  4. IRobot Roomba Adapter
    6.4k
851 Beiträge 101 Kommentatoren 389.5k Aufrufe 65 Beobachtet
  • JB_SullivanJ JB_Sullivan
    Leider immer noch einen Arsch voll Fehlermeldungen bei der Installation.
    C:\>npm install canvas@2.6.0 --unsafe-perm=true
    > canvas@2.6.0 install C:\node_modules\canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using needle for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-win32-unknown-ia32.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.0 and node@10.16.0 (node-v64 ABI, unknown) (falling back to source compile with node-gyp)
    gyp ERR! configure error
    gyp ERR! stack Error: Can't find Python executable "python2.7", you can set the PYTHON env variable.
    gyp ERR! stack     at PythonFinder.failNoPython (C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
    gyp ERR! stack     at PythonFinder.<anonymous> (C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
    gyp ERR! stack     at C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\graceful-fs\polyfills.js:282:31
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:153:21)
    gyp ERR! System Windows_NT 10.0.17763
    gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\\node_modules\\canvas\\build\\Release\\canvas.node" "--module_name=canvas" "--module_path=C:\\node_modules\\canvas\\build\\Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64" "--python=python2.7" "--msvs_version=2017"
    gyp ERR! cwd C:\node_modules\canvas
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\node_modules\canvas\build\Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64 --python=python2.7 --msvs_version=2017' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (C:\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Windows_NT 10.0.17763
    node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd C:\node_modules\canvas
    node-pre-gyp ERR! node -v v10.16.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open 'C:\package.json'
    npm WARN !invalid#1 No description
    npm WARN !invalid#1 No repository field.
    npm WARN !invalid#1 No README data
    npm WARN !invalid#1 No license field.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.6.0 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.6.0 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     C:\Users\SmartHome\AppData\Roaming\npm-cache\_logs\2019-08-20T19_49_18_807Z-debug.log
    C:\>
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    #281
    @JB_Sullivan Sehr gut!! Das ist tatsächlich ein Fortschritt. Er versucht jetzt endlich canvas zu compilen.
    node-gyp kennt den Python Pfad nicht.
    node-gyp --python "C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7"
    und
    npm set python "C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7"
    Meine Adapter: https://zefau.github.io/iobroker/
    • JB_SullivanJ Offline
      JB_Sullivan
      #282
      @Zefau sagte in IRobot Roomba Adapter:
      Na du kriegst noch graue Haare mit mir :D
      Habe ich gemacht, aber leider immer noch alles voller Fehler
      C:\>node-gyp --python "C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7"
        Usage: node-gyp <command> [options]
        where <command> is one of:
          - build - undefined
          - clean - Removes any generated build files and the "out" dir
          - configure - Generates MSVC project files for the current module
          - rebuild - Runs "clean", "configure" and "build" all at once
          - install - Install node development files for the specified node version.
          - list - undefined
          - remove - Removes the node development files for the specified version
      node-gyp@5.0.3  C:\Users\SmartHome\AppData\Roaming\npm\node_modules\node-gyp
      node@10.16.0
      C:\>npm set python "C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7"
      gyp ERR! stack Error: Can't find Python executable "C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7", you can set the PYTHON env variable.
      gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\\node_modules\\canvas\\build\\Release\\canvas.node" "--module_name=canvas" "--module_path=C:\\node_modules\\canvas\\build\\Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64" "--python=C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7" "--msvs_version=2017"
      gyp ERR! not ok
      node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\node_modules\canvas\build\Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64 --python=C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Python 2.7 --msvs_version=2017' (1)
      npm ERR! errno 1
      npm ERR!
      npm ERR!     C:\Users\SmartHome\AppData\Roaming\npm-cache\_logs\2019-08-20T19_59_21_725Z-debug.log
      C:\>
      ZefauZ 1 Antwort Letzte Antwort
            - build - undefined
            - list - undefined
        node@10.16.0
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        C:\>
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        #283
        @JB_Sullivan Er braucht die genaue .exe, nicht nur den Pfad. Diese befindet sich bei mir unter C:\Users\<User>\.windows-build-tools\python27\python.exe. Bei dir auch?
        Dann einfach
        node-gyp --python "C:\Users\<User>\.windows-build-tools\python27\python.exe"
        und
        npm set python "C:\Users\<User>\.windows-build-tools\python27\python.exe"
          JB_Sullivan
          schrieb am zuletzt editiert von JB_Sullivan
          #284
          npm set python "C:\Users<User>.windows-build-tools\python27\python.exe"
          Nein, ich habe einen anderen Installationspfad - ob der richtig ist - don`t know.
