  3. Einsteigerfragen
  4. FritzDect 210 kann kein Passwort eingeben
    5.5k
36 Beiträge 9 Kommentatoren 1.4k Aufrufe 8 Beobachtet
    @mp48
    iob stop
    iob fix
    iob start
    warten...
    iob diag
    MP48
    2. Versuch mit dem vollen Ausdruck
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.03.12 12:27:53 =~=~=~=~=~=~=~=~=~=~=~=
    login as: pi
    pi@192.168.2.145's password:
    Linux PiSmart 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
    permitted by applicable law.
    Last login: Tue Mar 12 11:37:17 2024 from 192.168.2.100
    pi@PiSmart:~ $
    pi@PiSmart:~ $ iob diag
    *** iob diag is starting up, please wait ***
    The state system.host.PiSmart.versions.nodeNewestNext was not found!
    The state system.host.PiSmart.versions.npmNewestNext was not found!
    The state system.host.PiSmart.versions.nodeCurrent was not found!
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: PiSmart
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.32-v7l+
          Architecture: arm
    Model: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     12:31:53 up 7 days, 23:29,  2 users,  load average: 0.07, 0.15, 0.28
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Tue 2024-03-12 12:31:53 CET
               Universal time: Tue 2024-03-12 11:31:53 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    Boot Target: multi-user.target
    *** MEMORY ***
    Mem:            3.8G        437M        2.9G        0.0K        547M        3.4G
    Swap:            99M          0B         99M
    Total:          3.9G        437M        3.0G
             3838 M total memory
              437 M used memory
              245 M active memory
              630 M inactive memory
             2853 M free memory
               69 M buffer memory
              478 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  2.6G   25G  10% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     768M  844K  767M   1% /run
    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Mon Mar  4 13:02:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:42:25:50 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=a2da186f-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Mar  4 13:02:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Mon Mar  4 13:02:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Mar  4 13:02:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    785M/var/
    462M/var/log
    457M/var/log/journal/cc83b83448f54cf2803da45a72b7bc88
    130M/var/cache
    Archived and active journals take up 456.0M in the file system.
    /opt/iobroker/backups:
    30M/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    71M/opt/iobroker/iobroker-data/
    34M/opt/iobroker/iobroker-data/backup-objects
    28M/opt/iobroker/iobroker-data/files
    12M/opt/iobroker/iobroker-data/files/jarvis
    7.9M/opt/iobroker/iobroker-data/files/web
    8.6M/opt/iobroker/iobroker-data/objects.jsonl
    4.5M/opt/iobroker/iobroker-data/files/web.admin/static/js/2.b1d56998.chunk.js.map
    4.3M/opt/iobroker/iobroker-data/files/jarvis/js/vendor.6018d81d.js
    1.4M/opt/iobroker/iobroker-data/files/jarvis/js/app.d3faf308.js
    1.4M/opt/iobroker/iobroker-data/backup-objects/2024-03-12_11-03_objects.jsonl.gz
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node v12.22.12
    /usr/bin/npm 6.14.16
    /usr/bin/npx 6.14.16
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.12-deb-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
     *** 12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 4.0.23
    admin: 5.3.8
    javascript: "javascript" not found
    Adapters from github: 0
    Adapter State
    + system.adapter.admin.0                  : admin                 : PiSmart                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : PiSmart                                  -  enabled
    + system.adapter.discovery.0              : discovery             : PiSmart                                  -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : PiSmart                                  -  enabled
    + system.adapter.history.0                : history               : PiSmart                                  -  enabled
    + system.adapter.jarvis.0                 : jarvis                : PiSmart                                  -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : PiSmart                                  -  enabled
    + system.adapter.web.0                    : web                   : PiSmart                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 5.3.8  [Updatable]
    Adapter    "backitup"     : 2.10.11  , installed 2.4.9  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.0.3  [Updatable]
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.0.11 [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
    Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
    Adapter    "smartmeter"   : 3.4.0    , installed 3.3.4  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
    Objects and States
    Objects: 298
    States: 241
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:3 https://deb.nodesource.com/node_12.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (5089 B/s)
    Reading package lists...
