  4. RPI2 - GPIO is not initialized
rpi2 gpio
10 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • ThisoftT Offline
    ThisoftT Offline
    Thisoft
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry Pi 2 Model B Rev 1.1
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte
    Betriebssystem: Linux 9 (stretch)
    Node-Version: 16.20.1
    Nodejs-Version: 16.20.1
    NPM-Version: 8.19.4
    Installationsart: Skript - Slave
    Image genutzt: Nein
    Weitere Software: pivCCU
    wie im Thema angegeben bekomme ich die GPIO's nicht mehr zum Laufen. Folgendes Log beim Start des RPI2-Adapters:
    admin.0
    	2023-12-02 17:49:21.116	warn	Cannot read file ("rpi2.admin"/"rpi.png"): Not exists
    admin.0
    	2023-12-02 17:49:21.081	warn	Cannot read file ("rpi2.admin"/"rpi.png"): Not exists
    rpi2.0
    	2023-12-02 17:49:20.794	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/Debug/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/Release/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/out/Debug/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/Debug/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/out/Release/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/Release/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/default/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/compiled/16.20.1/linux/arm/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/addon-build/release/install-root/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/addon-build/debug/install-root/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/addon-build/default/install-root/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/lib/binding/node-v93-linux-arm/epoll.node
    Außerdem - wenn ich die Einstellungen des RPI2-Adapters aufrufen will erhalte ich einen "Fehler 404".
    Rebuild des Adapters hab ich bereits gemacht. Was könnte ich noch tun? Oder ist meine Linux-Version zu alt dafür? Weiß auch nicht genau seit welchem Update oder so das nicht mehr funktioniert - brauche die GPIO's halt nur zu Weihnachten... dafür jetzt um so dringender :-(
    Vielen Dank schon mal...
    • ThisoftT Thisoft
      NPM-Version: 8.19.4
      Image genutzt: Nein
      admin.0
      admin.0
      rpi2.0
      @thisoft sagte in RPI2 - GPIO is not initialized:
      Linux 9 (stretch)
      ist das dein Ernst?
      wir sind bei 12 (bookworm)
      für 9 gibt's nix mehr
      ThisoftT 1 Antwort Letzte Antwort
        Linux 9 (stretch)
        ist das dein Ernst?
        ThisoftT Offline
        ThisoftT Offline
        Thisoft
        Ja, ist mein Ernst. Ist ja "nur" n Slave und lief bis jetzt unauffällig. Außerdem scheue ich mich vor Linux-Upgrades weil ich da bisher schon mehrmals den Fall hatte dass die Kiste Schrott war und ich komplett neu aufsetzen musste :-( Läuft das Aktuelle dann überhaupt noch auf dem Pi2?
        Außerdem - ist es möglich in kurzen Worten zu erklären warum da jetzt plötzlich der GPIO-Zugriff nicht mehr funktioniert?
        • ThisoftT Thisoft
          @thisoft
          Installier da was lebendiges.
          • ThisoftT Thisoft
            warum nicht?
            EDIT:
            lediglich 64Bit gehen nicht bei pi2
            sieh mal mit sudo raspi-config nach
              warum nicht?
              EDIT:
              ThisoftT Offline
              ThisoftT Offline
              Thisoft
              @homoran sagte in RPI2 - GPIO is not initialized:
              Hmm, hab ich gemacht und hab da den "Remote-Access for GPIO" Enabled was angeblich auch erfolgreich war. Aber nach verlassen des Config-Tools kam diese Fehlermeldung:
              pi@piPivCCU:~ $ sudo raspi-config
              Failed to get unit file state for pigpiod.service: No such file or directory
              Mag ja sein dass mein System nicht ganz frisch ist... trotzdem würde ich gern verstehen wieso das voriges Jahr noch funktioniert hat und jetzt nicht mehr...
              • ThisoftT Thisoft
                @thisoft
                Weil dein System tot ist wird da nichts mehr dran getan. Bei den gpios wurde da in den letzen Jahren was umgestellt, bei deiner Antiquität aber nicht mehr.
                Installier es neu...