          Ich habe es jetzt damit mal versucht und anschließend CANVAS nochmal installiert. Offensichtlich war es zum Teil wohl nicht ganz verkehrt, denn jetzt habe ich einen ganzen Sack voll neuer Meldungen bekommen. Leider waren auch da wieder ein paar Errors dabei.
          ..... achso - immer noch keine Karte. Ich denke für Heute lassen wir es gut sein ;) Ich muss morgen wieder raus - Danke erstmal
          C:>node-gyp --python "C:\Program Files\Python\python.exe"
          - build - undefined
          - list - undefined
          node@10.16.0
          C:>npm set python "C:\Program Files\Python\python.exe"
          C:>npm install canvas@2.6.0 --unsafe-perm=true
          Warning: Missing input files:
          C:\GTK\bin\libfreetype-6.dll
          C:\GTK\bin\libintl-8.dll
          Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
          Copying C:/libjpeg-turbo/bin/jpeg62.dll to C:\node_modules\canvas\build\Release\jpeg62.dll
          1 Datei(en) kopiert.
          Backend.cc
          ImageBackend.cc
          PdfBackend.cc
          SvgBackend.cc
          BMPParser.cc
          Backends.cc
          c:\node_modules\canvas\src\bmp\bmpparser.cc(189): warning C4018: ">": Konflikt zwischen "signed" und "unsigned" [C:\nod
          e_modules\canvas\build\canvas.vcxproj]
          c:\node_modules\canvas\src\bmp\bmpparser.cc(204): warning C4018: ">": Konflikt zwischen "signed" und "unsigned" [C:\nod
          Canvas.cc
          CanvasGradient.cc
          CanvasPattern.cc
          CanvasRenderingContext2d.cc
          closure.cc
          color.cc
          Image.cc
          ImageData.cc
          init.cc
          register_font.cc
          win_delay_load_hook.cc
          Bibliothek "C:\node_modules\canvas\build\Release\canvas.lib" und Objekt "C:\node_modules\canvas\build\Release\canv
          as.exp" werden erstellt.
          Code wird generiert.
          All 2104 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
          Codegenerierung ist abgeschlossen.
          canvas.vcxproj -> C:\node_modules\canvas\build\Release\canvas.node
          Copying C:/GTK/bin/libpangoft2-1.0-0.dll to C:\node_modules\canvas\build\Release\libpangoft2-1.0-0.dll
          Copying C:/GTK/bin/libgthread-2.0-0.dll to C:\node_modules\canvas\build\Release\libgthread-2.0-0.dll
          Copying C:/GTK/bin/libpangowin32-1.0-0.dll to C:\node_modules\canvas\build\Release\libpangowin32-1.0-0.dll
          Copying C:/GTK/bin/libglib-2.0-0.dll to C:\node_modules\canvas\build\Release\libglib-2.0-0.dll
          Copying C:/GTK/bin/libcairo-2.dll to C:\node_modules\canvas\build\Release\libcairo-2.dll
          Copying C:/GTK/bin/libpango-1.0-0.dll to C:\node_modules\canvas\build\Release\libpango-1.0-0.dll
          Copying C:/GTK/bin/libfontconfig-1.dll to C:\node_modules\canvas\build\Release\libfontconfig-1.dll
          Copying C:/GTK/bin/libintl-8.dll to C:\node_modules\canvas\build\Release\libintl-8.dll
          Das System kann die angegebene Datei nicht finden.
