  4. Adapter lassen sich nicht mehr aktualisieren
23 Beiträge 6 Kommentatoren 3.1k Aufrufe 6 Beobachtet
  • T t1m0
    Grüße,
    seit ein paar Tagen bin ich nicht in der Lage irgendwelche updates durchzuführen. Ich habe, zumindest nicht wissentlich, irgendetwas geändert.
    Ich bekomme immer, egal welchen Adapter ich Updaten will, folgende Fehlermeldung:
    $ iobroker upgrade hm-rpc@1.17.0 --debug
    Update hm-rpc from @1.16.0 to @1.17.0
    NPM version: 10.5.0
    Installing iobroker.hm-rpc@1.17.0... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm ERR! code 127
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.npm WARN deprecated har-validator@5.1.5: this library is no longer supportednpm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.loghost.iobroker Cannot install iobroker.hm-rpc@1.17.0: 127
    ERROR: Process exited with code 25
    Mein System:
    pi@iobroker:~$ uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    /usr/bin/corepack
    v18.20.2
    v18.20.2
    10.5.0
    10.5.0
    0.25.2
    5.0.19
    pi
    pi cdrom floppy sudo audio dip video plugdev netdev iobroker
    tty
    /home/pi
    OK:1 http://security.debian.org/debian-security buster/updates InRelease
    OK:2 http://deb.debian.org/debian buster InRelease
    OK:3 http://deb.debian.org/debian buster-updates InRelease
    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Aktualisierung für 7 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
      Installiert:           18.20.2-1nodesource1
      Installationskandidat: 18.20.2-1nodesource1
      Versionstabelle:
     *** 18.20.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.20.1-1nodesource1 500
         18.20.0-1nodesource1 500
         18.19.1-1nodesource1 500
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         10.24.0~dfsg-1~deb10u4 500
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
    Über eure Hilfe wäre ich sehr Dankbar!
    t1m0
    Keiner mehr eine Idee was ich noch tun kann, oder woran es liegen könnte?
      t1m0
      Ich habe nun keinen anderen Ausweg gesehen, als Iobroker neu zu installieren und ein Backup einzuspielen. Dies hat auch alles wunderbar funktioniert. Ich kann nun wieder alles aktualisieren.
      Ein Adapter hat aber Probleme gemacht, und den gleichen Fehler ausgespuckt. Den Adapter habe ich dann gelöscht und neu installiert. Nun habe ich auch hier keine Probleme mehr und Iobroker funktioniert wieder!!! 😳
      • T t1m0
        @t1m0 sagte in Adapter lassen sich nicht mehr aktualisieren:
        Und welcher Adapter war das?
