  3. Einsteigerfragen
  4. FritzDect 210 kann kein Passwort eingeben
36 Beiträge 9 Kommentatoren 1.4k Aufrufe 8 Beobachtet
  • M MP48
    @djmarc75
    Hallo DJMarc75,
    hier iob diag Teil 1
    und Teil 2
    @mp48
    iob stop
    iob fix
    iob start
    warten...
    iob diag
    • DJMarc75D DJMarc75
      @mp48 bitte keine Bildchen von Text.
      Text immer kopieren und hier in Codetags einstellen
      Wie das geht siehe hier:
      edit:
      iob stop
      iob fix
      iob start
      iob diag
      nacheinander eingeben
      MP48
      @djmarc75
                              v.2023-10-10
         Static hostname: PiSmart
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.15.32-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               armhf
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     178
      Pending iob updates:    11
      /home/iobroker/.diag.sh: line 486: nodejs: command not found
      Nodejs-Installation:
                              /usr/bin/node           v12.22.12
                              /usr/bin/npm            6.14.16
                              /usr/bin/npx            6.14.16
      /home/iobroker/.diag.sh: line 490: corepack: command not found
      Recommended versions are nodejs  and npm
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      for more information on how to fix these errors.
      MEMORY:
      Mem:            3.8G        431M        2.9G        0.0K        546M        3.4G
      Swap:            99M          0B         99M
      Total:          3.9G        431M        3.0G
      Active iob-Instances:   9
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.23
                              admin                   5.3.8
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : PiSmart                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : PiSmart                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                298
      States:                 241
      Size of iob-Database:
      8.6M    /opt/iobroker/iobroker-data/objects.jsonl
      124K    /opt/iobroker/iobroker-data/states.jsonl
      So richtig?
      • M MP48
        @djmarc75
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Kernel:                 armv7l
        Userland:               armhf
        User-ID:                1000
        X-Server:               false
        Please check
        MEMORY:
        Swap:            99M          0B         99M
                                admin                   5.3.8
        Objects type: jsonl
        States  type: jsonl
        Objects:                298
        States:                 241
        So richtig?
        Samson71S Offline
        Samson71S Offline
        Samson71
        @mp48 sagte in FritzDect 210 kann kein Passwort eingeben:
        So richtig?
        Ich habe das mal etwas "hübsch" gemacht. Der Versuch war ja da ;)
        Ist aber nur der Summary. Nicht die Komplettausgabe. Klar ist aber jetzt schon, dass Nodejs falsch/veraltet ist.
        Markus
        Bitte beachten:
        • Samson71S Samson71
          So richtig?
          CodierknechtC Offline
          Codierknecht
          @samson71
          Da ist nicht nur Node veraltet
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            @mp48
            iob stop
            iob fix
            iob start
            warten...
            iob diag
            MP48
            2. Versuch mit dem vollen Ausdruck
            =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.03.12 12:27:53 =~=~=~=~=~=~=~=~=~=~=~=
            login as: pi
            pi@192.168.2.145's password:
            Linux PiSmart 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Tue Mar 12 11:37:17 2024 from 192.168.2.100
            pi@PiSmart:~ $
            pi@PiSmart:~ $ iob diag
            *** iob diag is starting up, please wait ***
            The state system.host.PiSmart.versions.nodeNewestNext was not found!
            The state system.host.PiSmart.versions.npmNewestNext was not found!
            The state system.host.PiSmart.versions.nodeCurrent was not found!