          Copying C:/GTK/bin/libfreetype-6.dll to C:\node_modules\canvas\build\Release\libfreetype-6.dll
          Copying C:/GTK/bin/libgmodule-2.0-0.dll to C:\node_modules\canvas\build\Release\libgmodule-2.0-0.dll
          Copying C:/GTK/bin/libpangocairo-1.0-0.dll to C:\node_modules\canvas\build\Release\libpangocairo-1.0-0.dll
          Copying C:/GTK/bin/libgobject-2.0-0.dll to C:\node_modules\canvas\build\Release\libgobject-2.0-0.dll
          Copying C:/GTK/bin/libpng14-14.dll to C:\node_modules\canvas\build\Release\libpng14-14.dll
          Copying C:/GTK/bin/zlib1.dll to C:\node_modules\canvas\build\Release\zlib1.dll
          Copying C:/GTK/bin/libexpat-1.dll to C:\node_modules\canvas\build\Release\libexpat-1.dll
          All 1 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
          canvas-postbuild.vcxproj -> C:\node_modules\canvas\build\Release\canvas-postbuild.node
          npm WARN saveError ENOENT: no such file or directory, open 'C:\package.json'
          • canvas@2.6.0
            added 72 packages from 36 contributors and audited 103 packages in 42.706s
            found 0 vulnerabilities
          C:>
          ZefauZ 2 Antworten Letzte Antwort
            - build - undefined
            - list - undefined
            node@10.16.0
            Backend.cc
            ImageBackend.cc
            PdfBackend.cc
            SvgBackend.cc
            BMPParser.cc
            Backends.cc
            Canvas.cc
            CanvasGradient.cc
            CanvasPattern.cc
            closure.cc
            color.cc
            Image.cc
            ImageData.cc
            init.cc
            register_font.cc
            • canvas@2.6.0
            C:>
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            #285
            @JB_Sullivan Sieht erfolgreich aus. Adapter neustarten und gucken, ob er eine Karte erstellt, wenn der Roomba fährt :-)
              - build - undefined
              - list - undefined
              node@10.16.0
              Backend.cc
              ImageBackend.cc
              PdfBackend.cc
              SvgBackend.cc
              BMPParser.cc
              Backends.cc
              Canvas.cc
              CanvasGradient.cc
              CanvasPattern.cc
              closure.cc
              color.cc
              Image.cc
              ImageData.cc
              init.cc
              register_font.cc
              • canvas@2.6.0
              C:>
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #286
              @JB_Sullivan Sehe gerade, dass du canvas nicht im iobroker.roomba Ordner installiert hast, oder? Wechsel nochmal in den iobroker.roomba Ordner und installiere canvas dort, dann sollte es klappen.
                JB_Sullivan
                #287
                Also nochmal von Anfang an? .... und dann hier hin C:\ioBroker\iobroker-data\files\roomba ?
                Also quasi so - C:\ioBroker\iobroker-data\files\roomba>npm install canvas@2.6.0 --unsafe-perm=true
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  #288
                  @JB_Sullivan Ne C:\ioBroker\node_modules\iobroker.roomba
                    JB_Sullivan
                    #289
                    OK - next try
                    C:\ioBroker\node_modules\iobroker.roomba>npm install canvas@2.6.0 --unsafe-perm=true
                    canvas@2.6.0 install C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                    node-pre-gyp WARN Using request for node-pre-gyp https download
                    Copying C:/libjpeg-turbo/bin/jpeg62.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                    \jpeg62.dll
                    Backend.cc
                    ImageBackend.cc
                    PdfBackend.cc
                    SvgBackend.cc
                    BMPParser.cc
                    Backends.cc
                    c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(189): warning C4018: ">": Konflikt zw
                    ischen "signed" und "unsigned" [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                    c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(204): warning C4018: ">": Konflikt zw
                    Canvas.cc
                    CanvasGradient.cc
                    CanvasPattern.cc
                    closure.cc
                    color.cc
                    Image.cc
                    ImageData.cc
                    init.cc
                    register_font.cc
                    Bibliothek "C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.lib" und Objekt "C:
                    ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.exp" werden erstellt.
