  4. ERROR: Process exited with code 1 / keine Updates möglich
41 Beiträge 4 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • B Belei
    Jetzt wird er geschwätzich, hat er es jetzt re-installiert?
    root@ioBrokerNuc:~# iobroker upgrade tr-064@4.2.18 --host ioBrokerNuc --debug
    Would you like to reinstall version 4.2.18 of tr-064 now? [(y)es, (n)o]: y
    Update tr-064 from @4.2.18 to @4.2.18
    NPM version: 10.2.3
    Installing iobroker.tr-064@4.2.18... (System call)
    npm WARN skipping integrity check for git dependency ssh://git@github.com/noopka                  t/browser-serialport.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason                  s. As it's a core Node module, we will not transfer it over to other users. You                   may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                   a built-in Node module. If you've depended on crypto, you should switch to the o                  ne that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                  s its own type definitions, so you do not need this installed.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                  ecause it extends the now deprecated request package, see https://github.com/req                  uest/request/issues/3142
    npm WARN deprecated abab@2.0.6: Use your platform's native atob() and btoa() met                  hods instead
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                  ON 3
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy.                   new code should use the URLSearchParams API instead.
    npm WARN deprecated domexception@4.0.0: Use your platform's native DOMException                   instead
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                   does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated jscs-preset-wikimedia@1.0.1: No longer maintained. We recomm                  ent migrating to ESLint with eslint-config-wikimedia.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                  e a low-severity ReDos regression when used in a Node.js environment. It is reco                  mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                  ues/797)
    npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@n                  pmjs.com for more info.
    npm WARN deprecated uuid@2.0.3: Please upgrade  to version 7 or higher.  Older v                  ersions may use Math.random() in certain circumstances, which is known to be pro                  blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                  ersions may use Math.random() in certain circumstances, which is known to be pro                  blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                  hub.com/request/request/issues/3142
    npm WARN deprecated jscs@3.0.7: JSCS has merged with ESLint! See - https://mediu                  m.com/@markelog/jscs-end-of-the-line-bc9bf0b3fdb2
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and                   not recommended for usage due to the number of issues. Because of the V8 engine                   whims, feature detection in old core-js versions could cause a slowdown up to 10                  0x even if nothing is polyfilled. Some versions have web compatibility issues. P                  lease, upgrade your dependencies to the actual version of core-js.
    changed 1382 packages in 7m
    127 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.tr-064.0"
    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @belei sagte in ERROR: Process exited with code 1 / keine Updates möglich:
    Ist nur Werbung :)
    B 1 Antwort Letzte Antwort
    • B Belei
      NPM version: 10.2.3
      Ja.
      Am Rande: Zieh das Fenster von deinem puTTY breiter. Das schwindelige Ding fabriziert da komische Zeilenumbrüche.
      • GlasfaserG Glasfaser
        Ist nur Werbung :)
        Belei
        @glasfaser
        npm fund ?? Spendenanfrage oder was? :-)
        • B Belei
          @glasfaser
          Ja.
          • B Belei
            @glasfaser
            @belei
            Wie schaut es bei
            iob update
            aus?
              @belei
              Wie schaut es bei
              iob update
              aus?
              Belei
              Sind noch paar... Aber es geht voran. Wundert mich nur das jeder einzel abgefragt wird und es pro Adapter im mindestens 5 minuten braucht.
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
              Adapter    "backitup"     : 2.9.8    , installed 2.6.19 [Updatable]
              Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
              Adapter    "fb-checkpresence": 1.2.2 , installed 1.1.25 [Updatable]
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
              Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
              Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
              Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
              Adapter    "hue"          : 3.10.1   , installed 3.7.1  [Updatable]
              Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
              Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "iqontrol"     : 2.3.0    , installed 2.1.0  [Updatable]
              Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
              Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
              Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
              Adapter    "mihome-vacuum": 4.1.0    , installed 3.11.0 [Updatable]
              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
              Adapter    "proxmox"      : 2.2.2    , installed 1.3.5  [Updatable]
              Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
              Adapter    "radar2"       : 2.1.0    , installed 2.1.0
              Adapter    "rflink"       : 2.1.6    , installed 2.1.6
              Adapter    "scenes"       : 2.3.9    , installed 2.3.9
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
              Adapter    "vis"          : 1.5.4    , installed 1.5.4
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
              • B Belei
                Mit
                iob upgrade all -y
                fragt die Kiste nicht mehr bei jedem Adapter.
