  4. [Gelöst] javascript.0 müllt LOG zu
3 Beiträge 2 Kommentatoren 348 Aufrufe 2 Beobachtet
  • Smart_HomeS Offline
    Smart_HomeS Offline
    Smart_Home
    schrieb am zuletzt editiert von Smart_Home
    folgendes Problem. Ich habe ioBroker komplett auf einem neuen System aufgesetzt und per Backup die alten Daten aufgespielt. Nun habe ich allerdings das komische Verhalten von javascript im Zusammenhang mit zigbee. Werde daraus nicht schlau. Evtl. hat jemand den goldenen Tipp:
    2024-10-05 14:17:48.891 - info: admin.0 (1021) ==> Connected system.user.admin from ::ffff:192.168.1.231
    2024-10-05 14:17:59.164 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:17:59.166 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:17:59.167 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:17:59.167 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:17:59.167 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:17:59.167 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:14.178 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:18:14.180 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:18:14.180 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:14.181 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:14.181 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:14.181 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:14.229 - warn: javascript.0 (1049) getState "zigbee.0.54ef441000ac4ff2.illuminance" not found (3) states[id]=null
    2024-10-05 14:18:14.231 - warn: javascript.0 (1049) at Object. (script.js.Meine_Geräte.Treppenhaus.Beleuchtung_EG:5:7)
    2024-10-05 14:18:14.231 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:14.231 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:14.231 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:14.231 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:29.167 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:18:29.175 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:18:29.175 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:29.175 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:29.176 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:29.176 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:33.769 - info: admin.0 (1021) <== Disconnect system.user.admin from ::ffff:192.168.1.231
    2024-10-05 14:18:44.165 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:18:44.166 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:18:44.167 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:44.167 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:44.167 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:44.167 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:46.210 - warn: javascript.0 (1049) getState "zigbee.0.54ef441000ac4ff2.illuminance" not found (3) states[id]=null
    2024-10-05 14:18:46.212 - warn: javascript.0 (1049) at Object. (script.js.Meine_Geräte.Treppenhaus.Beleuchtung_EG:5:7)
    2024-10-05 14:18:46.212 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:46.212 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:46.213 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:46.213 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:46.213 - warn: javascript.0 (1049) getState "zigbee.0.54ef441000ac4ff2.illuminance" not found (3) states[id]=null
    2024-10-05 14:18:46.215 - warn: javascript.0 (1049) at Object. (script.js.Meine_Geräte.Treppenhaus.Beleuchtung_EG:5:133)
    2024-10-05 14:18:46.215 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:46.215 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:46.215 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:46.215 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:53.511 - warn: javascript.0 (1049) getState "zigbee.0.54ef441000ac4ff2.illuminance" not found (3) states[id]=null
    2024-10-05 14:18:53.515 - warn: javascript.0 (1049) at Object. (script.js.Meine_Geräte.Treppenhaus.Beleuchtung_EG:5:7)
    2024-10-05 14:18:53.515 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:53.515 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:53.516 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:53.516 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:18:59.164 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:18:59.166 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:18:59.166 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:18:59.167 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:18:59.167 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:18:59.167 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:19:14.167 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:19:14.169 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:19:14.169 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:19:14.169 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:19:14.169 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:19:14.169 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:19:25.493 - warn: javascript.0 (1049) getState "zigbee.0.54ef441000ac4ff2.illuminance" not found (3) states[id]=null
    2024-10-05 14:19:25.495 - warn: javascript.0 (1049) at Object. (script.js.Meine_Geräte.Treppenhaus.Beleuchtung_EG:5:7)
    2024-10-05 14:19:25.495 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:19:25.495 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:19:25.495 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:19:25.495 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:19:25.496 - warn: javascript.0 (1049) getState "zigbee.0.54ef441000ac4ff2.illuminance" not found (3) states[id]=null
    2024-10-05 14:19:25.497 - warn: javascript.0 (1049) at Object. (script.js.Meine_Geräte.Treppenhaus.Beleuchtung_EG:5:133)
    2024-10-05 14:19:25.498 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:19:25.498 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:19:25.498 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:19:25.498 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:19:29.165 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:19:29.168 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:19:29.168 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:19:29.168 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:19:29.168 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:19:29.169 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    2024-10-05 14:19:44.165 - warn: javascript.0 (1049) getState "zigbee.1.7cb03eaa0a06fe87.available" not found (3)
    2024-10-05 14:19:44.167 - warn: javascript.0 (1049) at Object. (script.js.Neustarts_der_Adapter.Zigbee:9:7)
    2024-10-05 14:19:44.168 - warn: javascript.0 (1049) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2024-10-05 14:19:44.168 - warn: javascript.0 (1049) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2024-10-05 14:19:44.168 - warn: javascript.0 (1049) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
    2024-10-05 14:19:44.169 - warn: javascript.0 (1049) at processImmediate (node:internal/timers:483:21)
    • Smart_HomeS Smart_Home
      David G.D Online
      David G.D Online
      David G.
      @smart_home
      Irgend ein Script macht da Stress.
      Vermutlich eins in dem du was mit
      machst.
      Das Script heißt vermutlich
      (So deute ich es)
      Du kannst ja nach dem Gerät in deinen Scripten suchen.
      Smart_HomeS 1 Antwort Letzte Antwort
      • David G.D David G.
        @smart_home
        machst.
        (So deute ich es)
        Smart_HomeS Offline
        Smart_HomeS Offline
        Smart_Home
        @david-g OMG, danke für den Tipp! :D Tatsächlich war es ein altes Script.
        Problem gelöst.