                    canvas.vcxproj -> C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node
                    Copying C:/GTK/bin/libpangoft2-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Releas
                    Copying C:/GTK/bin/libgthread-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                    Copying C:/GTK/bin/libpangowin32-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Rele
                    Copying C:/GTK/bin/libglib-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\l
                    ibglib-2.0-0.dll
                    Copying C:/GTK/bin/libcairo-2.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\libc
                    airo-2.dll
                    Copying C:/GTK/bin/libpango-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\
                    libpango-1.0-0.dll
                    Copying C:/GTK/bin/libfontconfig-1.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                    Copying C:/GTK/bin/libintl-8.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\libin
                    tl-8.dll
                    Copying C:/GTK/bin/libfreetype-6.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\l
                    ibfreetype-6.dll
                    Copying C:/GTK/bin/libgmodule-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                    Copying C:/GTK/bin/libpangocairo-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Rele
                    Copying C:/GTK/bin/libgobject-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                    Copying C:/GTK/bin/libpng14-14.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\lib
                    png14-14.dll
                    Copying C:/GTK/bin/zlib1.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\zlib1.dll
                    Copying C:/GTK/bin/libexpat-1.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\libe
                    xpat-1.dll
                    canvas-postbuild.vcxproj -> C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas-postbu
                    ild.node
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules\fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"ia32"})
                    • canvas@2.6.0
                      added 377 packages from 1037 contributors, updated 1 package and audited 7531 packages in 46.328s
                      OK - next try
                      \jpeg62.dll
                      Backend.cc
                      ImageBackend.cc
                      PdfBackend.cc
                      SvgBackend.cc
                      BMPParser.cc
                      Backends.cc
                      Canvas.cc
                      CanvasGradient.cc
                      CanvasPattern.cc
                      closure.cc
                      color.cc
                      Image.cc
                      ImageData.cc
                      init.cc
                      register_font.cc
                      ibglib-2.0-0.dll
                      airo-2.dll
                      libpango-1.0-0.dll
                      tl-8.dll
                      ibfreetype-6.dll
                      png14-14.dll
                      xpat-1.dll
                      ild.node
                      • canvas@2.6.0
                      ZefauZ Offline
                      ZefauZ Offline
                      Zefau
                      #290
                      @JB_Sullivan sagte in IRobot Roomba Adapter:
                      Sieht super aus. Lass den Roomba laufen! :D
                        JB_Sullivan
                        #291
                        OK - muss ich morgen machen - das kann ich um die Uhrzeit hier keinem mehr antun. Teste ich morgen. Aber auf jeden Fall schonmal vielen Dank für deine Unterstützung.
                        Rückmeldung gibt es dann morgen.
                          JB_Sullivan
                          #292
                          Tja, Schade - hat leider nicht geklappt. Habe den Adapter nach der Aktion von gestern Abend gestoppt und neu gestartet und den Roboter einen vollen Zyklus laufen lassen - manuell gestartet.
                          In der Handy-App bekomme ich sowohl eine Reinigungskarte als auch eine WiFi Karte angezeigt.
                          Wenn ich aber hier bei deinem Adapter gucke, schreibt er mir beim Klick auf "Mission" -> Download Map = "No Map to Download"
                          2019-08-18 14_38_27-iRobot Roomba.png 2019-08-21 11.01.22.jpg 2019-08-21 11.01.15.jpg
                          Auch die Datenpunkte die vermutlich für die Kartdarstellung gefüllt sein müssten, sind leer.
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            #293
                            @JB_Sullivan hmmm.. merkwürdig. Kannst du das Interface mal auf debug stellen und auch in der Adapter Konfiguration die Option Debug Mode for mission data aktivieren?
                            Die Option Refresh time (in sec.) preferences will be retrieved from robot bitte auf 20 Sekunden.
                            Wenn das alles eingestellt ist, bitte den Roomba für 5 Minuten laufen lassen (muss nicht lange sein) und mir das Log mal zuschicken (Achtung: Es wird eine Menge ausgegeben).
                            JB_SullivanJ 1 Antwort Letzte Antwort
                            • ZefauZ Zefau
                              JB_Sullivan
                              #294
                              @Zefau mache ich in einer Woche - sitze gerade
                              am Flughafen und warte auf den Flieger ;)
                                JB_Sullivan
                                #295
                                So - I`m back in Town.
                                Hier schonmal eine erste Debug Ausgabe. Ich vermute mal der Pfad ist falsch oder? Da ist doch einmal node_modules zuviel oder? Wie bekomme ich das geheilt? Die Pfad Angabe muss doch bestimmt in irgend einer Config Datei drin stehen. Kann man die Händisch editieren? Das ganze node_modules Verzeichnis wurde nämlich noch ein zweites mal im iobroker.roomba Ordner angelegt. Ich vermute das ist nicht korrekt oder? Obwohl da die Datei canvas.node ebenfalls vorhanden ist.
                                roomba.0	2019-08-29 09:33:56.569	info	Connecting to Roomba (10.xxx.xxx.xxx)..
                                roomba.0	2019-08-29 09:33:56.569	debug	Das angegebene Modul wurde nicht gefunden. \\?\C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node
                                roomba.0	2019-08-29 09:33:56.569	warn	Canvas not installed! Thus, no map drawings are possible.