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            Press any key to continue
            ======== Start marking the full check here =========
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Model: Raspberry Pi 4 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : armhf
            Systemuptime and Load:
             12:31:53 up 7 days, 23:29,  2 users,  load average: 0.07, 0.15, 0.28
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            *** Time and Time Zones ***
                           Local time: Tue 2024-03-12 12:31:53 CET
                       Universal time: Tue 2024-03-12 11:31:53 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server: false
            Desktop:
            Terminal: tty
            *** MEMORY ***
            Mem:            3.8G        437M        2.9G        0.0K        547M        3.4G
            Swap:            99M          0B         99M
            Total:          3.9G        437M        3.0G
                     3838 M total memory
                      437 M used memory
                      245 M active memory
                      630 M inactive memory
                     2853 M free memory
                       69 M buffer memory
                      478 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            lifetime oom required: 0 Mbytes
            total time in oom handler: 0 ms
            max time spent in oom handler: 0 ms
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G  2.6G   25G  10% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     768M  844K  767M   1% /run
            /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
            [Mon Mar  4 13:02:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:42:25:50 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=a2da186f-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Mon Mar  4 13:02:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Mon Mar  4 13:02:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mon Mar  4 13:02:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
            Show mounted filesystems \(real ones only\):
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            785M/var/
            462M/var/log
            457M/var/log/journal/cc83b83448f54cf2803da45a72b7bc88
            130M/var/cache
            Archived and active journals take up 456.0M in the file system.
            /opt/iobroker/backups:
            30M/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            71M/opt/iobroker/iobroker-data/
            34M/opt/iobroker/iobroker-data/backup-objects
            28M/opt/iobroker/iobroker-data/files
            12M/opt/iobroker/iobroker-data/files/jarvis
            7.9M/opt/iobroker/iobroker-data/files/web
            8.6M/opt/iobroker/iobroker-data/objects.jsonl
            4.5M/opt/iobroker/iobroker-data/files/web.admin/static/js/2.b1d56998.chunk.js.map
            4.3M/opt/iobroker/iobroker-data/files/jarvis/js/vendor.6018d81d.js
            1.4M/opt/iobroker/iobroker-data/files/jarvis/js/app.d3faf308.js
            1.4M/opt/iobroker/iobroker-data/backup-objects/2024-03-12_11-03_objects.jsonl.gz
            USB-Devices by-id:
            USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /home/iobroker/.diag.sh: line 277: nodejs: command not found
            /home/iobroker/.diag.sh: line 281: corepack: command not found
            /home/iobroker/.diag.sh: line 288: nodejs: command not found
            nodejs:
              Installed: 12.22.12-deb-1nodesource1
              Candidate: 12.22.12-deb-1nodesource1
              Version table:
             *** 12.22.12-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller: 4.0.23
            admin: 5.3.8
            javascript: "javascript" not found
            Adapters from github: 0
            Adapter State
            + system.adapter.backitup.0               : backitup              : PiSmart                                  -  enabled
            + system.adapter.discovery.0              : discovery             : PiSmart                                  -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : PiSmart                                  -  enabled
            + system.adapter.history.0                : history               : PiSmart                                  -  enabled
            + system.adapter.jarvis.0                 : jarvis                : PiSmart                                  -  enabled
            + system.adapter.smartmeter.1             : smartmeter            : PiSmart                                  -  enabled
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.13.16  , installed 5.3.8  [Updatable]
            Adapter    "backitup"     : 2.10.11  , installed 2.4.9  [Updatable]
            Adapter    "discovery"    : 4.2.0    , installed 3.0.3  [Updatable]
            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
            Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
            Adapter    "jarvis"       : 3.1.8    , installed 3.0.11 [Updatable]
            Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
            Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
            Adapter    "smartmeter"   : 3.4.0    , installed 3.3.4  [Updatable]
            Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
            Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
            Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
            Objects and States
            Objects: 298
            States: 241
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Get:3 https://deb.nodesource.com/node_12.x bullseye InRelease [4586 B]
            Fetched 4586 B in 1s (5089 B/s)
            Reading package lists...
            Pending Updates: 178
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       411441     15809/io.jarvis.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13557      540/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       409535     15703/iobroker.js-c
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       409542     15703/iobroker.js-c
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13559      540/sshd: /usr/sbin
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       411400     15788/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       410212     15722/io.admin.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12435      395/avahi-daemon: r
            udp        0      0 0.0.0.0:41777           0.0.0.0:*                           108        12437      395/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14490      774/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        12436      395/avahi-daemon: r
            udp6       0      0 :::39352                :::*                                108        12438      395/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          393822     774/dhcpcd
            2024-03-12 11:54:07.736  - info: jarvis.0 (15809) starting. Version 3.0.11 in /opt/iobroker/node_modules/iobroker.jarvis, node: v12.22.12, js-controller: 4.0.23
            2024-03-12 11:54:07.775  - info: jarvis.0 (15809) No Backup found for styles, thus backing up initially.
