  4. Performance verbessern
30 Beiträge 7 Kommentatoren 4.8k Aufrufe 5 Beobachtet
    @sunny9999 sagte in Performance verbessern:
    Ram Auslastung und CPU Auslastung auf dem ESXI sieht eigentlich alles gut aus, da ist nichts am Limit...
    und bei top?
    sunny9999
    Full Diag sieht so aus :
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: IOBROKER-MASTER
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: vmware
              Kernel: Linux 6.1.0-17-amd64
        Architecture: x86-64
     Hardware Vendor: VMware, Inc.
      Hardware Model: VMware Virtual Platform
    Firmware Version: 6.00
    model name      : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz
    Docker          : false
    Virtualization  : vmware
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:54:06 up 25 days, 10:19,  1 user,  load average: 0.28, 0.29, 0.34
    CPU threads: 16
    *** Time and Time Zones ***
                   Local time: Tue 2024-02-06 18:54:07 CET
               Universal time: Tue 2024-02-06 17:54:07 UTC
                     RTC time: Tue 2024-02-06 17:54:07
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    debian
    /home/debian
    debian cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             12G        8.2G        1.2G        3.2M        3.4G        4.4G
    Swap:           2.1G        296M        1.8G
    Total:           14G        8.5G        3.1G
            11926 M total memory
             7776 M used memory
             1345 M active memory
             8112 M inactive memory
             1179 M free memory
              403 M buffer memory
             2883 M swap cache
             2043 M total swap
              283 M used swap
             1760 M free swap
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * apcupsd.service loaded failed failed UPS power management daemon
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                                                               Type      Size  Used Avail Use% Mounted on
    udev        devtmpfs  5.8G     0  5.8G   0% /dev
    tmpfs        tmpfs     1.2G  1.5M  1.2G   1% /run
    /dev/mapper/debian10--vg-root                                            ext4      107G   43G   59G  42% /
    tmpfs        tmpfs     5.9G     0  5.9G   0% /dev/shm
    tmpfs        tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1        ext2      234M  128M   95M  58% /boot
    /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  144K  1.1G   1% /tmp
    /dev/mapper/debian10--vg-home                                            ext4       70G  8.6G   58G  13% /home
    /dev/mapper/debian10--vg-var                                             ext4      6.4G  1.9G  4.1G  32% /var
    tmpfs        tmpfs     1.2G   68K  1.2G   1% /run/user/116
    192.168.10.47:/volume1/IOBROKER                                          nfs4      2.7T  1.6T  1.1T  61% /mnt/IOBROKERDATA
    192.168.10.47:/volume2/Backup                                            nfs4      1.9T  499G  1.4T  26% /mnt/BACKUP
    192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4      1.9T  499G  1.4T  26% /mnt/photosyno
    tmpfs        tmpfs     1.2G   60K  1.2G   1% /run/user/1000
    [Fri Jan 12 08:34:47 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jan 12 08:34:48 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
    [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
    [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
    [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET              SOURCE        FSTYPE OPTIONS
    /                   /dev/mapper/debian10--vg-root                                            ext4   rw,relatime,errors=remount-ro
    |-/boot             /dev/sda1        ext2   rw,relatime
    |-/tmp              /dev/mapper/debian10--vg-tmp                                             ext4   rw,relatime
    |-/home             /dev/mapper/debian10--vg-home                                            ext4   rw,relatime
    |-/var              /dev/mapper/debian10--vg-var                                             ext4   rw,relatime
    |-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
    |-/mnt/BACKUP       192.168.10.47:/volume2/Backup                                            nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
    `-/mnt/photosyno    192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
    /var:
    1.9G    /var/
    1.5G    /var/lib
    525M    /var/lib/grafana
    520M    /var/lib/grafana/plugins
    516M    /var/lib/grafana/plugins/grafana-image-renderer
    Archived and active journals take up 11.1M in the file system.