                                roomba.0	2019-08-29 09:33:56.569	info	starting. Version 1.0.6 in C:/ioBroker/node_modules/iobroker.roomba, node: v10.16.0
                                  JB_Sullivan
                                  #296
                                  So, jetzt geht gar nichts mehr - SCHEIß Google Autofill In. Beim speichern der neuen Mission Debug Einstellungen hat mir Auofill In irgend eine Grütze bei Benutzernamen und Passwort rein geschrieben.
                                  Ein neuer Versuch den Roomba zu initialisieren scheitert mit der Meldung, das ich erst den Adapter starten soll - der ist aber gestartet. Ein Restart führt dazu, das der Adapter kurz auf grün geht und dann wieder rot wird.
                                  Ich bekomme jetzt jedenfalls keine Verbindun mehr zum Roomba. Ich glaube ich lösche nochmal alles und fange gaaaanz von vorne an.
                                  roomba.0	2019-08-29 10:22:20.553	info	Adapter stopped und unloaded.
                                  roomba.0	2019-08-29 10:22:20.553	error	at TLSWrap.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                                  roomba.0	2019-08-29 10:22:20.553	error	at TLSSocket.Readable.push (_stream_readable.js:224:10)
                                  roomba.0	2019-08-29 10:22:20.553	error	at readableAddChunk (_stream_readable.js:269:11)
                                  roomba.0	2019-08-29 10:22:20.553	error	at addChunk (_stream_readable.js:288:12)
                                  roomba.0	2019-08-29 10:22:20.553	error	at TLSSocket.emit (events.js:198:13)
                                  roomba.0	2019-08-29 10:22:20.553	error	at TLSSocket.ondata (_stream_readable.js:693:20)
                                  roomba.0	2019-08-29 10:22:20.553	error	at Writable.write (C:\ioBroker\node_modules\iobroker.roomba\node_modules\readable-stream\lib\_stream_writable.js:334:11)
                                  roomba.0	2019-08-29 10:22:20.553	error	at writeOrBuffer (C:\ioBroker\node_modules\iobroker.roomba\node_modules\readable-stream\lib\_stream_writable.js:417:5)
                                  roomba.0	2019-08-29 10:22:20.553	error	at doWrite (C:\ioBroker\node_modules\iobroker.roomba\node_modules\readable-stream\lib\_stream_writable.js:428:64)
                                  roomba.0	2019-08-29 10:22:20.553	error	at Writable.writable._write (C:\ioBroker\node_modules\iobroker.roomba\node_modules\mqtt\lib\client.js:302:5)
                                  roomba.0	2019-08-29 10:22:20.553	error	at work (C:\ioBroker\node_modules\iobroker.roomba\node_modules\mqtt\lib\client.js:292:12)
                                  roomba.0	2019-08-29 10:22:20.553	error	at MqttClient._handlePacket (C:\ioBroker\node_modules\iobroker.roomba\node_modules\mqtt\lib\client.js:350:12)
                                  roomba.0	2019-08-29 10:22:20.553	error	at MqttClient._handleConnack (C:\ioBroker\node_modules\iobroker.roomba\node_modules\mqtt\lib\client.js:920:15)
                                  roomba.0	2019-08-29 10:22:20.553	error	Error: Connection refused: Not authorized
                                  roomba.0	2019-08-29 10:22:20.553	error	uncaught exception: Connection refused: Not authorized
                                  roomba.0	2019-08-29 10:22:18.725	info	Connecting to Roomba (10.122.60.10)..
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    schrieb am zuletzt editiert von Zefau
                                    #297
                                    @JB_Sullivan bevor du neu anfängst, zieh dir die Github Version. Der Fehler ist bekannt.
                                    Und nutze nach dem Update unbedingt den Upload Button, damit das Backend aktualisiert wird.
                                    EDIT: bzw. lösche das Passwort komplett raus, damit der Adapter nicht versucht zu verbinden.
                                      JB_Sullivan
                                      #298
                                      Sorry - keine Chance mehr. Selbst wenn ich die ganzen Daten (IP / Benutzername / PW) händisch eintrage bleibt der Adapter rot.
                                      Auch der automatische Prozess über die Wlan Taste ergibt nur einen roten Adapter :( Ich habe alles so gemacht wie von dir beschrieben - löschen, aktualisieren usw.
