  4. Backitup Error
    1.0k
    6.1k
Backitup Error
65 Beiträge 10 Kommentatoren 10.7k Aufrufe 8 Beobachtet
  • I io2345
    Somit wissen wir nun, dass es nicht an fehlenden Ressourcen liegt:
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
    Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     10:37:58 up 2 min,  0 user,  load average: 0.33, 0.27, 0.21
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
    Failed to query server: Connection timed out
    Failed to parse bus message: Connection timed out
    *** Users and Groups ***
    User that called 'iob diag':
    iobrokeradmin
    HOME=/home/iobrokeradmin
    GROUPS=iobrokeradmin sudo users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.6G        896M        7.4G         86K        275M        7.7G
    Swap:           536M          0B        536M
    Total:          9.1G        896M        8.0G
    Active iob-Instances:   14
             8192 M total memory
              854 M used memory
              951 M active memory
              114 M inactive memory
             7074 M free memory
                0 M buffer memory
              262 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 10:39:13 up 3 min,  0 user,  load average: 0.20, 0.24, 0.20
    Tasks:  35 total,   1 running,  34 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   7072.8 free,    856.6 used,    262.8 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7335.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * nftables.service                   loaded failed failed nftables
    * systemd-hostnamed.service          loaded failed failed Hostname Service
    * systemd-logind.service             loaded failed failed User Login Management
    * systemd-networkd.service           loaded failed failed Network Configuration
    * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
    * systemd-sysusers.service           loaded failed failed Create System Users
    * systemd-timedated.service          loaded failed failed Time & Date Service
    * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
    * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
    * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
    10 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.0G  3.5G  54% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
    tmpfs                            tmpfs  2.4G   80K  2.4G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    [Fri Dec 27 17:47:17 2024] EXT4-fs (dm-1): mounted filesystem b474fcca-8614-4935-abf2-ede52e720980 ro with ordered data mode. Quota mode: none.
    [Fri Dec 27 17:47:19 2024] EXT4-fs (dm-1): re-mounted b474fcca-8614-4935-abf2-ede52e720980 r/w. Quota mode: none.
    [Fri Dec 27 17:47:38 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 17:47:42 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 17:47:46 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 17:49:01 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
    [Fri Dec 27 17:49:02 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 18:09:03 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 18:09:19 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Fri Dec 27 18:12:24 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 18:15:55 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Fri Dec 27 18:15:56 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): write access unavailable, skipping orphan cleanup
    [Fri Dec 27 18:25:37 2024] EXT4-fs (dm-11): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c ro without journal. Quota mode: none.
    [Fri Dec 27 18:31:42 2024] EXT4-fs (dm-11): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
    [Fri Dec 27 18:44:42 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
    [Fri Dec 27 18:47:46 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 18:48:58 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
    [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
    [Fri Dec 27 21:04:00 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Fri Dec 27 23:44:56 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
    [Fri Dec 27 23:45:17 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
    [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Sat Dec 28 15:37:57 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
    [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
    [Sat Dec 28 15:39:12 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Sat Dec 28 15:39:13 2024] EXT4-fs (dm-11): mounted filesystem 5b07b028-f437-49c7-a755-773599939bdd r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 14:56:32 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
    [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-11): unmounting filesystem 5b07b028-f437-49c7-a755-773599939bdd.
    [Sun Dec 29 15:14:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Sun Dec 29 15:14:23 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 15:30:22 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Sun Dec 29 15:30:25 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 15:39:00 2024] EXT4-fs (dm-10): mounted filesystem 6c988c5d-52d2-4285-89cf-5764421c8470 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 15:40:42 2024] EXT4-fs (dm-10): unmounting filesystem 6c988c5d-52d2-4285-89cf-5764421c8470.
    [Sun Dec 29 15:52:08 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 15:52:30 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
    [Sun Dec 29 15:52:52 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
    [Sun Dec 29 15:52:56 2024] EXT4-fs (dm-12): mounted filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 16:41:57 2024] EXT4-fs (dm-6): unmounting filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336.
    [Sun Dec 29 16:41:58 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 21:13:10 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 21:13:18 2024] EXT4-fs (dm-7): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
    [Sun Dec 29 21:28:18 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 21:28:31 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
    [Sun Dec 29 21:29:23 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 21:51:57 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
    [Sun Dec 29 21:51:58 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
    [Sun Dec 29 21:59:13 2024] EXT4-fs (dm-12): unmounting filesystem d8ca295a-a5b1-4216-b609-50e6e71b31a2.
