  4. Vis-2 installiert nicht
    1.0k
16 Beiträge 3 Kommentatoren 2.2k Aufrufe 3 Beobachtet
  • H Offline
    Heino
    Hallo
    ich habe jetzt schon mehrfach versucht die VIS-2 zu installieren. Die Vis-1 ist bei mir am laufen.
    Wenn ich aber die VIS-2 installiere endet das immer wie folgt:
    ERROR: Process exited with code null
    weniger
    mehr
    $ iobroker add vis-2 2 --host iobroker --debug
    host.iobroker install adapter vis-2
    upload [12] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [9] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [6] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [3] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/vis-2.png vis-2.png image/png
    upload [685] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/asset-manifest.json asset-manifest.json application/json
    upload [650] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/img/favicon.png img/favicon.png image/png
    upload [600] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png image/png
    upload [550] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png image/png
    upload [500] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png image/png
    upload [450] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png image/png
    upload [400] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png image/png
    upload [350] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png image/png
    upload [300] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png image/png
    upload [250] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/signals/motionColor.png signals/motionColor.png image/png
    Weis jemand weiter? Vielen Dank schon mal
    Gruß Heino
    • H Heino
      Hallo
      weniger
      mehr
      Gruß Heino
      @heino ist dazu im Betatester Thread nichts bekannt?
      • H Heino
        Hallo
        weniger
        mehr
        Gruß Heino
        @heino
        iob diag
        sagt?
        H 1 Antwort Letzte Antwort
          @heino
          iob diag
          sagt?
          Heino
          sorry Thomas ich verstehe nicht was du meinst
          HomoranH H 2 Antworten Letzte Antwort
          • H Heino
            @heino sagte in Vis-2 installiert nicht:
            Bitte die Ausgabe von iob diag in der Langfassung hier in code-tags posten
            • H Heino
              Heino
              @heino
              Hallo Thomas ich hoffe es hilft weiter. Ich stecke noch nicht so tief drin und musste auch das mit dem iob diag erstmal rausfinden.
              Skript v.2023-10-25
              *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer-container
                       Chassis: container
                Virtualization: lxc
              Operating System: Ubuntu 22.04.3 LTS
                        Kernel: Linux 5.15.104-1-pve
                  Architecture: x86-64
              model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               10:58:46 up 41 days, 13:52,  1 user,  load average: 0.04, 0.03, 0.00
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Wed 2023-12-13 10:58:46 CET
                         Universal time: Wed 2023-12-13 09:58:46 UTC
                               RTC time: n/a
                            NTP service: inactive
                        RTC in local TZ: no
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            4.1G        2.8G        584M        0.0K        750M        1.3G
              Swap:           1.0G        347M        676M
              Total:          5.1G        3.1G        1.3G
                       4096 M total memory
                       2761 M used memory
                        727 M active memory
                       2667 M inactive memory
                        583 M free memory
                          0 M buffer memory
                        750 M swap cache
                       1024 M total swap
                        347 M used swap
                        676 M free swap
              *** FAILED SERVICES ***
                UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
              * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
              1 loaded units listed.
              *** FILESYSTEM ***
              Filesystem                       Type   Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--200--disk--0 ext4    20G  4.5G   15G  24% /
              none                             tmpfs  492K  4.0K  488K   1% /dev
              tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
              tmpfs                            tmpfs  3.1G  120K  3.1G   1% /run
              tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
              Check not possible in LXC or Docker
              Show mounted filesystems:
              TARGET                                        SOURCE                           FSTYPE      OPTIONS
              /                                             /dev/mapper/pve-vm--200--disk--0 ext4        rw,relatime,stripe=16
              |-/run                                        tmpfs                            tmpfs       rw,nosuid,nodev,size=3241100k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
              | |-/run/lock                                 tmpfs                            tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
              | `-/run/credentials/systemd-sysusers.service none                             ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
              |-/dev                                        none                             tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
              | |-/dev/shm                                  tmpfs                            tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
              | |-/dev/mqueue                               mqueue                           mqueue      rw,relatime
              | |-/dev/.lxc/proc                            proc                             proc        rw,relatime
              | |-/dev/.lxc/sys                             sys                              sysfs       rw,relatime
              | |-/dev/full                                 udev[/full]                      devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
              | |-/dev/null                                 udev[/null]                      devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
              | |-/dev/random                               udev[/random]                    devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
              | |-/dev/tty                                  udev[/tty]                       devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
              | |-/dev/urandom                              udev[/urandom]                   devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
              | |-/dev/zero                                 udev[/zero]                      devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