    Pending Updates: 178
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       411441     15809/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13557      540/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       409535     15703/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       409542     15703/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13559      540/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       411400     15788/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       410212     15722/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12435      395/avahi-daemon: r
    udp        0      0 0.0.0.0:41777           0.0.0.0:*                           108        12437      395/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14490      774/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12436      395/avahi-daemon: r
    udp6       0      0 :::39352                :::*                                108        12438      395/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          393822     774/dhcpcd
    2024-03-12 11:54:07.736  - info: jarvis.0 (15809) starting. Version 3.0.11 in /opt/iobroker/node_modules/iobroker.jarvis, node: v12.22.12, js-controller: 4.0.23
    2024-03-12 11:54:07.775  - info: jarvis.0 (15809) No Backup found for styles, thus backing up initially.
    2024-03-12 11:54:07.817  - info: jarvis.0 (15809) Found Backups for devices.
    2024-03-12 11:54:07.818  - info: jarvis.0 (15809) Found Backups for layout.
    2024-03-12 11:54:07.820  - info: jarvis.0 (15809) Found Backups for widgets.
    2024-03-12 11:54:07.821  - info: jarvis.0 (15809) Found Backups for settings.
    2024-03-12 11:54:07.848  - info: jarvis.0 (15809) Connection: WebSocket opened on port 8400 using http...
    2024-03-12 11:54:08.567  - error: fritzdect.0 (15816) --------------- error calling the fritzbox -----------
    2024-03-12 11:54:08.568  - error: fritzdect.0 (15816) API msg   => error calling executeCommand
    2024-03-12 11:54:08.569  - error: fritzdect.0 (15816) API funct => login_SID
    2024-03-12 11:54:08.569  - error: fritzdect.0 (15816) no response part in returned error message
    2024-03-12 11:54:08.570  - error: fritzdect.0 (15816) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
    2024-03-12 11:54:08.570  - error: fritzdect.0 (15816) login not possible, check user and permissions
    2024-03-12 11:56:52.717  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 11:59:53.709  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:02:54.732  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:05:55.750  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:08:56.727  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:11:57.753  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:14:58.727  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:17:59.728  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:21:00.719  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:24:01.737  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:27:02.754  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    2024-03-12 12:30:03.713  - info: smartmeter.1 (15751) Received 5 values, 2 updated
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    v.2023-10-10
             Icon name: computer
          Architecture: arm
    Installation: native
    Kernel: armv7l
    Userland: armhf
    Timezone: Europe/Berlin (CET, +0100)
    User-ID: 1000
    X-Server: false
    Pending OS-Updates: 178
    Pending iob updates: 11
    /home/iobroker/.diag.sh: line 486: nodejs: command not found
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Nodejs-Installation:
    Recommended versions are nodejs  and npm
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        462M        2.8G        0.0K        547M        3.3G
    Swap:            99M          0B         99M
    Total:          3.9G        462M        2.9G
    Active iob-Instances: 9
    ioBroker Core: js-controller 4.0.23
    admin 5.3.8
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 298
    States: 241
    Size of iob-Database:
    696K/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    pi@PiSmart:~ $
    So besser?
    • M MP48
      login as: pi
      pi@PiSmart:~ $
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: false
      Desktop:
      Terminal: tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3838 M total memory
                437 M used memory
                245 M active memory
               2853 M free memory
                 69 M buffer memory
                478 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      785M/var/
      462M/var/log
      130M/var/cache
      USB-Devices by-id:
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 5.3.8
      Adapter State
      + instance is alive
      Objects and States
      Objects: 298
      States: 241
      v.2023-10-10
               Icon name: computer
            Architecture: arm
      Kernel: armv7l
      Userland: armhf
      User-ID: 1000
      X-Server: false
      Please check
      MEMORY:
      Swap:            99M          0B         99M
      admin 5.3.8
      Objects type: jsonl
      States  type: jsonl
      Objects: 298
      States: 241
      pi@PiSmart:~ $
      So besser?
      CodierknechtC Offline
      Codierknecht
      @mp48 sagte in FritzDect 210 kann kein Passwort eingeben:
      So besser?
      Dass das nicht vernünftig formatiert ist, siehst Du ja selbst.
      Die Kiste ist steinalt.
      sudo apt update
      iob stop
      sudo apt full-upgrade
      iob update
      iob upgrade all
      iob upgrade self
      sudo reboot
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        So besser?
        sudo apt update
        iob stop
        iob update
        iob upgrade all
        iob upgrade self
        sudo reboot
        @codierknecht sagte in FritzDect 210 kann kein Passwort eingeben:
        iob upgrade all
        wird mit node 12 wohl nicht klappen.