            2024-03-12 11:54:07.817  - info: jarvis.0 (15809) Found Backups for devices.
            2024-03-12 11:54:07.818  - info: jarvis.0 (15809) Found Backups for layout.
            2024-03-12 11:54:07.820  - info: jarvis.0 (15809) Found Backups for widgets.
            2024-03-12 11:54:07.821  - info: jarvis.0 (15809) Found Backups for settings.
            2024-03-12 11:54:07.848  - info: jarvis.0 (15809) Connection: WebSocket opened on port 8400 using http...
            2024-03-12 11:54:08.567  - error: fritzdect.0 (15816) --------------- error calling the fritzbox -----------
            2024-03-12 11:54:08.568  - error: fritzdect.0 (15816) API msg   => error calling executeCommand
            2024-03-12 11:54:08.569  - error: fritzdect.0 (15816) API funct => login_SID
            2024-03-12 11:54:08.569  - error: fritzdect.0 (15816) no response part in returned error message
            2024-03-12 11:54:08.570  - error: fritzdect.0 (15816) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
            2024-03-12 11:54:08.570  - error: fritzdect.0 (15816) login not possible, check user and permissions
            2024-03-12 11:56:52.717  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 11:59:53.709  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:02:54.732  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:05:55.750  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:08:56.727  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:11:57.753  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:14:58.727  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:17:59.728  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:21:00.719  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:24:01.737  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:27:02.754  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            2024-03-12 12:30:03.713  - info: smartmeter.1 (15751) Received 5 values, 2 updated
            iob diag has finished.
            Press any key for a summary
            Copy text starting here:
            v.2023-10-10
                     Icon name: computer
                  Architecture: arm
            Kernel: armv7l
            Userland: armhf
            User-ID: 1000
            X-Server: false
            Please check
            MEMORY:
            Mem:            3.8G        462M        2.8G        0.0K        547M        3.3G
            Swap:            99M          0B         99M
            Total:          3.9G        462M        2.9G
            admin 5.3.8
            ioBroker Status: iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            Objects: 298
            States: 241
            696K/opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            pi@PiSmart:~ $
            So besser?
            • M MP48
              login as: pi
              pi@PiSmart:~ $
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : armhf
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server: false
              Desktop:
              Terminal: tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3838 M total memory
                        437 M used memory
                        245 M active memory
                       2853 M free memory
                         69 M buffer memory
                        478 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              785M/var/
              462M/var/log
              130M/var/cache
              USB-Devices by-id:
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 5.3.8
              Adapter State
              + instance is alive
              Objects and States
              Objects: 298
              States: 241
              v.2023-10-10
                       Icon name: computer
                    Architecture: arm
              Kernel: armv7l
              Userland: armhf
              User-ID: 1000
              X-Server: false
              Please check
              MEMORY:
              Swap:            99M          0B         99M
              admin 5.3.8
              Objects type: jsonl
              States  type: jsonl
              Objects: 298
              States: 241
              pi@PiSmart:~ $
              So besser?
              Codierknecht
              So besser?
              Dass das nicht vernünftig formatiert ist, siehst Du ja selbst.
              Die Kiste ist steinalt.
              sudo apt update
              iob stop
              sudo apt full-upgrade
              iob update
              iob upgrade all
              iob upgrade self
              sudo reboot
              • CodierknechtC Codierknecht
                So besser?
                sudo apt update
                iob stop
                iob update
                iob upgrade all
                iob upgrade self
                sudo reboot
                @codierknecht sagte in FritzDect 210 kann kein Passwort eingeben:
                iob upgrade all
                wird mit node 12 wohl nicht klappen.
                Zumindest nicht vollständig aktuell.
                ob man da noch mit dem nodejs-update schrittweise versuchen soll bin ich mir nicht sicher.
                Das OS ist ja auch noch 32bittig
                  iob upgrade all
                  Codierknecht
                  Da hast Du auch wieder Recht.
                  Neuaufbau mit aktuellem 64Bit-OS dürfte wohl am sichersten sein.