    [Mon Dec 30 08:36:04 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
    [Mon Dec 30 08:36:59 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
    [Mon Dec 30 08:38:47 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
    [Mon Dec 30 08:38:48 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
    [Mon Dec 30 10:34:28 2024] EXT4-fs (dm-7): unmounting filesystem d5b68628-1741-4194-a2d4-3a4554f5a933.
    [Mon Dec 30 10:35:26 2024] EXT4-fs (dm-7): mounted filesystem d5b68628-1741-4194-a2d4-3a4554f5a933 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
    /var:
    421M    /var/
    249M    /var/cache
    245M    /var/cache/apt
    170M    /var/cache/apt/archives
    147M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    793M    /opt/iobroker/iobroker-data/
    741M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    15M     /opt/iobroker/iobroker-data/states.jsonl
    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 227)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker8                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker8                                -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker8                                -  enabled
    + system.adapter.email.0                  : email                 : ioBroker8                                -  enabled
    + system.adapter.enigma2.0                : enigma2               : ioBroker8                                -  enabled
      system.adapter.habpanel.0               : habpanel              : ioBroker8                                - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker8                                -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : ioBroker8                                -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : ioBroker8                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker8                                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.tuya.0                   : tuya                  : ioBroker8                                - disabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker8                                -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker8                                -  enabled
    + system.adapter.web.0                    : web                   : ioBroker8                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker8                                -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        13663
    States:         9996
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7969660    331/master
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7972212    167/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7971162    167/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7969436    1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7974525    515/io.mqtt.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7975376    595/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7971236    342/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7969661    331/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7970523    1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          7970885    1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7977080    562/io.upnp.0
    udp        0      0 0.0.0.0:55622           0.0.0.0:*                           1001       7975269    562/io.upnp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7970942    87/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7969437    1/init
    udp6       0      0 :::111                  :::*                                0          7970456    1/init
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
    2024-12-30 10:36:17.738  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
    2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
    2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
    2024-12-30 10:36:17.739  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
    2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set" with regex /SmartPlug3\.[^.]*\.set/
    2024-12-30 10:36:18.067  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/set"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.set/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+" with regex /cmnd\.SmartPlug3\.[^\.]*$/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/SmartPlug3/+"  with regex /mqtt\.0\.cmnd\.SmartPlug3\.[^\.]*$/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get" with regex /SmartPlug3\.[^.]*\.get/
    2024-12-30 10:36:18.068  - info: mqtt.0 (515) Client [SmartPlug3] subscribes on "SmartPlug3/+/get"  with regex /mqtt\.0\.SmartPlug3\.[^.]*\.get/
    2024-12-30 10:36:18.805  - info: viessmannapi.0 (580) 1 installations found.
    2024-12-30 10:36:19.776  - info: host.ioBroker8 instance system.adapter.web.0 in version "6.2.5" started with pid 595
    2024-12-30 10:36:20.511  - info: web.0 (595) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2024-12-30 10:36:20.605  - info: web.0 (595) socket.io server listening on port 8082
    2024-12-30 10:36:20.610  - info: web.0 (595) http server listening on port 8082
    Dann bleiben wir halt auf Debian 11. Der Container ist ja nicht aus dem Internet erreichbar (der Host auch nicht)
    #61
    @io2345 sagte in Backitup Error:
    Die Liste ist auch deutlich zu umfangreich. Die müssen auch bei einem Container starten..
    • I io2345
      Danke für's Kümmern.
      Ich habe bei beiden Containern (Debian 11 und 12) das Gleiche gemacht: Die Anleitung für die CT-Installation habe ich von hier: Proxmox Installation. Ungefähr nach dem ersten Drittel kommt der Abschnitt "Erstellen eines Linux Containers (LXC) + ioBroker Installation im Anschluß".
      Dann die Einstellungen für den NAS-Share im BackItUp-Plugin eingestellt und darüber das identische Backup wiedereingespielt.
      HomoranH Offline
      HomoranH Offline
      #62
      damit ist der Restore noch lange nicht fertig.
      Srlbst wenn in der Basis nicht der Wurm drin wöre, würde jetzt erst begonnen alle Pakete für das neue Systrm passend neu zu bauen.