                  Mit
                  iob upgrade all -y
                  Belei
                  Erstmal vielen Dank für die super kompetente schnelle Hilfe hier von allen!! 👍 👏
                  Die gute Nachricht ist, es ist alles durchgeupdatet und iob wieder gestartet.
                  Die schlechte ist, es kam der einrichtungsassistent und nun sind nur 3 Instanzen aktiv statt über 20.
                  Die korekten Adapter stehen aber noch unter Adapter. Es fehlt auch der Punkte Scripte im Menü.
                  Habe Scripte mal als Instanz aktiviert, die Scripte sind auch wech.....
                  • B Belei
                    @belei
                    iob diag
                    sagt?
                    B 2 Antworten Letzte Antwort
                      @belei
                      iob diag
                      sagt?
                      Belei
                      schrieb am zuletzt editiert von Belei
                      @thomas-braun said in ERROR: Process exited with code 1 / keine Updates möglich:
                      iob diag
                      Wenn ich den als root ausführe sagt er, mach nicht als root.
                      Wenn ich ihn mit einem standard User ausführe sagt er:
                      [sudo] Passwort für benni:
                      Leider darf der Benutzer benni »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf ioBrokerNuc nicht ausführen
                      EDIT:
                      Hab ihm jetzt in die sudo Gruppe gepackt
                        @belei
                        iob diag
                        sagt?
                        Belei
                                                v.2023-10-10
                           Static hostname: ioBrokerNuc
                                 Icon name: computer-vm
                                   Chassis: vm
                            Virtualization: kvm
                          Operating System: Debian GNU/Linux 10 (buster)
                                    Kernel: Linux 4.19.0-25-amd64
                              Architecture: x86-64
                        Installation:           kvm
                        Kernel:                 x86_64
                        Userland:               amd64
                        Timezone:               Europe/Berlin (CET, +0100)
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     0
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                /usr/bin/node           v18.19.0
                                                /usr/bin/npm            10.2.3
                                                /usr/bin/npx            10.2.3
                                                /usr/bin/corepack       0.22.0
                        Recommended versions are nodejs 18.19.0 and npm 10.2.3
                        MEMORY:
                        Mem:           2.0G        972M        312M        1.0M        709M        856M
                        Swap:          2.0G         29M        2.0G
                        Total:         4.0G        1.0G        2.3G
                        Active iob-Instances:   6
                        Active repo(s): stable
                        ioBroker Core:          js-controller           5.0.17
                                                admin                   6.12.0
                        Objects type: jsonl
                        States  type: redis
                        + system.adapter.admin.0                  : admin                 : ioBrokerNuc                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        Objects:                198
                        States:                 7866
                        Size of iob-Database:
                        4.1M    /opt/iobroker/iobroker-data/objects.jsonl
                        108K    /opt/iobroker/iobroker-data/objects.json.migrated
                        68K     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        8.0K    /opt/iobroker/iobroker-data/states.json.bak
                        === Mark text until here for copying ===
                        • B Belei
                                                  v.2023-10-10
                                     Chassis: vm
                              Virtualization: kvm
                          Installation:           kvm
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          MEMORY:
                          Swap:          2.0G         29M        2.0G
                                                  admin                   6.12.0
                          Objects type: jsonl
                          States  type: redis
                          Objects:                198
                          States:                 7866
                          @belei
                          Die Langfassung.
                            @belei
                            Die Langfassung.
                            Belei
                            Guten Morgen,
                            ich hab gestern Nacht noch ein Backup vom Backitup Adapter eingespielt.
