  4. [Vorlage] Spotify Skript
    5.7k
javascript
745 Beiträge 95 Kommentatoren 333.5k Aufrufe 41 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    wendy2702
    #161
    @Worn:
    Hi again,
    bei mir gehen die Probleme leider weiter. Im Log erscheint zunächst Folgendes, danach wird der JS Adapter neu gestartet.
    host.raspiben	2018-01-31 08:24:08.386	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
    Caught	2018-01-31 08:24:08.385	error	by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:310:9)
    Caught	2018-01-31 08:24:08.385	error	by controller[0]: at ClientRequest.emit (events.js:188:7)
    Caught	2018-01-31 08:24:08.385	error	by controller[0]: at emitOne (events.js:96:13)
    Caught	2018-01-31 08:24:08.385	error	by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    Caught	2018-01-31 08:24:08.384	error	by controller[0]: at Request.emit (events.js:188:7)
    Caught	2018-01-31 08:24:08.384	error	by controller[0]: at emitOne (events.js:96:13)
    Caught	2018-01-31 08:24:08.384	error	by controller[0]: at self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    Caught	2018-01-31 08:24:08.384	error	by controller[0]: at Request._callback (script.js.Spotify.SpotifyScript:205:16)
    Caught	2018-01-31 08:24:08.384	error	by controller[0]: at script.js.Spotify.SpotifyScript:689:31
    Caught	2018-01-31 08:24:08.382	error	by controller[0]: at CreatePlaybackInfo (script.js.Spotify.SpotifyScript:214:72)
    Caught	2018-01-31 08:24:08.374	error	by controller[0]: TypeError: Cannot read property 'is_playing' of null
    javascript.0	2018-01-31 08:24:08.315	error	at TLSSocket.socketErrorListener (_http_client.js:310:9)
    javascript.0	2018-01-31 08:24:08.315	error	at ClientRequest.emit (events.js:188:7)
    javascript.0	2018-01-31 08:24:08.315	error	at emitOne (events.js:96:13)
    javascript.0	2018-01-31 08:24:08.315	error	at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    javascript.0	2018-01-31 08:24:08.315	error	at Request.emit (events.js:188:7)
    javascript.0	2018-01-31 08:24:08.315	error	at self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    javascript.0	2018-01-31 08:24:08.315	error	at Request._callback (script.js.Spotify.SpotifyScript:205:16)
    javascript.0	2018-01-31 08:24:08.315	error	at script.js.Spotify.SpotifyScript:689:31
    javascript.0	2018-01-31 08:24:08.315	error	at CreatePlaybackInfo (script.js.Spotify.SpotifyScript:214:72)
    javascript.0	2018-01-31 08:24:08.315	error	TypeError: Cannot read property 'is_playing' of null
    javascript.0	2018-01-31 08:24:08.312	error	uncaught exception: Cannot read property 'is_playing' of null
    javascript.0	2018-01-31 08:24:08.260	error	script.js.Spotify.SpotifyScript: erron in Request
    Grüße
    Ben `
    ganz so Problemlos läuft es bei mir dann wohl auch nicht nach 4 Tagen.
    Hatte gerade auch diese log Einträge allerdings ohne restart vom JS Adapter und scheinbar funktioniert das script auch noch.
    Habe das Skript jetzt auch erstmal aus "Common" verschoben und werde weiter beobachten.
    Mirko
    • W Offline
      W Offline
      Worn
      #162
      also in meinem Fall:
      Ich nutze die aktuelle Version und habe dort auch nichts angepasst, außer diesen einen State volume_percent, da dazu immer ein Fehler im Log stand. Aktuell habe ich weiterhin die im letzten Post beschriebenen Fehler. Es funktioniert bei mir meist nur nach einem Neustart ein paar mal beim testen. Wenn das Ganze ein paar Stunden läuft, dann ist ziemlich sicher, dass es nicht mehr klappt.