              | |-/dev/pts                                  devpts                           devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/ptmx                                 devpts[/ptmx]                    devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/console                              devpts[/0]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/tty1                                 devpts[/1]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | `-/dev/tty2                                 devpts[/2]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              |-/proc                                       proc                             proc        rw,nosuid,nodev,noexec,relatime
              | |-/proc/sys                                 proc[/sys]                       proc        ro,relatime
              | | |-/proc/sys/net                           proc[/sys/net]                   proc        rw,nosuid,nodev,noexec,relatime
              | | |-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]              tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
              | | `-/proc/sys/fs/binfmt_misc                binfmt_misc                      binfmt_misc rw,nosuid,nodev,noexec,relatime
              | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]             proc        ro,relatime
              | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/diskstats                           lxcfs[/proc/diskstats]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/loadavg                             lxcfs[/proc/loadavg]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/meminfo                             lxcfs[/proc/meminfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/stat                                lxcfs[/proc/stat]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/swaps                               lxcfs[/proc/swaps]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | `-/proc/uptime                              lxcfs[/proc/uptime]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              `-/sys                                        sysfs                            sysfs       ro,nosuid,nodev,noexec,relatime
                |-/sys/fs/fuse/connections                  fusectl                          fusectl     rw,nosuid,nodev,noexec,relatime
                |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]      sysfs       rw,nosuid,nodev,noexec,relatime
                |-/sys/kernel/debug                         debugfs                          debugfs     rw,nosuid,nodev,noexec,relatime
                |-/sys/kernel/security                      securityfs                       securityfs  rw,nosuid,nodev,noexec,relatime
                |-/sys/fs/pstore                            pstore                           pstore      rw,nosuid,nodev,noexec,relatime
                |-/sys/fs/cgroup                            none                             cgroup2     rw,nosuid,nodev,noexec,relatime
                `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]   fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              /var:
              642M    /var/
              264M    /var/cache
              259M    /var/cache/apt
              255M    /var/lib
              168M    /var/cache/apt/archives
              Archived and active journals take up 120.0M in the file system.
              /opt/iobroker/backups:
              56M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              559M    /opt/iobroker/iobroker-data/
              456M    /opt/iobroker/iobroker-data/files
              99M     /opt/iobroker/iobroker-data/files/vis-2
              88M     /opt/iobroker/iobroker-data/files/echarts.admin
              70M     /opt/iobroker/iobroker-data/backup-objects
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              27M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
              23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7a8ffe778629ec119544757840c9ce8d-if00-port0
              *** NodeJS-Installation ***
              ./iob_diag: line 283: nodejs: command not found
              /usr/bin/node           v18.17.1
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              /usr/bin/corepack       0.18.0
              ./iob_diag: line 294: nodejs: command not found
              *** nodejs is NOT correctly installed ***
              Run ob nodejs-update to fix it.
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                      100 /var/lib/dpkg/status
                   12.22.9~dfsg-1ubuntu3.2 500
                      500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                      500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                   12.22.9~dfsg-1ubuntu3 500
                      500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   2
              Adapter State
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.devices.0                : devices               : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                system.adapter.pylontech.0              : pylontech             : iobroker                                 - disabled, port: 23
              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              + system.adapter.tr-064.1                 : tr-064                : iobroker-slave                           -  enabled
              + system.adapter.tr-064.2                 : tr-064                : iobroker-slave                           -  enabled
              + system.adapter.tr-064.3                 : tr-064                : iobroker-slave                           -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                system.adapter.vis-homekittiles.0       : vis-homekittiles      : iobroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "bidirectional-counter": 2.1.3, installed 2.1.0 [Updatable]
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "deyeidc"      : 0.0.14   , installed 0.0.11 [Updatable]
              Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
              Adapter    "echarts"      : 1.5.4    , installed 1.5.1  [Updatable]
              Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
              Adapter    "proxmox"      : 2.2.2    , installed 1.3.4  [Updatable]
              Adapter    "pylontech"    : 0.0.7    , installed 0.0.7
              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.0  [Updatable]
              Adapter    "solax"        : 0.8.0    , installed 0.6.0  [Updatable]
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Objects and States
              Objects:        1736
              States:         1466
              Hit:1 https://repos.influxdata.com/debian stable InRelease
              Hit:2 https://deb.nodesource.com/node_18.x jammy InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
              Reading package lists...