    /opt/iobroker/backups:
    1.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    31G     /opt/iobroker/iobroker-data/
    30G     /opt/iobroker/iobroker-data/history
    947M    /opt/iobroker/iobroker-data/files
    195M    /opt/iobroker/iobroker-data/backup-objects
    176M    /opt/iobroker/iobroker-data/files/vis-2
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.1.6
    Adapters from github:   21
    Adapter State
    + system.adapter.admin.0                  : admin                 : IOBROKER-MASTER                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alarm.0                  : alarm                 : IOBROKER-MASTER                          -  enabled
    + system.adapter.alexa2.0                 : alexa2                : IOBROKER-MASTER                          -  enabled
      system.adapter.alias-manager.0          : alias-manager         : IOBROKER-MASTER                          -  enabled
      system.adapter.apcups.0                 : apcups                : IOBROKER-MASTER                          - disabled
    + system.adapter.asterisk.0               : asterisk              : IOBROKER-MASTER                          -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : IOBROKER-MASTER                          -  enabled
    + system.adapter.backitup.1               : backitup              : IOBROKER-SLAVE                           -  enabled
    + system.adapter.chromecast.0             : chromecast            : IOBROKER-MASTER                          -  enabled
      system.adapter.daswetter.0              : daswetter             : IOBROKER-MASTER                          -  enabled
      system.adapter.device-watcher.0         : device-watcher        : IOBROKER-MASTER                          - disabled
      system.adapter.devices.0                : devices               : IOBROKER-MASTER                          -  enabled
    + system.adapter.discovery.0              : discovery             : IOBROKER-MASTER                          -  enabled
      system.adapter.dwd.0                    : dwd                   : IOBROKER-MASTER                          -  enabled
    + system.adapter.echarts.0                : echarts               : IOBROKER-MASTER                          -  enabled
    + system.adapter.email.0                  : email                 : IOBROKER-MASTER                          -  enabled
      system.adapter.feiertage.0              : feiertage             : IOBROKER-MASTER                          -  enabled
      system.adapter.flot.0                   : flot                  : IOBROKER-MASTER                          -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : IOBROKER-MASTER                          -  enabled
    + system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : IOBROKER-MASTER                          -  enabled
    + system.adapter.govee-app.0              : govee-app             : IOBROKER-MASTER                          -  enabled
    + system.adapter.ham.0                    : ham                   : IOBROKER-MASTER                          -  enabled
    + system.adapter.hass.0                   : hass                  : IOBROKER-MASTER                          -  enabled, port: 8123
      system.adapter.heatingcontrol.0         : heatingcontrol        : IOBROKER-MASTER                          - disabled
      system.adapter.hiob.0                   : hiob                  : IOBROKER-MASTER                          - disabled
    + system.adapter.history.0                : history               : IOBROKER-MASTER                          -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : IOBROKER-MASTER                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : IOBROKER-MASTER                          -  enabled, port: 80
      system.adapter.husq-automower.0         : husq-automower        : IOBROKER-MASTER                          - disabled
      system.adapter.ical.0                   : ical                  : IOBROKER-MASTER                          -  enabled
      system.adapter.ical.1                   : ical                  : IOBROKER-MASTER                          -  enabled
      system.adapter.ical.2                   : ical                  : IOBROKER-MASTER                          -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : IOBROKER-MASTER                          -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBROKER-MASTER                          -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBROKER-MASTER                          -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOBROKER-MASTER                          -  enabled
    + system.adapter.influxdb.0               : influxdb              : IOBROKER-MASTER                          -  enabled, port: 8086
      system.adapter.info.0                   : info                  : IOBROKER-MASTER                          - disabled
    + system.adapter.javascript.0             : javascript            : IOBROKER-MASTER                          -  enabled
    + system.adapter.kodi.0                   : kodi                  : IOBROKER-MASTER                          -  enabled, port: 9090
    + system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER-MASTER                          -  enabled
    + system.adapter.linktap.0                : linktap               : IOBROKER-MASTER                          -  enabled
    + system.adapter.linux-control.0          : linux-control         : IOBROKER-MASTER                          -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IOBROKER-MASTER                          -  enabled, port: 54321