                            Jetzt sind die Instancen wieder da. Hab dann noch mal wieder die Adpater upgedatet und den fix laufen lassen. Jetzt kommen Fehler beim starten der Adapter:
                            Aber hier erstmal der diag:
                            ======== Start marking the full check here =========
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                       Chassis: vm
                                Virtualization: kvm
                            model name      : Common KVM processor
                            Docker          : false
                            Virtualization  : kvm
                            Kernel          : x86_64
                            Userland        : amd64
                            Systemuptime and Load:
                             11:12:12 up  2:09,  1 user,  load average: 0.14, 0.27, 0.58
                            CPU threads: 8
                            *** Time and Time Zones ***
                                           Local time: Sun 2024-01-07 11:12:12 CET
                                       Universal time: Sun 2024-01-07 10:12:12 UTC
                                             RTC time: Sun 2024-01-07 10:12:13
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            benni
                            /home/benni
                            benni cdrom floppy sudo audio dip video plugdev netdev
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           2.0G        484M        794M        4.0M        716M        1.3G
                            Swap:          2.0G         26M        2.0G
                            Total:         4.0G        510M        2.8G
                                     1994 M total memory
                                      484 M used memory
                                      703 M active memory
                                      281 M inactive memory
                                      794 M free memory
                                      168 M buffer memory
                                      547 M swap cache
                                     2044 M total swap
                                       26 M used swap
                                     2018 M free swap
                            *** FAILED SERVICES ***
                            0 loaded units listed. Pass --all to see loaded but inactive units, too.
                            To show all installed unit files use 'systemctl list-unit-files'.
                            *** FILESYSTEM ***
                            udev           devtmpfs  983M     0  983M   0% /dev
                            tmpfs          tmpfs     200M  5.6M  194M   3% /run
                            /dev/sda1      ext4       14G  9.0G  4.1G  69% /
                            tmpfs          tmpfs     998M     0  998M   0% /dev/shm
                            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                            tmpfs          tmpfs     998M     0  998M   0% /sys/fs/cgroup
                            tmpfs          tmpfs     200M     0  200M   0% /run/user/0
                            [Sun Jan  7 09:02:54 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                            [Sun Jan  7 09:02:57 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                            Show mounted filesystems \(real ones only\):
                            TARGET        SOURCE    FSTYPE OPTIONS
                            /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
                            `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                            /var:
                            439M    /var/
                            249M    /var/cache
                            241M    /var/cache/apt
                            178M    /var/cache/apt/archives
                            171M    /var/lib
                                  Users in the 'systemd-journal' group can see all messages. Pass -q to
                                  turn off this notice.
                            No journal files were opened due to insufficient permissions.
                            /opt/iobroker/backups:
                            544M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            481M    /opt/iobroker/iobroker-data/
                            284M    /opt/iobroker/iobroker-data/files
                            142M    /opt/iobroker/iobroker-data/backup-objects
                            76M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                            find: Failed to change directory: /root: Permission denied
                            find: Failed to restore initial working directory: /root: Permission denied
                            USB-Devices by-id:
                            USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2231944-if00
                            /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_95635333930351A0A2D0-if00
                            *** NodeJS-Installation ***
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Installed: 18.19.0-1nodesource1
                              Candidate: 18.19.0-1nodesource1
                              Version table:
                             *** 18.19.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                    100 /var/lib/dpkg/status
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                                 10.24.0~dfsg-1~deb10u3 500
                                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                 10.24.0~dfsg-1~deb10u1 500
                                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Core adapters versions
                            js-controller:  5.0.17
                            admin:          6.12.0
                            javascript:     3.6.4
                            Adapters from github:   0
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ioBrokerNuc                              -  enabled, port: 8081, bind: 192.168.178.32, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : ioBrokerNuc                              -  enabled
