  4. keine Adapter mehr installieren /Updaten
    1.0k
    6.1k
errror npmfehler update
17 Beiträge 2 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • F Offline
    Farmer-cb
    Servus
    Kann seit kurzem keine Adapter mehr Updaten bzw Installieren.
    jedesmal kommt so eine Fehlermeldung:
    Update alexa2 from @3.26.4 to @3.26.5
    NPM version: 10.2.4
    Installing iobroker.alexa2@3.26.5... (System call)
    npm ERR! code 128
    npm ERR! An unknown git error occurred
    npm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/TA2k/ioBroker.renault.git
    npm ERR! Warning: Permanently added the ECDSA host key for IP address '140.82.121.3' to the list of known hosts.
    npm ERR! git@github.com: Permission denied (publickey).
    npm ERR! fatal: Could not read from remote repository.
    npm ERR!
    npm ERR! Please make sure you have the correct access rights
    npm ERR! and the repository exists.
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-17T15_51_40_273Z-debug-0.log
    host.iobroker Cannot install iobroker.alexa2@3.26.5: 128
    erster Teil von iobroker diag kommt:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 10 (buster)
                Kernel: Linux 5.15.131-2-pve
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:06:05 up 24 min,  1 user,  load average: 1.26, 1.07, 0.91
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Wed 2024-04-17 18:06:05 CEST
               Universal time: Wed 2024-04-17 16:06:05 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    Farmer
    /home/Farmer
    Farmer sudo
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:           6.0G        3.4G        1.9G        8.0M        630M        2.6G
    Swap:          1.0G          0B        1.0G
    Total:         7.0G        3.4G        3.0G
             6000 M total memory
             3431 M used memory
              320 M active memory
             3543 M inactive memory
             1937 M free memory
                0 M buffer memory
              630 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * sys-kernel-debug.mount        loaded failed failed Kernel Debug File System
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    3 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       24G  8.5G   14G  38% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     3.9G  8.1M  3.9G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     782M     0  782M   0% /run/user/0
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems \(real ones only\):
    TARGET                    SOURCE                           FSTYPE     OPTIONS
    /                         /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
    |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    579M    /var/
    384M    /var/cache
    380M    /var/cache/apt
    318M    /var/cache/apt/archives
    187M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    21M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    745M    /opt/iobroker/iobroker-data/
    444M    /opt/iobroker/iobroker-data/files
    197M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    50M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
         18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
     *** 18.19.1-1nodesource1 1001
            100 /var/lib/dpkg/status
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u4 500
            500 http://security.debian.org buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://ftp.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.renault@0.0.21 /opt/iobroker/node_modules/iobroker.renault
    npm ERR! invalid: iobroker.vis-plumb@1.0.3 /opt/iobroker/node_modules/iobroker.vis-plumb
    npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! invalid: samsungtv@0.0.0 /opt/iobroker/node_modules/samsungtv
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
    npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
    npm ERR! A complete log of this run can be found in: /home/Farmer/.npm/_logs/2024-04-17T16_06_07_268Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    npm ERR! A complete log of this run can be found in: /home/Farmer/.npm/_logs/2024-04-17T16_06_15_318Z-debug-0.log
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
    + system.adapter.digitalstrom.0           : digitalstrom          : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.ekey.0                   : ekey                  : iobroker                                 -  enabled, port: 56000, bind: 0.0.0.0
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
    + system.adapter.renault.1                : renault               : iobroker                                 -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
      system.adapter.sayit.1                  : sayit                 : iobroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonnen.0                 : sonnen                : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.2                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.3                    : sql                   : iobroker                                 -  enabled, port: 3306
      system.adapter.sql.4                    : sql                   : iobroker                                 - disabled, port: 3306