    + system.adapter.mqtt-client.0            : mqtt-client           : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.0                   : mqtt                  : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mytime.0                 : mytime                : IOBROKER-MASTER                          - disabled
    + system.adapter.net-tools.0              : net-tools             : IOBROKER-MASTER                          -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOBROKER-MASTER                          -  enabled
    + system.adapter.node-red.0               : node-red              : IOBROKER-MASTER                          -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER                          -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : IOBROKER-MASTER                          -  enabled
      system.adapter.oasecontrol.0            : oasecontrol           : IOBROKER-MASTER                          - disabled
    + system.adapter.ocpp.0                   : ocpp                  : IOBROKER-MASTER                          -  enabled, port: 9220
    + system.adapter.onkyo.0                  : onkyo                 : IOBROKER-MASTER                          -  enabled
      system.adapter.onvif.0                  : onvif                 : IOBROKER-MASTER                          - disabled
    + system.adapter.ping.0                   : ping                  : IOBROKER-MASTER                          -  enabled
    + system.adapter.pushover.0               : pushover              : IOBROKER-MASTER                          -  enabled
    + system.adapter.reolink.0                : reolink               : IOBROKER-MASTER                          -  enabled
    + system.adapter.robonect.0               : robonect              : IOBROKER-MASTER                          -  enabled
    + system.adapter.samsung.0                : samsung               : IOBROKER-MASTER                          -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : IOBROKER-MASTER                          - disabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : IOBROKER-MASTER                          -  enabled
    + system.adapter.scenes.0                 : scenes                : IOBROKER-MASTER                          -  enabled
    + system.adapter.scheduler.0              : scheduler             : IOBROKER-MASTER                          -  enabled
    + system.adapter.shelly.0                 : shelly                : IOBROKER-MASTER                          -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : IOBROKER-MASTER                          - disabled
    + system.adapter.simple-api.0             : simple-api            : IOBROKER-MASTER                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : IOBROKER-MASTER                          -  enabled
      system.adapter.smartmeter.0             : smartmeter            : IOBROKER-SLAVE                           - disabled
    + system.adapter.smartthings.0            : smartthings           : IOBROKER-MASTER                          -  enabled
    + system.adapter.sonoff.0                 : sonoff                : IOBROKER-MASTER                          -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : IOBROKER-MASTER                          -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER-MASTER                          -  enabled
    + system.adapter.synology.0               : synology              : IOBROKER-MASTER                          -  enabled, port: 5000
    + system.adapter.tahoma.0                 : tahoma                : IOBROKER-MASTER                          -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBROKER-MASTER                          -  enabled
    + system.adapter.telegram.0               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : IOBROKER-MASTER                          -  enabled
    + system.adapter.text2command.1           : text2command          : IOBROKER-MASTER                          -  enabled
    + system.adapter.time-switch.0            : time-switch           : IOBROKER-MASTER                          -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : IOBROKER-MASTER                          -  enabled
      system.adapter.trashschedule.1          : trashschedule         : IOBROKER-MASTER                          - disabled
    + system.adapter.unifi.0                  : unifi                 : IOBROKER-MASTER                          -  enabled
      system.adapter.upnp.0                   : upnp                  : IOBROKER-MASTER                          - disabled
    + system.adapter.vaillant.0               : vaillant              : IOBROKER-MASTER                          -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-bars.0               : vis-bars              : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IOBROKER-MASTER                          -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-metro.0              : vis-metro             : IOBROKER-MASTER                          - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBROKER-MASTER                          -  enabled
      system.adapter.vis-weather.0            : vis-weather           : IOBROKER-MASTER                          -  enabled
      system.adapter.vis.0                    : vis                   : IOBROKER-MASTER                          -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : IOBROKER-MASTER                          -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : IOBROKER-MASTER                          -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : IOBROKER-MASTER                          -  enabled