      Grüße
      Ben
      • L Offline
        Lucky
        #163
        obwohl es bei mir jetzt seit 8 Tagen ohne Probleme läuft, vermute ich etwas … ich werde heute Abend mal eine Änderung ausprobieren
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          #164
          Nutzt du denn auch JS 3.6.1 ?
          Was vermutest du denn?
          :mrgreen:
          • L Offline
            Lucky
            #165
            ich habe JS 3.5.1 neuere werden mir gar nicht angeboten, auch nicht nach manuellem update..
            deutet darauf hin das schon beim Request Modul ein Fehler auftritt, der Rest resultiert daraus @wendy2702:
            Muss jetzt auch mal fragen.
            Hatte bisher Javascript 3.4.0 installiert und scheinbar war es irgendwann mal dabei oder ich hatte "Querystring" mal installiert… in grauer vorzeit.
            Jetzt habe ich das Update auf JS 3.6.1 gemacht und "querystring" fehlt wieder da im Suchpfad:
            /opt/iobroker/node_modules/iobroker.javascript/node_modules/querystring
            nicht vorhanden.
            Welche Methode zum querystring installieren ist denn die Empfehlenswerte um es dauerhaft zu behalten? `
            ich bin der Meinung das es sich nur manuell installieren lässt
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              #166
              @Lucky:
              ich bin der Meinung das es sich nur manuell installieren lässt `
              Welches Repo hast du denn eingstellt? Auf Latest gibt es jetzt schon 3.6.3
              Das es manuell installiert werden muss weiß ich. Meine Frage war gedacht ob ich das in das iobroker directory installieren lasse wo es benötigt wird oder besser in ein „default“ directory und dann als zusätzliches Modul im Adapter angeben soll.
              • L Offline
                Lucky
                #167
                ok, hatte Default noch drin, habe jetzt JS 3.6.3 bis lang läufts
                • wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  #168
                  Hast du das mit der Playlist integration noch vor Augen ?
                  :mrgreen:
                  • L Offline
                    Lucky
                    #169
                    ups :lol:
                    Edit:
                    ehrlich gesagt überlege ich noch wie ich das am besten anstelle, es würde zwar gehen einen Datenpunkt als Number mit den Playlisten als States anzulegen, um diese zur Laufzeit zu ändern würde man aber die Option 'SetObjekt' aktivieren müssen, das würde es für ungeübte wieder schwieriger machen das Skript zum laufen zu bringen.
                    alternativ könnte man einen Datenpunkt als String anlegen der die Namen der Playlisten enthält und dazu einen Nummerischen Index, würde dir das helfen ?
                    • fischi87F Offline
                      fischi87F Offline
                      fischi87
                      #170
                      @Lucky:
                      ups :lol:
                      Edit:
                      alternativ könnte man einen Datenpunkt als String anlegen der die Namen der Playlisten enthält und dazu einen Nummerischen Index, würde dir das helfen ? `
                      was hast du für eine node Version? hat es vielleicht damit etwas zutun warum es bei mir einfach nicht Funktionieren will :?
                      • E Offline
                        el-lutschi
                        #171
                        kann mir jemand sagen wie ich einstelle, dass Shuffel immer "an" ist.
                        Wenn ich unter "Player" Shuffle auf "true" setze passiert einfach nichts.
                        • wendy2702W Online
                          wendy2702W Online
                          wendy2702
                          #172
                          @Lucky:
                          ups :lol:
                          Edit:
                          das mit der Playlist hat sich heute für mich erledigt da ich die Auswahl jetzt anders realisiere.
                          • wendy2702W Online
                            wendy2702W Online
                            wendy2702
                            #173
                            das Script läuft jetzt seit 2 Tagen mit einem Gast Account aus dem Familiy Abo…. Dafür ein DICKES DANKESCHÖN
                            Kann man sich irgendwie anzeigen lassen welche Playlist gerade läuft?
                            Oder kann man eventuell eine solche Funktion in das Script einbauen, also ein Datenpunkt in dem die Aktuelle Playlist steht?