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.vr200.0                  : vr200                 : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 192.168.111.20, run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8080, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "ekey"         : 1.2.3    , installed 1.2.3
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.1  [Updatable]
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
    Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
    Adapter    "renault"      : 0.0.15   , installed 0.0.21
    Adapter    "s7"           : 1.4.3    , installed 1.4.2  [Updatable]
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.8.0    , installed 6.9.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sonnen"       : 1.18.0   , installed 1.17.0 [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.3
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vr200"        : 1.0.0    , installed 1.0.0
    Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Objects and States
    Objects:        37069
    States:         36368
    Hit:1 http://ftp.debian.org/debian buster InRelease
    Hit:2 http://security.debian.org buster/updates InRelease
    Hit:3 http://ftp.debian.org/debian buster-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 30
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          621956498  114/sshd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       621960050  527/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       621963415  602/io.shelly.0
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        621957189  117/redis-server 12
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          621956646  272/master
    tcp        0      0 192.168.111.20:9292     0.0.0.0:*               LISTEN      1000       621964589  677/io.hm-rpc.2
    tcp        0      0 192.168.111.20:2001     0.0.0.0:*               LISTEN      1000       621961489  557/io.hm-rpc.0
    tcp        0      0 192.168.111.20:2010     0.0.0.0:*               LISTEN      1000       621961914  662/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       621957432  128/iobroker.js-con
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          621956647  272/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          621956500  114/sshd
    tcp6       0      0 :::3000                 :::*                    LISTEN      1000       621966717  798/io.fullybrowser
    tcp6       0      0 ::1:6379                :::*                    LISTEN      107        621957190  117/redis-server 12
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       621957604  309/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      1000       621967294  861/io.web.1
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       621967111  845/io.simple-api.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       621964977  738/io.sonos.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       621963260  722/io.mihome-vacuu
    udp        0      0 192.168.111.20:5353     0.0.0.0:*                           1000       621963619  647/io.tr-064.0
    udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1000       621970782  921/io.ekey.0
    2024-04-17 17:46:58.438  - info: admin.0 (309) ==> Connected system.user.admin from ::ffff:192.168.108.21
    2024-04-17 17:47:08.911  - info: admin.0 (309) <== Disconnect system.user.admin from ::ffff:192.168.108.21
    2024-04-17 17:47:43.275  - error: proxmox.0 (813) Check storage -- Problem found.. maybe offline
    2024-04-17 17:48:00.028  - info: host.iobroker instance system.adapter.ical.0 started with pid 2164
    2024-04-17 17:48:12.168  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-04-17 17:51:00.022  - info: host.iobroker instance system.adapter.ical.2 started with pid 3139
    2024-04-17 17:51:09.505  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
    2024-04-17 17:51:23.387  - info: host.iobroker "system.adapter.alexa2.0" disabled
    2024-04-17 17:51:23.387  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
    2024-04-17 17:51:23.524  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
    2024-04-17 17:51:24.046  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-04-17 18:00:00.045  - info: host.iobroker instance system.adapter.ical.2 started with pid 3326
    2024-04-17 18:00:00.083  - info: javascript.0 (336) script.js.common.Wetterdaten.Regenmengenmesser: daten in letzte Stunde schreiben
    2024-04-17 18:00:04.082  - info: host.iobroker instance system.adapter.ical.0 started with pid 3341
    2024-04-17 18:00:08.095  - info: host.iobroker instance system.adapter.ical.1 started with pid 3356
    2024-04-17 18:00:10.553  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
    2024-04-17 18:00:15.972  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-04-17 18:00:16.441  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2024-04-17 18:01:00.042  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 3372
    2024-04-17 18:01:01.133  - info: host.iobroker instance system.adapter.parser.0 scheduled normal terminated and will be restarted on schedule.
