  4. [gelöst] Iobroker Update Probleme
22 Beiträge 5 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • LoegsLifeL LoegsLife
    nun, Zigbee adapter Instaliert.
    ls -la /dev/serial/by-id/
    total 0
    drwxr-xr-x 2 root root 60 Jun 19 14:46 .
    drwxr-xr-x 4 root root 80 Jun 19 14:46 ..
    lrwxrwxrwx 1 root root 13 Jun 19 14:46 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2654229-if00 -> ../../ttyACM0
    "/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2654229-if00 -> ../../ttyACM0 " bei COM-Anschlussname , Typ Deconz/Conbee ausgewählt, Erweiterte Pan ID leicht geändert, Pan ID leicht umgeändert,
    Adapter Gelb
    Log zeigt :
    host.iobroker
    2024-06-19 15:30:34.372	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    host.iobroker
    2024-06-19 15:30:34.371	info	"system.adapter.zigbee.0" disabled
    zigbee.0
    2024-06-19 15:29:02.834	error	Error herdsman start
    zigbee.0
    2024-06-19 15:29:02.833	error	Failed to start Zigbee
    zigbee.0
    2024-06-19 15:29:02.832	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2654229-if00 -> ../../ttyACM0 '"
    zigbee.0
    2024-06-19 15:29:02.697	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.0
    2024-06-19 15:29:02.684	info	Starting Zigbee npm ...
    zigbee.0
    2024-06-19 15:29:02.683	info	Try to reconnect. 1 attempts left
    zigbee.0
    2024-06-19 15:28:52.679	error	Error herdsman start
    zigbee.0
    2024-06-19 15:28:52.679	error	Failed to start Zigbee
    zigbee.0
    2024-06-19 15:28:52.678	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2654229-if00 -> ../../ttyACM0 '"
    zigbee.0
    2024-06-19 15:28:52.182	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.0
    2024-06-19 15:28:51.877	info	Starting Zigbee npm ...
    joa...
    aber durch ls -la /dev/serial/by-id/ erkennt man das der Stick da ist...
    @loegslife sagte in Iobroker Update Probleme:
    Das ist wie oben schon mal beschrieben falsch. Ich hatte dir da auch den genauen Link hingeschrieben. Musst du nur noch richtig eintragen... Halt ohne das Link Target...
    LoegsLifeL 1 Antwort Letzte Antwort
      LoegsLifeL Offline
      LoegsLifeL Offline
      LoegsLife
      @thomas-braun ja, erkannt, habe
      -> ../../ttyACM0
      mit rein kopiert, entschuldigt.
      Bislang läuft alles super. vielen dank für eure hilfe!
