  4. Iob Diag Mulitihost und VIS Edit Probleme
17 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
    toki1973
    Habe Probleme, das der VIS Edito ständig keine Verbindung bekommt und ich keine Änderungen vornehmen kann. Hat das was mit dem Problem beim Multihost bei iob diag damit zu tun?
    toki@iobroker:~$ ======================= SUMMARY =======================
                            v.2023-10-10
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-16-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            /usr/bin/corepack       0.22.0
    Recommended versions are nodejs 18.19.0 and npm  Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.iobroker"]
    No connection to databases possible ...
    MEMORY:
    Mem:            6.3G        4.7G        958M        532K        923M        1.6G
    Swap:           1.0G        471M        550M
    Total:          7.4G        5.2G        1.5G
    Active iob-Instances:   36
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.0
    Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ioBroker Status:         Connection is closed.
     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
     Unable to subscribe to meta namespace "meta." changes: Connection is closed.
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    =================== END OF SUMMARY ====================/process/task_queues:95:5):12:23)
    NUC, PROXMOX, Grafana, Influx, Unify
    • T toki1973
                              v.2023-10-10
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      MEMORY:
                              admin                   6.12.0
              throw e;
      @toki1973 sagte in Iob Diag Mulitihost und VIS Edit Probleme:
      Das dürfte schon dein Problem sein.
        toki1973
        @thomas-braun Das bedeutet? Und was schafft Abhilfe? Ich habe noch kein Redis installiert.
        • T toki1973
          @toki1973
          Was ist denn das da genau für ein Konstrukt?
          Multihost? Ist das der Server oder der Client?
          Welche Datenbank wurde/wird da verwendet?
            @toki1973
            toki1973
            Kein Multihost - das "dachte" das System schonmal. Datenbank ist eigentlich nur Influx im Einsatz . Aber das hat ja hier nichts zu bedeuten
            • T toki1973
              @toki1973 zeig mal den Objektbaum von system.host im Expertenmodus
              • T toki1973
                Nein, es ist die Datenbank für states und objects gemeint.
                Zeig mal die Langfassung von iob diag.
                  toki1973
                  Sind da noch Altlasten von alten VMs drin?
                  Inzwischen nennt sich das system iobroker welches aktiv ist
                  • T toki1973
                    sieht so aus.
                    für den Screenshot bitte Fenster auf lesbare Größe verkleinern.
                    nicht jeder hat ein 8K-Handy
                    die wichtigere Frage ist, wo sind die alten hosts noch registriert?
                    Nach Restore kein iob host this gemacht?
                    Beim Restore seltsame Meldungen gehabt?
                      toki1973
                      schrieb am zuletzt editiert von toki1973
                      Skript v.2023-10-10
                        sieht so aus.
                        toki1973
                        @homoran said in Iob Diag Mulitihost und VIS Edit Probleme:
                        Nein das habe ich nicht gemacht - jetzt noch tun? Objektbäume löschen?
                        • T toki1973
                          nur, wenn du
                          @homoran sagte in Iob Diag Mulitihost und VIS Edit Probleme:
                          negativ bescheiden kannst
                            nur, wenn du
                            toki1973
                            Das sind nicht mehr aktive VMs. Buster wurde durch Bookworm durch eine Neuinstallation ersetzt
                            • T toki1973
                              hab ich verstanden.
                              Aber wissen das auch alle Adapter, Objekte usw.?
                                hab ich verstanden.
                                toki1973
                                @homoran Wie kann ich das prüfen?
                                • T toki1973
                                  @toki1973 keine Ahnung!
                                  löschen, und wenn's dann nicht läuft hättest du es nicht löschen dürfen 😂
                                    toki1973
                                    @homoran 🙄 😄