                  @thisoft
                  ThisoftT Offline
                  ThisoftT Offline
                  Thisoft
                  Tja - dann frag ich mich nur mal wieder warum Linux-Jünger immer behaupten dass Linux gerade für so Steuerungs-Systeme vieeel besser wäre als Windows? Wegen der Windows-Updates wird ja gemunkelt - aber wenn bei Linux auch ständig dranrum-geupdatet werden muss... wo ist da der Vorteil?
                  • ThisoftT Thisoft
                    Das ständig Verbesserungen einfließen ist der Vorteil.
                    Du partizipierst daran, wenn du dein System pflegen würdest.
                    Ist so ähnlich wie mit einem Auto, das will auch gewartet werden. Bei Oldtimern wird das aber zunehmend schwerer mit passenden Teilen.
                    Hier vermute ich, daß ein aktuelles 'raspi-config' aus dem raspberryOS stable verwendet wird. Das setzt aber auch voraus, das das Betriebssystem auch stable ist und nicht wie bei dir mausetot.
                    Nein, 'never tatsch ä rannink süstähm' war noch nie richtig.
                    • ThisoftT Offline
                      ThisoftT Offline
                      Thisoft
                      So, der ioBroker-Slave auf dem neuen Bookworm-System läuft wieder. Ist ja schön dass ständig verbessert wird - macht es aber nicht unbedingt einfacher wenn es inzwischen gefühlt 10 verschiedene Möglichkeiten gibt eine feste IP und sonstige Netzwerkeinstellungen zu definieren. Wobei das nmcli ja schon nicht schlecht ist, man muss nur mal wieder alles anders machen ;-) Damit sind wir bei meinem Problem was ich noch habe - die piVCCU läuft zwar, ist aber von außen nicht erreichbar was entsprechend der IP-Konfiguration für mich auch erklärbar ist - ich bin aber mit meinem Latein etwas am Ende wie ich jetzt die Bridge definieren müsste, habe auch im einschlägigen Forum noch keine Anleitung für nmcli gefunden... :-) Kann mir hier jemand vielleicht mehr dazu sagen?
                      pi@piPivCCU:~ $ sudo systemctl status pivccu
                      ● pivccu.service - piVCCU
                           Loaded: loaded (/lib/systemd/system/pivccu.service; enabled; preset: enabled)
                           Active: active (running) since Mon 2023-12-04 04:47:02 CET; 5h 38min ago
                         Main PID: 6432 (lxc-start)
                            Tasks: 0 (limit: 1571)
                              CPU: 2.947s
                           CGroup: /system.slice/pivccu.service
                                   ‣ 6432 /usr/bin/lxc-start --lxcpath /var/lib/piVCCU3 --name lxc --pidfile /var/run/pivccu3.pid --daemon
                      Dec 04 04:46:53 piPivCCU systemd[1]: Starting pivccu.service - piVCCU...
                      Dec 04 04:47:01 piPivCCU start_container.sh[6429]: kernel.sched_rt_runtime_us = -1
                      Dec 04 04:47:02 piPivCCU systemd[1]: Started pivccu.service - piVCCU.
                      pi@piPivCCU:~ $ ip addr
                      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                          inet 127.0.0.1/8 scope host lo
                             valid_lft forever preferred_lft forever
                          inet6 ::1/128 scope host noprefixroute
                      2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000
                          link/ether b8:27:eb:7d:64:a4 brd ff:ff:ff:ff:ff:ff
                          inet 192.168.137.61/24 brd 192.168.137.255 scope global noprefixroute eth0
                          inet6 fe80::2750:188a:6cf8:9854/64 scope link noprefixroute
                      4: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
                          inet 192.168.137.94/24 brd 192.168.137.255 scope global br0
                          inet6 fe80::ba27:ebff:fe7d:64a4/64 scope link
                      5: lxcbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
                          link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
                          inet 10.0.3.1/24 brd 10.0.3.255 scope global lxcbr0
                      6: vethpivccu@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
                          link/ether fe:75:2c:88:46:99 brd ff:ff:ff:ff:ff:ff link-netnsid 0
                          inet6 fe80::fc75:2cff:fe88:4699/64 scope link
                      pi@piPivCCU:~ $