    + system.adapter.web.0                    : web                   : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.webcal.0                 : webcal                : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
    + system.adapter.yahka.0                  : yahka                 : IOBROKER-MASTER                          -  enabled
    + system.adapter.zigbee.1                 : zigbee                : IOBROKER-SLAVE                           -  enabled, port: /dev/ttyACM0
    + system.adapter.zigbee.2                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.24:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "apcups"       : 1.0.15   , installed 1.0.15
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-watcher": 2.9.6   , installed 2.9.6
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "doorio"       : 2.1.4    , installed 2.1.4
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "kodi"         : 3.0.0    , installed 3.0.0
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linktap"      : 0.3.0    , installed 0.3.0
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "mpd"          : 1.1.1    , installed 1.1.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "onvif"        : 1.1.1    , installed 1.1.1
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "reolink"      : 1.0.3    , installed 1.0.3
    Adapter    "robonect"     : 1.3.4    , installed 1.3.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "smartthings"  : 0.0.4    , installed 0.1.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vaillant"     : 0.1.2    , installed 0.4.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "volumio"      : 0.1.2    , installed 0.1.3
    Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "webcal"       : 1.3.0    , installed 1.1.0  [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        56453
    States:         48398
    W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 17
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          65         1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16086      969/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       74578738   2501883/node-red
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       74583578   2502418/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       74587586   2502993/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       74587587   2502993/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       74591520   2502919/io.sonoff.0
    tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       75512632   2690492/nc
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          73118439   2210884/cupsd
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        18592      1008/asterisk
    tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       74582911   2502463/io.hm-rpc.0
    tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       74595393   2502564/io.hm-rpc.1
    tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       74583000   2502888/io.hm-rpc.2
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        74603472   2507490/redis-serve
    tcp        0      0 127.0.0.1:44949         0.0.0.0:*               LISTEN      122        42316113   250044/plugin_start
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1711       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16088      969/sshd: /usr/sbin
    tcp6       0      0 :::9220                 :::*                    LISTEN      1001       74585814   2503615/io.ocpp.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       74594491   2502433/io.nuki-ext
    tcp6       0      0 :::35615                :::*                    LISTEN      1001       74591906   2504296/io.yahka.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      122        42309336   249599/grafana
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          73118438   2210884/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       74592281   2501830/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74598671   2504408/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        22728      1022/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       74591795   2503730/io.simple-a
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15910      1/init
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          73118444   2210886/cups-browse
    udp        0      0 0.0.0.0:42823           0.0.0.0:*                           111        23664      879/avahi-daemon: r
    udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       75515310   2502935/io.sonos.0
    udp        0      0 0.0.0.0:35072           0.0.0.0:*                           121        22715      1008/asterisk
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       74596509   2503080/io.mihome-v
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        18609      1008/asterisk
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        18610      1008/asterisk
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       74592712   2503132/io.chromeca
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        23662      879/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          22563      1/init
    udp6       0      0 :::50118                :::*                                111        23665      879/avahi-daemon: r