    2024-04-17 18:01:01.133  - info: host.iobroker Restart adapter system.adapter.parser.0 because enabled
    2024-04-17 18:01:01.172  - info: pegelalarm.0 (3372) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.19.1, js-controller: 5.0.19
    2024-04-17 18:01:02.230  - info: host.iobroker instance system.adapter.parser.0 started with pid 3387
    2024-04-17 18:01:09.924  - info: pegelalarm.0 (3372) Terminated (NO_ERROR): Without reason
    2024-04-17 18:01:10.434  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    zweiter Teil:
                            v.2023-10-10
               Chassis: container
        Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     30
    Pending iob updates:    7
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                            /usr/bin/npm            10.2.4
                            /usr/bin/npx            10.2.4
    Recommended versions are nodejs 18.20.2 and npm 10.5.0
    MEMORY:
    Mem:           6.0G        3.5G        1.9G        8.0M        630M        2.5G
    Swap:          1.0G          0B        1.0G
    Total:         7.0G        3.5G        2.9G
    Active iob-Instances:   36
    ioBroker Core:          js-controller           5.0.19
                            admin                   6.13.16
    Objects type: jsonl
    States  type: redis
    Objects:                37069
    States:                 36368
    Size of iob-Database:
    18M     /opt/iobroker/iobroker-data/objects.json.migrated
    18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    80K     /opt/iobroker/iobroker-data/states.json
    76K     /opt/iobroker/iobroker-data/states.json.bak
    smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
    Thomas BraunT 3 Antworten Letzte Antwort
    • F Farmer-cb
      Servus
      NPM version: 10.2.4
      npm ERR! code 128
      npm ERR!
      Skript v.2023-10-10
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      Farmer
      /home/Farmer
      Farmer sudo
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:          1.0G          0B        1.0G
               6000 M total memory
               3431 M used memory
                320 M active memory
               1937 M free memory
                  0 M buffer memory
                630 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      *** FILESYSTEM ***
      /var:
      579M    /var/
      384M    /var/cache
      380M    /var/cache/apt
      187M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        37069
      States:         36368
      Pending Updates: 30
      zweiter Teil:
                              v.2023-10-10
                 Chassis: container
          Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
      MEMORY:
      Swap:          1.0G          0B        1.0G
                              admin                   6.13.16
      Objects type: jsonl
      States  type: redis
      Objects:                37069
      States:                 36368
      @farmer-cb sagte in keine Adapter mehr installieren /Updaten:
      ECDSA
      Wird wohl damit in Verbindung stehen.
      https://www.golem.de/news/sicherheitsluecke-in-putty-rekonstruktion-privater-ecdsa-schluessel-moeglich-2404-184208.html
      Da müssen die Schlüssel aktualisiert werden.
      • F Farmer-cb
        Servus
        NPM version: 10.2.4
        npm ERR! code 128
        npm ERR!
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        Farmer
        /home/Farmer
        Farmer sudo
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:          1.0G          0B        1.0G
                 6000 M total memory
                 3431 M used memory
                  320 M active memory
                 1937 M free memory
                    0 M buffer memory
                  630 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        *** FILESYSTEM ***
        /var:
        579M    /var/
        384M    /var/cache
        380M    /var/cache/apt
        187M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        admin:          6.13.16
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        37069
        States:         36368
        Pending Updates: 30
        zweiter Teil:
                                v.2023-10-10
                   Chassis: container
            Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1001
        X-Server:               false
                                /usr/bin/npm            10.2.4
                                /usr/bin/npx            10.2.4
        MEMORY:
        Swap:          1.0G          0B        1.0G
                                admin                   6.13.16
        Objects type: jsonl
        States  type: redis
        Objects:                37069
        States:                 36368
        Pending OS-Updates: 30 Pending iob updates: 7
        Und neben den Schlüsseln musst du dein System auch auf Stand bringen...
        Leute, Leute, Leute...
        Dabei ist das ein nur Zweizeiler für das OS.
        sudo apt update
        sudo apt full-upgrade
        • F Farmer-cb
          Servus
          NPM version: 10.2.4
          npm ERR! code 128
          npm ERR!
