  4. Node Red startet immer neu
3 Beiträge 2 Kommentatoren 431 Aufrufe 1 Beobachtet
  • N Offline
    N Offline
    NetFritz
    Hallo
    Habe in Node Red den
    node-red-contrib-telegrambot 15.1.7
    über die Palette installiert.
    Beim Einrichten ist Node Red von der Weboberfläche nicht mehr erreichbar,
    Als Fehlermeldung kommt.
    2024-01-02 11:43:06.136 - info: node-red.0 (142065) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2024-01-02 11:43:10.240 - warn: node-red.0 (142065) 2 Jan 11:43:10 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
    2024-01-02 11:43:10.536 - error: node-red.0 (142365) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-01-02 11:43:10.538 - error: node-red.0 (142365) unhandled promise rejection: ETELEGRAM: 404 Not Found
    2024-01-02 11:43:10.538 - error: node-red.0 (142365) Error: ETELEGRAM: 404 Not Found
    at /opt/iobroker/iobroker-data/node-red/node_modules/node-telegram-bot-api/src/telegram.js:299:15
    at tryCatcher (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/util.js:16:23)
    at Promise._settlePromiseFromHandler (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:547:31)
    at Promise._settlePromise (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:604:18)
    at Promise._settlePromise0 (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:649:10)
    at Promise._settlePromises (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:729:18)
    at _drainQueueStep (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:93:12)
    at _drainQueue (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:86:9)
    at Async._drainQueues (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:102:5)
    at Async.drainQueues [as _onImmediate] (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:15:14)
    at process.processImmediate (node:internal/timers:478:21)
    2024-01-02 11:43:10.539 - error: node-red.0 (142365) Exception-Code: ETELEGRAM: ETELEGRAM: 404 Not Found
    2024-01-02 11:43:11.044 - info: node-red.0 (142365) terminating
    2024-01-02 11:43:11.045 - warn: node-red.0 (142365) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-01-02 11:43:11.581 - info: node-red.0 (142065) node-red exited with 6
    Habe dann in der Konsole den node-red-contrib-telegrambot deinstalliert.
    npm remove node-red-contrib-telegrambot
    removed 141 packages, and audited 1 package in 860ms
    found 0 vulnerabilities
    Danach die Fehlermeldung von oben weiter.
    Wie bekomme ich Node Red wieder zum laufen?
    Die letzte Lösung ist ein Backup, dann fehlt mir einiges von Gestern.
    Das letzte von Heute Nacht enthält ja den Fehler.
    Gruß NetFritz
    • Marc BergM Online
      Marc BergM Online
      Marc Berg
      @netfritz sagte in Node Red startet immer neu:
      Den Sicherheitmodus aktivieren
      und speichen, danach Node Red aufrufen und Telegram über den Pallettenmanager wieder entfernen. Danach den Sicherheitmodus wieder deaktivieren.
      N 1 Antwort Letzte Antwort
      • Marc BergM Marc Berg
        N Offline
        N Offline
        NetFritz
        @marc-berg
        Hallo Danke
        Habe ich vor kurzen in einem anderen Beitrag auch gefunden.
        Sicherheitsmodus aktiviert
        Node Rede Start
        Telegram war im Flows nicht mehr drin.
        Dann Telegram Node im Palettenmanager deinstalliert.
        Dann Sicherheitsmodus deaktiviert.
        Node Red startet wieder.
        Alles Gut.
        Gruß NetFritz
