  4. Bekomme nervigen Error zu Rpi2.0 [gelöst]
    2.7k
    4.8k
    4.0k
4 Beiträge 2 Kommentatoren 492 Aufrufe 2 Beobachtet
  • J Offline
    Jojo1900
    schrieb am zuletzt editiert von Jojo1900
    Unter iobroker/Protokolle/logs erhalte ich die Errormeldung
    Quelle Rpi2.0, debug error
    erscheint jede Minute 2x
    Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30227472 3400232 25272652 12% / /1024
    Kann mir jemand weiterhelfen......
    Thomas BraunT J 2 Antworten Letzte Antwort
    • J Jojo1900
      @jojo1900
      Schalte die Überwachung des Datenträgers im Adapter aus.
      J 1 Antwort Letzte Antwort
      • J Jojo1900
        Jojo1900
        @jojo1900
        iob diag
        Copy text starting here:
                                v.2023-10-10
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-v8
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/node           v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                /usr/bin/corepack       0.22.0
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:            4.0G        1.5G        824M        1.2M        1.7G        2.4G
        Swap:           104M          0B        104M
        Total:          4.1G        1.5G        929M
        Active iob-Instances:   14
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.13.9
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        Objects:                4385
        States:                 4883
        Size of iob-Database:
        23M     /opt/iobroker/iobroker-data/objects.jsonl
        9.5M    /opt/iobroker/iobroker-data/objects.json.migrated
        9.5M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        5.5M    /opt/iobroker/iobroker-data/states.jsonl
        848K    /opt/iobroker/iobroker-data/states.json.migrated
        848K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        840K    /opt/iobroker/iobroker-data/states.json.broken
        === Mark text until here for copying ===
        pi@raspberrypi:~ $
          @jojo1900
          Jojo1900
          Danke.....ist erledigt......und gelöst