                              system.adapter.amazon-dash.0            : amazon-dash           : ioBrokerNuc                              -  enabled
                            + system.adapter.backitup.0               : backitup              : ioBrokerNuc                              -  enabled
                              system.adapter.ble.0                    : ble                   : ioBrokerNuc                              - disabled
                              system.adapter.discovery.0              : discovery             : ioBrokerNuc                              - disabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerNuc                              - disabled
                              system.adapter.feiertage.0              : feiertage             : ioBrokerNuc                              - disabled
                              system.adapter.flot.0                   : flot                  : ioBrokerNuc                              - disabled
                              system.adapter.fritzdect.0              : fritzdect             : ioBrokerNuc                              - disabled
                              system.adapter.history.0                : history               : ioBrokerNuc                              - disabled
                            + system.adapter.hm-rega.0                : hm-rega               : ioBrokerNuc                              - disabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerNuc                              - disabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : ioBrokerNuc                              - disabled, port: 18701
                            + system.adapter.hm-rpc.3                 : hm-rpc                : ioBrokerNuc                              - disabled, port: 12010
                            + system.adapter.hue.0                    : hue                   : ioBrokerNuc                              -  enabled, port: 443
                              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerNuc                              - disabled
                            + system.adapter.info.0                   : info                  : ioBrokerNuc                              -  enabled
                            + system.adapter.iot.0                    : iot                   : ioBrokerNuc                              - disabled
                            + system.adapter.javascript.0             : javascript            : ioBrokerNuc                              - disabled
                              system.adapter.lovelace.0               : lovelace              : ioBrokerNuc                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerNuc                              - disabled, port: 54321
                              system.adapter.mobile.0                 : mobile                : ioBrokerNuc                              - disabled
                            + system.adapter.ping.0                   : ping                  : ioBrokerNuc                              - disabled
                            + system.adapter.pushover.0               : pushover              : ioBrokerNuc                              - disabled
                            + system.adapter.rflink.0                 : rflink                : ioBrokerNuc                              - disabled
                            + system.adapter.shelly.0                 : shelly                : ioBrokerNuc                              - disabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.tr-064.0                 : tr-064                : ioBrokerNuc                              - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerNuc                              - disabled
                              system.adapter.vis.0                    : vis                   : ioBrokerNuc                              - disabled
                              system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerNuc                              - disabled
                              system.adapter.web-speedy.0             : web-speedy            : ioBrokerNuc                              - disabled
                            + system.adapter.web.0                    : web                   : ioBrokerNuc                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.weishaupt-wem.0          : weishaupt-wem         : ioBrokerNuc                              - disabled
                            + system.adapter.zigbee.0                 : zigbee                : ioBrokerNuc                              - disabled, port: /dev/ttyACM1
                            + instance is alive
                            ioBroker-Repositories
                            Installed ioBroker-Instances
                            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                            Adapter    "hue"          : 3.10.1   , installed 3.10.1
                            Adapter    "info"         : 2.0.0    , installed 2.0.0
                            Controller "js-controller": 5.0.17   , installed 5.0.17
                            Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                            Objects and States
                            Objects:        9477
                            States:         7735
                            Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                            Hit:2 http://ftp.de.debian.org/debian buster InRelease
                            Hit:3 http://ftp.de.debian.org/debian buster-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14812      695/sshd
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16850      691/exim4
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       63068      18600/iobroker.js-c
                            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        15514      505/redis-server 12
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10492      1/init
                            tcp        0      0 192.168.178.32:8081     0.0.0.0:*               LISTEN      1001       63114      18625/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14814      695/sshd
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16851      691/exim4
