  4. Telegram Adapter Version 3.21 sendet keine Nachrichten mehr
telegram adapter version 3.21
9 Beiträge 4 Kommentatoren 779 Aufrufe 3 Beobachtet
    Tom2323
    Leider schickt mir mein Telegram Adapter seit dem 10.04.24 eine Nachrichten mehr. Im Debug vom Telegram Adapter ist nichts auffälliges, es werden auch sonst keine Fehler im Log angezeigt.
    telegram.0 2024-04-14 07:51:07.534	debug	Message sent
    telegram.0 2024-04-14 07:51:07.533	debug	Request: {"message_id":8202,"from":{"id":5302xxx275,"is_bot":true,"first_name":"NAME","username":"NAME_Bot"},"chat":{"id":5351xxx055,"first_name":"NAME","last_name":"NAME","type":"private"},"date":1713073867,"text":"Started!"}
    telegram.0 2024-04-14 07:51:07.473	debug	Send message to [NAME]: "Started!"
    telegram.0 2024-04-14 07:51:07.467	debug	getMe: {"id":5302xxx275,"is_bot":true,"first_name":"NAME","username":"NAME","can_join_groups":true,"can_read_all_group_messages":false,"supports_inline_queries":false,"can_connect_to_business":false}
    telegram.0 2024-04-14 07:51:07.197	debug	Start polling with: 300(number) ms interval
    telegram.0 2024-04-14 07:51:06.810	debug	Schedule restart: 4 5 * * 0
    telegram.0 2024-04-14 07:51:06.749	info	starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.19.0, js-controller: 5.0.19
    telegram.0 2024-04-14 07:51:06.294	debug	Plugin sentry Initialize Plugin (enabled=true)
    telegram.0 2024-04-14 07:51:06.213	debug	States connected to redis: 127.0.0.1:9000
    telegram.0 2024-04-14 07:51:06.046	debug	States create User PubSub Client
    telegram.0 2024-04-14 07:51:06.045	debug	States create System PubSub Client
    telegram.0 2024-04-14 07:51:05.994	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    telegram.0 2024-04-14 07:51:05.895	debug	Objects connected to redis: 127.0.0.1:9001
    telegram.0 2024-04-14 07:51:05.886	debug	Objects client initialize lua scripts
    telegram.0 2024-04-14 07:51:05.713	debug	Objects create User PubSub Client
    telegram.0 2024-04-14 07:51:05.711	debug	Objects create System PubSub Client
    telegram.0 2024-04-14 07:51:05.658	debug	Objects client ready ... initialize now
    telegram.0 2024-04-14 07:51:05.568	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Nachrichten wie Restarting… und Started! bekomme ich aber bei allem anderen kommt nun nichts mehr an.
    Simple Sachen gehen nicht mehr:
    Momentan läuft bei mir die Telegram Adapter Version 3.21.
    Hat jemand eine Idee wo es klemmen könnte?
    Grüße Tom
    Thomas BraunT O 2 Antworten Letzte Antwort
    • T Tom2323
      Grüße Tom
      @tom2323 sagte in Telegram Adapter Version 3.21 sendet keine Nachrichten mehr:
      node: v18.19.0
      Zunächst die Kiste komplett auf Stand bringen. Gilt für das Betriebssystem, für nodejs und die iob-Adapter.
      • T Tom2323
        Grüße Tom
        O Offline
        O Offline
        oFbEQnpoLKKl6mbY5e13
        schrieb am zuletzt editiert von oFbEQnpoLKKl6mbY5e13
        @tom2323
        In deinem Blockly gibt es aber mehr als eine Fehlerquelle. Ziehe entweder zum Testen den Telegram-Baustein aus dem Trigger raus, oder baue ein Debug-Baustein ein, damit du weißt, dass der Trigger ausgeführt wurde.
        • haselchenH Offline
          haselchenH Offline
          haselchen
          @tom2323
          Wenn du 0,5 sek brauchst , dann stell da ne Zeit in Millisekunden ein .
          Meines Erachtens gibt es deine Schreibweise in dem Baustein nicht .
          Aber im Grunde ist die Angabe auch Quatsch .
          Nimm 1 sek und fertig .
            Tom2323
            Ich habe mehrere Blockly-Skripte mit Telegram, die alle vor kurzem tadellos funktioniert haben.
            Danke für die Infos über die Fehler im Blockly-Skripte, werde mir bei Gelegenheit das ganze mal etwas genauer angucken.
            Aber ich glaube nicht, dass das das eigentliche Problem ist.
            Habe schon einiges am Raspberry aktualisiert unter anderem dieses:
            sudo apt update
            sudo apt dist-upgrade
            sudo apt full-upgrade
            iob backup
            iob stop
            iob update
            iob fix
            iob upgrade self
            iobroker upgrade
            iob start
            Was könnte ich denn noch testen oder aktualisieren?
            • T Tom2323
              sudo apt update
              iob backup
              iob stop
              iob update
              iob fix
              iob upgrade self
              iobroker upgrade
              iob start
              haselchenH Offline
              haselchenH Offline
              haselchen
              @tom2323
              Vielleicht den Hilfestellungen folgen?
              @oFbEQnpoLKKl6mbY5e13 gab Dir schonmal einen und ich auch .
              Wäre hilfreich wenn Du deren Ergebnisse hier posten würdest.
              Du kannst auch noch vor dem Timeout ein stopTimeout Baustein platzieren.
              • haselchenH haselchen
                @tom2323
                Tom2323
                @haselchen said in Telegram Adapter Version 3.21 sendet keine Nachrichten mehr:
                Ich verstehe leider nicht, was du meinst?
                @Du kannst auch noch vor dem Timeout ein stopTimeout Baustein platzieren.
                Wie mache ich das ?
                  Tom2323
                  schrieb am zuletzt editiert von Tom2323
                  Bei Skripte steht “Instanz ist deaktiviert" das steht doch sonst nicht da, oder?
                    Tom2323
                    Okay, ich habe den Fehler gefunden, es war nicht der Telegram Adapter der scheint gut zu funktionieren.
                    Es war der Javascript Adapter, der aus irgendwelchen tollen Gründen nicht automatisch gestartet ist.🤔
                    Danke an alle😉
