  5. Blockly zeigt Warn Meldungen.
    6.6k
43 Beiträge 5 Kommentatoren 4.8k Aufrufe 1 Beobachtet
  • E Einstein2002
    Zeit
    debug
    Nachricht
    mqtt.0
    2024-05-27 21:16:09.055	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER2[SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER2]
    mqtt.0
    2024-05-27 21:16:10.087	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER1[SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER1]
    mqtt.0
    2024-05-27 21:16:10.087	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER1[SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER1]
    mqtt.0
    2024-05-27 21:16:10.086	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER2[SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER2]
    mqtt.0
    2024-05-27 21:16:10.086	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER2[SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER2]
    mqtt.0
    2024-05-27 21:16:10.086	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Terrasse_DG.cmnd.POWER[SmartHome/Haus/Obergeschoss/Terrasse/TV_Terrasse_DG/cmnd/POWER]
    javascript.0
    2024-05-27 21:16:10.085	warn	at processImmediate (node:internal/timers:476:21)
    javascript.0
    2024-05-27 21:16:10.084	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
    javascript.0
    2024-05-27 21:16:10.084	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
    javascript.0
    2024-05-27 21:16:10.084	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1396:38)
    javascript.0
    2024-05-27 21:16:10.084	warn	at Object.<anonymous> (script.js.Terrassensteuerung.Terrasse_mit_TV:15:3)
    javascript.0
    2024-05-27 21:16:10.084	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1975:20)
    javascript.0
    2024-05-27 21:16:10.084	warn	State "mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TerrasseLED.cmnd.POWER" not found
    mqtt.0
    javascript.0
    2024-05-27 21:16:09.053	warn	at processImmediate (node:internal/timers:476:21)
    mqtt.0
    2024-05-27 21:16:09.055	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER2[SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER2]
    mqtt.0
    2024-05-27 21:16:09.055	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER1[SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER1]
    mqtt.0
    2024-05-27 21:16:09.055	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER1[SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER1]
    mqtt.0
    2024-05-27 21:16:09.054	info	send2Server mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Terrasse_DG.cmnd.POWER[SmartHome/Haus/Obergeschoss/Terrasse/TV_Terrasse_DG/cmnd/POWER]
    javascript.0
    javascript.0
    2024-05-27 21:16:09.053	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
    javascript.0
    2024-05-27 21:16:09.053	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
    javascript.0
    2024-05-27 21:16:09.053	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1396:38)
    javascript.0
    2024-05-27 21:16:09.053	warn	at Object.<anonymous> (script.js.Terrassensteuerung.Terrasse_mit_TV:5:3)
    javascript.0
    2024-05-27 21:16:09.053	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1975:20)
    javascript.0
    2024-05-27 21:16:09.052	warn	State "mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TerrasseLED.cmnd.POWER" not found
    @einstein2002 sagte in Blockly zeigt Warn Meldungen.:
    wo kommt der denn vor?
    edit. Das ist jeweils die erste Zeile
    • E Einstein2002
      Hallo zusammen, ich habe zwei Blockly Scripte und bei beiden kommt jedes mal wenn ich diese ausführe eine Fehlermeldung.
      An was könnte dies liegen??
      Das Script läuft und macht was es soll. Irgendein Tipp??
      @einstein2002 sagte: ich habe zwei Blockly
      Man wendet keine zwei Trigger auf den gleichen Datenpunkt an, sondern:
      HomoranH E 4 Antworten Letzte Antwort
        @paul53 leider nein.
        in seinem zweiten Trigger würde das nicht passen
        da sind switch1 und switch2 vertauscht
        E paul53P 2 Antworten Letzte Antwort
          Einstein2002
          @paul53 Ja das sind zwei unterschiedliche, ich habe zwei Rollos die öffnen bzw. schließen möchte, ich habe nur den einen hochgeladen.