                                        JB_Sullivan
                                        #299
                                        So ich habe jetzt den ganzen Nachmittag herum gemacht. Ich habe ALLE Versionen vorwärts und rückwärts up - und down gegradet - incl. Upload Button. Absolut keine Chance mehr eine Verbindung mit dem Roomba aufzubauen.
                                        Ich dachte es liegt evtl. an der Authentifizierungs Methode aber egal was ich auch versuche ich kriege keine Verbindung. Ich habe in der Roomba APP extra nochmal ein neues Passwort vergeben.
                                        Trotzdem tut die Anmeldemaske so, als ob er keine Verbindung zum Adapter aufbauen kann.
                                        Kleine Anmerkung am Rande - du hast unter "Einstellungen" bei Passwort - " Passwort zeigen / vergeben" stehen. Das soll bestimmt VERBERGEN heißen.
                                        Verbinde zum Adapter..
                                        Verbunden zum Adapter. Lade Zugangsdaten..
                                        Lade Zugangsdaten..
                                        Zugangsdaten konnten nicht geladen werden! Folge der Anleitung und versuche es nochmal. ([object Object])
                                        Lade IP Adresse..
                                        IP Adresse konnte nicht geladen werden! (bind EADDRINUSE 0.0.0.0:5678)
                                        $ ./iobroker add roomba --host iobroker
                                        NPM version: 6.9.0
                                        npm install iobroker.roomba@1.0.6 --production --save --prefix "C:/ioBroker" (System call)
                                        node-pre-gyp
                                        WARN
                                        node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-win32-unknown-ia32.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.0 and node@10.16.0 (node-v64 ABI, unknown) (falling back to source compile with node-gyp)
                                        gyp
                                        ERR!
                                        build error
                                        gyp
                                        ERR!
                                        stack
                                        Error: C:\Program Files\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
                                        gyp
                                        ERR!
                                        stack
                                        at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                                        gyp
                                        ERR!
                                        stack
                                        gyp
                                        ERR!
                                        stack
                                        at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                        gyp
                                        ERR! System Windows_NT 10.0.17763gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "build" "--fallback-to-build" "--module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node" "--module_name=canvas" "--module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                                        gyp ERR! cwd C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                                        gyp ERR! not ok
                                        node-pre-gyp
                                        ERR! build error node-pre-gyp
                                        ERR!
                                        stack
                                        Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                                        node-pre-gyp
                                        ERR!
                                        stack at ChildProcess.<anonymous> (C:\ioBroker\node_modules\iobroker.roomba\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        node-pre-gyp
                                        ERR!
                                        command
                                        "C:\Program Files\nodejs\node.exe" "C:\ioBroker\node_modules\iobroker.roomba\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
                                        node-pre-gyp
                                        ERR!
                                        cwd
                                        node-pre-gyp
                                        ERR!
                                        node -v
                                        v10.16.0
                                        node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                                        npm
                                        ERR!
                                        code
                                        ELIFECYCLE
                                        npm
                                        ERR! errno 1
                                        npm
                                        ERR!
                                        canvas@2.6.0 install: node-pre-gyp install --fallback-to-build
                                        npm
                                        ERR!
                                        Exit status 1
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-08-29T20_13_45_429Z-debug.log
                                        host.iobroker install adapter roomba
                                        NPM version: 6.9.0
                                        node-pre-gyp
                                        WARN
                                        gyp
                                        ERR! build error
                                        gyp
                                        ERR!
                                        stack
                                        gyp
                                        ERR!
                                        stack
                                        gyp
                                        ERR!
                                        stack
                                        gyp
                                        ERR!
                                        stack
                                        gyp
                                        ERR!
                                        System
                                        gyp
                                        ERR!
                                        command
                                        gyp
                                        ERR!
                                        cwd
                                        gyp
                                        ERR!
                                        node -v
                                        v10.16.0
                                        gyp
                                        ERR!
                                        node-gyp -v
                                        v3.8.0
                                        gyp
                                        ERR!
                                        not ok
                                        node-pre-gyp
                                        ERR! build error
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        System
                                        node-pre-gyp
                                        ERR!
                                        command
                                        node-pre-gyp
                                        ERR!
                                        cwd
                                        node-pre-gyp
                                        ERR!
                                        node -v
                                        v10.16.0
                                        node-pre-gyp
                                        ERR!
                                        node-pre-gyp -v
                                        v0.11.0
                                        node-pre-gyp
                                        ERR!
