  4. Homeconnect Fehlermeldung
55 Beiträge 5 Kommentatoren 7.2k Aufrufe 2 Beobachtet
    TimoWald
    Meine hOmeconnect Geräte lassen sich nicht mehr steueren.
    Adapter ist grün.
    Hier ein Auszug aus dem LOG.
    2024-07-04 16:06:35.450 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/0
    2024-07-04 16:06:36.151 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/0
    2024-07-04 16:06:36.868 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/1
    2024-07-04 16:06:37.569 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/1
    2024-07-04 16:06:37.731 - error: homeconnect.0 (98957) AxiosError: Request failed with status code 429
    2024-07-04 16:06:37.731 - error: homeconnect.0 (98957) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 10950 seconds.","key":"429"}}
    2024-07-04 16:06:38.271 - warn: openknx.0 (21678) Ignoring GroupValue_Read of unknown GA 3/3/1
    2024-07-04 16:06:39.042 - error: homeconnect.0 (98957) AxiosError: Request failed with status code 429
    2024-07-04 16:06:39.042 - error: homeconnect.0 (98957) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 10949 seconds.","key":"429"}}
    2024-07-04 16:06:40.222 - error: homeconnect.0 (98957) AxiosError: Request failed with status code 429
    2024-07-04 16:06:40.223 - error: homeconnect.0 (98957) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 10948 seconds.","key":"429"}}
    Was läuft da verkehrt?
    • T TimoWald
      Adapter ist grün.
      @timowald sagte in Homeconnect Fehlermeldung:
      The rate limit "1000 calls in 1 day" was reached. Requests are blocked during the remaining period of 10948 seconds."
      Du fragst zu häufig was an und für den Rest des Tages hast du nun Pause.
        TimoWald
        @thomas-braun Wie bekomme ich raus was angefragt wird und von wo aus die anfrage kommt?
        • T TimoWald
          TT-Tom
          @timowald
          Setzte mal den Adapter in den Debug Modus. Dann sieht man vielleicht im log etwas.
          Gruß Tom
          Public Transport
          NSPanel Adapter Wiki
          T 2 Antworten Letzte Antwort
          • T TT-Tom
            @timowald
            TimoWald
            @tt-tom Habe ich jetzt mal gemacht. Warte jetzt mal etwas und setze den LOG hier rein.
            • T TT-Tom
              @timowald
              TimoWald
              @tt-tom Hier mal der LOG nach 3 Minuten.
              Jede Minute passiert etwas.
              2024-07-04 16:52:01.914 - info: host.iobroker "system.adapter.homeconnect.0" enabled
              2024-07-04 16:52:02.309 - info: host.iobroker instance system.adapter.homeconnect.0 started with pid 101249
              2024-07-04 16:52:03.207 - debug: homeconnect.0 (101249) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2024-07-04 16:52:03.275 - debug: homeconnect.0 (101249) Objects client ready ... initialize now
              2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create System PubSub Client
              2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create User PubSub Client
              2024-07-04 16:52:03.441 - debug: homeconnect.0 (101249) Objects client initialize lua scripts
              2024-07-04 16:52:03.446 - debug: homeconnect.0 (101249) Objects connected to redis: 127.0.0.1:9001
              2024-07-04 16:52:03.535 - debug: homeconnect.0 (101249) Redis States: Use Redis connection: 127.0.0.1:9000
              2024-07-04 16:52:03.638 - debug: homeconnect.0 (101249) States create System PubSub Client
              2024-07-04 16:52:03.639 - debug: homeconnect.0 (101249) States create User PubSub Client
              2024-07-04 16:52:03.768 - debug: homeconnect.0 (101249) States connected to redis: 127.0.0.1:9000
              2024-07-04 16:52:03.837 - debug: homeconnect.0 (101249) Plugin sentry Initialize Plugin (enabled=true)
              2024-07-04 16:52:04.158 - info: homeconnect.0 (101249) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.17.1, js-controller: 5.0.19
              2024-07-04 16:52:04.231 - debug: homeconnect.0 (101249) Found current session
              2024-07-04 16:52:04.232 - debug: homeconnect.0 (101249) Refresh Token
              2024-07-04 16:52:04.554 - debug: homeconnect.0 (101249) {"access_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","expires_in":86400,"id_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","refresh_token":"eyJyZWdpb24iOiJFVSIsInN0YWdlIjoiUFJEIiwiY3JlZiI6IjA4MjUxMkJEIiwidG9rZW4iOiJiZThjOTA5OC1hYmZlLTQ3N2ItODAwMi1kMzQwYjJhYjVjZmQiLCJjbHR5IjoicHJpdmF0ZSIsIngtcmVnIjoiRVUiLCJ4LWVudiI6IlBSRCJ9","scope":"IdentifyAppliance Monitor Settings Control","token_type":"Bearer"}
              2024-07-04 16:52:04.555 - debug: homeconnect.0 (101249) Get device list
              2024-07-04 16:52:04.735 - error: homeconnect.0 (101249) AxiosError: Request failed with status code 429
              2024-07-04 16:52:04.736 - error: homeconnect.0 (101249) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 85880 seconds.","key":"429"}}
              2024-07-04 16:52:04.737 - debug: homeconnect.0 (101249) Start EventStream
              2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) 429 Too Many Requests
              2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