              Pending Updates: 67
              *** Listening Ports ***
              Netid State  Recv-Q Send-Q       Local Address:Port  Peer Address:PortProcess
              udp   UNCONN 0      0            127.0.0.53%lo:53         0.0.0.0:*    users:(("systemd-resolve",pid=109,fd=13))
              udp   UNCONN 0      0      192.168.188.87%eth0:68         0.0.0.0:*    users:(("systemd-network",pid=92,fd=17))
              udp   UNCONN 0      0                  0.0.0.0:111        0.0.0.0:*    users:(("rpcbind",pid=97,fd=5),("systemd",pid=1,fd=58))
              udp   UNCONN 0      0                  0.0.0.0:41599      0.0.0.0:*    users:(("rpc.statd",pid=183867,fd=8))
              udp   UNCONN 0      0                127.0.0.1:875        0.0.0.0:*    users:(("rpc.statd",pid=183867,fd=5))
              udp   UNCONN 0      0           192.168.188.87:5353       0.0.0.0:*    users:(("io.tr-064.0",pid=1857189,fd=29))
              udp   UNCONN 0      0                  0.0.0.0:5678       0.0.0.0:*    users:(("io.discovery.0",pid=1586716,fd=29))
              udp   UNCONN 0      0                     [::]:111           [::]:*    users:(("rpcbind",pid=97,fd=7),("systemd",pid=1,fd=60))
              udp   UNCONN 0      0                     [::]:33742         [::]:*    users:(("rpc.statd",pid=183867,fd=10))
              tcp   LISTEN 0      4096               0.0.0.0:52715      0.0.0.0:*    users:(("rpc.statd",pid=183867,fd=9))
              tcp   LISTEN 0      4096               0.0.0.0:111        0.0.0.0:*    users:(("rpcbind",pid=97,fd=4),("systemd",pid=1,fd=57))
              tcp   LISTEN 0      4096         127.0.0.53%lo:53         0.0.0.0:*    users:(("systemd-resolve",pid=109,fd=14))
              tcp   LISTEN 0      100              127.0.0.1:25         0.0.0.0:*    users:(("master",pid=308,fd=13))
              tcp   LISTEN 0      511                0.0.0.0:1883       0.0.0.0:*    users:(("io.sonoff.0",pid=1717855,fd=34))
              tcp   LISTEN 0      511                0.0.0.0:9000       0.0.0.0:*    users:(("iobroker.js-con",pid=1586525,fd=27))
              tcp   LISTEN 0      511                0.0.0.0:9001       0.0.0.0:*    users:(("iobroker.js-con",pid=1586525,fd=21))
              tcp   LISTEN 0      4096                  [::]:111           [::]:*    users:(("rpcbind",pid=97,fd=6),("systemd",pid=1,fd=59))
              tcp   LISTEN 0      511                      *:8081             *:*    users:(("io.admin.0",pid=1586543,fd=30))
              tcp   LISTEN 0      511                      *:8082             *:*    users:(("io.web.0",pid=1586778,fd=29))
              tcp   LISTEN 0      128                      *:8086             *:*    users:(("influxd",pid=132,fd=9))
              tcp   LISTEN 0      4096                     *:22               *:*    users:(("systemd",pid=1,fd=61))
              tcp   LISTEN 0      100                  [::1]:25            [::]:*    users:(("master",pid=308,fd=14))
              tcp   LISTEN 0      4096                  [::]:41309         [::]:*    users:(("rpc.statd",pid=183867,fd=11))
              2023-12-13 10:59:00.005  - silly: sonoff.0 (1717855) States user redis pmessage sonoff.0.*/sonoff.0.Tasmota-67.POWER:{"val":false,"ack":false,"ts":1702461540002,"q":0,"c":"script.js.Haus.Steuerung_Warmwasser","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1702461240002}
              2023-12-13 10:59:00.005  - debug: sonoff.0 (1717855) stateChange sonoff.0.Tasmota-67.POWER: {"val":false,"ack":false,"ts":1702461540002,"q":0,"c":"script.js.Haus.Steuerung_Warmwasser","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1702461240002}
              2023-12-13 10:59:00.005  - debug: sonoff.0 (1717855) onStateChange sonoff.0.Tasmota-67.POWER: {"val":false,"ack":false,"ts":1702461540002,"q":0,"c":"script.js.Haus.Steuerung_Warmwasser","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1702461240002}
              2023-12-13 10:59:00.006  - debug: sonoff.0 (1717855) Send to "Tasmota-67": tele/tasmota_F7C950/POWER = OFF
              2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) [Tasmota-67] Received: stat/tasmota_F7C950/RESULT = {"POWER":"OFF"}
              2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) [Tasmota-67] Received: stat/tasmota_F7C950/POWER = OFF
              2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) updateState sonoff.0.Tasmota-67.POWER - 1
              2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) process task: {"type":"addObject","id":"sonoff.0.Tasmota-67.POWER","data":{"_id":"sonoff.0.Tasmota-67.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"Tasmota-67 POWER"},"native":{},"type":"state"}}
              2023-12-13 10:59:00.162  - silly: sonoff.0 (1717855) States user redis pmessage sonoff.0.*/sonoff.0.Tasmota-67.POWER:{"val":false,"ack":true,"ts":1702461540161,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1702461240002}
              2023-12-13 10:59:00.163  - debug: sonoff.0 (1717855) stateChange sonoff.0.Tasmota-67.POWER: {"val":false,"ack":true,"ts":1702461540161,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1702461240002}
              2023-12-13 10:59:00.850  - debug: sonoff.0 (1717855) Client [Tasmota79-HaustuerLED] pingreq
              2023-12-13 10:59:02.652  - debug: sonoff.0 (1717855) Client [Tasmota111-Tannenbaum] pingreq
              2023-12-13 10:59:03.209  - debug: sonoff.0 (1717855) Client [Tasmota112-Tim] pingreq
              2023-12-13 10:59:04.967  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
              2023-12-13 10:59:05.307  - debug: sonoff.0 (1717855) Client [Tasmota114-Pflanze] pingreq
              2023-12-13 10:59:10.168  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
              2023-12-13 10:59:11.749  - debug: sonoff.0 (1717855) Client [Tasmota78-LuefterPV] pingreq
              2023-12-13 10:59:15.175  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
              2023-12-13 10:59:17.787  - debug: sonoff.0 (1717855) Client [Tasmota36-Trockner] pingreq
              2023-12-13 10:59:20.289  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
              2023-12-13 10:59:25.295  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
              2023-12-13 10:59:27.433  - debug: sonoff.0 (1717855) Client [Tasmota25-Garage] pingreq
              2023-12-13 10:59:30.095  - debug: sonoff.0 (1717855) Client [Tasmota-67] pingreq
              2023-12-13 10:59:30.300  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
              2023-12-13 10:59:30.852  - debug: sonoff.0 (1717855) Client [Tasmota79-HaustuerLED] pingreq
