapter.smartcontrol.0           : smartcontrol          : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.socketio.0               : socketio              : HP-EliteDesk-800-G3-DM-35W               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                        system.adapter.sony-bravia.0            : sony-bravia           : HP-EliteDesk-800-G3-DM-35W               - disabled
                                      + system.adapter.sourceanalytix.0         : sourceanalytix        : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.tr-064.0                 : tr-064                : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.vis.0                    : vis                   : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.web.0                    : web                   : HP-EliteDesk-800-G3-DM-35W               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.webcal.0                 : webcal                : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                        system.adapter.ws.0                     : ws                    : HP-EliteDesk-800-G3-DM-35W               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      + system.adapter.yahka.0                  : yahka                 : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : HP-EliteDesk-800-G3-DM-35W               -  enabled, port: /dev/ttyUSB0
                                      + system.adapter.zwave2.0                 : zwave2                : HP-EliteDesk-800-G3-DM-35W               -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 7.1.5    , installed 6.13.16 [Updatable]
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                      Adapter    "backitup"     : 3.0.25   , installed 2.11.0 [Updatable]
                                      Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                                      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "echarts"      : 1.9.2    , installed 1.7.2  [Updatable]
                                      Adapter    "email"        : 1.3.1    , installed 1.3.1
                                      Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                      Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                      Controller "js-controller": 6.0.11   , installed 5.0.19 [Updatable]
                                      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
                                      Adapter    "material"     : 1.3.1    , installed 1.3.1
                                      Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
                                      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                      Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                                      Adapter    "plex"         : 1.1.4    , installed 1.1.4
                                      Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
                                      Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                      Adapter    "schoolfree"   : 1.1.5    , installed 1.1.5
                                      Adapter    "shelly"       : 8.2.1    , installed 6.6.1  [Updatable]
                                      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                      Adapter    "webcal"       : 1.3.10   , installed 1.3.10
                                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
                                      Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
                                      Objects and States
                                      Objects:        19305
                                      States:         16059
                                      Hit:1 https://linux.teamviewer.com/deb stable InRelease
                                      Hit:2 https://downloads.plex.tv/repo/deb public InRelease
                                      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                                      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Hit:6 https://apt.postgresql.org/pub/repos/apt jammy-pgdg InRelease
                                      Hit:7 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                                      Hit:8 https://ppa.launchpadcontent.net/linuxuprising/libpng12/ubuntu jammy InRelease
                                      Hit:9 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security InRelease
                                      Hit:10 https://ppa.launchpadcontent.net/ondrej/apache2/ubuntu jammy InRelease
                                      Hit:11 https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates InRelease
                                      Hit:12 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
                                      Hit:13 https://esm.ubuntu.com/infra/ubuntu jammy-infra-security InRelease
                                      Hit:14 https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates InRelease
                                      Hit:15 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                      Hit:16 https://ftp.postgresql.org/pub/pgadmin/pgadmin4/apt/jammy pgadmin4 InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:32469           0.0.0.0:*               LISTEN      999        34671433   2850536/Plex DLNA S
                                      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      135        12959      1392/mariadbd