              2024-07-04 16:52:04.838 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
              2024-07-04 16:52:14.813 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:52:14.814 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:52:40.625 - info: solax.0 (21770) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
              2024-07-04 16:53:14.742 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
              2024-07-04 16:53:14.743 - debug: homeconnect.0 (101249) Start EventStream
              2024-07-04 16:53:14.817 - error: homeconnect.0 (101249) 429 Too Many Requests
              2024-07-04 16:53:14.818 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
              2024-07-04 16:53:14.818 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
              2024-07-04 16:53:16.253 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:53:16.254 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:54:13.597 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:54:13.598 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:54:24.749 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
              2024-07-04 16:54:24.750 - debug: homeconnect.0 (101249) Start EventStream
              2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) 429 Too Many Requests
              2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
              2024-07-04 16:54:24.826 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
              2024-07-04 16:55:15.037 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:55:15.038 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
              2024-07-04 16:55:34.756 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
              2024-07-04 16:55:34.756 - debug: homeconnect.0 (101249) Start EventStream
              2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) 429 Too Many Requests
              2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
              2024-07-04 16:55:34.862 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
              Thomas BraunT T haselchenH 3 Antworten Letzte Antwort
              • T TimoWald
                node: v18.17.1
                Bring das auf eine aktuelle Version.
                iob nodejs-update 20
                  node: v18.17.1
                  TimoWald
                  @thomas-braun Den Befehl in der Console?
                  • T TimoWald
                    @timowald
                    Ja. Deine Installation steht auf dem falschen Gleis.
                      TimoWald
                      @thomas-braun Da kommt diese Meldung:
                      Zur Info: IoBroker läuft auf Proxmox.
                      • T TimoWald
                        @timowald
                        Du sollst ja auch NICHT als root herumhampeln. Auch nicht im Proxmox-Container.
                        Als USER:
                        iob stop
                        iob fix
                        • T TimoWald
                          TT-Tom
                          @timowald schalte mal den Adapter ab bis morgen. Heute kommen da eh keine sinnvolle Meldungen zurück, weil du kein Connect mehr bekommst.
                          Gruß Tom
                          Public Transport
                          • T TT-Tom
                            @tt-tom sagte in Homeconnect Fehlermeldung:
                            Das stimmt.
                            Die Zeit kann man dann für ein vollständiges und richtiges Setup des Containers verwenden.
                              TimoWald
                              @thomas-braun said in Homeconnect Fehlermeldung:
                              Wie kann ich nachträglich noch einen Standard benutzer hinzufügen?
                              • T TimoWald
                                @timowald
                                Steht in der Doku drin:
                                https://www.iobroker.net/#de/documentation/install/proxmox.md
                                  TimoWald
                                  @thomas-braun Also geht das im nachhinein gar nicht mehr?
                                  • T TimoWald
                                    @timowald
                                    Klar geht das. Einfache User können natürlich jederzeit angelegt und auch wieder gelöscht werden.
                                      @timowald
                                      TimoWald
                                      schrieb am zuletzt editiert von TimoWald
                                      @thomas-braun ich mus ihn doch anlegen über die konsole in proxmox oder über Putty oder liege ich da falsch?
                                      Mus ich einen Benutzer für den IObroker oder für Proxmox anlegen?
                                      • T TimoWald
                                        @timowald
                                        Mit einem Terminal. Ich würde da aber immer was 'gescheites' verwenden.
                                        puTTY halte ich nicht für gescheit...
                                        Das Terminal aus proxmos kenne ich nicht. Keine Ahnung was die da verwenden.
                                        • T TimoWald
                                          Das steht doch in der Anleitung drin, oder nicht?