      Das dauert.
      I 1 Antwort Letzte Antwort
        Das dauert.
        I Offline
        I Offline
        io2345
        schrieb am zuletzt editiert von io2345
        #63
        Richtig, aber da muss ich ja manuell nichts mehr machen. Hat gefühlt etwa fünfzehn Minuten gedauert, bis die Pakete geladen, installiert und die Adapter wieder drin waren. Gestartet sind die hinzugefügten Adapter-Instanzen übrigens nicht von alleine, die musste ich manuell starten. War aber bei dem Debian11-CT genauso.
        • I io2345
          HomoranH Offline
          HomoranH Offline
          #64
          aber du solltest in der Zeit auch nichts machen!
          das kann man konfigurieren.
          Ist aber nicht grundlos so.
          Du kannst so noch die Einstellungen auf neue Gegebenheiten anpassen.
          • I io2345
            Hab jetzt mal drei GB und 2 CPU eingestellt, was die Situation aber bestenfalls marginal verbessert. So bin ich eher geneigt anzunehmen, dass Debian 12 der Grund ist. Welches Template habt ihr denn verwendet - ebenfalls Debian 12 oder was anderes? Einfach alle durchprobieren möchte ich jetzt auch nicht unbedingt...
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
            Failed to query system properties: Connection timed out
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             08:42:16 up 3 min,  0 user,  load average: 0.35, 0.41, 0.27
            CPU threads: 2
            iobrokeradmin
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            3.2G        957M        2.0G         86K        279M        2.3G
            Swap:           536M          0B        536M
            Total:          3.8G        957M        2.5G
                     3072 M total memory
                      913 M used memory
                     1009 M active memory
                      119 M inactive memory
                     1891 M free memory
                        0 M buffer memory
                      266 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            top - 08:43:32 up 4 min,  0 user,  load average: 0.12, 0.33, 0.25
            MiB Mem :   3072.0 total,   1890.1 free,    914.9 used,    267.1 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2157.1 avail Mem
            *** FILESYSTEM ***
            /var:
            421M    /var/
            249M    /var/cache
            245M    /var/cache/apt
            147M    /var/lib
            786M    /opt/iobroker/iobroker-data/
            23M     /opt/iobroker/iobroker-data/objects.jsonl
            13M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker8           ioBroker8 (version: 7.0.6, hostname: ioBroker8     , alive, uptime: 272)
            admin:          7.1.5
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        13663
            States:         9996
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7724560    167/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7724563    167/iobroker.js-con
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7724430    331/master
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7720832    1/init
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7728433    515/io.mqtt.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7729441    581/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7724676    342/io.admin.0
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7724431    331/master
            tcp6       0      0 :::111                  :::*                    LISTEN      0          7720834    1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          7725083    1/init
            udp        0      0 0.0.0.0:54961           0.0.0.0:*                           1001       7728536    548/io.upnp.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7725061    88/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7720833    1/init
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       7728704    548/io.upnp.0
            udp6       0      0 :::111                  :::*                                0          7720835    1/init
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/set"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.set/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+" with regex /cmnd\.SmartPlug2\.[^\.]*$/
            2024-12-30 08:39:41.861  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/SmartPlug2/+"  with regex /mqtt\.0\.cmnd\.SmartPlug2\.[^\.]*$/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get" with regex /SmartPlug2\.[^.]*\.get/
            2024-12-30 08:39:41.862  - info: mqtt.0 (515) Client [SmartPlug2] subscribes on "SmartPlug2/+/get"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.get/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
            2024-12-30 08:39:41.982  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
            2024-12-30 08:39:41.983  - info: mqtt.0 (515) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
            2024-12-30 08:39:42.604  - info: web.0 (581) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
            2024-12-30 08:39:42.699  - info: web.0 (581) socket.io server listening on port 8082
            2024-12-30 08:39:42.701  - info: web.0 (581) http server listening on port 8082
            2024-12-30 08:40:55.500  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
            2024-12-30 08:41:00.499  - info: admin.0 (342) <== Disconnect system.user.admin from ::ffff:192.168.0.28 admin
            2024-12-30 08:41:02.730  - info: admin.0 (342) ==> Connected system.user.admin from ::ffff:192.168.0.28
            CodierknechtC Offline
            Codierknecht
            #65
            Genau das. Läuft wie geschnitten Brot.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
