  4. node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version
11 Beiträge 3 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • Smart_HomeS Offline
    Smart_HomeS Offline
    Smart_Home
    Hallo zusammen, wollte den JS-Controller updaten. Seitdem funktioniert der Slave nicht mehr und hat sich verabschiedet. Bin über jeden Rat froh.
    Folgender Fehler ist wahrscheinlich der Grund:
    node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
    Beim Master hat das Update ganz normal funktioniert....
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: ioBroker-Slave
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     00:23:33 up 21 min,  1 user,  load average: 0.18, 0.28, 0.25
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    VCHI initialization failed
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** Time and Time Zones ***
                   Local time: Sun 2024-09-15 00:23:33 BST
               Universal time: Sat 2024-09-14 23:23:33 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marco
    HOME=/home/marco
    GROUPS=marco sudo iobroker
    js-controller is not running
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G         51M        7.3G        8.0M        512M        7.6G
    Swap:           99M          0B         99M
    Total:         8.0G         51M        7.4G
    Active iob-Instances:   0
             7898 M total memory
               51 M used memory
              177 M active memory
              319 M inactive memory
             7334 M free memory
               55 M buffer memory
              457 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 00:23:33 up 21 min,  1 user,  load average: 0.18, 0.28, 0.25
    Tasks: 130 total,   1 running, 129 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  1.5 sy,  0.0 ni, 98.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7898.7 total,   7335.1 free,     50.9 used,    512.7 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7607.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       30G  4.3G   24G  16% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1001
    [Sun Sep 15 00:01:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:F9:35 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=218c65c6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sun Sep 15 00:01:35 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Sep 15 00:01:35 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Sep 15 00:01:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE         FSTYPE     OPTIONS
    /                                     /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=3879288k,nr_inodes=74941,mode=755
    | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
    |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | |-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | `-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
    | `-/sys/kernel/config                configfs       configfs   rw,relatime
    |-/proc                               proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1001                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=808828k,mode=700,uid=1001,gid=1001
    `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    860M    /var/cache
    855M    /var/cache/apt
    796M    /var/cache/apt/archives
    93M     /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    47M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    7.8M    /opt/iobroker/iobroker-data/
    3.3M    /opt/iobroker/iobroker-data/files
    2.8M    /opt/iobroker/iobroker-data/files/info.admin
    2.4M    /opt/iobroker/iobroker-data/files/info.admin/lib
    1.1M    /opt/iobroker/iobroker-data/files/info.admin/lib/fonts
    1.9M    /opt/iobroker/iobroker-data/objects.json.bak
    436K    /opt/iobroker/iobroker-data/files/info.admin/lib/fonts/fontawesome-webfont.svg
    264K    /opt/iobroker/iobroker-data/files/info.admin/lib/js/simplemde.min.js
    256K    /opt/iobroker/iobroker-data/files/info.admin/words.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00
    *** NodeJS-Installation ***
    nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    /usr/bin/corepack
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Core adapters versions
    js-controller:
    admin:
    javascript:
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14248      576/sshd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14250      576/sshd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14119      568/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13966      362/avahi-daemon: r
    udp        0      0 0.0.0.0:37212           0.0.0.0:*                           108        13968      362/avahi-daemon: r
    udp6       0      0 :::50847                :::*                                108        13969      362/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13967      362/avahi-daemon: r
    2024-09-14 21:12:22.453  - warn: zigbee.1 (23454) DeviceAvailability:Stopping to ping 0x7cb03eaa0a06b83e Plug 01 after 4 ping attempts
    2024-09-14 21:19:54.673  - info: zigbee.1 (23454) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2403592","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
    2024-09-14 21:31:41.015  - info: host.ioBroker-Slave Controller will upgrade itself to version 6.0.11
    2024-09-14 22:52:52.662  - info: zigbee.1 (23454) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2403592","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
    2024-09-14 22:52:58.076  - info: zigbee.1 (23454) Zigbee: allowing new devices to join.