    udp6       0      0 :::54441                :::*                                121        22716      1008/asterisk
    udp6       0      0 :::5353                 :::*                                111        23663      879/avahi-daemon: r
    2024-02-06 18:54:18.958  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
    2024-02-06 18:54:18.964  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
    2024-02-06 18:54:18.966  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
    2024-02-06 18:54:19.652  - info: ocpp.0 (2503615) Requesting StatusNotification from "/2203020632A"
    2024-02-06 18:54:19.769  - debug: ocpp.0 (2503615) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116565Z","commandOcpp":"StatusNotification"}
    2024-02-06 18:54:19.770  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.1": Available
    2024-02-06 18:54:19.929  - debug: ocpp.0 (2503615) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116827Z","commandOcpp":"StatusNotification"}
    2024-02-06 18:54:19.930  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
    2024-02-06 18:54:20.726  - info: ocpp.0 (2503615) Requesting MeterValues from "/2203020632A"
    2024-02-06 18:54:21.798  - info: ocpp.0 (2503615) Sending GetConfiguration to "/2203020632A"
    2024-02-06 18:54:21.937  - debug: ocpp.0 (2503615) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"30"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
    2024-02-06 18:54:21.990  - info: ocpp.0 (2503615) Supported profiles by client "/2203020632A" are "Core"
    2024-02-06 18:54:22.001  - info: ocpp.0 (2503615) Removing SmartCharging functionality as unsupported
    2024-02-06 18:54:22.009  - info: ocpp.0 (2503615) Removing LocalAuthListManagement functionality as unsupported
    2024-02-06 18:54:27.560  - info: linktap.0 (2504393) updateWateringStatus started
    2024-02-06 18:54:28.086  - info: linktap.0 (2504393) Queried watering status for device Ventil-1. Status: 200
    2024-02-06 18:54:28.588  - info: linktap.0 (2504393) Queried watering status for device Ventil-2. Status: 200
    2024-02-06 18:54:29.087  - info: linktap.0 (2504393) Queried watering status for device Ventil-3. Status: 200
    2024-02-06 18:54:29.590  - info: linktap.0 (2504393) Queried watering status for device Ventil-4. Status: 200
    2024-02-06 18:54:30.091  - info: linktap.0 (2504393) Queried watering status for device Ventil-5. Status: 200
    2024-02-06 18:54:30.591  - info: linktap.0 (2504393) Queried watering status for device Ventil-6. Status: 200
    2024-02-06 18:54:30.592  - info: linktap.0 (2504393) updateWateringStatus finished
    2024-02-06 18:54:30.720  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching CheckDeadBatt()
    2024-02-06 18:54:30.722  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeTable
    2024-02-06 18:54:30.726  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeJSONTable
    Top sieht so aus :
    top - 18:58:10 up 25 days, 10:23,  1 user,  load average: 0.47, 0.44, 0.39
    Tasks: 420 total,   1 running, 419 sleeping,   0 stopped,   0 zombie
    %Cpu(s):   1.0/0.5     1[|        ]
    MiB Mem :  11926.7 total,    930.9 free,   8022.1 used,   3290.3 buff/cache
    MiB Swap:   2044.0 total,   1761.0 free,    283.0 used.   3904.6 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
    2502494 iobroker  20   0  970908 115660  39628 S   5.9   0.9   0:33.15 io.alexa2.0
    2502418 iobroker  20   0  718700 119496  38512 S   3.0   1.0   9:29.04 io.shelly.0
    2507490 redis     20   0 2380112 956748   8916 S   2.6   7.8  25:35.59 redis-server
    2501928 iobroker  20   0 1228744 348208  45036 S   2.3   2.9  26:04.94 io.javascript.0
    2501985 iobroker  20   0 1026816 164916  38276 S   1.7   1.4   9:44.20 io.influxdb.0
    2501872 iobroker  20   0  889924 156760  38196 S   1.0   1.3   9:43.59 io.history.0
    2502388 iobroker  20   0  677664 104916  38476 S   1.0   0.9   8:04.91 io.kodi.0
    2503052 iobroker  20   0   10.7g 112432  40076 S   1.0   0.9   1:53.66 io.synology.0
       1008 asterisk -11   0 5204544  35892  20324 S   0.7   0.3 312:22.63 asterisk
       1338 Debian-+  20   0 6338796 107844  35444 S   0.7   0.9  63:55.86 gnome-shell
    2692777 debian    20   0   11648   5448   3296 R   0.7   0.0   0:00.55 top
        802 root      20   0  241528   9844   6408 S   0.3   0.1  47:58.63 vmtoolsd
     249599 grafana   20   0 1677572 128360  51340 S   0.3   1.1  24:23.42 grafana
     250044 grafana   20   0  664160  61604  14420 S   0.3   0.5  72:02.49 plugin_start_li
    2501812 iobroker  20   0   11.1g 282464  45948 S   0.3   2.3   2:25.60 iobroker.js-con
    2501894 iobroker  20   0 1004340 131644  44840 S   0.3   1.1   1:03.47 io.telegram.2
    2501913 iobroker  20   0  687568  79528  38324 S   0.3   0.7   0:13.81 io.email.0
    2502001 iobroker  20   0 1003480 123116  39248 S   0.3   1.0   1:03.21 io.telegram.0
    2502018 iobroker  20   0  687428  81080  38204 S   0.3   0.7   0:13.52 io.pushover.0
    2502357 iobroker  20   0 1005648 130384  44844 S   0.3   1.1   1:03.65 io.telegram.1
    2502510 iobroker  20   0  698448  92956  38472 S   0.3   0.8   0:19.54 io.hass.0
    2502935 iobroker  20   0  686568  81752  38264 S   0.3   0.7   0:33.03 io.sonos.0
    2502993 iobroker  20   0  773696  98832  38352 S   0.3   0.8   0:28.60 io.mqtt.0
    2503080 iobroker  20   0  693196  88192  38196 S   0.3   0.7   0:29.98 io.mihome-vacuu
    2503148 iobroker  20   0  690772  83992  38244 S   0.3   0.7   1:53.38 io.net-tools.0
    2503429 iobroker  20   0  737980 112192  38280 S   0.3   0.9   0:50.42 io.mqtt-client.