                  @MP48
                  Hast Du ein aktuelles Backup?
                  Dann solltest Du mal einen Neuaufbau in Betracht ziehen.
                  Wie @Homoran schon schreibt, ist die Kiste dermaßen veraltet, dass das mit Updates alleine schwierig werden könnte. Da ist neumachen letztendlich stressfreier.
                  M 2 Antworten Letzte Antwort
                    @MP48
                    MP48
                    @codierknecht
                    ich fahre jetzt mal ein update. Das wollte ich eigentlich vermeiden, denn "never change a running system". Aber fuer alle Notfaelle habe ich ein Backup. Ich melde mich wieder wenn ich fertig bin.
                    HomoranH DJMarc75D R 3 Antworten Letzte Antwort
                    • M MP48
                      @codierknecht
                      da siehst du ja jetzt, dass dieser Spruch absoluter Blödsinn ist.
                      kann nämlich bei so großen Versionssprüngen gewaltig in die Hose gehen.
                      • M MP48
                        @codierknecht
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        Völlig falsch !
                        Wie man sieht läuft ja Dein System nicht ordentlich ;)
                        Ein System will gepflegt werden, sonst fällt Dir das auf die Füße.
                        Lehrling seit 1975 !!!
                        • M MP48
                          @codierknecht
                          reutli
                          boah, ich fahr gleich aus der Hose!!! 👿
                          Ein Spruch aus den 80er Jahren einfach auf alles angewendet. Ich weiss gar nicht wie man es geschafft hat, den Schwachsinn in die Köpfe der Leute zu bekommen....
                          ... und wie bekommt man das aus demn Köpfen dann wieder raus?
                          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                          *Wer freundlich ist, dem wird freundlich geholfen *
                            @MP48
                            MP48
                            @codierknecht
                            Hallo an alle Helfer,
                            erst einmal meinen herzlichen Dank an alle Helfer, die ihre Freizeit opfern um einem Unwissenden zu helfen.
                            Nun zurueck zu meinem Thema. Ich habe gestern in mehreren Durchgaengen mein komplettes System auf den aktuellen Stand gebracht (das hat ein paar Stunden gedauert, aber Rentner haben ja bekanntlich viel Zeit). Danach habe ich den FritzDect Adapter installiert und siehe da, ich konnte jetzt auch das Password eingeben und ...schwupps schon waren alle Werte von der FritzDect Steckdose da. Heute werde ich dann noch versuchen die Werte in jarvis zu visualisieren.
                            Damit kann dieser Case geschlossen werden. Vielen Dank noch einmal an alle Helfer!
                            R Thomas BraunT 2 Antworten Letzte Antwort
                            • M MP48
                              @codierknecht
                              reutli
                              @mp48
                              klasse, dann hat sich das gelohnt.
                              Dann bitte nicht mehr "never change a running system" sondern "keep the system save & running by regular updates" 😊
                              • M MP48
                                @codierknecht
                                Und die 'Summary' von
                                iob diag
                                schaut nun wie aus?
                                  iob diag
                                  schaut nun wie aus?
                                  MP48
                                  sehr gut wuerde ich sagen.
                                  v.2023-10-10
                                           Icon name: computer
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  Kernel: aarch64
                                  Userland: armhf
                                  User-ID: 1000
                                  X-Server: false
                                  Pending OS-Updates: 0
                                  Pending iob updates: 0
                                  Nodejs-Installation: /usr/bin/nodejs v18.19.1
                                  /usr/bin/node v18.19.1
                                  /usr/bin/npm 10.2.4
                                  /usr/bin/npx 10.2.4
                                  /usr/bin/corepack 0.22.0
                                  Recommended versions are nodejs 18.19.1 and npm 10.2.4
                                  MEMORY:
                                  Mem:            3.8G        466M        2.9G        0.0K        406M        3.3G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        466M        3.0G
                                  ioBroker Core: js-controller 5.0.19
                                  admin 6.13.16
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects: 370
                                  States: 300
                                  9.1M/opt/iobroker/iobroker-data/objects.jsonl
                                  8.2M/opt/iobroker/iobroker-data/states.jsonl
                                  code_text
