  4. Admin Adapter - error: Cannot find module './lib/mediaType'
1 Beiträge 1 Kommentatoren 1.1k Aufrufe
  • kmxakK Offline
    kmxakK Offline
    kmxak
    Moin,
    habe gestern auf alle neuen Versionen geupdatet.
    Danach noch bisschen mit VIS gespielt und dann gerade eben wollte ich einmal drauf schauen und nun erhalte ich bei aufruf der URL:
    <code>[code]Error: Cannot find module './lib/mediaType'
        at Function.Module._resolveFilename (module.js:469:15)
        at Function.Module._load (module.js:417:25)
        at Module.require (module.js:497:17)
        at require (internal/module.js:20:19)
        at loadModule (/opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator/index.js:114:16)
        at Negotiator.mediaTypes (/opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator/index.js:76:52)
        at Accepts.type.Accepts.types (/opt/iobroker/node_modules/iobroker.admin/node_modules/accepts/index.js:100:33)
        at IncomingMessage.req.accepts (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/request.js:134:23)
        at ServerResponse.res.format (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/response.js:627:11)
        at ServerResponse.redirect (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/response.js:888:8)
        at /opt/iobroker/node_modules/iobroker.admin/lib/web.js:163:25
        at Layer.handle [as handle_request] (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/router/layer.js:95:5)
        at trim_prefix (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/router/index.js:317:13)
        at /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/router/index.js:284:7
        at Function.process_params (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/router/index.js:335:12)
        at next (/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/router/index.js:275:10)[/code]</code>
    Zu laufen scheint noch alles Telegram kommt an JS wird auch noch ausgeführt. Scheint nur der Admin betroffen zu sein.
    Habe nun nur den admin adapter restartet (jetzt komme ich wieder drauf) und mal in den logs nachgesehen:
    admin.0	2017-08-15 23:51:50.434	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v6.11.1
    admin.0	2017-08-15 23:51:47.016	info	terminating
    admin.0	2017-08-15 23:51:46.996	info	terminating https server on port 8081
    admin.0	2017-08-15 23:31:08.848	info	Repository received successfully.
    admin.0	2017-08-15 23:31:08.172	info	Request actual repository...
    nix auffälliges.
    Werde morgen nochmal nachsehen ob es dann wieder auftritt.
    Hat noch einer eine Idee was das war?
    Gruß Alex