    2504296 iobroker  20   0  760992  93404  39180 S   0.3   0.8   0:58.30 io.yahka.0
    2504393 iobroker  20   0  958140  93000  39352 S   0.3   0.8   1:01.79 io.linktap.0
    2662239 root      20   0       0      0      0 I   0.3   0.0   0:03.22 kworker/9:0-events
          1 root      20   0  169580  12604   7964 S   0.0   0.1   0:34.39 systemd
          2 root      20   0       0      0      0 S   0.0   0.0   0:04.01 kthreadd
          3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
          4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
          5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
          6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
          8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
         10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
         11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
         12 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
         13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
         14 root      20   0       0      0      0 S   0.0   0.0   0:23.37 ksoftirqd/0
    Da steht oben immer ein anderer Wert drin , je nach dem alle mit io.XXXX , aber nur so um die 9% bis max 30%
    • S sunny9999
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: vm 🖴
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 16
                    NTP service: active
                RTC in local TZ: no
      debian
      /home/debian
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               7776 M used memory
               1179 M free memory
                403 M buffer memory
               2883 M swap cache
               2043 M total swap
                283 M used swap
               1760 M free swap
      *** FILESYSTEM ***
      /var:
      1.9G    /var/
      1.5G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: redis
      States  type: redis
      admin:          6.13.16
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        56453
      States:         48398
      Pending Updates: 17
      Top sieht so aus :
      HomoranH Offline
      HomoranH Offline
      achwas :-)
      aber hiet
      ist kein Hinweis auf Überlastung durch I/O oder Prozesse
      • S sunny9999
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 16
                      NTP service: active
                  RTC in local TZ: no
        debian
        /home/debian
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 7776 M used memory
                 1179 M free memory
                  403 M buffer memory
                 2883 M swap cache
                 2043 M total swap
                  283 M used swap
                 1760 M free swap
        *** FILESYSTEM ***
        /var:
        1.9G    /var/
        1.5G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: redis
        States  type: redis
        admin:          6.13.16
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        56453
        States:         48398
        Pending Updates: 17
        Top sieht so aus :
        @sunny9999
        Deine .list-Files für influxdb sind komplett chaotisch. Hat aber nix mit deinem 'Problem' direkt zu tun.
        Und wozu brauchst du die gnome-shell?
          @sunny9999
          sunny9999
          keine Ahnung wo die herkommt........kann man die deinstallieren und wenn ja wie ? wenns was bringt.......
          Idee wie ich die Influxdb .list files hinbiegen kann ? ( nur so am Rande).......
          • S sunny9999
            HomoranH Offline
            HomoranH Offline
            @sunny9999 was machst du mit den mounts?
            rauschen da die Daten dauerhaft und viel durch?
            bei diashow werde ich auch hellhörig
              sunny9999
              die mounts sind nur für Backups.....die slideshow läuft nicht, war mal ein Versuch, danke für den Hinweis schon fast vergessen....jetzt disabled....
              • S sunny9999
                sudo rm /etc/apt/sources.list.d/influx*
                wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                rm influxdata-archive_compat.key
                sudo apt update
                sudo apt full-upgrade
                Setz den user 'debian' in die Gruppe 'adm':
                sudo usermod -a -G adm debian
                Boot Target: graphical.target
                sudo systemctl set-default multi-user.target
                sudo reboot
                Was ist denn mit dem los?
                  sudo apt update
                  sudo reboot
                  sunny9999
                  @thomas-braun sagte in Performance verbessern:
                  Top Vielen Dank !
                  das war mal ein daemon für ne apc usv .....die hing damals als Server im Netz, weiss nur nicht wie ich die wieder deinstallieren kann, weisst du das ?