              Copy text starting here:
                                      v.2023-10-25
                       Chassis: container
                Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               amd64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                0
              X-Server:               false
              Pending OS-Updates:     67
              Pending iob updates:    8
              ./iob_diag: line 498: nodejs: command not found
              Nodejs-Installation:
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              Recommended versions are nodejs 18.19.0 and npm 10.2.3
              Wrong installation path detected. This needs to be fixed.
              Please check
              for more information on how to fix these errors or run:
              iobroker nodejs-update
              MEMORY:
              Mem:            4.1G        2.8G        520M        0.0K        773M        1.3G
              Total:          5.1G        3.2G        1.2G
              Active iob-Instances:   19
              ioBroker Core:          js-controller           5.0.16
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                1736
              States:                 1466
              Size of iob-Database:
              36M     /opt/iobroker/iobroker-data/objects.jsonl
              7.3M    /opt/iobroker/iobroker-data/states.jsonl
                                      v.2023-10-25
                       Chassis: container
                Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               amd64
              User-ID:                0
              X-Server:               false
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              Please check
              MEMORY:
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                1736
              States:                 1466
              • H Heino
                @heino
                Skript v.2023-10-25
                *** BASE SYSTEM ***
                         Chassis: container
                  Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 4
                                 RTC time: n/a
                          RTC in local TZ: no
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                         4096 M total memory
                         2761 M used memory
                          727 M active memory
                          583 M free memory
                            0 M buffer memory
                          750 M swap cache
                         1024 M total swap
                          347 M used swap
                          676 M free swap
                *** FILESYSTEM ***
                /var:
                642M    /var/
                264M    /var/cache
                259M    /var/cache/apt
                255M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        1736
                States:         1466
                Pending Updates: 67
                                        v.2023-10-25
                         Chassis: container
                  Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                User-ID:                0
                X-Server:               false
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                Please check
                MEMORY:
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                1736
                States:                 1466
                                        v.2023-10-25
                         Chassis: container
                  Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                User-ID:                0
                X-Server:               false
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                Please check
                MEMORY:
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                1736
                States:                 1466
                root
                Hampel da nicht als root durch den Container. Wie man einen user anlegt steht u. a. in der Installationsanleitung zum ioBroker drin.
                Mit dem frischen User:
                sudo apt update
                sudo apt full-upgrade
                Updates einspielen.
                iob nodejs-update
                richtet das richtig ein.
                  root
                  sudo apt update
                  Updates einspielen.
                  iob nodejs-update
                  Heino
                  Hallo Thomas
                  ich denke das ich soweit alles gemacht habe, alledings wenn ich Vis-2 installiere stürzt der ioB ab und startet sofort wieder
                  ======== Start marking the full check here =========
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Chassis: container
                    Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   19:52:19 up  1:10,  2 users,  load average: 0.18, 0.23, 0.18
                  CPU threads: 4
                                 Local time: Wed 2023-12-13 19:52:19 CET
                             Universal time: Wed 2023-12-13 18:52:19 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  heiko
                  /home/heiko
                  heiko sudo iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            4.1G        136M        3.2G        0.0K        756M        4.0G
                  Swap:           1.0G         25M        998M
                  Total:          5.1G        161M        4.2G
                           4096 M total memory
                            136 M used memory
                            452 M active memory
                            367 M inactive memory
                           3203 M free memory
                              0 M buffer memory
                            756 M swap cache
                           1024 M total swap
                             25 M used swap
                            998 M free swap
                  * iobroker.service     loaded failed failed ioBroker Server
                  2 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--200--disk--0 ext4    20G  4.4G   15G  24% /
                  dmesg: read kernel buffer failed: Operation not permitted
                  Show mounted filesystems \(real ones only\):
                  /var:
                  690M    /var/
                  295M    /var/cache
                  290M    /var/cache/apt
                  256M    /var/lib
                  199M    /var/cache/apt/archives
                  Archived and active journals take up 8.0M in the file system.