        Zumindest nicht vollständig aktuell.
        ob man da noch mit dem nodejs-update schrittweise versuchen soll bin ich mir nicht sicher.
        Das OS ist ja auch noch 32bittig
          iob upgrade all
          Codierknecht
          Da hast Du auch wieder Recht.
          Neuaufbau mit aktuellem 64Bit-OS dürfte wohl am sichersten sein.
          @MP48
          Hast Du ein aktuelles Backup?
          Dann solltest Du mal einen Neuaufbau in Betracht ziehen.
          Wie @Homoran schon schreibt, ist die Kiste dermaßen veraltet, dass das mit Updates alleine schwierig werden könnte. Da ist neumachen letztendlich stressfreier.
          M 2 Antworten Letzte Antwort
            @MP48
            MP48
            @codierknecht
            ich fahre jetzt mal ein update. Das wollte ich eigentlich vermeiden, denn "never change a running system". Aber fuer alle Notfaelle habe ich ein Backup. Ich melde mich wieder wenn ich fertig bin.
            HomoranH DJMarc75D R 3 Antworten Letzte Antwort
            • M MP48
              @codierknecht
              da siehst du ja jetzt, dass dieser Spruch absoluter Blödsinn ist.
              kann nämlich bei so großen Versionssprüngen gewaltig in die Hose gehen.
              • M MP48
                @codierknecht
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                Völlig falsch !
                Wie man sieht läuft ja Dein System nicht ordentlich ;)
                Ein System will gepflegt werden, sonst fällt Dir das auf die Füße.
                Lehrling seit 1975 !!!
                • M MP48
                  @codierknecht
                  reutli
                  boah, ich fahr gleich aus der Hose!!! 👿
                  Ein Spruch aus den 80er Jahren einfach auf alles angewendet. Ich weiss gar nicht wie man es geschafft hat, den Schwachsinn in die Köpfe der Leute zu bekommen....
                  ... und wie bekommt man das aus demn Köpfen dann wieder raus?
                  iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                  *Wer freundlich ist, dem wird freundlich geholfen *
                    @MP48
                    MP48
                    @codierknecht
                    Hallo an alle Helfer,
                    erst einmal meinen herzlichen Dank an alle Helfer, die ihre Freizeit opfern um einem Unwissenden zu helfen.
                    Nun zurueck zu meinem Thema. Ich habe gestern in mehreren Durchgaengen mein komplettes System auf den aktuellen Stand gebracht (das hat ein paar Stunden gedauert, aber Rentner haben ja bekanntlich viel Zeit). Danach habe ich den FritzDect Adapter installiert und siehe da, ich konnte jetzt auch das Password eingeben und ...schwupps schon waren alle Werte von der FritzDect Steckdose da. Heute werde ich dann noch versuchen die Werte in jarvis zu visualisieren.
                    Damit kann dieser Case geschlossen werden. Vielen Dank noch einmal an alle Helfer!
                    R Thomas BraunT 2 Antworten Letzte Antwort
                    • M MP48
                      @codierknecht
                      reutli
                      @mp48
                      klasse, dann hat sich das gelohnt.
                      Dann bitte nicht mehr "never change a running system" sondern "keep the system save & running by regular updates" 😊
                      • M MP48
                        @codierknecht
                        Und die 'Summary' von
                        iob diag
                        schaut nun wie aus?
                          iob diag
                          schaut nun wie aus?
                          MP48
                          sehr gut wuerde ich sagen.
                          v.2023-10-10
                                   Icon name: computer
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                          Kernel: aarch64
                          Userland: armhf
                          User-ID: 1000
                          X-Server: false
                          Pending OS-Updates: 0
                          Pending iob updates: 0
                          Nodejs-Installation: /usr/bin/nodejs v18.19.1
                          /usr/bin/node v18.19.1
                          /usr/bin/npm 10.2.4
                          /usr/bin/npx 10.2.4
                          /usr/bin/corepack 0.22.0
                          Recommended versions are nodejs 18.19.1 and npm 10.2.4
                          MEMORY:
                          Mem:            3.8G        466M        2.9G        0.0K        406M        3.3G
                          Swap:            99M          0B         99M
                          Total:          3.9G        466M        3.0G
                          ioBroker Core: js-controller 5.0.19
                          admin 6.13.16
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 370
                          States: 300
                          9.1M/opt/iobroker/iobroker-data/objects.jsonl
                          8.2M/opt/iobroker/iobroker-data/states.jsonl
                          code_text