                  Alles so gemacht.....iob diag sieht nun wie folgt aus :
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   19:36:28 up 8 min,  1 user,  load average: 0.74, 1.27, 0.75
                  CPU threads: 16
                                 Local time: Tue 2024-02-06 19:36:28 CET
                             Universal time: Tue 2024-02-06 18:36:28 UTC
                                   RTC time: Tue 2024-02-06 18:36:28
                                NTP service: active
                            RTC in local TZ: no
                  debian
                  /home/debian
                  debian adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:             12G        6.2G        4.5G        1.4M        2.1G        6.3G
                  Swap:           2.1G          0B        2.1G
                  Total:           14G        6.2G        6.6G
                           5937 M used memory
                            505 M active memory
                           6580 M inactive memory
                           4246 M free memory
                            136 M buffer memory
                           1892 M swap cache
                           2043 M total swap
                              0 M used swap
                           2043 M free swap
                  *** FILESYSTEM ***
                  tmpfs        tmpfs     1.2G  1.3M  1.2G   1% /run
                  /dev/mapper/debian10--vg-root                                            ext4      107G   43G   60G  42% /
                  /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  116K  1.1G   1% /tmp
                  /dev/mapper/debian10--vg-var                                             ext4      6.4G  2.0G  4.0G  34% /var
                  [Tue Feb  6 19:27:39 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Feb  6 19:27:40 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
                  [Tue Feb  6 19:27:41 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
                  [Tue Feb  6 19:27:41 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
                  [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
                  `-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                  /var:
                  2.0G    /var/
                  1.5G    /var/lib
                  Archived and active journals take up 85.3M in the file system.
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  admin:          6.13.16
                  javascript:     7.1.6
                  Adapter State
                    system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          - disabled
                  + instance is alive
                  Objects and States
                  Objects:        56453
                  States:         48433
                  Hit:4 https://apt.grafana.com stable InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15837      2046/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15786      1951/io.mqtt.0
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14320      1673/node-red
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15787      1951/io.mqtt.0
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       26969      1916/io.sonoff.0
                  tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       55666      6053/nc
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23748      934/cupsd
                  tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       25253      2066/io.hm-rpc.2
                  tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       19362      2317/io.hm-rpc.1
                  tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       17928      2299/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13258      943/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14049      1/init
                  tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        15631      969/asterisk
                  tcp        0      0 127.0.0.1:40241         0.0.0.0:*               LISTEN      122        35029      1280/plugin_start_l
                  tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        20140      2535/redis-server 0
                  tcp6       0      0 :::9220                 :::*                    LISTEN      1001       20418      3039/io.ocpp.0
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23747      934/cupsd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13260      943/sshd: /usr/sbin
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          16407      1/init
                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       15044      2284/io.nuki-extend
                  tcp6       0      0 :::3000                 :::*                    LISTEN      122        14218      1239/grafana
                  tcp6       0      0 :::38891                :::*                    LISTEN      1001       32649      2497/io.yahka.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38416      2882/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32148      1304/io.admin.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      998        35014      981/influxd
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24244      2692/io.simple-api.
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28072      1/init
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          28194      986/cups-browsed
                  udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       62557      2195/io.sonos.0
                  udp        0      0 0.0.0.0:60858           0.0.0.0:*                           121        33541      969/asterisk
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15909      2165/io.mihome-vacu
                  udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        15648      969/asterisk
                  udp        0      0 0.0.0.0:45969           0.0.0.0:*                           111        31874      870/avahi-daemon: r
                  udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        15649      969/asterisk
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22049      1853/io.chromecast.