                            Danke und Gruß
                            Mirko
                            • wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              #174
                              Heute morgen kleiner Rückschlag…nichts geht mehr beim starten von Spotify über VIS und das steht im log:
                              javascript.0	2018-02-04 11:31:31.192	error	script.js.Spotify.Spotify_Controll_v050: Fehler 202 Function Refresh_Token
                              javascript.0	2018-02-04 11:31:31.192	error	script.js.Spotify.Spotify_Controll_v050: FEHLER BEIM ERNEUTEN DATEN ANFORDERN !
                              javascript.0	2018-02-04 11:31:31.049	info	script.js.Spotify.Spotify_Controll_v050: Token Saved!
                              javascript.0	2018-02-04 11:31:31.048	info	script.js.Spotify.Spotify_Controll_v050: neuer Token eingetroffen
                              javascript.0	2018-02-04 11:31:30.895	info	script.js.Spotify.Spotify_Controll_v050: Token wird erneut angefordert !
                              javascript.0	2018-02-04 11:31:30.893	info	script.js.Spotify.Spotify_Controll_v050: Access Token Abgelaufen!!
                              • L Offline
                                Lucky
                                #175
                                neue Versionen gibt es ab sofort nur noch im ersten Post auf Seite 1 !!!
                                @wendy2702:
                                Oder kann man eventuell eine solche Funktion in das Script einbauen, also ein Datenpunkt in dem die Aktuelle Playlist steht? `
                                ist in Version 0.5.1 eingebaut ! teste mal
                                @wendy2702:
                                202 bedeutet das der Server die Anfrage angenommen hat, aber sie zur zeit nicht verarbeiten kann, in diesem Fall die Aktion nochmal ausfühen
                                ist aber auch in 0.5.1 verbessert !
                                • wendy2702W Online
                                  wendy2702W Online
                                  wendy2702
                                  #176
                                  Top!
                                  Du bis ja schneller als die Feuerwehr!
                                    MasterG87
                                    #177
                                    Leider funktioniert mein Spotify Skript nicht mehr und es lässt den ganzen Javascript Adapter abstürzen.
                                    Hat jemand eine Idee woran das liegt? Hier der Log Output:
                                    error        Caught by controller[0]: at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:444:12)
                                    error	Caught by controller[0]: at tryToString (fs.js:457:3)
                                    error	Caught by controller[0]: at script.js.Spotify.Spotify:107:28
                                    error	Caught by controller[0]: at Object.parse (native)
                                    error	Caught by controller[0]: SyntaxError: Unexpected end of JSON input
                                    Ich habe die neuste Version vom Skript vom 4.2.2018. Die Befehl node-gyp hat bei mir version 3.6.2 und nodejs hat version 6.12.3. Der javascript iobroker Adapter ist auf Version 3.6.4.
                                    Habt ihr einen Tipp?
                                    • L Offline
                                      Lucky
                                      #178
                                      oben jetzt Version 0.5.3 !
                                      Stabilität verbessert
                                      Tacks jetzt auch als Listenstring
                                      • W Offline
                                        W Offline
                                        Worn
                                        #179
                                        Habe geupdated. Läuft :). Seltsamerweise hatten sich meine Probleme verflüchtigt. Ich habe seit meinem letzten Post keine Probleme mehr gehabt :). Happy user!
                                        • twonkyT Offline
                                          twonkyT Offline
                                          twonky
                                          #180
                                          Ich glaube du hast an einer Stelle ein Zeichen vergessen:
                                          Im Listener für javascript.0.Spotify.Authorization.Authorized:
                                           else if(err==202||(err==502)||(err=401)){  //202,401 und 502 lassen den Interval  weiter laufen
        DummyBody={is_playing:false};//tritt ein wenn kein Player geöffnet ist
        CreatePlaybackInfo(DummyBody)}
                                          Dort fehlt ein = vor der 401. Da es eine Zuweisung mit einer Konstante ist, ist die Bedingung immer erfüllt.
                                          EDIT:
                                          Und ich denke du hast ein Typo drin. Der neue State in Get_Playlist_Tracks heißt "Track_List_Sting", ich denke da fehlt ein r. ;)