          Die Ursache war der Datenpunkt mit der LED.POWER
          Den habe ich jetzt neu zugewiesen und jetzt ist der Fehler weg.
          Danke für die Info und Hilfe, da hatte ich nicht an die Protokolle gedacht!
          Sorry noch einmal für die Kleine Auflösung.
          Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
          Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
            Einstein2002
            on({ id: [].concat(['0_userdata.0.Terrasse_mit_TV']), val: true }, async (obj) => {
              let value = obj.state.val;
              let oldValue = obj.oldState.val;
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_LED.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_LED/cmnd/POWER */, true);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Terrasse_DG.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Terrasse_DG/cmnd/POWER */, true);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER1 */, true);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER1 */, true);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER2 */, false);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER2 */, false);
            on({ id: [].concat(['0_userdata.0.Terrasse_mit_TV']), val: false }, async (obj) => {
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_LED.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_LED/cmnd/POWER */, false);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Terrasse_DG.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Terrasse_DG/cmnd/POWER */, false);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER2 */, true);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER2 */, true);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER1 */, false);
              setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER1 */, false);
            Bei ON ist die 1. Zeile
            Das ist das zweite Script
              Einstein2002
              @paul53 sagte in Blockly zeigt Warn Meldungen.:
              Ich versuch das mal umzubauen.
              • E Einstein2002
                da ist jetzt ein Unterstrich mehr
                E 1 Antwort Letzte Antwort
                  Einstein2002
                  oh man, ich hatte den neu angelegt und dabei wohl einen Unterstrich eingefügt.
                  Danke!!!!
                    @homoran sagte: da sind switch1 und switch2 vertauscht
                    Genau deshalb würde es passen: "POWER2" sind negiert, alle anderen nicht.
                    E HomoranH 2 Antworten Letzte Antwort
                      Einstein2002
                      Ja das Passt schon, da hängt ein Sonoff Dual R3 dahinter, der hat Power1 und Power2.
                      Als Rollladen Schalter darf immer nur einer auf True stehen. Deswegen habe ich dies so gewählt, ich bin gerade am anlegen von Alias Punkten und versuche so meine Objekte neu anzulegen. Wenn ich nachher eine passende Lösung gefunden habe teile ich diese hier im Forum.
                      Bitte noch etwas um Geduld, ich bin da noch immer nicht so fit und brauche etwas Zeit.
                        Einstein2002
                        Hallo Paul53,
                        das wird so nicht funktionieren, folgende Bedingung habe ich:
                        Ein paar LED am Boden, die sollen angehen wenn ich die Terrasse öffne, dann soll der Rollo hochfahren, Power1 wird auf True gesetzt, dadurch wird Power2 Automatisch False.
                        Der andere Auslöser bewirkt das gleiche wie oben, hat aber den zweiten Rollo mit Power1 auf True und Power2 auf False, dann noch einen weiteren Sonoff der eine weitere Steckdose anschaltet.
                        Das würde ja noch mit dem "Wert" gehen, aber jetzt beim Ausschalten der Terrasse kommt die Problematik:
                        Ich muss die Steckdose auf False setzten,
                        der Rollo mit Power2 aber auf True, das bewirkt das Herunterfahren des Rollos. Der "Wert" wäre aber bei beiden "False"
                        Ist das richtig??
                        • E Einstein2002
                          Hallo Paul53,
                          Ist das richtig??
                          @einstein2002 sagte: Der "Wert" wäre aber bei beiden "False"
                          Nein, der nicht-Block negiert: false --> true, true --> false.
                            Einstein2002
                            Okay, habe das "nicht" überlesen!! Klar dann geht es. Sorry mein Fehler!
                              aber doch unterschiedlich
                              im oberen Teil ist der dritte negiert, im unteren Teil der zweite
                                Einstein2002
                                Das liegt aber an der Reihenfolge, die habe ich nicht eingehalten. Da habe ich Power 1 und Power2 vertauscht
                                • E Einstein2002
                                  @einstein2002 das ist da leider icht zu sehen.
