  4. [Gelöst] Update js-controller geht nicht
45 Beiträge 3 Kommentatoren 6.3k Aufrufe 3 Beobachtet
    @stephan1966
    systemctl status deconz*
    wirft jetzt was raus?
    Stephan1966
    #41
    @thomas-braun ```
    === Mark text until here for copying ===
    pi@raspberrypismarthome:~ $ systemctl status deconz*
    ● deconz-update.service - deCONZ: ZigBee gateway -- Update Service
         Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:22 CET; 2 days ago
        Process: 542 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
       Main PID: 542 (code=exited, status=203/EXEC)
            CPU: 3ms
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Start request repeated too quickly.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Failed with result 'exit-code'.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
    ● deconz-init.service - deCONZ: ZigBee gateway -- Initialisation
         Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:21 CET; 2 days ago
        Process: 397 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
       Main PID: 397 (code=exited, status=203/EXEC)
            CPU: 4ms
    Dez 19 14:54:21 raspberrypismarthome systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
    Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
    Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
    Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
    Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Failed with result 'exit-code'.
    Dez 19 14:54:21 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
    ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service
         Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled)
        Process: 547 ExecStart=/usr/bin/deCONZ-WIFI2.sh (code=exited, status=203/EXEC)
       Main PID: 547 (code=exited, status=203/EXEC)
            CPU: 2ms
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Scheduled restart job, restart counter is at 5.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- WIFI Service.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Start request repeated too quickly.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Failed with result 'exit-code'.
    Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- WIFI Service.
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
         Active: active (running) since Tue 2023-12-19 14:54:21 CET; 2 days ago
       Main PID: 400 (deCONZ)
          Tasks: 6 (limit: 3933)
            CPU: 55min 35.525s
         CGroup: /system.slice/deconz.service
                 └─400 /usr/bin/deCONZ -platform minimal --http-port=80
    Dez 19 14:54:21 raspberrypismarthome systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
    Dez 19 14:54:22 raspberrypismarthome deCONZ[400]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
    Dez 19 14:54:23 raspberrypismarthome deCONZ[400]: libpng warning: iCCP: known incorrect sRGB profile
    Dez 19 14:54:25 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
    Dez 19 14:54:28 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
    Beste Grüße,
    Stephan
    Iobroker Nutzer seit 2022
    • S Stephan1966
      @thomas-braun ```
              CPU: 3ms
              CPU: 4ms
              CPU: 2ms
              CPU: 55min 35.525s
      #42
      @stephan1966 sagte in Update js-controller geht nicht:
      ls -lAh /usr/bin/deCONZ-WIFI2.sh
      ls -lAh /usr/bin/deCONZ-update2.sh
        Stephan1966
        #43
        @thomas-braun sagte in Update js-controller geht nicht:
        pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-WIFI2.sh
        ls: Zugriff auf '/usr/bin/deCONZ-WIFI2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
        pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-update2.sh
        ls: Zugriff auf '/usr/bin/deCONZ-update2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
        Beste Grüße,
        Stephan
        • S Stephan1966
          #44
          @stephan1966
          Das ist dann auch der Grund, warum der Service failed.
          Ich hab aber kein deconz laufen, keine Ahnung wo der Eintrag für die Services überhaupt herkommt.
            @stephan1966
            Stephan1966
            #45
            Es scheint ja bis auf eine Lampe bei mir alles zu funktionieren, ob die Lampe damit zusammenhängt bekomme ich ja vielleicht noch heraus!
            Danke für den Super-Support 👍
            Beste Grüße,
            Stephan
