  4. Probleme nach Update Telegramm und Alexa Adapter
15 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • H Offline
    Henny112
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     16:38:39 up  1:00,  2 users,  load average: 3.84, 3.09, 2.93
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-04-19 16:38:39 CEST
               Universal time: Fri 2024-04-19 14:38:39 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.6G        1.7G         56M        513M        2.0G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.8G
             3838 M total memory
             1638 M used memory
              271 M active memory
             1779 M inactive memory
             1686 M free memory
               77 M buffer memory
              436 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  9.4G   19G  34% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G   57M  1.9G   3% /run
    tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Fri Apr 19 15:37:50 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:18:E5:11 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bcdf1e39-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Apr 19 15:37:51 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Apr 19 15:37:51 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Apr 19 15:37:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    1.4G    /var/cache/apt
    1.4G    /var/cache
    1.3G    /var/cache/apt/archives
    97M     /var/lib
    Archived and active journals take up 55.9M in the file system.
    /opt/iobroker/backups:
    1.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    982M    /opt/iobroker/iobroker-data/
    552M    /opt/iobroker/iobroker-data/files
    183M    /opt/iobroker/iobroker-data/backup-objects
    176M    /opt/iobroker/iobroker-data/iobroker-data
    158M    /opt/iobroker/iobroker-data/files/vis-2
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2437483-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: node-mihome@^0.0.32, required by iobroker.javascript@7.8.0
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-19T14_38_53_961Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : raspberrypi                              - disabled
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
    + system.adapter.backitup.2               : backitup              : raspberrypi                              -  enabled
    + system.adapter.backitup.3               : backitup              : raspberrypi                              -  enabled
      system.adapter.blockly-plus.0           : blockly-plus          : raspberrypi                              - disabled
    + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
    + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "deconz"       : 1.4.0    , installed 1.4.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.2.1    , installed 3.2.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Objects and States
    Objects:        11993
    States:         10982
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://phoscon.de/apt/deconz buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        1      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17848      342/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18463      651/sshd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       78421      17652/io.shelly.1
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17851      342/deCONZ
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       69596      16229/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       69589      16229/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       71835      16283/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       77717      18505/io.web.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       78642      18135/io.nuki-exten
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18465      651/sshd
    tcp6       0      0 :::8089                 :::*                    LISTEN      1001       71098      16372/io.admin.1
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       76103      17513/io.shelly.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       75955      17428/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15160      643/dhcpcd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       73682      17239/io.mihome-vac
    udp        0      0 0.0.0.0:46820           0.0.0.0:*                           108        15917      387/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15915      387/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       75482      17797/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17854      342/deCONZ
    udp6       0      0 :::46482                :::*                                108        15918      387/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15175      643/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15916      387/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       75484      17797/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       75483      17797/io.deconz.0
    2024-04-19 16:41:25.994  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
    2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-19 16:41:25.995  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-19 16:41:25.996  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/index.js:35:30)
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19) {
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
    2024-04-19 16:41:25.997  - error: host.raspberrypi Caught by controller[0]: }
    2024-04-19 16:41:26.002  - error: host.raspberrypi Caught by controller[0]: Node.js v18.20.2
    2024-04-19 16:41:26.002  - error: host.raspberrypi instance system.adapter.telegram.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-19 16:41:26.003  - info: host.raspberrypi Restart adapter system.adapter.telegram.1 because enabled
    iob diag has finished.
    Press any key for a summary
    J 1 Antwort Letzte Antwort
    • H Henny112
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               3838 M total memory
               1638 M used memory
                271 M active memory
               1686 M free memory
                 77 M buffer memory
                436 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.6G    /var/
      1.4G    /var/cache/apt
      1.4G    /var/cache
      97M     /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11993
      States:         10982
      Pending Updates: 1
      Jaksa
      @henny112
      Was für Probleme hast du genau? Die Adapter selber laufen habe die selben Versionen im Einsatz.
      Dein System basiert auf Debian 10. Ein sehr guter Anfang wäre das Museum zu schließen und das ganze mal auf Debian 12 anzuheben.