                                        not ok
                                        npm
                                        ERR!
                                        code
                                        ELIFECYCLE
                                        npm
                                        ERR!
                                        errno
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        Exit status 1
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-08-29T20_14_12_928Z-debug.log
                                        NPM version: 6.9.0
                                        node-pre-gyp
                                        WARN
                                        gyp
                                        ERR!
                                        build error
                                        gyp
                                        ERR!
                                        stack
                                        gyp ERR!
                                        stack
                                        at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp
                                        ERR!
                                        stack
                                        gyp
                                        ERR!
                                        stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                        gyp
                                        ERR!
                                        System
                                        gyp
                                        ERR!
                                        command
                                        gyp
                                        ERR!
                                        cwd
                                        gyp
                                        ERR!
                                        node -v
                                        v10.16.0
                                        gyp
                                        ERR!
                                        node-gyp -v
                                        v3.8.0
                                        gyp
                                        ERR!
                                        not ok
                                        node-pre-gyp
                                        ERR! build error
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR!
                                        stack
                                        node-pre-gyp
                                        ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack
                                        node-pre-gyp
                                        ERR!
                                        System
                                        node-pre-gyp
                                        ERR!
                                        command
                                        node-pre-gyp
                                        ERR!
                                        cwd
                                        node-pre-gyp
                                        ERR!
                                        node -v
                                        v10.16.0
                                        node-pre-gyp
                                        ERR!
                                        node-pre-gyp -v
                                        v0.11.0
                                        node-pre-gyp
                                        ERR!
                                        not ok
                                        npm
                                        ERR!
                                        code ELIFECYCLE
                                        npm
                                        ERR! errno
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        Exit status 1
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        npm
                                        ERR!
                                        npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-08-29T20_14_41_520Z-debug.log
                                        ERROR: host.iobroker Cannot install roomba
                                        ERROR: process exited with code 13
                                          JB_Sullivan
                                          #300
                                          So der Spaß geht weiter - nachdem ich nun den Schritt gegangen bin und ein altes Backup eingespielt habe (vom19.08.2019) bin ich überhaupt nicht mehr in der Lage den roomba Adapter upzudaten oder ihn zu installieren.
                                          Es kommen Fehlermeldungen on Mass:
                                          Beim Versuch den Adpter über Admin auf 1.0.6 hoch zu ziehen:
                                          $ ./iobroker upgrade roomba
                                          Update roomba from @1.0.4 to @1.0.6
                                          NPM version: 6.9.0
                                          npm
                                          WARN rollback Rolling back iobroker.roomba@1.0.6 failed (this is probably harmless): EBUSY: resource busy or locked, rmdir 'C:\ioBroker\node_modules\iobroker.roomba'
                                          npm
                                          ERR! path C:\ioBroker\node_modules\iobroker.roombanpm
                                          ERR! code
                                          EBUSY
                                          npm
                                          ERR!
                                          errno
                                          -4082
                                          npm
                                          ERR!
                                          syscall
                                          rename
                                          npm ERR!
                                          EBUSY: resource busy or locked, rename 'C:\ioBroker\node_modules\iobroker.roomba' -> 'C:\ioBroker\node_modules.iobroker.roomba.DELETE'
                                          npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-08-30T05_25_49_712Z-debug.log
                                          ERROR: host.iobroker Cannot install iobroker.roomba@1.0.6: 4294963214
                                          Und hier ein paar Meldungen wenn man versucht den Canvas Adapter gemäß GitHub Beschreibung zu installieren.
                                          \jpeg62.dll
                                          Backend.cc
                                          ImageBackend.cc
                                          PdfBackend.cc
                                          SvgBackend.cc
                                          BMPParser.cc
                                          Backends.cc
                                          Canvas.cc
                                          CanvasGradient.cc
                                          CanvasPattern.cc
                                          closure.cc
                                          color.cc
                                          Image.cc
                                          ImageData.cc
                                          init.cc
                                          register_font.cc
                                          ibglib-2.0-0.dll
                                          airo-2.dll
                                          libpango-1.0-0.dll
                                          tl-8.dll
                                          ibfreetype-6.dll
                                          png14-14.dll
                                          xpat-1.dll
                                          ild.node
                                          • canvas@2.6.0
                                            added 379 packages from 1042 contributors, updated 1 package and audited 7531 packages in 45.46s
                                          Ich bin mit meinem Latein echt am Ende.