                  536M    /opt/iobroker/iobroker-data/
                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                  USB-Devices by-id:
                  /usr/bin/nodejs         v18.19.0
                  /usr/bin/node           v18.19.0
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  /usr/bin/corepack       0.22.0
                  nodejs:
                    Installed: 18.19.0-1nodesource1
                    Candidate: 18.19.0-1nodesource1
                    Version table:
                   *** 18.19.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  Errors in npm tree:
                  ioBroker Status
                  Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                    system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Objects and States
                  Objects:        1738
                  States:         1297
                  Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:59945           0.0.0.0:*               LISTEN      111        98303819   519/rpc.statd
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          98300533   309/master
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          98298769   1/init
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        98302081   112/systemd-resolve
                  tcp6       0      0 :::51255                :::*                    LISTEN      111        98303823   519/rpc.statd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          98302993   1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          98298771   1/init
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          98300534   309/master
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        98301266   132/influxd
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        98302080   112/systemd-resolve
                  udp        0      0 192.168.188.87:68       0.0.0.0:*                           105        98301105   92/systemd-networkd
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          98298770   1/init
                  udp        0      0 127.0.0.1:695           0.0.0.0:*                           0          98303813   519/rpc.statd
                  udp        0      0 0.0.0.0:37882           0.0.0.0:*                           111        98303817   519/rpc.statd
                  udp6       0      0 :::111                  :::*                                0          98298772   1/init
                  udp6       0      0 :::54874                :::*                                111        98303821   519/rpc.statd
                  2023-12-13 19:49:25.131  - info: trashschedule.0 (4973) terminating
                  2023-12-13 19:49:25.133  - info: web.0 (4990) terminating
                  2023-12-13 19:49:25.134  - info: fritzdect.0 (5061) terminating
                  2023-12-13 19:49:25.135  - info: discovery.0 (4935) terminating
                  2023-12-13 19:49:25.136  - info: energiefluss.0 (5035) terminating
                  2023-12-13 19:49:25.231  - info: host.iobroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.286  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.288  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.288  - info: host.iobroker instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.320  - info: host.iobroker instance system.adapter.energiefluss.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.352  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.352  - info: host.iobroker instance system.adapter.sayit.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.355  - silly: sonoff.0 (4814) States system redis pmessage system.adapter.*.logging/system.adapter.javascript.0.logging:{"val":false,"ack":true,"ts":1702493365338,"q":0,"from":"system.host.iobroker","lc":1698784769164}
                  2023-12-13 19:49:25.355  - silly: sonoff.0 (4814) system.adapter.javascript.0: logging false
                  2023-12-13 19:49:25.369  - silly: sonoff.0 (4814) States system redis pmessage system.adapter.*.logging/system.adapter.admin.0.logging:{"val":false,"ack":true,"ts":1702493365364,"q":0,"from":"system.host.iobroker","lc":1702493365364}
                  2023-12-13 19:49:25.369  - silly: sonoff.0 (4814) system.adapter.admin.0: logging false
                  2023-12-13 19:49:25.424  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.424  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.425  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.425  - info: host.iobroker instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.464  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.658  - info: host.iobroker instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.669  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
                  2023-12-13 19:49:25.669  - info: host.iobroker All instances are stopped.
                  2023-12-13 19:49:25.860  - info: host.iobroker terminated
                  iob diag has finished.
                  • H Heino
                    Hallo Thomas
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    heiko
                    /home/heiko
                    heiko sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           1.0G         25M        998M
                             4096 M total memory
                              136 M used memory
                              452 M active memory
                             3203 M free memory
                                0 M buffer memory
                              756 M swap cache
                             1024 M total swap
                               25 M used swap
                              998 M free swap
                    *** FILESYSTEM ***
                    /var:
                    690M    /var/
                    295M    /var/cache
                    290M    /var/cache/apt
                    256M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        1738
                    States:         1297
                    Pending Updates: 0
                    @heino
                    systemctl status iobroker
                    sagt?
                      @heino
                      sagt?