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          Farmer
          /home/Farmer
          Farmer sudo
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:          1.0G          0B        1.0G
                   6000 M total memory
                   3431 M used memory
                    320 M active memory
                   1937 M free memory
                      0 M buffer memory
                    630 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          *** FILESYSTEM ***
          /var:
          579M    /var/
          384M    /var/cache
          380M    /var/cache/apt
          187M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          admin:          6.13.16
          javascript:     7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        37069
          States:         36368
          Pending Updates: 30
          zweiter Teil:
                                  v.2023-10-10
                     Chassis: container
              Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1001
          X-Server:               false
                                  /usr/bin/npm            10.2.4
                                  /usr/bin/npx            10.2.4
          MEMORY:
          Swap:          1.0G          0B        1.0G
                                  admin                   6.13.16
          Objects type: jsonl
          States  type: redis
          Objects:                37069
          States:                 36368
          Seh ich ja jetzt erst...
          Buster ist abgekündigt. Installier da was lebendes.
          Debian 12 'Bookworm' z. B. Im Container ja kein Ding.
          F 1 Antwort Letzte Antwort
            Farmer-cb
            schrieb am zuletzt editiert von Farmer-cb
            Servus
            wollte jetzt den iobroker komplett neu aufziehen und ein Backup einspielen. aber leider
            bekomme ich beim Backuperstellen einen Fehler
            Parsing error on getStates("io.undefined"), returning "null" for "undefined": Unexpected token u in JSON at position 0
            host.iobroker 36380 states saved
            host.iobroker 37080 objects saved
            Backup created: /opt/iobroker/backups/2024_04_18-17_08_05_backupiobroker.tar.gz
            This backup can only be restored with js-controller version up from 4.1
            beim wiedereinspielen kommt dann:
            root@iobroker:/opt/iobroker# iobroker  restore 2024_04_18-17_08_05_backupiobroker.tar.gz
            iobroker controller daemon is not running
            host.iobroker OK.
            Removing current installation of iobroker.admin
            removed 43 packages in 1s
            56 packages are looking for funding
              run `npm fund` for details
            Removing current installation of iobroker.backitup
            removed 170 packages in 914ms
            29 packages are looking for funding
            Removing current installation of iobroker.discovery
            removed 44 packages in 2s
            15 packages are looking for funding
            host.iobroker Connecting to new DB "redis/jsonl" (can take up to 20s) ...
            No connection to states 127.0.0.1:6379[redis]
            • F Farmer-cb
              Servus
              host.iobroker OK.
              root@iobroker
              Nicht als root herumhampeln...
                root@iobroker
                Farmer-cb
                hab ich verschlafen... jetzt umgestellt
                iob diag sagt:
                iob diag (neues system) sagt folgendes:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Chassis: container ☐
                  Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                 17:33:28 up 31 min,  2 users,  load average: 0.41, 0.53, 0.70
                CPU threads: 4
                               Local time: Thu 2024-04-18 17:33:28 CEST
                           Universal time: Thu 2024-04-18 15:33:28 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                Farmer
                /home/Farmer
                Farmer sudo users
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            4.3G        105M        3.5G        139K        733M        4.2G
                Swap:           4.3G        106K        4.3G
                Total:          8.6G        105M        7.8G
                         4096 M total memory
                          100 M used memory
                          266 M active memory
                          458 M inactive memory
                         3295 M free memory
                            0 M buffer memory
                          699 M swap cache
                         4096 M total swap
                            0 M used swap
                         4095 M free swap
                * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                * iobroker.service        loaded failed failed ioBroker Server
                *** FILESYSTEM ***
                /dev/mapper/pve-vm--101--disk--0 ext4       16G  2.1G   13G  14% /
                tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
                /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                /var:
                479M    /var/
                250M    /var/cache
                246M    /var/cache/apt
                197M    /var/lib
                170M    /var/cache/apt/archives
                Archived and active journals take up 8.0M in the file system.