                                      tcp        0      0 127.0.0.1:3551          0.0.0.0:*               LISTEN      0          14580      1926/apcupsd
                                      tcp        0      0 127.0.0.1:44343         0.0.0.0:*               LISTEN      999        34675767   2850838/Plex Plug-i
                                      tcp        0      0 127.0.0.1:43629         0.0.0.0:*               LISTEN      1001       54829568   6486/io.yahka.0
                                      tcp        0      0 127.0.0.1:35587         0.0.0.0:*               LISTEN      999        34672616   2850582/Plex Plug-i
                                      tcp        0      0 127.0.0.1:35253         0.0.0.0:*               LISTEN      999        34674803   2850840/Plex Plug-i
                                      tcp        0      0 0.0.0.0:5432            0.0.0.0:*               LISTEN      137        14422      1345/postgres
                                      tcp        0      0 127.0.0.1:33481         0.0.0.0:*               LISTEN      999        34667320   2850579/Plex Plug-i
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          61613767   887636/cupsd
                                      tcp        0      0 192.168.246.131:1883    0.0.0.0:*               LISTEN      1001       60998124   775858/io.mqtt.0
                                      tcp        0      0 192.168.246.131:1882    0.0.0.0:*               LISTEN      1001       32796      5986/io.shelly.0
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9014       1192/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12996      1192/iobroker.js-co
                                      tcp        0      0 127.0.0.1:41289         0.0.0.0:*               LISTEN      999        34669396   2850478/Plex Plug-i
                                      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      999        34668395   2850433/Plex Media
                                      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      999        34672973   2850538/Plex Tuner
                                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        11706      1006/systemd-resolv
                                      tcp        0      0 127.0.0.1:38639         0.0.0.0:*               LISTEN      1001       3136699    6486/io.yahka.0
                                      tcp        0      0 0.0.0.0:1056            0.0.0.0:*               LISTEN      999        34671426   2850536/Plex DLNA S
                                      tcp        0      0 127.0.0.1:5433          0.0.0.0:*               LISTEN      137        8857       1346/postgres
                                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          18609      2004/smbd
                                      tcp        0      0 127.0.0.1:45109         0.0.0.0:*               LISTEN      1001       60630874   6486/io.yahka.0
                                      tcp        0      0 0.0.0.0:8200            0.0.0.0:*               LISTEN      132        19512      1946/minidlnad
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11815      1253/sshd: /usr/sbi
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6330       1/init
                                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          18610      2004/smbd
                                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       31572      6398/io.socketio.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13863      1849/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       29458      6469/io.web.0
                                      tcp6       0      0 :::32400                :::*                    LISTEN      999        34668393   2850433/Plex Media
                                      tcp6       0      0 :::5900                 :::*                    LISTEN      1000       19739      2206/gnome-remote-d
                                      tcp6       0      0 :::5432                 :::*                    LISTEN      137        14423      1345/postgres
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          61613766   887636/cupsd
                                      tcp6       0      0 :::3389                 :::*                    LISTEN      1000       19737      2206/gnome-remote-d
                                      tcp6       0      0 :::42497                :::*                    LISTEN      1001       33024      6486/io.yahka.0
                                      tcp6       0      0 :::1716                 :::*                    LISTEN      1000       17898      2637/kdeconnectd
                                      tcp6       0      0 :::9192                 :::*                    LISTEN      1001       37051      6654/io.iobapp.0
                                      tcp6       0      0 :::445                  :::*                    LISTEN      0          18607      2004/smbd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          11817      1253/sshd: /usr/sbi
                                      tcp6       0      0 :::80                   :::*                    LISTEN      0          2361518    200297/apache2
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          749        1/init
                                      tcp6       0      0 :::139                  :::*                    LISTEN      0          18608      2004/smbd
                                      udp        0      0 192.168.246.131:5353    0.0.0.0:*                           1001       28345      6018/io.tr-064.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        13587      1101/avahi-daemon:
