  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • T TT-Tom
    @stoffel67
    Nix mit npm install machen, sondern über
    iob upgrade self
    stoffel67
    @tt-tom
    OK werden den JS-controller updaten
    Mein Adapter: JUNG/GIRA eNet-Adapter
    S Thomas BraunT T 3 Antworten Letzte Antwort
    • S stoffel67
      @tt-tom
      stoffel67
      @stoffel67
      pi@raspberrypi:/opt/iobroker $ iob stop
      pi@raspberrypi:/opt/iobroker $ iob upgrade self
      Update js-controller from @5.0.12 to @6.0.9
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.1
      Installing iobroker.js-controller@6.0.9... (System call)
      Try to solve ENOTEMPTY error automatically
      Could not handle ENOTEMPTY, because no deletable files were found
      npm error code ENOTEMPTY
      npm error syscall rename
      npm error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types
      npm error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue
      npm error errno -39
      npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue'
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_32_43_299Z-debug-0.log
      host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
      • S stoffel67
        @tt-tom
        @stoffel67
        Hau den javascript-Adapter nochmal drüber.
        • S stoffel67
          @tt-tom
          TT-Tom
          @stoffel67
          Das mine-db Problem löst du damit aber nicht.
          Gruß Tom
          Public Transport
          NSPanel Adapter Wiki
          • S stoffel67
            @stoffel67
            Stopped Objects DB
            Stopped States DB
            NPM version: 10.8.1
            npm error errno -39
            @stoffel67
            iob stop
            iob fix
            iob update
            iob upgrade all -y
            iob upgrade self
              @stoffel67
              iob stop
              iob fix
              iob update
              iob upgrade all -y
              iob upgrade self
              stoffel67
              es wird immer schlimmer
              iob fix
              iob update
              iob upgrade all -y
              iob upgrade self
              library: loaded
              Library version=2024-05-24
                  Welcome to the ioBroker installation fixer!
                  Script version: 2024-01-04
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
              Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
              Es wurden 13,3 MB in 15 s geholt (855 kB/s).
                  Checking ioBroker user and directory permissions (2/5)
              Created /etc/sudoers.d/iobroker
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
              Used repository: stable
              Adapter    "admin"        : 7.0.22   , installed 7.0.22
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "ble"          : 0.14.0   , installed 0.14.0
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
              Adapter    "enet"         : 1.0.1    , installed 1.0.1
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
              Adapter    "proxy"        : 1.3.2    , installed 1.3.2
              Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
              Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
              Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
              Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
              Adapter    "withings"     : 0.0.13   , installed 0.0.13
              Adapter    "ws"           : 2.6.1    , installed 2.6.1
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
              Update radar2 from @2.1.0 to @2.2.0
              NPM version: 10.8.1
              Installing iobroker.radar2@2.2.0... (System call)
              npm error code 7
              npm error path /opt/iobroker/node_modules/@abandonware/noble
              npm error command failed
              npm error command sh -c node-gyp-build
              npm error gyp ERR! UNCAUGHT EXCEPTION
              npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
              npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
              npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
              npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
              npm error gyp ERR! System Linux 6.1.21-v7+
              npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
              npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
              npm error gyp ERR! node -v v20.16.0
              npm error gyp ERR! node-gyp -v v7.1.2
              npm error gyp ERR! Node-gyp failed to build your package.
              npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
              host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
              Stopped Objects DB
              Stopped States DB
              NPM version: 10.8.1
              npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
              npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
              npm error errno -39
              npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
              • S stoffel67
                iob fix
                iob update
                iob upgrade all -y
                iob upgrade self
                library: loaded
                Done.
                Autostart enabled!
                NPM version: 10.8.1
                npm error code 7
                Stopped Objects DB
                Stopped States DB
                NPM version: 10.8.1
                npm error errno -39
                @stoffel67
                iob delete ble
                iob fix
                  @stoffel67
                  iob delete ble
                  iob fix
                  stoffel67
                  pi@raspberrypi:/opt/iobroker $ iob delete  ble
                  Delete adapter "ble"
                  host.raspberrypi Counted 1 instances of ble
                  host.raspberrypi Counted 1 meta of ble
                  host.raspberrypi Counted 1 adapter for ble
                  host.raspberrypi Counted 2 channels of ble
                  host.raspberrypi Counted 3 states of ble
                  host.raspberrypi Counted 14 states of system.adapter.ble
                  host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
                  host.raspberrypi file ble.admin deleted
                  host.raspberrypi object ble deleted
                  host.raspberrypi object ble.admin deleted
                  host.raspberrypi Deleting 22 object(s).
                  host.raspberrypi Deleting 1 state(s).
                  Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
                  You might have to delete it yourself!