                      Heino
                      @thomas-braun said in Vis-2 installiert nicht:
                      * iobroker.service - ioBroker Server
                           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                           Active: active (running) since Wed 2023-12-13 20:00:59 CET; 1h 18min ago
                             Docs: http://iobroker.net
                         Main PID: 7983 (iobroker.js-con)
                            Tasks: 166 (limit: 18909)
                           Memory: 1.1G
                              CPU: 6min 12.439s
                           CGroup: /system.slice/iobroker.service
                                   |- 7983 iobroker.js-controller "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                   |- 8001 io.admin.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                   |- 8028 io.history.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                   |- 8043 io.javascript.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                   |- 8073 io.sonoff.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   |- 8088 io.modbus.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   |- 8103 io.ping.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                   |- 8124 io.tr-064.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   |- 8143 io.discovery.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   |- 8160 io.backitup.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                   |- 8181 io.trashschedule.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                   |- 8198 io.web.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   |- 8240 io.sayit.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                   |- 8258 io.energiefluss.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   |- 8285 io.fritzdect.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                   `-11667 /bin/ping -n -w 2 -c 1 192.168.188.33
                      lines 1-25/25 (END)
                      • H Heino
                             Memory: 1.1G
                                CPU: 6min 12.439s
                        lines 1-25/25 (END)
                        @heino
                        iob update
                        iob upgrade all -y
                        • H Heino
                          Hallo Thomas
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          heiko
                          /home/heiko
                          heiko sudo iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:           1.0G         25M        998M
                                   4096 M total memory
                                    136 M used memory
                                    452 M active memory
                                   3203 M free memory
                                      0 M buffer memory
                                    756 M swap cache
                                   1024 M total swap
                                     25 M used swap
                                    998 M free swap
                          *** FILESYSTEM ***
                          /var:
                          690M    /var/
                          295M    /var/cache
                          290M    /var/cache/apt
                          256M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        1738
                          States:         1297
                          Pending Updates: 0
                          Mit welchen Meldungen?
                            Heino
                            wo sehe ich die Meldung
                            • H Heino
                              @heino
                              Im Log-File.
                              iob logs --watch | uniq
                              anschauen und in einem zweiten Terminal den Adapter installieren und den Absturz provozieren.
                              iob add vis-2 --debug
                                @heino
                                Im Log-File.
                                Heino
                                Hallo Thomas ich hoffe das hilft weiter
                                heiko@iobroker:~$ iob add vis-2 --debug
                                upload [11] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [8] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [7] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [4] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                 Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                 States database error: connect ECONNREFUSED 0.0.0.0:9000
                                2023-12-17 20:38:51.143  - debug: sonoff.0 (183902) Client [Tasmota78-LuefterPV] pingreq
                                2023-12-17 20:38:51.330  - debug: sonoff.0 (183902) Client [Tasmota-67] pingreq
                                2023-12-17 20:38:51.369  - debug: sonoff.0 (183902) Client [Tasmota79-HaustuerLED] pingreq
                                2023-12-17 20:38:51.658  - debug: sonoff.0 (183902) Client [Tasmota114-Pflanze] pingreq
                                2023-12-17 20:38:51.765  - debug: sonoff.0 (183902) Client [Tasmota36-Trockner] pingreq
                                2023-12-17 20:38:52.145  - debug: sonoff.0 (183902) Client [Tasmota112-Tim] pingreq
                                2023-12-17 20:38:59.574  - debug: sonoff.0 (183902) Client [Tasmota25-Garage] pingreq
                                2023-12-17 20:39:14.832  - info: host.iobroker iobroker add vis-2 --host iobroker
                                2023-12-17 20:39:15.879  - info: host.iobroker iobroker host.iobroker install adapter vis-2