                22M     /opt/iobroker/backups/
                15M     /opt/iobroker/iobroker-data/files
                13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                USB-Devices by-id:
                /usr/bin/nodejs         v18.20.2
                /usr/bin/node           v18.20.2
                /usr/bin/npm            10.5.0
                /usr/bin/npx            10.5.0
                /usr/bin/corepack       0.25.2
                nodejs:
                  Installed: 18.20.2-1nodesource1
                  Version table:
                 *** 18.20.2-1nodesource1 1001
                     18.19.0+dfsg-6~deb12u1 500
                        500 http://security.debian.org/debian-security stable-security/main amd64 Packages
                     18.13.0+dfsg1-1 500
                        500 http://deb.debian.org/debian stable/main amd64 Packages
                Errors in npm tree:
                ioBroker Status
                iobroker is not running on this host.
                Objects type: jsonl
                States  type: jsonl
                admin:          "admin" not found
                javascript:     "javascript" not found
                Adapters from github:   0
                Adapter State
                  system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + instance is alive
                Active repo(s): stable
                Used repository: stable
                Objects and States
                Objects:        142
                States:         76
                Hit:1 http://security.debian.org/debian-security stable-security InRelease
                Hit:2 http://deb.debian.org/debian stable InRelease
                Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          626469319  300/master
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          626541046  1/init
                tcp6       0      0 :::111                  :::*                    LISTEN      0          626541048  1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          626467646  1/init
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          626469320  300/master
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          626466679  92/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          626541047  1/init
                udp6       0      0 :::111                  :::*                                0          626541049  1/init
                2024-04-18 17:14:10.977  - info: host.iobroker received SIGTERM
                2024-04-18 17:14:10.977  - info: admin.0 (8788) terminating http server on port 8081
                2024-04-18 17:14:10.978  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                2024-04-18 17:14:10.979  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                2024-04-18 17:14:10.979  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                2024-04-18 17:14:10.982  - info: backitup.0 (8815) Got terminate signal TERMINATE_YOURSELF
                2024-04-18 17:14:10.981  - info: admin.0 (8788) Got terminate signal TERMINATE_YOURSELF
                2024-04-18 17:14:10.982  - info: discovery.0 (8830) Got terminate signal TERMINATE_YOURSELF
                2024-04-18 17:14:10.983  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                2024-04-18 17:14:10.983  - info: discovery.0 (8830) terminating
                2024-04-18 17:14:10.983  - info: admin.0 (8788) terminating
                2024-04-18 17:14:10.983  - info: backitup.0 (8815) terminating
                2024-04-18 17:14:10.984  - info: admin.0 (8788) Terminated (NO_ERROR): Without reason
                2024-04-18 17:14:10.983  - info: discovery.0 (8830) Terminated (NO_ERROR): Without reason
                2024-04-18 17:14:10.984  - info: backitup.0 (8815) Terminated (NO_ERROR): Without reason
                2024-04-18 17:14:11.029  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
                2024-04-18 17:14:11.029  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
                2024-04-18 17:14:11.479  - info: discovery.0 (8830) terminating
                2024-04-18 17:14:11.481  - info: backitup.0 (8815) terminating
                2024-04-18 17:14:11.481  - info: admin.0 (8788) terminating
                2024-04-18 17:14:11.528  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                2024-04-18 17:14:11.533  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                2024-04-18 17:14:11.537  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                2024-04-18 17:14:11.537  - info: host.iobroker All instances are stopped.
                2024-04-18 17:14:11.650  - info: host.iobroker terminated
                                        v.2023-10-10
                  Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                User-ID:                1001
                X-Server:               false
                Pending OS-Updates:     0
                Pending iob updates:    0
                Nodejs-Installation:    /usr/bin/nodejs         v18.20.2
                                        /usr/bin/npm            10.5.0
                                        /usr/bin/npx            10.5.0
                MEMORY:
                Mem:            4.3G        107M        3.4G        139K        740M        4.2G
                Total:          8.6G        107M        7.7G
                Active iob-Instances:   1
                                        admin                   "admin" not found
                ioBroker Status:        iobroker is not running on this host.