    2024-09-14 22:53:14.152  - info: zigbee.1 (23454) Starting interview of '0x54ef441000ac4ff2'
    2024-09-14 22:53:26.152  - info: zigbee.1 (23454) Successfully interviewed '0x54ef441000ac4ff2', device has successfully been paired
    2024-09-14 22:53:26.152  - info: zigbee.1 (23454) Device '0x54ef441000ac4ff2' is supported, identified as: Aqara Motion sensor P1 (RTCGQ14LM)
    2024-09-14 22:53:26.154  - info: zigbee.1 (23454) -> Configuring 0x54ef441000ac4ff2 lumi.motion.ac02
    2024-09-14 22:53:26.185  - warn: zigbee.1 (23454) download icon from https://www.zigbee2mqtt.io/images/devices/RTCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/RTCGQ14LM.png
    2024-09-14 22:53:30.267  - info: zigbee.1 (23454) DeviceConfigure successful 0x54ef441000ac4ff2 lumi.motion.ac02
    2024-09-14 22:54:30.567  - info: zigbee.1 (23454) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2403592","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
    2024-09-14 22:54:59.278  - info: zigbee.1 (23454) Zigbee: stop joining
    2024-09-14 23:08:32.542  - info: host.ioBroker-Slave received SIGTERM
    2024-09-14 23:08:32.548  - info: zigbee.1 (23454) cleaned everything up...
    2024-09-14 23:08:32.547  - info: host.ioBroker-Slave stopInstance system.adapter.zigbee.1 (force=false, process=true)
    2024-09-14 23:08:32.562  - info: host.ioBroker-Slave stopInstance system.adapter.zigbee.1 send kill signal
    2024-09-14 23:08:32.555  - info: zigbee.1 (23454) Zigbee: disabling joining new devices.
    2024-09-14 23:08:32.707  - info: zigbee.1 (23454) Got terminate signal TERMINATE_YOURSELF
    2024-09-14 23:08:32.900  - info: zigbee.1 (23454) terminating
    2024-09-14 23:08:32.901  - info: zigbee.1 (23454) Terminated (NO_ERROR): Without reason
    2024-09-14 23:08:33.058  - info: zigbee.1 (23454) terminating
    2024-09-14 23:08:33.679  - info: host.ioBroker-Slave instance system.adapter.zigbee.1 terminated with code 0 (NO_ERROR)
    2024-09-14 23:08:33.680  - info: host.ioBroker-Slave All instances are stopped.
    2024-09-14 23:08:33.776  - info: host.ioBroker-Slave terminated
    iob diag has finished.
    Press any key for a summary
    • Smart_HomeS Smart_Home
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      marco
      HOME=/home/marco
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               7898 M total memory
                 51 M used memory
                177 M active memory
               7334 M free memory
                 55 M buffer memory
                457 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      1.1G    /var/
      860M    /var/cache
      855M    /var/cache/apt
      93M     /var/lib
      USB-Devices by-id:
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      /usr/bin/corepack
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      js-controller:
      admin:
      javascript:
      Adapter State
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 0
      @smart_home sagte in node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version:
      buster
      Ist tot und muss durch eine noch aktiv unterstützte Version ersetzt werden.
      Installier da NEU Raspberry OS 12 'Bookworm'. In der 64Bit-Lite-Version. Und dann dort die richtige Zeitzone setzen. Oder wohnst du in England?
      Künftig das Betriebssystem besser auf Stand halten.
        Smart_HomeS Offline
        Smart_Home
        @thomas-braun verdammt....hatte gehofft es geht ohne. Ne ist Deutschland. Danke dir.
        Thomas BraunT OliverIOO 3 Antworten Letzte Antwort
          @smart_home
          Nein, das geht auch bei dir nicht ohne komplette Neuinstallation.
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @smart_home
            du hast da auch noch ein paar andere Issues
            das wird mit dem nächsten betriebssystem nicht besser
            Meine Adapter und Widgets
            Links im Profil
              @smart_home
              Bring das vorübgehend per
              iob nodejs-update 18
              auf die letzte Version, die noch mit buster funktioniert.
              Smart_HomeS 1 Antwort Letzte Antwort
                @smart_home
                Smart_HomeS Offline
                Smart_HomeS Offline
                Smart_Home
                @thomas-braun sagte in node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version:
                Gott sei dank! :D Jetzt funktionieren wenigstens die Zigbee Geräte wieder.
                Dankeeee...
                  Dankeeee...
                  @smart_home
                  Das ist aber nur eine behelfsmäßige Krücke. Das muss in nächster Zeit komplett neuinstalliert werden. Kommste nicht drumherum.
                    @smart_home
                    Smart_HomeS Offline
                    Smart_HomeS Offline
                    Smart_Home
                    @thomas-braun I know. Danke dir. :)
                      @smart_home
                      Und die Zeitzone würde ich jetzt korrigieren. Und auch auf dem Master danach schauen.
                        @smart_home
                        @apollon77
                        Magst du bitte den aktuellen Code von 'nodejs-update' hochladen? Danke.