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        31872      870/avahi-daemon: r
                  udp6       0      0 :::111                  :::*                                0          17472      1/init
                  udp6       0      0 :::44160                :::*                                121        33542      969/asterisk
                  udp6       0      0 :::5353                 :::*                                111        31873      870/avahi-daemon: r
                  udp6       0      0 :::46869                :::*                                111        31875      870/avahi-daemon: r
                  2024-02-06 19:36:45.696  - debug: ocpp.0 (3039) {"chargePointSerialNumber":"2203020632A","chargePointModel":"Aura T2 outlet","chargePointVendor":"Charge Amps","firmwareVersion":"72.2.0.0","iccid":"0","commandOcpp":"BootNotification"}
                  2024-02-06 19:36:45.696  - info: ocpp.0 (3039) Received boot notification from "/2203020632A"
                  2024-02-06 19:36:45.813  - debug: ocpp.0 (3039) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:45.7744021Z","commandOcpp":"StatusNotification"}
                  2024-02-06 19:36:45.813  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.1": Available
                  2024-02-06 19:36:45.821  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.1.lastTransactionConsumption
                  2024-02-06 19:36:45.824  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.1.transactionEndMeter
                  2024-02-06 19:36:45.954  - debug: ocpp.0 (3039) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:45.7744353Z","commandOcpp":"StatusNotification"}
                  2024-02-06 19:36:45.954  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.2": Available
                  2024-02-06 19:36:45.961  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
                  2024-02-06 19:36:45.964  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
                  2024-02-06 19:36:46.641  - info: ocpp.0 (3039) Requesting StatusNotification from "/2203020632A"
                  2024-02-06 19:36:46.744  - debug: ocpp.0 (3039) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:46.7099585Z","commandOcpp":"StatusNotification"}
                  2024-02-06 19:36:46.745  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.1": Available
                  2024-02-06 19:36:46.860  - debug: ocpp.0 (3039) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:46.7099797Z","commandOcpp":"StatusNotification"}
                  2024-02-06 19:36:46.860  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.2": Available
                  2024-02-06 19:36:47.725  - info: ocpp.0 (3039) Requesting MeterValues from "/2203020632A"
                  2024-02-06 19:36:48.802  - info: ocpp.0 (3039) Sending GetConfiguration to "/2203020632A"
                  2024-02-06 19:36:48.945  - debug: ocpp.0 (3039) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"120"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
                  2024-02-06 19:36:48.992  - info: ocpp.0 (3039) Supported profiles by client "/2203020632A" are "Core"
                  2024-02-06 19:36:49.000  - info: ocpp.0 (3039) Removing SmartCharging functionality as unsupported
                  2024-02-06 19:36:49.009  - info: ocpp.0 (3039) Removing LocalAuthListManagement functionality as unsupported
                  2024-02-06 19:36:57.137  - warn: robonect.0 (1764) No connection to lawn mower (Not able to ping it). Check network connection.
                  2024-02-06 19:36:58.693  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] activated Zone 'BUERO2.Benni+Markus'. However, device(s) 'BUERO2.B+M-Lampe-Decke' not turned on as these are already on.
                  2024-02-06 19:36:58.693  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] Zone 'BUERO2.Benni+Markus': Timer of 240s will be set to turn off once no more motion recognized.
                  2024-02-06 19:36:58.694  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] 'zoneOff' 360s timer still running 329s. We stop it and set new to 360s.
                  • S sunny9999
                    Top Vielen Dank !
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Chassis: vm 🖴
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 16
                                  NTP service: active
                              RTC in local TZ: no
                    debian
                    /home/debian
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           2.1G          0B        2.1G
                             5937 M used memory
                              505 M active memory
                             4246 M free memory
                              136 M buffer memory
                             1892 M swap cache
                             2043 M total swap
                                0 M used swap
                             2043 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.0G    /var/
                    1.5G    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: redis
                    States  type: redis
                    admin:          6.13.16
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        56453
                    States:         48433
                    Pending Updates: 0
                    HomoranH Offline
                    HomoranH Offline
                    hast du vieles auf debug?
                    kostet auch Ressourcen
                    • S sunny9999
                      Top Vielen Dank !
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 16
                                    NTP service: active
                                RTC in local TZ: no
                      debian
                      /home/debian
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           2.1G          0B        2.1G
                               5937 M used memory
                                505 M active memory
                               4246 M free memory
                                136 M buffer memory
                               1892 M swap cache
                               2043 M total swap
                                  0 M used swap
                               2043 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.0G    /var/
                      1.5G    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: redis
                      States  type: redis
                      admin:          6.13.16
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        56453
                      States:         48433
                      Pending Updates: 0
                      So wie du es auch installiert hast?
                      Einstweilen kannst du es auch maskieren:
                      sudo systemctl mask apcupsd.service