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          10495      1/init
                            udp        0      0 0.0.0.0:41002           0.0.0.0:*                           107        16387      376/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13802      370/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9927       1/init
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        16385      376/avahi-daemon: r
                            udp6       0      0 :::111                  :::*                                0          9932       1/init
                            udp6       0      0 :::5353                 :::*                                107        16386      376/avahi-daemon: r
                            udp6       0      0 :::57837                :::*                                107        16388      376/avahi-daemon: r
                            2024-01-07 11:12:38.956  - error: host.ioBrokerNuc Caught by controller[0]:             throw 'Unknown objects type: ' + config.objects.type;
                            2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]:             ^
                            2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]: Unknown objects type: jsonl
                            2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                            2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]: Node.js v18.19.0
                            2024-01-07 11:12:38.958  - error: host.ioBrokerNuc instance system.adapter.amazon-dash.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-01-07 11:12:38.958  - info: host.ioBrokerNuc Restart adapter system.adapter.amazon-dash.0 because enabled
                            2024-01-07 11:13:03.356  - info: host.ioBrokerNuc instance system.adapter.alexa2.0 started with pid 29459
                            2024-01-07 11:13:04.079  - error: host.ioBrokerNuc Caught by controller[0]: /node_modules/iobroker.js-controller/lib/adapter.js:194
                            2024-01-07 11:13:04.080  - error: host.ioBrokerNuc Caught by controller[0]:             throw 'Unknown objects type: ' + config.objects.type;
                            2024-01-07 11:13:04.080  - error: host.ioBrokerNuc Caught by controller[0]:             ^
                            2024-01-07 11:13:04.081  - error: host.ioBrokerNuc Caught by controller[0]: Unknown objects type: jsonl
                            2024-01-07 11:13:04.082  - error: host.ioBrokerNuc Caught by controller[0]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                            2024-01-07 11:13:04.082  - error: host.ioBrokerNuc Caught by controller[0]: Node.js v18.19.0
                            2024-01-07 11:13:04.083  - error: host.ioBrokerNuc instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-01-07 11:13:04.084  - info: host.ioBrokerNuc Restart adapter system.adapter.alexa2.0 because enabled
                            2024-01-07 11:13:08.998  - info: host.ioBrokerNuc instance system.adapter.amazon-dash.0 started with pid 29519
                            2024-01-07 11:13:09.570  - error: host.ioBrokerNuc Caught by controller[0]: /node_modules/iobroker.js-controller/lib/adapter.js:194
                            2024-01-07 11:13:09.570  - error: host.ioBrokerNuc Caught by controller[0]:             throw 'Unknown objects type: ' + config.objects.type;
                            2024-01-07 11:13:09.571  - error: host.ioBrokerNuc Caught by controller[0]:             ^
                            2024-01-07 11:13:09.571  - error: host.ioBrokerNuc Caught by controller[1]: Unknown objects type: jsonl
                            2024-01-07 11:13:09.571  - error: host.ioBrokerNuc Caught by controller[2]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                            2024-01-07 11:13:09.572  - error: host.ioBrokerNuc Caught by controller[3]: Node.js v18.19.0
                            2024-01-07 11:13:09.572  - error: host.ioBrokerNuc instance system.adapter.amazon-dash.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-01-07 11:13:09.573  - info: host.ioBrokerNuc Restart adapter system.adapter.amazon-dash.0 because enabled
                            iob diag has finished.
                            • B Belei
                              Guten Morgen,
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                         Chassis: vm
                                  Virtualization: kvm
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 8
                                            NTP service: active
                                        RTC in local TZ: no
                              benni
                              /home/benni
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:          2.0G         26M        2.0G
                                       1994 M total memory
                                        484 M used memory
                                        703 M active memory
                                        794 M free memory
                                        168 M buffer memory
                                        547 M swap cache
                                       2044 M total swap
                                         26 M used swap
                                       2018 M free swap
                              *** FILESYSTEM ***
                              /var:
                              439M    /var/
                              249M    /var/cache
                              241M    /var/cache/apt
                              171M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              admin:          6.12.0
                              javascript:     3.6.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        9477
                              States:         7735
                              Pending Updates: 0
                              Welche Fehler? Die mit dem /root cwd?
                              Die kommen durch dein herumgehampel als root.
                              Bring auch die letzten Adapter noch auf Stand und dann ziehst du mit dem Backup auf ein frisches System um. Ohne aktiven root.