      Erstell dir ein Backup von deinem IOB, installier Debian 12 frisch und spiel dann dein Backup ein und prüfe ob die Adapter dann nicht doch laufen.
      H 1 Antwort Letzte Antwort
      • J Jaksa
        @henny112
        Henny112
        @jaksa sagte in Probleme nach Update Telegramm und Alexa Adapter:
        @henny112
        Danke für deine Antwort aber da ja mehrere das Problem haben ist es damit ja nicht aus der Welt geschafft. Sondern nur der einfachste Ausweg. Habe ich dann da ein Problem mit einem Adapter wechsel ich wieder zurück ist ja auch nicht die Lösung des Problems. Alles andere und auch diese Adapter liefen ja bis dahin. Und ich denke da soll man eher schauen was das Problem ist als alles andere. Bisher hatte ich nie Probleme.
        Thomas BraunT ? 2 Antworten Letzte Antwort
        • H Henny112
          @henny112
          @henny112 sagte in Probleme nach Update Telegramm und Alexa Adapter:
          Eines deiner Grundprobleme ist die abgesoffene Version deines Betriebssystems.
          Wenn die Basis sauber ist schaut man sich den Rest an.
          Neuinstallation als reines 64Bit-System.
          • H Henny112
            @henny112
            @henny112
            Wenn dein Debian veraltet ist, wirst du bald noch mehr Probleme mit updates bekommen..
              @henny112
              Henny112
              @ilovegym Wird Raspian denn nicht mehr weiter geführt das es veraltet ist ? Debian kenne ich mich gar nicht mit aus . Wo sind da Unterschiede ? LG
              • H Henny112
                Raspbian basiert auf Debian. Für den Raspberry werden (insbesondere in der 32Bit-Version) da diverse Dinge noch an den Raspberry angepasst.
                Die Unterschiede bestehen im wesentlichen aus diesen Gerätespezifischen Anpassungen.
                Und die Basis Debian 10 'Buster' ist aufgegeben worden. Aktuell ist Debian 12 'Bookworm' die Basis.
                  Henny112
                  @thomas-braun sagte in Probleme nach Update Telegramm und Alexa Adapter:
                  Das bedeutet ich würde mir die neue Raspian Version laden sehe ich das richtig? Das ja Debian 12 oder welche Version wird empfohlen? Der rest müsste ja so sein wie aktuell oder?
                  • H Henny112
                    @henny112
                    Mach es per RaspiImager.
                    Ich hab mal irgendwo eine Anleitung 'Einfacher geht's nicht' im Forum hinterlassen. Such mal danach.
                      @henny112
                      Henny112
                      @henny112
                      Ja schaue gleich mal eben neue Karte besorgen. 😂
                      mcm1957M H 2 Antworten Letzte Antwort
                      • H Henny112
                        @henny112
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        Es gab heute kurze Zeit (ca 30 Minuten) ein fehlerhaftes Downloadpaket. Durch eine Neuinstallation bzw ein Update eines Adapters sollte der Fehler automatisch behoben werden.
                        Bitte diesbezügliche Diskussion primär in diesem Topic führen um Parallelitäten zu minimieren.
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • H Henny112
                          @henny112
                          Henny112
                          @henny112
                          Danke habe alles neu Installiert läuft wieder aber der Fehler der da war wurde ja genannt. Naja nun ist de SD mal neu. :-) Aber danke trotzdem.
                          • mcm1957M mcm1957
                            Henny112
                            @mcm57 sagte in Probleme nach Update Telegramm und Alexa Adapter:
                            Danke Dir aber nun ist alles neu.
                            • H Henny112
                              Henny112
                              Danke allen für die Tipps. Habe eine Neuinstallation gemacht nun rennt der Hobel wieder. Vielen Dank an alle. MFG
                              • H Henny112
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                Für das zugrundeliegende Problem gibts nun einen eigenen Topic mit Erläuterung. Falls noch wer Hilfe braucht bitte dort melden:
                                https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