                  • S stoffel67
                    @stoffel67
                    iob list adapters
                    iob fix
                      @stoffel67
                      iob list adapters
                      iob fix
                      stoffel67
                      der fix läuft eigentlich immer durch
                      pi@raspberrypi:/opt/iobroker $ iob list adapters
                      iob fix
                      system.adapter.admin                   : admin          - v7.0.22
                      system.adapter.backitup                : backitup       - v2.11.0
                      system.adapter.discovery               : discovery      - v4.5.0
                      system.adapter.ds18b20                 : ds18b20        - v2.0.5
                      system.adapter.enet                    : enet           - v1.0.1
                      system.adapter.info                    : info           - v1.9.26
                      system.adapter.javascript              : javascript     - v8.7.6
                      system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                      system.adapter.modbus                  : modbus         - v6.1.0
                      system.adapter.node-red                : node-red       - v5.2.1
                      system.adapter.palazzetti              : palazzetti     - v0.0.6
                      system.adapter.proxy                   : proxy          - v1.3.2
                      system.adapter.radar2                  : radar2         - v2.1.0
                      system.adapter.rpi2                    : rpi2           - v1.3.2
                      system.adapter.shelly                  : shelly         - v7.0.0
                      system.adapter.simple-api              : simple-api     - v2.8.0
                      system.adapter.slideshow               : slideshow      - v0.1.4
                      system.adapter.smartmeter              : smartmeter     - v3.4.0
                      system.adapter.socketio                : socketio       - v6.7.0
                      system.adapter.sonoff                  : sonoff         - v3.0.3
                      system.adapter.terminal                : terminal       - v0.2.2
                      system.adapter.tr-064                  : tr-064         - v4.2.18
                      system.adapter.vis                     : vis            - v1.5.6
                      system.adapter.vw-connect              : vw-connect     - v0.0.67
                      system.adapter.web                     : web            - v6.2.5
                      system.adapter.withings                : withings       - v0.0.13
                      system.adapter.ws                      : ws             - v2.6.1
                      system.adapter.yahka                   : yahka          - v1.0.3
                      pi@raspberrypi:/opt/iobroker $ iob fix
                      library: loaded
                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Done.
                      Autostart enabled!
                      • S stoffel67
                        iob fix
                        library: loaded
                        Done.
                        Autostart enabled!
                        @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                        Soll es ja auch. Muss da ja aufräumen.
                        iob stop
                        iob fix
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        HomoranH S 2 Antworten Letzte Antwort
                          iob stop
                          iob fix
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                          iob stop
                          iob fix
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          @stoffel67
                          bitte einzeln aufrufen!
                            iob stop
                            iob fix
                            iob update
                            iob upgrade all -y
                            iob upgrade self
                            stoffel67
                            iob fix
                            iob update
                            iob upgrade all -y
                            iob upgrade self
                            library: loaded
                            OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Done.
                            Autostart enabled!
                            NPM version: 10.8.1
                            npm error code 7
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 10.8.1
                            npm error errno -39
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                            sollte ich das ganze evtl. einfach neu aufsetzen…
                            es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                            der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                            • S stoffel67
                              iob fix
                              iob update
                              iob upgrade all -y
                              iob upgrade self
                              library: loaded
                              Done.
                              Autostart enabled!
                              NPM version: 10.8.1
                              npm error code 7
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 10.8.1
                              npm error errno -39
                              @stoffel67
                              Du sollst die Befehle einzeln, zeilenweise eingeben.
                                @stoffel67
                                stoffel67
                                ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                                vielen Dank für deine Hilfe!!!!super
                                  @stoffel67
                                  stoffel67
                                  so ich versuch es nochmal
                                  Zeilen einzeln... und es kommt das:
                                  pi@raspberrypi:~ $ iob fix
                                  library: loaded
                                  Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                  Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                                  Done.
                                  Autostart enabled!
                                  pi@raspberrypi:~ $
                                  pi@raspberrypi:~ $ iob update
                                  pi@raspberrypi:~ $ iob upgrade all -y
                                  NPM version: 10.8.1
                                  npm error code 7
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                                  pi@raspberrypi:~ $ iob upgrade self
                                  Stopped Objects DB
                                  Stopped States DB
                                  NPM version: 10.8.1
                                  npm error errno -39
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                                  • S stoffel67
                                    library: loaded
                                    Done.
                                    Autostart enabled!
                                    pi@raspberrypi:~ $
                                    NPM version: 10.8.1
                                    npm error code 7
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 10.8.1
                                    npm error errno -39
                                    @stoffel67
                                    Schmeiß den radar2-Adapter mal raus.
                                    Dann nochmal wie zuvor.
                                      @stoffel67
                                      stoffel67
                                      das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                                      Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                      • S stoffel67
                                        @stoffel67
                                        Ja natürlich den Adapter.
                                        • S stoffel67
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                                          Instanz löschen:
                                          löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
                                          Adapter löschen:
                                          Löscht den Adaptercode und seine Dependencies
                                          Löscht auch alle Instanzen.
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