                                      udp        0      0 192.168.246.131:38362   0.0.0.0:*                           999        34672968   2850433/Plex Media
                                      udp        0      0 127.0.0.1:55415         0.0.0.0:*                           999        34672965   2850433/Plex Media
                                      udp        0      0 0.0.0.0:6587            0.0.0.0:*                           999        34671430   2850536/Plex DLNA S
                                      udp        0      0 0.0.0.0:32410           0.0.0.0:*                           999        34672962   2850433/Plex Media
                                      udp        0      0 0.0.0.0:32412           0.0.0.0:*                           999        34672963   2850433/Plex Media
                                      udp        0      0 0.0.0.0:32413           0.0.0.0:*                           999        34672964   2850433/Plex Media
                                      udp        0      0 0.0.0.0:32414           0.0.0.0:*                           999        34672961   2850433/Plex Media
                                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        11705      1006/systemd-resolv
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6331       1/init
                                      udp        0      0 192.168.246.255:137     0.0.0.0:*                           0          16886      1907/nmbd
                                      udp        0      0 192.168.246.131:137     0.0.0.0:*                           0          16885      1907/nmbd
                                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16873      1907/nmbd
                                      udp        0      0 192.168.246.255:138     0.0.0.0:*                           0          16888      1907/nmbd
                                      udp        0      0 192.168.246.131:138     0.0.0.0:*                           0          16887      1907/nmbd
                                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16874      1907/nmbd
                                      udp        0      0 127.0.0.1:41668         0.0.0.0:*                           999        34672967   2850433/Plex Media
                                      udp        0      0 0.0.0.0:33708           0.0.0.0:*                           114        13589      1101/avahi-daemon:
                                      udp        0      0 192.168.246.131:59144   0.0.0.0:*                           999        34672966   2850433/Plex Media
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           999        34671423   2850536/Plex DLNA S
                                      udp        0      0 239.255.255.250:1900    0.0.0.0:*                           132        19511      1946/minidlnad
                                      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           999        34672969   2850433/Plex Media
                                      udp        0      0 192.168.246.131:51908   0.0.0.0:*                           999        34672970   2850433/Plex Media
                                      udp        0      0 192.168.246.131:60724   0.0.0.0:*                           132        51167039   1946/minidlnad
                                      udp        0      0 0.0.0.0:36799           0.0.0.0:*                           999        34667274   2850536/Plex DLNA S
                                      udp        0      0 0.0.0.0:53405           0.0.0.0:*                           999        34667277   2850536/Plex DLNA S
                                      udp6       0      0 :::5353                 :::*                                114        13588      1101/avahi-daemon:
                                      udp6       0      0 :::111                  :::*                                0          2597       1/init
                                      udp6       0      0 :::58951                :::*                                114        13590      1101/avahi-daemon:
                                      udp6       0      0 :::1716                 :::*                                1000       17897      2637/kdeconnectd
                                      2024-11-05 07:52:12.370  - info: javascript.0 (3255) script.js.Rolladen.sun_protect_OstSeite: positionsänderung rolladen schlafzimmer: 100; bestätigttrue; Ursprungsystem.adapter.shelly.0; Qualität0; zeit: 1730789532370; command: true; letzte änderung1730789532370; kommentar:
                                      2024-11-05 07:52:16.174  - info: history.0 (2961) Delete old history "/opt/iobroker/iobroker-data/history/20221105/history.zigbee.0.54ef4410001ffd4f.illuminance.json"
                                      2024-11-05 07:53:42.744  - info: javascript.0 (3255) script.js.FritzBox.read_Answering_machine_messages: Der Anruf von  Doris Jahn hat 99 sec gedauert
                                      2024-11-05 07:56:07.879  - info: sourceanalytix.0 (6628) Updating SourceAnalytix configuration for : zwave2.0.Node_018.Meter.value_001_electric_kwh_consumed
                                      2024-11-05 07:56:07.882  - info: sourceanalytix.0 (6628) Updating SourceAnalytix configuration for : zwave2.0.Node_018.Meter.value_001_electric_kwh_consumed
                                      2024-11-05 07:57:05.338  - info: shelly.0 (5986) [MQTT] Device with client id "shellyswitch25-D8F15B132C3F" connected!