                Objects type: jsonl
                States  type: jsonl
                Objects:                142
                States:                 76
                4.5M    /opt/iobroker/iobroker-data/objects.jsonl
                28K     /opt/iobroker/iobroker-data/states.jsonl
                • Thomas BraunT Online
                  • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                  • sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                  • iobroker.service loaded failed failed ioBroker Server
                  Eher ungünstig, wenn der Service nicht gestartet ist.
                  sudo systemctl start iobroker.service
                  sagt?
                    sagt?
                    Farmer-cb
                    als normaler user darf ich das nicht, muss ich den user in einer besonderen gruppe eintrage
                    meldung:
                    Farmer@iobroker:/opt/iobroker$ sudo systemctl start iobroker.service
                    [sudo] password for Farmer:
                    Sorry, user Farmer is not allowed to execute '/usr/bin/systemctl start iobroker.service' as root on iobroker
                    • F Farmer-cb
                      meldung:
                      @farmer-cb
                      Das muss der Farmer (am Rande: Besser usernames in Kleinschreibung) aber können:
                      Farmer
                      /home/Farmer
                      Farmer sudo users
                      Hast du den Farmer mal aus- und wieder eingeloggt? Gruppenrechte werden nur beim einloggen neugelesen.
                        @farmer-cb
                        Farmer
                        /home/Farmer
                        Farmer sudo users
                        Farmer-cb
                        habs hinbekommen.
                        sudo systemctl start iobroker.service erzeugt keine Meldung.
                        Aber:
                        Farmer@iobroker:~$ sudo systemctl status iobroker.service
                        * iobroker.service - ioBroker Server
                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                             Active: active (running) since Thu 2024-04-18 18:02:51 CEST; 31s ago
                               Docs: http://iobroker.net
                           Main PID: 1117 (iobroker.js-con)
                              Tasks: 18 (limit: 9301)
                             Memory: 67.8M
                                CPU: 1.134s
                             CGroup: /system.slice/iobroker.service
                                     |-1117 iobroker.js-controller
                                     `-1130 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js _restart
                        Apr 18 18:02:51 iobroker systemd[1]: Started iobroker.service - ioBroker Server.
                        Farmer@iobroker:~$ iobroker status
                        Farmer@iobroker:~$
                        • F Farmer-cb
                          habs hinbekommen.
                          Aber:
                               Memory: 67.8M
                                  CPU: 1.134s
                          Farmer@iobroker:~$
                          @farmer-cb
                          Ist redis installiert?
                          sudo apt update
                          apt policy redis
                            @farmer-cb
                            sudo apt update
                            apt policy redis
                            Farmer-cb
                            installiert sich das nicht automatisch bei einer iobroker neuinstallation
                            Farmer@iobroker:/opt/iobroker$ sudo apt update
                            Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Hit:3 http://deb.debian.org/debian stable InRelease
                            Reading package lists... Done
                            Building dependency tree... Done
                            All packages are up to date.
                            Farmer@iobroker:/opt/iobroker$ apt policy redis
                            redis:
                              Installed: (none)
                              Candidate: 5:7.0.15-1~deb12u1
                              Version table:
                                 5:7.0.15-1~deb12u1 500
                            • F Farmer-cb
                              redis:
                                Installed: (none)
                                Version table:
                              Nein. Wie du siehst nicht. Ist ein Ding vom Betriebssystem und muss vom Administrator manuell hinzugefügt werden. Der ioBroker läuft ja auch in der Voreinstellung nicht mittels redis.
                              Also jetzt
                              sudo apt install redis
                                Also jetzt
                                Farmer-cb
                                was ist eigentlich besser, json/redis.....
                                hab redis installiert und restore läuft gerade
                                • F Farmer-cb
                                  Hängt von deinem Setup ab.
                                  redis braucht viel RAM, ist aber bei einer großen Zahl von States/Objects schneller als jsonl oder file.
                                    Farmer-cb
                                    Guten Morgen
                                    Erst einmal vielen vielen Dank für die Unterstützung, jetzt :man-running: der iobroker wieder wie 🐖
                                    nun zu:
                                    @Thomas-Braun
                                    sollte ich hier Objects auch auf redis umstellen???
