  4. NodeRed fkt. nicht nach Node.js Update auf 18.20.2
    1.0k
    6.1k
49 Beiträge 11 Kommentatoren 6.0k Aufrufe 10 Beobachtet
  • surfer09S Offline
    surfer09S Offline
    surfer09
    nach dem Node.js Update auf 18.20.2 startet NodeRed nicht mehr bei mir. Kann jemand helfen?
    Mit 18.20.0 funktionierte noch alles.
    2024-04-11 15:28:36.531 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:36 - [error] Failed to start server:
    2024-04-11 15:28:36.531 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:36 - [error] Error: spawn EINVAL
    at ChildProcess.spawn (node:internal/child_process:414:11)
    at spawn (node:child_process:761:9)
    at Object.execFile (node:child_process:351:17)
    at I:\ioBroker\node_modules\@node-red\registry\lib\installer.js:581:27
    at new Promise ()
    at Object.checkPrereq (I:\ioBroker\node_modules\@node-red\registry\lib\installer.js:580:16)
    at Object.load (I:\ioBroker\node_modules\@node-red\registry\lib\index.js:59:22)
    at I:\ioBroker\node_modules\@node-red\runtime\lib\index.js:162:29
    2024-04-11 15:28:39.553 - info: host.IOBroker-Server "system.adapter.node-red.0" disabled
    2024-04-11 15:28:39.553 - info: host.IOBroker-Server stopInstance system.adapter.node-red.0 (force=false, process=true)
    2024-04-11 15:28:42.216 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:42 - [error] Failed to start server:
    2024-04-11 15:28:42.216 - error: node-red.0 (3356) Node-RED: 11 Apr 15:28:42 - [error] Error: spawn EINVAL
    at new Promise ()
    2024-04-11 15:28:44.556 - info: host.IOBroker-Server stopInstance timeout 5000 system.adapter.node-red.0 killing pid 3356
    2024-04-11 15:28:44.599 - warn: host.IOBroker-Server instance system.adapter.node-red.0 terminated due to SIGTERM
    2024-04-11 15:28:44.599 - info: host.IOBroker-Server instance system.adapter.node-red.0 terminated with code null ()
    • Adaptername: Node Red
    • Adapterversion: 5.2.0
    • js-controller Version: 5.0.19
    • Admin Version: 6.13.16
    • Hardwaresystem: NUC
    • Arbeitsspeicher: 12 GB
    • Festplattenart: SD-Karte, SSD, HDD, ...
    • Betriebssystem: Windows 10
    • Nodejs-Version: v18.20.2
    • NPM-Version: 10.5.0
    Gruß surfer ;-)
    • surfer09S surfer09
      at new Promise ()
      at new Promise ()
      Gruß surfer ;-)
      haus-automatisierungH Offline
      schrieb am zuletzt editiert von haus-automatisierung
      @surfer09 Spannend, weil 18.20.2 genau da eine "Sicherheitslücke" unter Windows geschlossen hat: https://nodejs.org/en/blog/vulnerability/april-2024-security-releases-2/
      Command injection via args parameter of child_process.spawn without shell option enabled on Windows (CVE-2024-27980) - (HIGH)
      Und genau diese Funktionen (process.spawn) werden genutzt um den Node-RED Prozess zu starten. Scheinbar muss man irgendwelche Flags setzen, um Prozesse starten zu dürfen (?). Müsste ich mir in Ruhe anschauen, aber mir fehlt dazu gerade etwas die Zeit.
      Am besten auf GitHub melden.
      Hier ist der Commit in node dazu: https://github.com/nodejs/node/commit/6627222409
      📚 Meine Dokumentation
      surfer09S 1 Antwort Letzte Antwort
        surfer09S Offline
        surfer09S Offline
        surfer09
        @haus-automatisierung So ein Mist, und ich tappe da auch noch in die Falle... :-( Hoffentlich gibt's da schnelle Hilfe zu.
          @surfer09 Ich bin momentan etwas ratlos, was da falsch sein könnte. Wie ich es verstanden habe, dürfen nur keine batch-Dateien direkt gestartet werden (?) Und das passiert hier ja nicht:
          https://github.com/ioBroker/ioBroker.node-red/blob/2da922e99894fa5e37da91d3169becacef95fcb4/main.js#L238-L251C41
          -1
            surfer09S Offline
            surfer09S Offline
            surfer09
            @haus-automatisierung Ich habe auf Github mal ein Issue erstellt. Habe ich zwar noch nicht so oft gemacht, ich hoffe man kann damit etwas anfangen :-).