                                2023-12-17 20:39:15.990  - info: host.iobroker iobroker upload [12] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                2023-12-17 20:39:16.002  - info: host.iobroker iobroker upload [11] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                2023-12-17 20:39:16.007  - info: host.iobroker iobroker upload [10] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                2023-12-17 20:39:16.013  - info: host.iobroker iobroker upload [9] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                2023-12-17 20:39:16.020  - info: host.iobroker iobroker upload [8] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                2023-12-17 20:39:16.026  - info: host.iobroker iobroker upload [7] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                2023-12-17 20:39:16.032  - info: host.iobroker iobroker upload [6] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                2023-12-17 20:39:16.038  - info: host.iobroker iobroker upload [5] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                2023-12-17 20:39:16.044  - info: host.iobroker iobroker upload [4] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                2023-12-17 20:39:16.051  - info: host.iobroker iobroker upload [3] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                2023-12-17 20:39:16.062  - info: host.iobroker iobroker upload [2] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                2023-12-17 20:39:16.067  - info: host.iobroker iobroker upload [1] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/jsonConfig.json jsonConfig.json application/json
                                2023-12-17 20:39:16.074  - info: host.iobroker iobroker upload [0] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/vis-2.png vis-2.png image/png
                                2023-12-17 20:39:17.803  - info: host.iobroker iobroker upload [685] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/asset-manifest.json asset-manifest.json application/json
                                2023-12-17 20:39:21.196  - debug: sonoff.0 (183902) Client [Tasmota78-LuefterPV] pingreq
                                2023-12-17 20:39:21.333  - debug: sonoff.0 (183902) Client [Tasmota-67] pingreq
                                2023-12-17 20:39:21.379  - debug: sonoff.0 (183902) Client [Tasmota79-HaustuerLED] pingreq
                                2023-12-17 20:39:21.685  - debug: sonoff.0 (183902) Client [Tasmota114-Pflanze] pingreq
                                2023-12-17 20:39:21.798  - debug: sonoff.0 (183902) Client [Tasmota36-Trockner] pingreq
                                2023-12-17 20:39:22.198  - debug: sonoff.0 (183902) Client [Tasmota112-Tim] pingreq
                                2023-12-17 20:39:29.906  - debug: sonoff.0 (183902) Client [Tasmota25-Garage] pingreq
                                2023-12-17 20:39:30.929  - info: host.iobroker iobroker upload [650] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/img/favicon.png img/favicon.png image/png
                                2023-12-17 20:39:31.156  - info: host.iobroker iobroker upload [600] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png image/png
                                2023-12-17 20:39:31.441  - info: host.iobroker iobroker upload [550] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png image/png
                                2023-12-17 20:39:31.683  - info: host.iobroker iobroker upload [500] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png image/png
                                2023-12-17 20:39:31.934  - info: host.iobroker iobroker upload [450] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png image/png
                                2023-12-17 20:39:32.213  - info: host.iobroker iobroker upload [400] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png image/png
                                2023-12-17 20:39:32.497  - info: host.iobroker iobroker upload [350] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png image/png
                                2023-12-17 20:39:32.772  - info: host.iobroker iobroker upload [300] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png image/png
                                2023-12-17 20:39:34.881  - info: host.iobroker iobroker upload [250] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/signals/motionColor.png signals/motionColor.png image/png
                                2023-12-17 20:39:42.170  - error: energiefluss.0 (183971) States database error: read ECONNRESET
                                2023-12-17 20:39:42.195  - info: admin.0 (183802) terminating http server on port 8081
                                2023-12-17 20:39:42.261  - info: javascript.0 (183888) Stop script script.js.Arbeitszimmer_Szene
                                2023-12-17 20:39:42.262  - error: trashschedule.0 (183953) States database error: read ECONNRESET
                                2023-12-17 20:39:42.236  - error: fritzdect.0 (183982) States database error: read ECONNRESET
                                2023-12-17 20:39:42.259  - error: web.0 (183959) States database error: read ECONNRESET
                                2023-12-17 20:39:42.313  - info: trashschedule.0 (183953) cleaned everything up...
                                2023-12-17 20:39:42.285  - error: sayit.0 (183993) States database error: read ECONNRESET
                                2023-12-17 20:39:42.321  - error: backitup.0 (183931) States database error: read ECONNRESET
                                2023-12-17 20:39:42.346  - info: fritzdect.0 (183982) cleaned everything up...
                                2023-12-17 20:39:42.309  - info: javascript.0 (183888) Stop script script.js.Fernsehszene
                                2023-12-17 20:39:42.320  - info: javascript.0 (183888) Stop script script.js.Haus.Schalter_Lampe_AZ
                                2023-12-17 20:39:42.329  - info: javascript.0 (183888) Stop script script.js.Haus.Zeit
                                2023-12-17 20:39:42.355  - info: javascript.0 (183888) Stop script script.js.Haus.Zeitschaltuhr_WZ
                                2023-12-17 20:39:42.356  - info: javascript.0 (183888) Stop script script.js.Haus.Zeitschaltuhr_AZ
                                2023-12-17 20:39:42.357  - info: javascript.0 (183888) Stop script script.js.Haus.Steuerung_Warmwasser
                                2023-12-17 20:39:42.360  - info: javascript.0 (183888) Stop script script.js.Haus.Schalter_WZ
                                2023-12-17 20:39:42.393  - info: sayit.0 (183993) stopping...
                                2023-12-17 20:39:42.393  - info: backitup.0 (183931) cleaned everything up...
                                2023-12-17 20:39:42.857  - warn: web.0 (183959) Timeout by termination of web-extensions!