                                  Aber dann hat @paul53 natürlich recht.
                                    Einstein2002
                                    So da habe ich mal fertig:
                                      <block type="on_ext" id="cWj)M#2q10ApriJ}z/J." x="-87" y="112">
                                        <field name="CONDITION">true</field>
                                        <value name="OID0">
                                          <shadow type="field_oid" id="#7nxk7{L]5dos]}o*Ulq">
                                            <field name="oid">0_userdata.0.Terrasse_mit_TV</field>
                                          </shadow>
                                        </value>
                                        <statement name="STATEMENT">
                                          <block type="control" id=",`L(EWw`b}Z~:?]0Oi|u">
                                            <field name="OID">alias.0.Haus.Terrasse.Unterstand.LED_Terrasse_Boden_und_Sonos_Amp.LED_Terrasse_Boden_und_Sonos_AMP</field>
                                            <value name="VALUE">
                                              <block type="on_source" id="~_]2dNN779yd/4NrnTm@">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="control" id="C++/OsdWV8_*Q3SnO1[@">
                                                <field name="OID">alias.0.Haus.Terrasse.Terrasse_TV_Steckdose_im_DG.Terrasse_TV_Steckdose_DG</field>
                                                  <block type="on_source" id="BxMF$`~}@j+71AGAP=mV">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="v_OmfSc.ziVQoLYX#hBj">
                                                    <field name="OID">alias.0.Haus.Terrasse.Rollo_Unterstand.Rollo_Hoch_Power1</field>
                                                      <block type="on_source" id="*Z}%_.YM}FDa.o}r][7g">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="control" id="=*R1a_=NxrAhs-#wwstI">
                                                        <field name="OID">alias.0.Haus.Terrasse.Rollo_TV.Rollo_Hoch_Power1</field>
                                                          <block type="on_source" id="I9r14*9?lH3rC#s]Pbj-">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="on_ext" id="F94}@P{!jE6@T-{iCB{5">
                                            <field name="CONDITION">false</field>
                                            <value name="OID0">
                                              <shadow type="field_oid" id="$qu1SRidmJz{9+c|tjI7">
                                              </shadow>
                                            </value>
                                              <block type="control" id="cV.Iz~{@^y@jj+@/klAC">
                                                  <block type="on_source" id="l]D]Z8E~6Lt^z44#R78k">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="E7,r/yW{WUBbTvj?G07W">
                                                      <block type="on_source" id="6Qp{]7J7V~[Eo62Dd3sO">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="control" id="xbP1k-}1n1?W7GFXNo^8">
                                                        <field name="OID">alias.0.Haus.Terrasse.Rollo_Unterstand.Rollo_Runter_Power2</field>
                                                          <block type="logic_negate" id="x0U:1pZV|Qg9t5[SraN]">
                                                            <value name="BOOL">
                                                              <block type="on_source" id="%)G^7cA1G8Nq;5m0xezI">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="control" id="DKD21eq}u~y8d*=lk%UY">
                                                            <field name="OID">alias.0.Haus.Terrasse.Rollo_TV.Rollo_Runter_Power2</field>
                                                              <block type="logic_negate" id="Zve0$RJ?xcYzxn_0Go2:">
        <value name="BOOL">
        <block type="on_source" id=")+|zwlUrATu3B}29e2{]">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </xml>
                                    Damit läuft es super. 1000 Dank an Euch
                                    • E Einstein2002
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                      <next>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="OID0">
                                                </shadow>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                      <next>
                                                              <value name="BOOL">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
        <value name="BOOL">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </xml>
                                      ein schönes xml 😁
                                        ein schönes xml 😁
                                        Einstein2002
                                        ja, Fotos soll ich ja nicht machen wegen der Auflösung..
                                        Das ist der Export von einem Blockly.
                                        • E Einstein2002
                                          nee, eine geeignete Auflösung wählen.
                                          So wie jetzt
                                          geht es gerade