              @surfer09 Wo denn? Gehört hier hin: https://github.com/ioBroker/ioBroker.node-red/issues
              Aber eventuell ist das auch ein Bug von Node-Red. Laut Stack crasht das hier:
              https://github.com/node-red/node-red/blob/9a3cb0b2b55fc018d7bc450081332b5180a2c7c5/packages/node_modules/%40node-red/registry/lib/installer.js#L581-L594
              Das Problem ist, dass der Befehl hier unter Windows mit .cmd endet:
              https://github.com/node-red/node-red/blob/9a3cb0b2b55fc018d7bc450081332b5180a2c7c5/packages/node_modules/%40node-red/registry/lib/installer.js#L28
              • haus-automatisierungH Offline
                Liegt also nicht an ioBroker, sondern an Node-RED. Habe hier reported:
                https://github.com/node-red/node-red/issues/4653
                  surfer09S Offline
                  surfer09S Offline
                  surfer09
                  Ob wohl heute noch ein Update kommt? Scheinbar wird ja schon dran gearbeitet..
                    @surfer09 Ja. Fixed in Node-RED 3.1.9
                      surfer09S Offline
                      surfer09S Offline
                      surfer09
                      @haus-automatisierung Nochmal eine blöde Frage... Der Adapter für den IOBroker bekommt jetzt auch noch ein Update? Da bin ich auf Version 5.2.0. Wie bekomme ich denn da jetzt die aktuellste Version?
                      ? Thomas BraunT haus-automatisierungH 4 Antworten Letzte Antwort
                        @surfer09 Hallo, besteht das Problem noch? Oder läuft wieder alles?
                          @surfer09 Bei mir kam das Problem auf durch den Wechsel von node 18.20.1 nach 18.20.2. Habe einfach wieder nach 18.19.0 gewechselt - weil da alles noch bestens lief - und gut wars. Wenn eine Umgebung 365x24 laufen muss, ist einfach wichtig, was hilft, nicht wer Schuld war - das kommt, wenn wieder alles läuft :-)
                            @hk30 sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
                            und gut wars
                            nicht unbedingt!
                            18.20.2 enthält einen Sicherheitspatch
                              @hk30 Und damit reißt du dir die mit den Versionen 18.20.x beseitigten Sicherheitslücken wieder auf.
                              Also keine clevere Idee.
                              node-red 3.1.9 ist ja wohl wieder kompatibel mit aktuellem nodejs. Also musst du das UPDATEN und nicht nodejs kaputt machen.
                              Kommt ganz easy auf ein aktuelles System:
                              echad@chet:/opt/iobroker $ npm ls node-red
                              iobroker.inst@3.0.0 /opt/iobroker
                              `-- iobroker.node-red@5.2.0
                                `-- node-red@3.1.9
                              ? 2 Antworten Letzte Antwort
                                  `-- node-red@3.1.9
                                @thomas-braun schon klar. Ein patch hilft (fast) immer. Und was war vor oder bis zum patch? Stillstand tut eben mehr weh. Weiss man vielleicht nicht auf Bastellösungen.
                                    `-- node-red@3.1.9
                                  @thomas-braun ich bin in letzter Zeit seh vorsichtig geworden mit der patcherei. Diesmal hab ich ziemlich sicher gewusst, welcher "patch" es wieder mal war. Jetzt gilt: Solange es läuft - alles gut. Man kennt ja den Spruch: Never touch a running system. Und wenn man seine Umgebung in Richtung Inet nicht zu offen oder sogar geschlossen hat, gibt es wenig Sicherheitslücken.
                                  Samson71S Thomas BraunT 2 Antworten Letzte Antwort
                                    Du meinst deine verbastelte, mit Sicherheitslücken versehene Frickelbude? Dann weißt du ja jetzt wie es besser geht.
                                    Downgrades sind nie eine gute Idee, aktuelle stabile Versionen sind für ein stabiles System zu verwenden.
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      Eine der schlimmsten und dümmsten Aussagen ever und gerade aktuell hier in der letzten Zeit immer wieder aufs Neue sinnlos proklamiert und vorgelebt. Geheult wird dann aber immer und um Hilfe gebettelt, wenn das System zu alt und völlig versumpft ist für weitere Updates.
                                      Markus
                                      Bitte beachten:
                                        Und genau der Spruch ist der Oberschwachsinn schlechthin.
                                        ? 1 Antwort Letzte Antwort
                                          @thomas-braun also hilfe gibts hier scheinbar nicht, nur dumme sprüche - ich wollte surfer09 helfen - mit meiner Lösung. Von den schlauen Leuten hier gab es keine Hilfe - ausser starken Sprüchen - kann man sich also schenken. Viel Spass ihr sicheren Bastler :-)