                                2023-12-17 20:39:42.871  - info: web.0 (183959) terminated http server on port 8082
                                2023-12-17 20:39:43.643  - info: tr-064.0 (183941) terminating with timeout
                                2023-12-17 20:39:43.667  - info: tr-064.0 (183941) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.690  - info: ping.0 (183920) terminating with timeout
                                2023-12-17 20:39:43.692  - info: modbus.0 (183895) terminating with timeout
                                2023-12-17 20:39:43.708  - info: ping.0 (183920) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.710  - info: modbus.0 (183895) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.741  - info: energiefluss.0 (183971) terminating with timeout
                                2023-12-17 20:39:43.745  - info: javascript.0 (183888) terminating with timeout
                                2023-12-17 20:39:43.745  - info: energiefluss.0 (183971) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.751  - info: sonoff.0 (183902) terminating with timeout
                                2023-12-17 20:39:43.753  - info: javascript.0 (183888) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.757  - debug: sonoff.0 (183902) Plugin sentry destroyed
                                2023-12-17 20:39:43.759  - info: sonoff.0 (183902) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.756  - info: discovery.0 (183909) terminating with timeout
                                2023-12-17 20:39:43.785  - info: discovery.0 (183909) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.817  - info: trashschedule.0 (183953) terminating with timeout
                                2023-12-17 20:39:43.824  - info: trashschedule.0 (183953) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.846  - info: admin.0 (183802) terminating with timeout
                                2023-12-17 20:39:43.852  - info: admin.0 (183802) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.857  - info: fritzdect.0 (183982) terminating with timeout
                                2023-12-17 20:39:43.861  - info: fritzdect.0 (183982) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.874  - info: web.0 (183959) terminating with timeout
                                2023-12-17 20:39:43.880  - info: web.0 (183959) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.897  - info: backitup.0 (183931) terminating with timeout
                                2023-12-17 20:39:43.897  - info: sayit.0 (183993) terminating with timeout
                                2023-12-17 20:39:43.904  - info: sayit.0 (183993) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:43.905  - info: backitup.0 (183931) Terminated (NO_ERROR): Without reason
                                2023-12-17 20:39:47.144  - error: tr-064.0 (183941) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.153  - warn: tr-064.0 (183941) get state error: Connection is closed.
                                2023-12-17 20:39:47.198  - error: modbus.0 (183895) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.206  - warn: modbus.0 (183895) get state error: Connection is closed.
                                2023-12-17 20:39:47.207  - warn: modbus.0 (183895) get state error: DB closed
                                2023-12-17 20:39:47.216  - error: ping.0 (183920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.223  - warn: ping.0 (183920) get state error: Connection is closed.
                                2023-12-17 20:39:47.215  - info: modbus.0 (183895) terminating
                                2023-12-17 20:39:47.219  - info: modbus.0 (183895) terminating
                                2023-12-17 20:39:47.229  - info: ping.0 (183920) terminating
                                2023-12-17 20:39:47.249  - error: energiefluss.0 (183971) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.256  - error: discovery.0 (183909) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.259  - error: sonoff.0 (183902) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.265  - warn: sonoff.0 (183902) get state error: Connection is closed.
                                2023-12-17 20:39:47.265  - warn: energiefluss.0 (183971) get state error: Connection is closed.
                                2023-12-17 20:39:47.271  - info: sonoff.0 (183902) terminating
                                2023-12-17 20:39:47.282  - warn: discovery.0 (183909) get state error: Connection is closed.
                                2023-12-17 20:39:47.292  - error: history.0 (183725) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.320  - error: history.0 (183725) States database error: connect ECONNREFUSED 0.0.0.0:9000
                                2023-12-17 20:39:47.324  - error: trashschedule.0 (183953) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.334  - warn: trashschedule.0 (183953) get state error: Connection is closed.
                                2023-12-17 20:39:47.367  - error: fritzdect.0 (183982) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.370  - error: web.0 (183959) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.376  - error: javascript.0 (183888) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.378  - warn: fritzdect.0 (183982) get state error: Connection is closed.
                                2023-12-17 20:39:47.385  - warn: sayit.0 (183993) get state error: DB closed
                                2023-12-17 20:39:47.389  - warn: javascript.0 (183888) get state error: DB closed
                                2023-12-17 20:39:47.390  - warn: javascript.0 (183888) get state error: DB closed
                                2023-12-17 20:39:47.395  - info: javascript.0 (183888) terminating
                                2023-12-17 20:39:47.396  - info: javascript.0 (183888) terminating
                                2023-12-17 20:39:47.405  - error: backitup.0 (183931) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                2023-12-17 20:39:47.411  - warn: backitup.0 (183931) get state error: Connection is closed.
                                2023-12-17 20:39:47.430  - error: admin.0 (183802) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                ^C
                                heiko@iobroker:~$
                                • H Heino
                                  ^C
                                  heiko@iobroker:~$
                                  @heino
                                  Da ist die Datenbank wohl hin oder nicht zu erreichen.