                                Belei
                                Die Fehler kommen bei starten der Adapter
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.098	info	Restart adapter system.adapter.amazon-dash.0 because enabled
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.097	error	instance system.adapter.amazon-dash.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.097	error	Caught by controller[0]: Node.js v18.19.0
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.096	error	Caught by controller[0]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.096	error	Caught by controller[0]: Unknown objects type: jsonl
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.095	error	Caught by controller[0]: ^
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.094	error	Caught by controller[0]: throw 'Unknown objects type: ' + config.objects.type;
                                host.ioBrokerNuc
                                	2024-01-07 11:49:53.094	error	Caught by controller[0]: /node_modules/iobroker.js-controller/lib/adapter.js:194
                                host.ioBrokerNuc
                                	2024-01-07 11:49:52.462	info	instance system.adapter.amazon-dash.0 started with pid 12567
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.011	info	Restart adapter system.adapter.alexa2.0 because enabled
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.011	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.010	error	Caught by controller[0]: Node.js v18.19.0
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.010	error	Caught by controller[0]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.010	error	Caught by controller[0]: Unknown objects type: jsonl
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.009	error	Caught by controller[0]: ^
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.009	error	Caught by controller[0]: throw 'Unknown objects type: ' + config.objects.type;
                                host.ioBrokerNuc
                                	2024-01-07 11:49:43.008	error	Caught by controller[0]: /node_modules/iobroker.js-controller/lib/adapter.js:194
                                host.ioBrokerNuc
                                	2024-01-07 11:49:42.306	info	instance system.adapter.alexa2.0 started with pid 12255
                                • B Belei
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  host.ioBrokerNuc
                                  @belei
                                  Installier den alexa2 nochmal drüber.
                                    Belei
                                    Seltsam hier behaupter er wieder ich hätte ne alte version drauf
                                    benni@ioBrokerNuc:/root$ iobroker upgrade alexa2
                                    This upgrade of "alexa2" will at least introduce the following changes:
                                    -> 3.26.3:
                                    Fixed the proxy login process
                                    -> 3.26.2:
                                    Removed infos how to get cookies manually because no longer available
                                    Optimized Admin configuration order of settings for history
                                    Fixed some crash cases reported by Sentry
                                    Added some more device types
                                    -> 3.26.1:
                                    Fix missing text in Admin Config
                                    -> 3.26.0:
                                    Automatically query of activity/history needs to be enabled manually (if you need it!)
                                    -> 3.25.5:
                                    Optimize activity detection to process all relevant entries in all cases
                                    -> 3.25.4:
                                    Optimize activity detection to process all relevant entries and not just the last one
                                    -> 3.25.3:
                                    Adjust History update to work with recent Amazon changes
                                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                    Would you like to upgrade alexa2 from @1.1.0 to @3.26.3 now? [(y)es, (n)o]: ^Cy
                                    Update alexa2 from @1.1.0 to @3.26.3
                                    NPM version: 10.2.3
                                    Installing iobroker.alexa2@3.26.3... (System call)
                                    Bei update zeigt er auch nur noch wenige an...
                                    benni@ioBrokerNuc:/root$ iob update
                                    Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
                                    • B Belei
                                      -> 3.26.3:
                                      -> 3.26.2:
                                      -> 3.26.1:
                                      -> 3.26.0:
                                      -> 3.25.5:
                                      -> 3.25.4:
                                      -> 3.25.3:
                                      NPM version: 10.2.3
                                      @belei
                                      Stell dich nicht in /root
                                      Da hast du nix zu suchen.
                                        @belei
                                        Belei
                                        Would you like to upgrade alexa2 from @1.1.0 to @3.26.3 now? [(y)es, (n)o]: y
                                        NPM version: 10.2.3
                                         Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                        added 32 packages, removed 17 packages, and changed 908 packages in 2m
                                        81 packages are looking for funding
                                        Update "system.adapter.alexa2.0"
                                        upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                                        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                                        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                                        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                                        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                                        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                                        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                                        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                                        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                                        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                                        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                                        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                                        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                                        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                                        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                                        benni@ioBrokerNuc:/opt/iobroker$ iob update
                                        • B Belei
                                          NPM version: 10.2.3
                                          @belei
                                          Keine Ahnung was da klemmt. Vielleicht verfummelte Rechte.
                                          Jag nochmal ein
                                          iob fix
                                          drüber.