                                      2024-11-05 08:06:59.450  - info: javascript.0 (3255) script.js.FritzBox.read_Answering_machine_messages: Der Anruf von  Doris Jahn hat 460 sec gedauert
                                      2024-11-05 08:07:37.237  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: {"scriptVersion":"0.1","src":"shellyplusuni-fcb467a626d4","srcBle":{"mac":"38:39:8f:99:0f:a1"},"payload":{"encryption":false,"BTHome_version":2,"pid":26,"battery":100,"button":2,"rssi":-66,"address":"38:39:8f:99:0f:a1"}}
                                      2024-11-05 08:07:37.237  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: 2
                                      2024-11-05 08:07:37.238  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: 38:39:8f:99:0f:a1
                                      2024-11-05 08:07:37.238  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: unlatch by button 1
                                      2024-11-05 08:12:16.178  - info: history.0 (2961) Delete old history "/opt/iobroker/iobroker-data/history/20221105/history.zigbee.0.ec1bbdfffe8ad6c3.opened.json"
                                      2024-11-05 08:12:34.536  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: {"scriptVersion":"0.1","src":"shellyplusuni-fcb467a626d4","srcBle":{"mac":"38:39:8f:99:0f:a1"},"payload":{"encryption":false,"BTHome_version":2,"pid":27,"battery":100,"button":2,"rssi":-81,"address":"38:39:8f:99:0f:a1"}}
                                      2024-11-05 08:12:34.537  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: 2
                                      2024-11-05 08:12:34.537  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: 38:39:8f:99:0f:a1
                                      2024-11-05 08:12:34.537  - info: javascript.0 (3255) script.js.Tuer.Shelly_button_as_key: unlatch by button 1
                                      2024-11-05 08:18:39.524  - info: sourceanalytix.0 (6628) Updating SourceAnalytix configuration for : zwave2.0.Node_018.Meter.value_001_electric_kwh_consumed
                                      2024-11-05 08:18:39.527  - info: sourceanalytix.0 (6628) Updating SourceAnalytix configuration for : zwave2.0.Node_018.Meter.value_001_electric_kwh_consumed
                                      2024-11-05 08:22:53.696  - info: webcal.0 (776226) found 7 calendar objects
                                      2024-11-05 08:22:54.169  - info: webcal.0 (776226) found 10 calendar objects
                                      2024-11-05 08:30:02.025  - info: javascript.0 (3255) script.js.FritzBox.read_Answering_machine_messages: Der Anruf von  Doris Jahn hat 25 sec gedauert
                                      2024-11-05 08:33:00.053  - info: host.HP-EliteDesk-800-G3-DM-35W instance system.adapter.weatherunderground.0 started with pid 963486
                                      2024-11-05 08:33:00.759  - info: weatherunderground.0 (963486) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.20.4, js-controller: 5.0.19
                                      2024-11-05 08:33:04.816  - info: weatherunderground.0 (963486) Terminated (NO_ERROR): Without reason
                                      2024-11-05 08:33:05.361  - info: host.HP-EliteDesk-800-G3-DM-35W instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                                                              v.2024-10-19
                                               Chassis: desktop
                                      Installation:           native
                                      Kernel:                 x86_64
                                      Userland:               64 bit
                                      Timezone:               Europe/Berlin (CET, +0100)
                                      User-ID:                1000
                                      Pending OS-Updates:     0
                                      Pending iob updates:    7
                                      Nodejs-Installation:
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      Recommended versions are nodejs 18.20.4 and npm 10.7.0
                                      nodeJS installation is correct
                                      MEMORY:
                                      Mem:             15G        9.6G        1.1G        356M        5.1G        5.6G
                                      Total:           17G         11G        1.1G
                                      ioBroker Core:          js-controller           5.0.19
                                                              admin                   6.13.16
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                19305
                                      States:                 16059
                                      Size of iob-Database:
                                      47M     /opt/iobroker/iobroker-data/objects.jsonl
                                      20M     /opt/iobroker/iobroker-data/states.jsonl
                                      • C chris299
                                        Script v.2024-10-19
                                        *** BASE SYSTEM ***
                                                 Chassis: desktop
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        CPU threads: 8
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        christoph
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Total:           17G         11G        569M
                                                 9646 M used memory
                                                  569 M free memory
                                                  296 M buffer memory
                                                 5355 M swap cache
                                                 2047 M total swap
                                                 2047 M used swap
                                                    0 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        131G    /var/
                                        96G     /var/www
                                        USB-Devices by-id:
                                        HINT:
                                        /dev/ttyUSB0
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          6.13.16
                                        javascript:     8.8.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        19305
                                        States:         16059
                                        Pending Updates: 0
        v.2024-10-19
                                                 Chassis: desktop
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        MEMORY:
                                        Total:           17G         11G        1.1G
        admin                   6.13.16
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                19305
                                        States:                 16059
                                        @chris299
                                        Und es gibt mindestens genauso viele Fälle, in den ein auf Stand gebracht es System die Kiste wieder ans laufen bekommen hat.
                                        Ich bin jedenfalls hier raus.
                                          @chris299
                                          chris299
                                          @thomas-braun controller und admin sind nun aktuell, aber geändert hat das an meinem ble problem leider nichts. Mal sehen, wann ich mich an das node-update traue....
